Hi Igor,
first of all I want to thank you for your amazing work. It's quite a huge thing you have here.
I have the Problem, that I can't get the wifi module on my Banana pro working, both in wheezy and jessie with kernel 3.4 with the image from 21.5.. I added ap6210 to /etc/modules, but wifi chip doesn't power up.
Any idea what could cause the problem?
I Attached a log from my boot in case you'd like to take a look
Greetings
Jonas
boot-log_jessie.txt
I still can't get wifi up. Both with wheezy and jessie with kernel 3.4.
For exmple in wheezy (modprobe and adding an entry in /etc/modules has the same effect doesn't it? I tried both versions):
root@bananapi:~# modprobe bcmdhd
<4>pm: parse wifi_used failed
<6>bcmdhd: got gpio2, mapped to irqno-22
dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON
[wifi_pm]: No select wifi, please check your config !!
=========== WLAN placed in POWER ON ========
failed to power up wifi chip, retry again (4 left) **
dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON
=========== WLAN placed in POWER OFF ========
failed to power up wifi chip, retry again (3 left) **
failed to power up wifi chip, retry again (2 left) **
failed to power up wifi chip, retry again (1 left) **
failed to power up wifi chip, max retry reached, exits **
ERROR: could not insert 'bcmdhd': No such device
Also I'm not sure which image to use at all. For my project I need wifi in AP-mode and I2S. Which image would you recommend?
It looks like you are not using proper script.bin file?
Where is your /boot/script.bin pointing to? It must be to the bananapro.bin
script.bin -> /boot/bin/bananapipro.bin
Just get the latest 3.4.107 and you will be fine. Get Wheezy if you don't want to find new problems.
I did indeed use the wrong script.bin, I now linked to /boot/bin/bananapipro.bin and bcmdhd still doesn't work, but ap6210 does work. Thank you!
AP in bridge mode works with module ap6210, now I'm trying to let it work as dhcp-server via dnsmasq.
Hello Igor
with a Banana Pro using this:
uname -a
Linux bananapi 4.0.4-bananapi #6 SMP Thu May 21 21:58:45 CEST 2015 armv7l GNU/Linux
I can't have the internal Wi-Fi up, I try adding to /etc/modules ap6210, ap6181 and bcmdhd.
I try to use only wlan and disabled the eth part of the /etc/network/interfaces
The script.bin is linking to /boot/bin/bananapipro.bin
But always receive a message when I test:
modprobe ap6210
FATAL: Module ap6210 not found
Please, can you help me?
Yes. On kernel 4.x we have yet another driver :)
brcmfmac
and script.bin is not relevant any more. We have dtb (/boot/dtb/bananapi.dtb). You might need to rename / copy bananapipro.dtb to bananapi.dtb that everything will work.
I'm having a lot of problems to bring to life the internal Wi-Fi.
Finally i installed the minimal desktop enviroment and "wicd" and using this, finally I can do the Wi-Fi stay up and running.
I need to do more test: headless mode, fixed IP, ...
Thanks
