Armbian 5.15.26-sunxi64 kernel breaks GPIO on NanoPi NEO2
Armbian 5.15.26-sunxi64 (bullseye)
NanoHatOLED fails:
- GPIO devices are missing;
- /proc/cpuinfo lacks Processor, Hardware info.
root@nanopineo2:~# uname -a
Linux nanopineo2 5.15.26-sunxi64 #trunk.0002 SMP Thu Mar 3 10:24:53 UTC 2022 aarch64 GNU/Linux
root@nanopineo2:~# gpio readall
piBoardRev: Unable to determine board revision from /proc/cpuinfo
 -> Is not NanoPi based board.
 ->  You may want to check:
 ->  http://www.lemaker.org/
root@nanopineo2:~# cat /tmp/nanohat-oled.log
open of gpio 0 returned -1: No such file or directory
error opening gpio sysfs entries
root@nanopineo2:~# cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 48.00
Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
Armbian 5.10.60-sunxi64 (bullseye)
NanoHatOLED is running fine:
root@nanopineo2:~# ls -l /sys/class/gpio
total 0
--w--w---- 1 root dialout 4096 Mar 29 23:42 export
lrwxrwxrwx 1 root root       0 Mar 29 23:42 gpio0 -> ../../devices/platform/soc/1c20800.pinctrl/gpiochip1/gpio/gpio0
lrwxrwxrwx 1 root root       0 Mar 29 23:42 gpio2 -> ../../devices/platform/soc/1c20800.pinctrl/gpiochip1/gpio/gpio2
lrwxrwxrwx 1 root root       0 Mar 29 23:42 gpio3 -> ../../devices/platform/soc/1c20800.pinctrl/gpiochip1/gpio/gpio3
lrwxrwxrwx 1 root root       0 Jan  1  1970 gpiochip0 -> ../../devices/platform/soc/1c20800.pinctrl/gpio/gpiochip0
lrwxrwxrwx 1 root root       0 Jan  1  1970 gpiochip352 -> ../../devices/platform/soc/1f02c00.pinctrl/gpio/gpiochip352
--w--w---- 1 root dialout 4096 Mar 29 23:42 unexport
 +-----+-----+----------+------+---+-NanoPi-NEO2--+------+----------+-----+-----+
 | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
 |     |     |     3.3V |      |   |  1 || 2  |   |      | 5V       |     |     |
 |  12 |   8 |  GPIOA12 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
 |  11 |   9 |  GPIOA11 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
 | 203 |   7 |  GPIOG11 |  OFF | 0 |  7 || 8  | 0 |  OFF | GPIOG6   | 15  | 198 |
 |     |     |       0v |      |   |  9 || 10 | 0 |  OFF | GPIOG7   | 16  | 199 |
 |   0 |   0 |   GPIOA0 | ALT2 | 0 | 11 || 12 | 0 |  OFF | GPIOA6   | 1   | 6   |
 |   2 |   2 |   GPIOA2 | ALT2 | 0 | 13 || 14 |   |      | 0v       |     |     |
 |   3 |   3 |   GPIOA3 | ALT2 | 0 | 15 || 16 | 0 |  OFF | GPIOG8   | 4   | 200 |
 |     |     |     3.3v |      |   | 17 || 18 | 0 |  OFF | GPIOG9   | 5   | 201 |
 |  64 |  12 |   GPIOC0 |  OFF | 0 | 19 || 20 |   |      | 0v       |     |     |
 |  65 |  13 |   GPIOC1 |  OFF | 0 | 21 || 22 | 0 |  OFF | GPIOA1   | 6   | 1   |
 |  66 |  14 |   GPIOC2 |  OFF | 0 | 23 || 24 | 0 |  OFF | GPIOC3   | 10  | 67  |
 +-----+----NanoPi-NEO2 USB/Audio-+----+
 | BCM | wPi |   Name   | Mode | V | Ph |
 |     |     |       5V |      |   | 25 |
 |     |     |  USB-DP1 |      |   | 26 |
 |     |     |  USB-DM1 |      |   | 27 |
 |     |     |  USB-DP2 |      |   | 28 |
 |     |     |  USB-DM2 |      |   | 29 |
 |     |     |    IR-RX |      |   | 30 |
 |  17 |  19 |  GPIOA17 |  OFF | 0 | 31 |
 |     |     |  PCM/I2C |      |   | 32 |
 |     |     |  PCM/I2C |      |   | 33 |
 |     |     |  PCM/I2C |      |   | 34 |
 |     |     |  PCM/I2C |      |   | 35 |
 |     |     |       0V |      |   | 36 |
 +-----+----NanoPi-NEO2 Debug UART-+----+
 |   4 |  17 |   GPIOA4 | ALT5 | 0 | 37 |
 |   5 |  18 |   GPIOA5 | ALT5 | 0 | 38 |
total 0
Is P2P the right place for a general issue (completely lost GPIO interface) with an officially supported SBC? 🤔
I hope Igor, listed as maintainer for NEO2, reads posts here.
Why is it moved to P2P since NanoPi NEO2 is officially supported and this bug affects others as well?
I do not understand.
  • Maarten1 changed the title to Armbian 5.15.26-sunxi64 kernel breaks GPIO on NanoPi NEO2
Now found:
So it is an upstream deprecation, but schwar3kat is looking into a way to restore the sysfs API. But generally, software (like NanoHatOLED) needs to move to recent libraries, like libgpiod then, to make use of GPIO in a future-prove way.
At least Linux v5.15 by default has the old sysfs API disabled, so if anything depends on it (has not been migrated to use libgpiod) and it hasn't been explicitly enabled for the build like Armbian did now, then yes.
