christian.colaci Posted September 15, 2016 Posted September 15, 2016 Hi everyone I've tried to flash "armbian*.raw" downloaded from here: http://www.armbian.com/odroid-c2/URL] the "Jessie desktop" version. I have a panasonic 16gb micro SD card They say that the ".raw" image can be written with Rufus...but they don't explain what kind of settings should I have to use. I've tried many of that settings bit with no result...the program always says "DONE" but when I put it in the odroid there's no boot. Does anyone know a "how to flash" please?? Inviato dal mio SHIELD Tablet utilizzando Tapatalk
tkaiser Posted September 15, 2016 Posted September 15, 2016 Does anyone know a "how to flash" please?? Do you succeed using Etcher?
christian.colaci Posted September 15, 2016 Author Posted September 15, 2016 http://uploads.tapatalk-cdn.com/20160915/fe90b9bb2fc06e679215a6846ebcdff9.jpg[/img Yes,today and that's what happened Inviato dal mio SM-G930F utilizzando Tapatalk
christian.colaci Posted September 15, 2016 Author Posted September 15, 2016 [EDIT] Downloaded again from the website and flashed with "etcher" (thank you ) Now it works...exept for the wifi because I have a wifi USB Stick (tp-link = Atheros chip) but it is not recognised from armbian...anyone knows why??? Inviato dal mio SM-G930F utilizzando Tapatalk
Igor Posted September 16, 2016 Posted September 16, 2016 Now it works...exept for the wifi because I have a wifi USB Stick (tp-link = Atheros chip) but it is not recognised from armbian...anyone knows why??? We only support onboard wifi chips, not all possible on the planet. But our system is prepared to build a driver. That is the best what we can do.
christian.colaci Posted September 16, 2016 Author Posted September 16, 2016 Ok...so I have to find "ath9k" driver and compile for armbian? Inviato dal mio SM-G930F utilizzando Tapatalk
Igor Posted September 17, 2016 Posted September 17, 2016 Ok...so I have to find "ath9k" driver and compile for armbian? Inviato dal mio SM-G930F utilizzando Tapatalk In this case it might be enough if you recompile kernel and enable it. We can do that within next update. https://github.com/igorpecovnik/lib/blob/master/config/kernel/linux-odroidc2-default.config#L1847
christian.colaci Posted September 17, 2016 Author Posted September 17, 2016 In this case it might be enough if you recompile kernel and enable it. We can do that within next update. https://github.com/igorpecovnik/lib/blob/master/config/kernel/linux-odroidc2-default.config#L1847 Sorry...how Can I do? Inviato dal mio SM-G930F utilizzando Tapatalk
Igor Posted September 17, 2016 Posted September 17, 2016 http://docs.armbian.com/Developer-Guide_Build-Preparation/
