I am looking for a Minimal Armbian for H3 chip with kiosk feature. I don't need desktop interface but still need a web browser to open at startup.
Is there any version like this? I need it minimum because i will install on eMMC of the Orange Pi PC Plus and it has only 8GB.
On 6/2/2022 at 8:41 PM, MacBreaker said:
Hello @thanh_tan,
next time I will try the same with Orange Pi One.
My search point to this adress:  https://desertbot.io/blog/raspberry-pi-touchscreen-kiosk-setup
It's based on a cli (small) image with Chromium, no desktop need.
Found also a artickel, but it's in german with the firefox browser.
Maybe this helps a little bit..
Markus
This derserbot cannot work on armbian since armbian doesn't allow autologin with username.
On Raspi they have on raspi-config
Boot Options> Desktop CLI> Console Autologin
but armbian-config don't
I have found the solution for autologin from console here https://askubuntu.com/questions/819117/how-can-i-get-autologin-at-startup-working-on-ubuntu-server-16-04-1
First, find the agetty
type -a agetty
It will returns, like this
agetty is /usr/sbin/agetty
agetty is /sbin/agetty
note /sbin/agetty
Then run this
sudo systemctl edit getty@tty1.service
This will the create a drop-in file (if neccessary) and open it an editor. Add the following, replacing myusername with username:
[Service]
ExecStart=
ExecStart=-/sbin/agetty --noissue --autologin myusername %I $TERM
Type=idle
This will:
Create the folder /etc/systemd/system/getty@tty1.service.d if necessary
Create the file /etc/systemd/system/getty@tty1.service.d/override.conf if necessary
Then reboot. Since i have follow the above instruction from desertbot.io, it will appear the website
great that it works for you and you were able to solve the differences between RPi and Armbian. 👍
For my part, I have not dig deep in the project, since for me it is a "bad weather project" in the future of this year.
Thanks for your tips, I'll use them... 🙂
What about the space of your eMMC?
I think no Problem.
Markus
18 hours ago, MacBreaker said:
I think no Problem.
Markus
The Orange PI PC Plus has 8GB and all the os and chromium took only 3GB.
That's sound good for me now
Hello @thanh_tan,
Markus
I have followed this instruction and success with display video on orange pi but there are two problem need to ask more.
1. How to get the sound output with HDMI out? Tried alsa-mixer to setup sound out with hdmi, but seem that chromium doesn't play the sound
2. The default resolution is 1024x800. Want to upgrade to 1080p but cannot
