I've tried nand-sata-install on Armbian_22.05.3_Odroidxu4_jammy_current_5.4.199.img and Armbian_22.05.3_Odroidxu4_focal_current_5.4.199.img. Right at the end of running nand-sata-install there's an error. If I try to install anything after nand-sata-install it will hang or the SSD will go into read only mode. To be safe I tested various SD cards and USB to SATA controllers.
sed: can't read /boot/boot.cmd: No such file or directory
Error while creating U-Boot loader image with mkimage
umount: /mnt/nand-sata-install.wwpusQ/bootfs: not mounted.
Edited by sgjava
Can you check /var/log/nand-sata-install.log? Maybe some clues what happened there.
Nothing weird from what I can tell. I ordered another USB3 to SATA adapter. An older XU4 I have has a similar log and it works, but it was installed months ago.
Mon Jun 27 07:13:25 PM EDT 2022: Start nand-sata-install.
Old UUID:  UUID=bc61c55d-8e89-422e-bd96-6bf0901b94ea
SD UUID:   UUID=bc61c55d-8e89-422e-bd96-6bf0901b94ea
SATA UUID: UUID=5e24c2e8-ebaf-4897-bc37-d10cfafb3d47
eMMC UUID:
Boot: $1
Root: $2 /dev/sda1 ext4
Usage: 1063
Dest: 227055
/etc/fstab:
UUID=bc61c55d-8e89-422e-bd96-6bf0901b94ea / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
/etc/mtab:
/dev/mmcblk1p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/sda1 /mnt/nand-sata-install.wwpusQ/rootfs ext4 rw,relatime,stripe=8191 0 0
/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
Files currently open for writing:
nfsdcld    701            root    6u   REG  179,1    32768 43678 /var/lib/nfs/nfsdcld/main.sqlite
vnstatd   1566          vnstat    3u   REG  179,1    69632 43683 /var/lib/vnstat/vnstat.db
Trying to stop running services to minimize open files:
Stopping nfs-mountd.service
Stopping nfs-idmapd.service
Stopping nfs-blkmap.service
Stopping cron.service
Checking again for open files:
Copying 44257 files to /dev/sda1. Finishing transfer to disk, boot from SD/eMMC
Mon Jun 27 07:16:08 PM EDT 2022: Finished
Edited by sgjava
