hotspot cubietruck
sbecue
thank for your work
i need to make a hotspot with cubietruck
I test all debian images for cubietruck but impossible
Configuration
- connexion VGA
- ethernet connected
- microsdcard 16G sandisk ou 32 g
- clavier with doogle usb
all image is dowload today
** Cubietruck_Debian_3.7_jessie_4.0.3
last message
Welcom to Debian GNU/Linux 8 (jessie)!
[TIME] Timed ou waiting for device dev-ttyS0.device.
[DEPEND] Dependency failed for serial Getty on ttyS0.
** Cubietruck_Debian_3.7_jessie_3.4.107.raw
Cannot Display This video mode
** Cubietruck_Debian_3.7_wheezy_3.4.107.raw
** Cubietruck_Debian_3.7_wheezy_4.0.3.raw
failed to bring up eth0
[OK] Restarting OpenBSD Secure Shell Server : sshd
15 minutes rient
tentative de connexion a ssh KO
** Cubietruck_Debian_3.8_jessie_3.4.107.raw
** Cubietruck_Debian_3.8_jessie_4.0.4.raw
** Cubietruck_Debian_3.8_wheezy_3.4.107.raw
** Cubietruck_Debian_3.8_wheezy_4.0.4.raw
15 minutes rient
** Cubietruck_Debian_3.6_jessie_3.4.107.raw : old image , not download today
boot: OK
update : OK
but wifi en mode hotspot don't work
if I write in /etc/modules file
bcmdhd :  I can't see my SSID with my wifi device
or
bcmdhd op_mode=2  : dont load the module
If the bcmdhd module is not load and I execute the commande
"modprobe bcmdhd op_mode=2"
and start hostapd, I can see my ssid with my wifi device
** Cubietruck_Ubuntu_3.8_trusty_4.0.4.raw
[3.628018] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
~3 minutes ...
ssh start/running, process961
wait and nothing
Have you a solution for me please ?
I'm sorry my english is bad,
My Linux is better, but not excelent!!!
Link to comment
Share on other sites
when the message is :
connect with ssh
edit /boot/boot.cmd
change resolution in ligne :
setenv bootargs console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1024x768p60 panic=10 consoleblank=0 enforcing=0 loglevel=1
execute
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
reboot
an is OK.
If not ok, move the resolution : 1024x768p60 by less
Link to comment
OK, some quick tips:
v3.7 jessie image is broken due to some systemd changes. I saw too late. 3.8 is boots ok - at least with network attached. I haven't tested without for a while. On new kernel there is no output to serial console by default.
loading with
bcmdhd op_mode=2
works with wheezy and trusty but not jessie ;)
4.0.4 different module
brcmfmac. It should work ... I haven't tested with 4.0.4 but with 3.19.x and it was working w/o problems.
If you want a proven configuration, stick to Wheezy with kernel 3.4.x
Video resolution. I'll go down with default one or made some other solution.
Waiting for 3min might not be enough. I am doing apt-get update at first boot.
Link to comment
OK thank you
I tested with Cubietruck_Debian_3.8_wheezy_3.4.107.raw
with ssh connection , I moved resolution and execute mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
upgraded system
network config
ip_forwarding
install dhcp-serveur
I see my ssid since my wifi client
But not connetced, i think is not hard , i find it.
Thank-you for your help
I find my problem and I write a article for hel in french
see you and thank's
Link to comment
My default example configuration is meant to work with /etc/network/interfaces.hostap where wlan0 and eth0 are connected to a bridge so wlan0 AP clients are geting a dhcp from the main network - from your router.
Link to comment
Ok it's work yesterday night
my hostapd.conf needed bridge=br0 instruction
I don't saw you configuration exmple in /etc/.
I saw in /etc/hostapd, is empty
Thank you for your work and your help
Sébastien
Link to comment
more /etc/hostapd.conf
ssid=cubietruck
interface=wlan0
hw_mode=g
channel=5
driver=nl80211
bridge=br0
logger_syslog=0
logger_syslog_level=0
wmm_enabled=1
ieee80211n=1
wpa=2
preamble=1
wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
noscan=1
#ht_capab=[HT40-][SHORT-GI-40][SHORT-GI-40][DSSS_CCK-40]
#country_code=SI
#ieee80211d=1
Configuration for realtek:
more /etc/hostapd.conf-rt
interface=wlan0
ctrl_interface=/var/run/hostapd
ssid=orangepi
channel=5
noscan=1
wpa=2
bridge=br0
wmm_enabled=1
driver=rtl871xdrv
beacon_int=100
hw_mode=g
ieee80211n=1
wme_enabled=1
ht_capab=[SHORT-GI-40][HT40+][HT40-][DSSS_CCK-40]
wpa_pairwise=CCMP
max_num_sta=8
wpa_group_rekey=86400
Link to comment
