nothin Posted May 9, 2022 Posted May 9, 2022 Hello, Armbian 22.02 images doesn't boot on rockpro64. I have tried: Armbian 22.02 Bullseye Armbian 22.02 Jammy XFCE It doesn't boot (not blinking white led). Previous builds works correctly: Armbian_21.08.1_Rockpro64_bullseye_current_5.10.60 0 Quote
taltamir Posted May 9, 2022 Posted May 9, 2022 I have the same issue. I went to https://www.armbian.com/rockpro64/ and downloaded and flashed both Armbian_22.02.2_Rockpro64_jammy_edge_5.16.17_xfce_desktop.img and Armbian_22.02.2_Rockpro64_focal_current_5.15.31_cinnamon_desktop.img both of which got stuck at the same spot. first time I waited 24 hours in case it was just being slow. but no, it just gets stuck there and won't boot. see attached image 0 Quote
taltamir Posted May 11, 2022 Posted May 11, 2022 On 5/9/2022 at 6:10 AM, nothin said: Previous builds works correctly: Armbian_21.08.1_Rockpro64_bullseye_current_5.10.60 Expand thanks for that info. I tried Armbian_21.08.1_Rockpro64_focal_current_5.10.60_cinnamon_desktop.img and it worked as well. 0 Quote
dkebler Posted June 10, 2022 Posted June 10, 2022 yup, it's stuck at the exact same place . `booting using the ftd blob...` I used 5.18 (latest) so this hasn't been resolved with 5.18 jammy edge. These are likely CI generated and only us who actually have boards know this isn't booting. focal versions and dietpit versions are booting so only the jammy versions are the problem. Not sure how we can resolve this. I don't know enough to track down the problem., Thoughts? 0 Quote
dkebler Posted June 10, 2022 Posted June 10, 2022 maybe one of the armbian dev's can help us troubleshoot/track down the issue. @admin 0 Quote
dkebler Posted June 16, 2022 Posted June 16, 2022 I tried flashing the spi u-boot, 2020 arufan version. Honestly not sure it took as I saw nothing on the monitor so had no idea if it was successful but now jammy server/cli version boots 0 Quote
Iuliu Posted June 21, 2022 Posted June 21, 2022 I have the exact problem. doing some more searching, the problem seems to be in U-boot: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=973323;msg=22 but this should have been fixed... 0 Quote
Igor Posted June 21, 2022 Posted June 21, 2022 On 6/21/2022 at 4:54 PM, Iuliu said: but this should have been fixed... Expand There are several ways, this is one of the fastest: https://docs.armbian.com/Developer-Guide_Build-Preparation/#building-armbian 0 Quote
James P. Hutchinson Posted July 1, 2022 Posted July 1, 2022 There is a short cut to fixing things... Grab this, https://github.com/sigmaris/u-boot/releases/download/v2021.04-rockpro64-ci/flash_spi.img.gz Flash it to a small spare SD card, remove the eMMC if there (or jumper around it), and boot. Then go back to Armbian. Cheers Anjin 0 Quote
taltamir Posted July 2, 2022 Posted July 2, 2022 So, we got a bunch of workarounds. Any plan on getting this fixed in future releases? I think I would stick to just using the older version that works, and just avoid updating until it is fixed. 0 Quote
2play Posted August 21, 2023 Posted August 21, 2023 (edited) Same on Linux 5.15.93-rockchip64 aarch64 GNU/Linux - Ubuntu 20.04.6 LTS With spi u-boot it boots. @James P. Hutchinson provided or @ayufan spi u-boot But u-boot on the armbian seems no go. (if i bridge 23-25 pins to disable spi u-boot) PS Seems a newer uboot armbian build compile and apply to SD from armbian-config fixes the sd boot (no SPI) but on reboot the one I tried stays on black screen. OK from power off/on or by pressing reset button Edited August 22, 2023 by 2play 0 Quote
