sbecue Posted May 25, 2015 Share Posted May 25, 2015 Hi, thank for your work i need to make a hotspot with cubietruck I test all debian images for cubietruck but impossible Configuration - connexion VGA - ethernet connected - microsdcard 16G sandisk ou 32 g - clavier with doogle usb all image is dowload today ** Cubietruck_Debian_3.7_jessie_4.0.3 last message Welcom to Debian GNU/Linux 8 (jessie)! [TIME] Timed ou waiting for device dev-ttyS0.device. [DEPEND] Dependency failed for serial Getty on ttyS0. ** Cubietruck_Debian_3.7_jessie_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.7_wheezy_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.7_wheezy_4.0.3.raw ... failed to bring up eth0 ... [OK] Restarting OpenBSD Secure Shell Server : sshd 15 minutes rient tentative de connexion a ssh KO ** Cubietruck_Debian_3.8_jessie_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.8_jessie_4.0.4.raw Welcom to Debian GNU/Linux 8 (jessie)! [TIME] Timed ou waiting for device dev-ttyS0.device. [DEPEND] Dependency failed for serial Getty on ttyS0. ** Cubietruck_Debian_3.8_wheezy_3.4.107.raw Cannot Display This video mode ** Cubietruck_Debian_3.8_wheezy_4.0.4.raw ... failed to bring up eth0 ... [OK] Restarting OpenBSD Secure Shell Server : sshd 15 minutes rient tentative de connexion a ssh KO ** Cubietruck_Debian_3.6_jessie_3.4.107.raw : old image , not download today boot: OK update : OK but wifi en mode hotspot don't work if I write in /etc/modules file bcmdhd : I can't see my SSID with my wifi device or bcmdhd op_mode=2 : dont load the module If the bcmdhd module is not load and I execute the commande "modprobe bcmdhd op_mode=2" and start hostapd, I can see my ssid with my wifi device ** Cubietruck_Ubuntu_3.8_trusty_4.0.4.raw [3.628018] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code ~3 minutes ... ... ssh start/running, process961 wait and nothing Have you a solution for me please ? I'm sorry my english is bad, My Linux is better, but not excelent!!! Link to comment Share on other sites More sharing options...
sbecue Posted May 25, 2015 Author Share Posted May 25, 2015 when the message is : Cannot Display This video mode connect with ssh edit /boot/boot.cmd change resolution in ligne : setenv bootargs console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1024x768p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 execute mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr reboot an is OK. If not ok, move the resolution : 1024x768p60 by less Link to comment Share on other sites More sharing options...
Igor Posted May 25, 2015 Share Posted May 25, 2015 OK, some quick tips:v3.7 jessie image is broken due to some systemd changes. I saw too late. 3.8 is boots ok - at least with network attached. I haven't tested without for a while. On new kernel there is no output to serial console by default. loading with bcmdhd op_mode=2 works with wheezy and trusty but not jessie 4.0.4 different module brcmfmac. It should work ... I haven't tested with 4.0.4 but with 3.19.x and it was working w/o problems. If you want a proven configuration, stick to Wheezy with kernel 3.4.x Video resolution. I'll go down with default one or made some other solution. Waiting for 3min might not be enough. I am doing apt-get update at first boot. Link to comment Share on other sites More sharing options...
sbecue Posted May 25, 2015 Author Share Posted May 25, 2015 OK thank you I tested with Cubietruck_Debian_3.8_wheezy_3.4.107.raw with ssh connection , I moved resolution and execute mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr upgraded system network config ip_forwarding install dhcp-serveur I see my ssid since my wifi client But not connetced, i think is not hard , i find it. Thank-you for your help I find my problem and I write a article for hel in french see you and thank's Link to comment Share on other sites More sharing options...
Igor Posted May 26, 2015 Share Posted May 26, 2015 My default example configuration is meant to work with /etc/network/interfaces.hostap where wlan0 and eth0 are connected to a bridge so wlan0 AP clients are geting a dhcp from the main network - from your router. Link to comment Share on other sites More sharing options...
sbecue Posted May 26, 2015 Author Share Posted May 26, 2015 Ok it's work yesterday night my hostapd.conf needed bridge=br0 instruction I don't saw you configuration exmple in /etc/. I saw in /etc/hostapd, is empty Thank you for your work and your help Sébastien Link to comment Share on other sites More sharing options...
Igor Posted May 26, 2015 Share Posted May 26, 2015 more /etc/hostapd.conf ssid=cubietruck interface=wlan0 hw_mode=g channel=5 driver=nl80211 bridge=br0 logger_syslog=0 logger_syslog_level=0 wmm_enabled=1 ieee80211n=1 wpa=2 preamble=1 wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 noscan=1 #ht_capab=[HT40-][SHORT-GI-40][SHORT-GI-40][DSSS_CCK-40] #country_code=SI #ieee80211d=1 Configuration for realtek: more /etc/hostapd.conf-rt interface=wlan0 ctrl_interface=/var/run/hostapd ssid=orangepi channel=5 noscan=1 wpa=2 wpa_passphrase=12345678 bridge=br0 wmm_enabled=1 driver=rtl871xdrv beacon_int=100 hw_mode=g ieee80211n=1 wme_enabled=1 ht_capab=[SHORT-GI-40][HT40+][HT40-][DSSS_CCK-40] wpa_key_mgmt=WPA-PSK wpa_pairwise=CCMP max_num_sta=8 wpa_group_rekey=86400 Link to comment Share on other sites More sharing options...
