Alsan Wong Posted September 24, 2016 Posted September 24, 2016 I'm trying to recompile the image from source (because I want the kernel with SATA PMP support, and I got the SATA port multiplier and 3 drives ready), but failed in the last step. As the attached image, the problem should be caused by "Device or resource busy". I'm using a fresh downloaded Ubuntu 16.4 VB image and follow every instructions in github. So, how can I get rid of it? Am I missing something? Thanks.
Igor Posted September 24, 2016 Posted September 24, 2016 Why don't you recompile kernel only if you need this tiny change and install this new kernel? I see from this screen, that it was done successfully. Beware when upgrading since if you use our tools, recreated kernel will be overwritten at next update.
zador.blood.stained Posted September 24, 2016 Posted September 24, 2016 @Alsan Wong And I believe you don't need to recompile anything to enable PMP, adding ahci_sunxi.enable_pmp=1 to kernel arguments in boot script should be enough
Alsan Wong Posted September 24, 2016 Author Posted September 24, 2016 yes, it worked! adding kernel parameter is much simplier. thank you very much.
MartinKeppler Posted October 10, 2016 Posted October 10, 2016 Got the same problem with compiling from source. Content of output/debug/tools-build.sh: /bin/bash: make: command not found. /bin/bash: make: command not found. Make is installed. Ideas?
MartinKeppler Posted October 11, 2016 Posted October 11, 2016 If I am right, the errors are coming from this two lines chroot $CACHEDIR/sdcard /bin/bash -c "cd /root/tools/temper/src; make clean" >> $DEST/debug/tools-build.log 2>&1 chroot $CACHEDIR/sdcard /bin/bash -c "cd /root/tools/temper/src; make $CTHREADS" >> $DEST/debug/tools-build.log 2>&1 in lib/extras/tools.sh. But why? I was able to build armbian from source till last week. Suddenly I got this error. For building I'm using a VirtualBox Ubuntu 16 64 bit. I setup a new VM, errors still there. I downloaded the lib again, errors still there. What can I do?
Igor Posted October 11, 2016 Posted October 11, 2016 Building desktop is currently broken. Working on this right now.
Solution Igor Posted October 11, 2016 Solution Posted October 11, 2016 Building desktop is currently broken. Working on this right now. Fixed. 1
