tylergemini Posted May 16, 2022 Posted May 16, 2022 (edited) Cannot connect to wifi via on-board wifi on Station P1. External USB WiFi controller (rtl88x2bu) works fine on the same board $ cat /boot/extlinux/extlinux.conf label Armbian kernel /boot/Image initrd /boot/uInitrd fdt /boot/dtb/rockchip/rk3399-roc-pc-plus.dtb append root=UUID=d98925da-408f-480e-b729-321ddcdbd2b8 console=ttyS2,1500000 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian $ uname -a Linux station-p1 5.15.25-media #22.02.1 SMP PREEMPT Sun Feb 27 09:07:40 UTC 2022 aarch64 GNU/Linux $ journalctl -u NetworkManager ... May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8375] device (wlan0): Activation: starting connection 'hive' (8ca80b92-474b-43a1-9eff-fdb4c899b491) May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8378] audit: op="connection-activate" uuid="8ca80b92-474b-43a1-9eff-fdb4c899b491" name="hive" pid=3192 uid=1000 result="success" May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8381] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8393] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8401] device (wlan0): Activation: (wifi) access point 'hive' has security, but secrets are required. May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8402] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8461] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed') May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8470] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8477] device (wlan0): Activation: (wifi) connection 'hive' has security, and secrets exist. No new secrets needed. May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8478] Config: added 'ssid' value 'hive' May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8478] Config: added 'scan_ssid' value '1' May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8479] Config: added 'bgscan' value 'simple:30:-70:86400' May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8479] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK' May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8479] Config: added 'auth_alg' value 'OPEN' May 15 15:59:01 station-p1 NetworkManager[1647]: <info> [1652619541.8479] Config: added 'psk' value '<hidden>' May 15 15:59:02 station-p1 NetworkManager[1647]: <info> [1652619542.2812] device (wlan0): supplicant interface state: disconnected -> scanning May 15 15:59:02 station-p1 NetworkManager[1647]: <info> [1652619542.2813] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning May 15 15:59:03 station-p1 NetworkManager[1647]: <info> [1652619543.9542] device (wlan0): supplicant interface state: scanning -> associating May 15 15:59:03 station-p1 NetworkManager[1647]: <info> [1652619543.9544] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating May 15 15:59:04 station-p1 NetworkManager[1647]: <info> [1652619544.5232] device (wlan0): supplicant interface state: associating -> associated May 15 15:59:04 station-p1 NetworkManager[1647]: <info> [1652619544.5233] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated May 15 15:59:08 station-p1 NetworkManager[1647]: <info> [1652619548.5682] device (wlan0): supplicant interface state: associated -> disconnected May 15 15:59:08 station-p1 NetworkManager[1647]: <info> [1652619548.5684] device (p2p-dev-wlan0): supplicant management interface state: associated -> disconnected May 15 15:59:08 station-p1 NetworkManager[1647]: <info> [1652619548.6683] device (wlan0): supplicant interface state: disconnected -> scanning May 15 15:59:08 station-p1 NetworkManager[1647]: <info> [1652619548.6684] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning May 15 15:59:20 station-p1 NetworkManager[1647]: <info> [1652619560.4017] device (wlan0): supplicant interface state: scanning -> associating May 15 15:59:20 station-p1 NetworkManager[1647]: <info> [1652619560.4018] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating May 15 15:59:21 station-p1 NetworkManager[1647]: <info> [1652619561.1998] device (wlan0): supplicant interface state: associating -> associated May 15 15:59:21 station-p1 NetworkManager[1647]: <info> [1652619561.1999] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated May 15 15:59:25 station-p1 NetworkManager[1647]: <info> [1652619565.2404] device (wlan0): supplicant interface state: associated -> disconnected May 15 15:59:25 station-p1 NetworkManager[1647]: <info> [1652619565.2405] device (p2p-dev-wlan0): supplicant management interface state: associated -> disconnected May 15 15:59:25 station-p1 NetworkManager[1647]: <info> [1652619565.3406] device (wlan0): supplicant interface state: disconnected -> scanning May 15 15:59:25 station-p1 NetworkManager[1647]: <info> [1652619565.3407] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning May 15 15:59:26 station-p1 NetworkManager[1647]: <warn> [1652619566.9893] device (wlan0): Activation: (wifi) association took too long May 15 15:59:26 station-p1 NetworkManager[1647]: <info> [1652619566.9894] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed') May 15 15:59:26 station-p1 NetworkManager[1647]: <warn> [1652619566.9919] device (wlan0): Activation: (wifi) asking for new secrets May 15 15:59:26 station-p1 NetworkManager[1647]: <warn> [1652619566.9927] device (wlan0): no secrets: No agents were available for this request. May 15 15:59:26 station-p1 NetworkManager[1647]: <info> [1652619566.9928] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed') May 15 15:59:26 station-p1 NetworkManager[1647]: <warn> [1652619566.9950] device (wlan0): Activation: failed for connection 'hive' May 15 15:59:26 station-p1 NetworkManager[1647]: <info> [1652619566.9994] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') May 15 15:59:28 station-p1 NetworkManager[1647]: <info> [1652619568.9468] device (wlan0): supplicant interface state: scanning -> disconnected May 15 15:59:28 station-p1 NetworkManager[1647]: <info> [1652619568.9469] device (p2p-dev-wlan0): supplicant management interface state: scanning -> disconnected ... Edited May 16, 2022 by tylergemini
Myron Posted May 16, 2022 Posted May 16, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
balbes150 Posted May 18, 2022 Posted May 18, 2022 16.05.2022 в 10:39, tylergemini сказал: Cannot connect to wifi via on-board wifi on Station P1 I checked the latest version with kernel 5.18, Wi-Fi works without problems.
