balbes150 Posted April 5, 2023 Author Posted April 5, 2023 Ver 20230405-edge kernel 6.3 work SD USB LAN 0 Quote
kjhdfgkio Posted April 7, 2023 Posted April 7, 2023 (edited) This is fantastic! It's the first Armbian I was able to get to boot on the ROC-RK3588S-PC board, which seems to be nearly identical to the board inside the M3. The only issue I have is that it doesn't seem to recognize the NVMe drive, or perhaps I'm just doing something wrong. Any tips for troubleshooting the NVMe? I'm using this image from the "20230330-legacy" folder: Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img armbianmonitor logs at: https://paste.armbian.com/uyiwocajac I also tried this image from the "20230330-current" folder: Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz Which booted fine, but seems to have no fancontrol, and also no NVMe. Logs for Lunar are at https://paste.armbian.com/catoxosije The NVMe drive I'm using is the SABRENT 2TB Rocket NVMe PCIe M.2 2242 (SB-1342-2TB): https://www.amazon.com/dp/B07XVRTG1H Edited April 7, 2023 by kjhdfgkio new details 0 Quote
kjhdfgkio Posted April 7, 2023 Posted April 7, 2023 (edited) It was a me issue... updating /boot/extlinux/extlinux.conf to point to "rk3588s-roc-pc-nvme.dtb" instead of "rk3588s-roc-pc.dtb" got the NVMe going. For the Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz image, the blue post-boot LED never comes on and the fan is always full speed. I saw the prior note about replacing the "/usr/bin/firefly-fan-control" file, but it looks like the image is completely missing the firefly-fan-control file to start with. Running firefly-fan-control is verbose mode gets: set_PWM: 59000 pwm: 50 pwm: 50 no such file /tmp/fan_temperature no such file /tmp/fan_temperature no such file /tmp/fan_temperature set_PWM: 59000 pwm: 50 SetValue: 53000.000000 ActualValue: 50000.000000 PID->Ek: 3000.000000 PID->LocSum: 3000.000000 PIDLoc: -4584.000000 pwm:50.000198 count is 0 fan_switch is 1 PID_fan_func exit set_PWM: 59000 pwm: 50 SetValue: 53000.000000 ActualValue: 50000.000000 PID->Ek: 3000.000000 PID->LocSum: 3000.000000 PIDLoc: -7584.000000 pwm:50.000198 So, it seems the -current build is missing some stuff for fan control. The other issue I have is that now that I've installed armbian on the eMMC, I can't seem to get this ROC-RK3588-PC to boot from the SDCard again. During boot I only get the Armbian logo image, and no amount of hitting space-bar gets me into to the uboot cli. Edited April 7, 2023 by kjhdfgkio doh! 0 Quote
balbes150 Posted April 8, 2023 Author Posted April 8, 2023 11 часов назад, kjhdfgkio сказал: installed armbian on the eMMC Write in detail how the installation was performed. 11 часов назад, kjhdfgkio сказал: I can't seem to get this ROC-RK3588-PC to boot from the SDCard again Check the launch from USB (burn the image to a USB flash drive instead of an SD card), connect to the device and turn on the power. When starting Armbian, disabling the screensaver works with the ESC button 11 часов назад, kjhdfgkio сказал: no amount of hitting space-bar gets me into to the uboot cli. management from u-boot only works with android versions installed in eMMC , this is not a u-boot function, it is an additional intermediate add-on 0 Quote
kjhdfgkio Posted April 10, 2023 Posted April 10, 2023 Quote Write in detail how the installation was performed. ROC-RK3588-PC running Firefly provided "ROC-RK3588S-PC_Ubuntu20.04-Gnome-r240_v1.0.6f_230404" image (which had been written over USB using RKDevTool 2.96 from a Windows 11 machine) Used Raspberry Pi Imager to write the provided image to an SDHC card on a Windows 11 machine Inserted SDHC card into the SBC's card slot Powered on the SBC It booted to Armbian Ran "lsblk", noticed there was no NVMe Edited "/boot/extlinux/extlinux.conf" to set the fdt file to "/boot/dtb/rockchip/rk3588s-roc-pc-nvme.dtb" (just added "-nvme" before ".dtb") Ran "reboot" Booted from Armbian again Ran "lsblk", was happy to see the "nvme0n1" drive - but noticed no partitions Ran "fdisk /dev/nvme0n1" - typed "n" for a new partition, took defaults, typed "w" to write and quit Typed 'armbian-install' Selected "Boot from eMMC - system on SATA, USB or NCMe" - answered "Y" to both prompts warning it would overwrite "mmcblk0p1" and "nvme0n1p1" Rebooted at the end Ran "mount" and was happy to see "/dev/nvme0n1p1 on /" and "/dev/mmcblk0p1 on /boot" Removed the SDHC card, tried power cycling a few more times, all seemed good Quote Check the launch from USB (burn the image to a USB flash drive instead of an SD card), connect to the device and turn on the power. The "Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img.xz" image on a USB flash drive seems to boot, as it gets to a point where the fan slows down and the post-boot blue LED just above the SD slot lights up, but there is no network or HDMI, so I can't do anything with it. The "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image on a USB flash drive booted, and took me to the initial "Create root password" prompt. HDMI and networking worked great. Thanks for the pointer here. USB flash drives are substantially faster than the SDHC cards, so this is a much better way to go. Quote When starting Armbian, disabling the screensaver works with the ESC button Works great, thank you! Quote management from u-boot only works with android versions installed in eMMC , this is not a u-boot function, it is an additional intermediate add-on Got it, thanks! 0 Quote
kjhdfgkio Posted April 10, 2023 Posted April 10, 2023 On the "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image, I'm seeing a Kernel panic that seems somewhat random while reading/writing to the NVMe. Here are two examples of it (OCR'd from a photo of the panic ... pretty sure I double checked every character in it). station-m3 login: [ 659.401029] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 659.401730] CPU: 5 PID: 1 Comm: systemd Tainted: G W 6.2.0-rc1-station-m3 #23.02.3 [ 659.402523] Hardware name: Firefly ROC-RK3588S-PC NVMe (DT) [ 659.403017] Call trace: [ 659.403236] dump_backtrace+0xdc/0x130 [ 659.403577] show_stack+0x18/0x30 [ 659.403874] dump_stack_lvl+0x64/0x80 [ 659.404204] dump_stack+0x18/0x34 [ 659.404502] panic+0x180/0x330 [ 659.404776] make_task_dead+0x0/0x16c [ 659.405104] do_group_exit+0x34/0x90 [ 659.405423] get_signal+0x830/0x894 [ 659.405734] do_notify_resume+0x2d0/0x1310 [ 659.406101] el0_svc+0xa4/0xb4 [ 659.406375] el0t_64_sync_handler+0xf4/0x120 [ 659.406754] elot_64_sync+0x1a0/0x1a4 [ 659.407081] SMP: stopping secondary CPUs [ 659.407496] Kernel Offset: disabled [ 659.407806] CPU features: 0x60000,000e0148,cc00720b [ 659.408239] Memory Limit: none [ 659.414666]---[ end Kernel panic- not syncing: Attempted to kill init! exitcode=0x0000000b ]--- station-m3 login: [ 1298.038509] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 1298.039211] CPU: 7 PID: 1 Comm: systemd Tainted: G W 6.2.0-rc1-station-m3 #23.02.3 [ 1298.040004] Hardware name: Firefly ROC-RK3588S-PC NVMe (DT) [ 1298.040498] Call trace: [ 1298.040718] dump_backtrace+0xdc/0x130 [ 1298.041060] show_stack+0x18/0x30 [ 1298.041358] dump_stack_lvl+0x64/0x80 [ 1298.041688] dump_stack+0x18/0x34 [ 1298.041986] panic+0x180/0x330 [ 1298.042260] make_task_dead+0x0/0x16c [ 1298.042587] do_group_exit+0x34/0x90 [ 1298.042906] get_signal+0x830/0x894 [ 1298.043217] do_notify_resume+0x2d0/0x1310 [ 1298.043583] el0_undef+0xf0/0xf4 [ 1298.043871] el0t_64_sync_handler+0xa0/0x120 [ 1298.044251] el0t_64_sync+0x1a0/0x1a4 [ 1298.044578] SMP: stopping secondary CPUs [ 1298.044930] Kernel Offset: disabled [ 1298.045239) CPU features: 0x60000,000e0148, cc00720b [ 1298.045671] Memory Limit: none [ 1298.052109] ---[ end Kernel panic- not syncing: Attempted to kill init! exitcode=0x0000000b ]--- I had another one that was a paging issue during a find_inode_fast call, but it seems to have been fixed by changing mergerfs to have "cache.files=off" rather than "cache.files=full" or "partial", so I'm assuming mergerfs just isn't fully 6.2.0 compatible yet. 0 Quote
balbes150 Posted April 10, 2023 Author Posted April 10, 2023 9 часов назад, kjhdfgkio сказал: Used Raspberry Pi Imager to write the provided image to an SDHC card on a Windows 11 machine the exact name of the image (or a link to it) 9 часов назад, kjhdfgkio сказал: ROC-RK3588-PC running Firefly provided "ROC-RK3588S-PC_Ubuntu20.04-Gnome-r240_v1.0.6f_230404" image (which had been written over USB using RKDevTool 2.96 from a Windows 11 machine) What was in eMMC before and what steps did you do earlier on M3 (installing different versions of Android\StationOS, including multiloading or other experiments with the previous system). 9 часов назад, kjhdfgkio сказал: is no network or HDMI Which monitor is connected and how ? 9 часов назад, kjhdfgkio сказал: On the "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image, I'm seeing a Kernel panic that seems somewhat random while reading/writing to the NVMe. Here are two examples of it (OCR'd from a photo of the panic ... pretty sure I double checked every character in it). This is a core for development, it has many flaws and bugs. 0 Quote
kjhdfgkio Posted April 11, 2023 Posted April 11, 2023 On 4/10/2023 at 2:36 AM, balbes150 said: the exact name of the image (or a link to it) "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" On 4/10/2023 at 2:36 AM, balbes150 said: What was in eMMC before and what steps did you do earlier on M3 (installing different versions of Android\StationOS, including multiloading or other experiments with the previous system). Whatever Android came on the eMMC for the device that Firefly shipped to me last week. I didn't actually look at the Android build, I just immediately used RKDevTool to flash "ROC-RK3588S-PC_Ubuntu20.04-Gnome-r240_v1.0.6f_230404" to it. On 4/10/2023 at 2:36 AM, balbes150 said: Which monitor is connected and how ? I've tried both a Dell U4021QW and a Phillips 272P7VUBNB/27. Both are just a direct HDMI cable from the RK's HDMI output port to the HDMI1 port on the monitor. I also tried a few different HDMI cables, some active, some passive. Again, works fine on USB boot from the "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image, but not the "Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img.xz" image. On 4/10/2023 at 2:36 AM, balbes150 said: This is a core for development, it has many flaws and bugs. Understood. Any pointers to ways I can collect more information or kernel dumps to help the team troubleshoot these issues? 0 Quote
balbes150 Posted April 12, 2023 Author Posted April 12, 2023 16 часов назад, kjhdfgkio сказал: but not the "Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img.xz" image. try to burn images 5.10 from the directory 20230302 to the SD card and check their launch, and then burn the same image to USB and check its operation. 0 Quote
kjhdfgkio Posted April 12, 2023 Posted April 12, 2023 7 hours ago, balbes150 said: try to burn images 5.10 from the directory 20230302 to the SD card and check their launch, and then burn the same image to USB and check its operation. "Armbian_23.02.0-trunk_Station-m3_jammy_legacy_5.10.110.img.xz" from the 20230302 folder on a USB flash drive has a "not syncing" kernel panic during boot. The normal shift+pageup doesn't seem to work for scrolling back up to get stack info. "Armbian_23.02.0-trunk_Station-m3_jammy_legacy_5.10.110.img.xz" from the 20230302 folder on an SD card has the same "not syncing" kernel panic during boot. I tried the "Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img.xz" image again from USB and got video this time (no changes, just worked this time?). It also landed at a "not syncing" kernel panic. When the stock bootloader was on the device I was able to boot the "Armbian_23.02.3_Station-m3_jammy_legacy_5.10.110.img.xz" image from SD and flash the device (eMMC bootloader/eMMC system), but after flashing the "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image (eMMC bootloader, SSD system) the jammy images seem to panic during boot. 0 Quote
balbes150 Posted April 13, 2023 Author Posted April 13, 2023 16 часов назад, kjhdfgkio сказал: but after flashing the "Armbian_23.02.3_Station-m3_lunar_current_6.2.0.img.xz" image (eMMC bootloader, SSD system) the jammy images seem to panic during boot. do not install versions with kernel 6.2 on eMMC, these are test versions with possible bugs and errors. 0 Quote
balbes150 Posted April 19, 2023 Author Posted April 19, 2023 Ver 20230417 edge (kernel 6.3-rc7) work SD, USB, LAN, WiFi, SATA\NVMe current (kernel 6.2) add WiFi 0 Quote
balbes150 Posted April 20, 2023 Author Posted April 20, 2023 ver 20230420 mesa 23.2.0-devel for pancsf fot kernel 6.2 https://disk.yandex.ru/d/FUqgx3Zz9ZSckw 0 Quote
kjhdfgkio Posted May 1, 2023 Posted May 1, 2023 (edited) On 4/13/2023 at 1:45 AM, balbes150 said: do not install versions with kernel 6.2 on eMMC, these are test versions with possible bugs and errors. I moved the eMMC install back to the legacy kernel. Any tips for collecting kernel panic dumps or auto-rebooting after a kernel panic? I set "kernel.panic=5" in /etc/sysctl.conf, but it seems to only reboot for about 1 in 5 kernel panics. For the other ones, everything has scrolled so far up that I can't get the details and the normal up arrows, or ctl+page up, keyboard sequences aren't scrolling. All the methods I know for getting kernel panic dumps require building the kernel on my own... I also tried installing the system watchdog service (apt install watchdog), but the /dev/watchdog device that exists in the Firefly linux image seems to be missing in this Armbian image. There are more details at https://wiki.t-firefly.com/en/ROC-RK3588S-PC/usage_watchdog.html Edited May 1, 2023 by kjhdfgkio watchdog 0 Quote
balbes150 Posted May 2, 2023 Author Posted May 2, 2023 15 часов назад, kjhdfgkio сказал: Any tips for collecting kernel panic dumps or auto-rebooting after a kernel panic? What kind of core panic are you writing about ? I don't see any messages about legacy kernel panic. 0 Quote
kjhdfgkio Posted May 3, 2023 Posted May 3, 2023 On 5/2/2023 at 2:53 AM, balbes150 said: What kind of core panic are you writing about ? I don't see any messages about legacy kernel panic. I'm not sure since I can't scroll up and I haven't been able to catch it as it is happening with a camera as I haven't found a specific trigger, but I've attached a picture of the not-very-useful end of it. I'm running the Plex server inside a docker container and it seems to be associated with Plex rescanning the media collection on a 2 hour timer, but I can't trigger it on manual rescans. There are no Plex clients trying to get media from this as I've just set it up on my desk to test the board out to see if it can replace my current Plex server. 0 Quote
balbes150 Posted May 4, 2023 Author Posted May 4, 2023 20 часов назад, kjhdfgkio сказал: I'm not sure since I can't scroll up and I haven't been able to catch it as it is happening with a camera as I haven't found a specific trigger, but I've attached a picture of the not-very-useful end of it. where is the system installed ? If on USB\SD, you can connect the media to the PC and open the log file and see the full output (/var/log) and find the reason that causes the kernel to panic. If the system is on SATA\NVMe - start the system from SD\USB media, mount SATA\NVMe and see the same logs. 0 Quote
balbes150 Posted May 5, 2023 Author Posted May 5, 2023 ver 20230428-EDK2-EFI kernel legacy and current 0 Quote
balbes150 Posted June 9, 2023 Author Posted June 9, 2023 Ver 20230609-edge (use u-boot) kernel 6.4-rc5 (no HDMI) 20230609-EDK2-EFI-edge kernel 6.4-rc5 - HDMI work only EDK2 (grub), HDMI in system not work root@192.168.1.20's password: ____ _ _ _ __ __ _____ / ___|| |_ __ _| |_(_) ___ _ __ | \/ |___ / \___ \| __/ _` | __| |/ _ \| '_ \ | |\/| | |_ \ ___) | || (_| | |_| | (_) | | | | | | | |___) | |____/ \__\__,_|\__|_|\___/|_| |_| |_| |_|____/ Welcome to Armbian 23.04 Lunar with bleeding edge Linux 6.4.0-rc5-media No end-user support: built from trunk System load: 36% Up time: 3 min Memory usage: 2% of 7.76G IP: 192.168.1.20 CPU temp: 37°C Usage of /: 51% of 3.4G RX today: 0 B [ 30 security updates available, 35 updates total: apt upgrade ] Last check: 2023-06-09 10:03 Last login: Fri Jun 9 13:03:38 2023 root@station-m3:~# neofetch root@station-m3 --------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.04) aarch64 ███████████████████████ Host: Firefly ROC-RK3588S-PC SATA ▄▄██ ██▄▄ Kernel: 6.4.0-rc5-media ▄▄██ ███████████ ██▄▄ Uptime: 3 mins ▄▄██ ██ ██ ██▄▄ Packages: 549 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Terminal: /dev/pts/0 ▄▄██ █████████████ ██▄▄ CPU: (8) ▄▄██ ██ ██ ██▄▄ Memory: 198MiB / 7943MiB ▄▄██ ██ ██ ██▄▄ ▄▄██ ██ ██ ██▄▄ ▄▄██ ██▄▄ ███████████████████████ █ █ █ █ █ █ █ █ █ █ █ root@station-m3:~# lspci root@station-m3:~# fdisk -l Disk /dev/ram0: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram4: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram5: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram6: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram7: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram8: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram9: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram10: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram11: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram12: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram13: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram14: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram15: 16 MiB, 16777216 bytes, 32768 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram0: 3.88 GiB, 4164710400 bytes, 1016775 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/sda: 119.24 GiB, 128035676160 bytes, 250069680 sectors Disk model: GN128 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xfa4731db Device Boot Start End Sectors Size Id Type /dev/sda1 2048 216059903 216057856 103G 83 Linux /dev/sda2 216059904 250068991 34009088 16.2G 82 Linux swap / Solaris Disk /dev/mmcblk1: 58.24 GiB, 62537072640 bytes, 122142720 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: E17A25F6-9411-4879-B537-9B2E202E5AFF Device Start End Sectors Size Type /dev/mmcblk1p1 32768 120913919 120881152 57.6G Linux filesystem Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/sdb: 3.7 GiB, 3967811584 bytes, 7749632 sectors Disk model: Silicon-Power4G Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 0AEF938A-4585-154F-81FE-D01D61B5A6EC Device Start End Sectors Size Type /dev/sdb1 32768 7340032 7307265 3.5G Linux filesystem Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes root@station-m3:~# 0 Quote
balbes150 Posted July 13, 2023 Author Posted July 13, 2023 Ver 20230713-edge kernel 6.4.3 Ver 20230714-edge kernel 6.5-rc1 add info https://bbs.stationpc.com/forum.php?mod=redirect&goto=findpost&ptid=323&pid=1443&fromuid=636914 0 Quote
balbes150 Posted September 11, 2023 Author Posted September 11, 2023 Ver 20230911-EDK2-EFI kernel legacy\current\edge On the edge version, HDMI does not work in the kernel itself, but HDMI is supported at the level of the selection menu in GRUB, this allows you to have several different versions of the kernel\system (for example, add a self-assembled EDGE kernel with its own configuration) and choose on the monitor screen which kernel\system to run not using the UART console. 0 Quote
balbes150 Posted October 13, 2023 Author Posted October 13, 2023 Ver 20231012-edge with core 6.5 works HDMI LAN USB SATA\NVMe. add mesa panthor https://bbs.stationpc.com/forum.php?mod=redirect&goto=findpost&ptid=323&pid=1515&fromuid=636914 0 Quote
balbes150 Posted October 14, 2023 Author Posted October 14, 2023 I launched the system on Station M3 on a 4k monitor (desktop resolution 4096×2160), checked the full-screen playback of all formats via MPV that I use (including 4k), everything is played without brakes. The temperature is 35-50 degrees (the fan is running at minimum rpm). I use a simple USB sound card to output sound. Similarly, everything works smoothly and without brakes when using KODI and copes with all the found video decoding formats in SW mode without any problems (there is enough performance). 0 Quote
balbes150 Posted October 27, 2023 Author Posted October 27, 2023 Version 20231026-current (pancsf) Version 20231026-edge (panthor) Added support for HDMI audio. 0 Quote
balbes150 Posted November 23, 2023 Author Posted November 23, 2023 ver 20231123 edge kernel 6.7-rc2 0 Quote
Vlad Milas Posted May 3, 2025 Posted May 3, 2025 Hello Balbes. Awsome work you have done here for the Station M3. I have 2 questions. 1. Is it possible to use Multiboot like Firfely shows it here ? https://en.t-firefly.com/solution/82.html The only reference I found on this page https://wiki.stationpc.com/docs/stationpc/systemos 2. When I use any of your Builds it boots from SD-Card, but asks for a Login. Username and password. 0 Quote
balbes150 Posted June 2, 2025 Author Posted June 2, 2025 03.05.2025 в 15:31, Vlad Milas сказал: Is it possible to use Multiboot like Firfely shows it here ? I haven't tested these functions, I don't know if it works or not. 03.05.2025 в 15:31, Vlad Milas сказал: When I use any of your Builds it boots from SD-Card, but asks for a Login. Username and password. https://docs.armbian.com/User-Guide_Getting-Started/#first-login 0 Quote
Vener Khabibullin Posted June 19, 2025 Posted June 19, 2025 Good day, respected Balbes150. Please advise an Armbian build for the Roc-rk3588s-pc v1.1, with support for an M.2 NVMe SSD, intended to be used as a "smart home" server. The image will be installed on an SD card. The single-board computer is connected to the home router via Ethernet cable. HDMI is only used temporarily to connect to a TV for initial setup (further configuration will be done via SSH). The board will run Docker containers. Thank you so much in advance! 0 Quote
