Simon-renegade Posted March 16, 2022 Posted March 16, 2022 Just burned the station m2 release onto EMMC and sadly found that there is no saveenv command. I used Ctrl-c to interrupt the u-boot into command line mode. Checked the supported command by typing help and found no saveenv in the list save - save file to a filesystem setcurs - set cursor position within screen setenv - set environment variables showvar - print local hushshell variables size - determine a file's size source - run script from memory sysboot - command to get and boot from syslinux files sysmem_dump- Dump sysmem layout sysmem_search- Search a available sysmem region test - minimal test like /bin/sh tftp - download image via network using TFTP protocol tftpbootm- tftpbootm aosp/uImage/FIT image via network using TFTP protocol tftpflash- flash image via network using TFTP protocol tftpput - TFTP put command, for uploading files to a server true - do nothing, successfully ums - Use the UMS [USB Mass Storage] usb - USB sub-system usbboot - boot from USB device version - print monitor, compiler and linker version
balbes150 Posted March 16, 2022 Posted March 16, 2022 @WernerPls change the name of the theme, it has nothing to do with Station M2, the user does not have a supported TV box.
umiddelb Posted March 17, 2022 Posted March 17, 2022 The u-boot feature set is defined during build-time. IIRC there has been a reason for disabling this feature in the past for certain platforms. 1
Simon-renegade Posted March 18, 2022 Author Posted March 18, 2022 17 hours ago, umiddelb said: The u-boot feature set is defined during build-time. IIRC there has been a reason for disabling this feature in the past for certain platforms. Thanks for the info!
