[SOLVED] I can no longer set gpio to Opi0+
Go to solution Solved by FRANK333,
  • Solution
ok thanks,
i solved it , no need to change kernel ,
i added in /boot/armbianEnv.txt overlay_prefix=sun50i-h5 which is specific for orange pi zero plus , overlays appeared in armbian-config i selected them ,
i inserted the pa gpio corresponding to the pin connected to the 1wire sensor and everything works.
  • FRANK333 changed the title to [SOLVED] I can no longer set gpio to Opi0+
