martin-by Posted October 3, 2016 Posted October 3, 2016 Hello,I made a fresh install of Ubuntu 16.04 lts (ARMBIAN) on armhf cubietruck (Armbian_5.20_Cubietruck_Ubuntu_xenial_3.4.112) .libav-tools is installed along with MPD & MPC.service mpd status reports:"mpd[6770]: /usr/bin/mpd: error while loading shared libraries: libavformat-ffmpeg.so.56: cannot open shared object file: No such file or directory"What is missing to start MPD?Best regards,Martin
martin-by Posted October 3, 2016 Author Posted October 3, 2016 Hi, I tested a MPD install on Armbian_5.20_Cubietruck_Ubuntu_xenial_4.7.3: apt update apt upgrade apt install mpd mpc It is the same issue: â— mpd.service - Music Player Daemon Loaded: loaded (/lib/systemd/system/mpd.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Mon 2016-10-03 15:21:29 UTC; 2min 32s ago Main PID: 11289 (code=exited, status=127) Oct 03 15:21:29 cubietruck systemd[1]: Started Music Player Daemon.Oct 03 15:21:29 cubietruck mpd[11289]: /usr/bin/mpd: error while loading shared libraries: libavformat-ffmpeg.so.56: cannot open shared object file: No such file or directoryOct 03 15:21:29 cubietruck systemd[1]: mpd.service: Main process exited, code=exited, status=127/n/aOct 03 15:21:29 cubietruck systemd[1]: mpd.service: Unit entered failed state.Oct 03 15:21:29 cubietruck systemd[1]: mpd.service: Failed with result 'exit-code'. Any tip to fix this? Best regards, Martin
zador.blood.stained Posted October 3, 2016 Posted October 3, 2016 There is an issue with packages configuration, it will be fixed with new image release.
Igor Posted October 4, 2016 Posted October 4, 2016 We haven't set a date yet, probably end of the month, hopefully before we plan to put out a bugfix release.
martin-by Posted October 4, 2016 Author Posted October 4, 2016 Ok, thank you for your quick response! So I have to wait until this new release.
Solution martin-by Posted October 14, 2016 Author Solution Posted October 14, 2016 Hello, today I made a upgrade & dist-upgrade, it seems MPD & MINIDLNA starts the service now. Thank you! Remark: but mounting a HDD partition in fstab fails and after boot the system hangs. My entry in fstab from old config is: UUID=638a7add-21ee-4cf7-8c1e-095c4ae727ff /mnt/HDD ext4 user,sync 0 0 Any hint for this? UPDATE: after falling back to my backup I realized the root of permanent reboot: Installed software after update & dist-upgrade : WEBMIN, MPD, MINIDLNA (proper reboot of system) apt install cups: no reboot any more (reboot within minutes) Are there any other problems within package? UPDATE2: ​OK, my fault. After installing my SSD for root device (deactivating tempfs & swap within fstab also) CUPS can be installed easily without any problems. Best regards, Martin
