November 5, 20233 yr Author 6 hours ago, paradigman said: I finally managed to install the latest EMMC: V1.0 Just remember that my device is 4gb 32gb I don't test 8gb 64gb images until my device arrive from China The v0.8 version was build from 64gb @hzdm and v0.9 ported it to 32gb and 64gb Edited November 5, 20233 yr by hotnikq
November 7, 20232 yr Author Next Step to the H96 MAX v56: @thc013 what did you think about using Rockchip SoCs NPU? Drivers: https://github.com/rockchip-linux/rknpu2 User Guide: https://github.com/rockchip-linux/rknpu2/blob/master/doc/Rockchip_RKNPU_User_Guide_RKNN_API_V1.4.0_EN.pdf OpenCV: https://opencv.org/blog/2022/11/29/working-with-neural-processing-units-npus-using-opencv/ A discussion on Reddit: https://www.reddit.com/r/OrangePI/comments/12b3jmj/accessing_the_npu_on_the_orange_pi/ Transformers models: https://github.com/usefulsensors/useful-transformers Usage: https://www.crowdsupply.com/useful-sensors/ai-in-a-box/ Usage: https://youtu.be/pN8mKZ5wpdQ Edited November 11, 20232 yr by hotnikq
December 12, 20232 yr Great work! I could do Step 1 and 2 and I could create a new user and it seems everything is working well. Now after rebooting the system nothing happens. Screen is black, no boot messages. Well, I'm not an expert and therefore I need some help. For me it looks like that a bootloader is missing or something else.
December 12, 20232 yr Author 8 hours ago, BrunoMerz said: Now after rebooting the system nothing happens. Dear @BrunoMerz it happends because you don't follow the first boot fix, "step 3" Now you need to setup all again. do the Step 1 and 2 again... 8 hours ago, BrunoMerz said: I could do Step 1 and 2 and I could create a new user and it seems everything is working well. Step 3: Do the First boot fix: When you boot, set the admin password, and after that, go to terminal and do the Device FIX: ################################ 8GB devices Fix ############################## 8GB device First Boot Comand: fdisk /dev/mmcblk1 t 4 1 w # this GPT file was generated from a 4gb device. # in 8gb device you will need to trick the gpt after instalation # First boot comand: What you will see on prompt: fdisk Welcome to fdisk (util-linux 2.37.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. This disk is currently in use - repartitioning is probably a bad idea. It's recommended to umount all file systems, and swapoff all swap partitions on this disk. Command (m for help): t Partition number (1-4, default 4): 4 Partition type or alias (type L to list all): 1 Changed type of partition 'Linux filesystem' to 'EFI System'. Command (m for help): w The partition table has been altered. Syncing disks. Now you can safe reboot and use your armbian device. Edited December 12, 20232 yr by hotnikq
December 18, 20232 yr I bought H96 MAX V56 RK3566 4G and installed Linux with RKDevTool_Release_v2.86 as was described. Everything works like a charm Very cheap small Linux PC I use it for the transmission and Samba :) One small thing I need is Volumio. Is it possible to somehow install this https://community.volumio.com/t/volumio3-on-radxa-rock-3a-open-beta-test/61516 image with the same tool? I did not succeed with that.
December 26, 20232 yr Author On 12/18/2023 at 10:50 AM, Andriy said: I need is Volumio @Andriy is talking aboud a Volumio OS distro, Transform your Raspberry Pi, or PC with Volumio's innovative software. First things first, Here is Armbian Distro, We talk about Debian and Arm things, So, for better support i think you can take the Volumio Forum as Base to Build your image, https://community.volumio.com/t/sound-quality-running-volumio-3-on-different-hw-devices/61059 By the Armbian Side, Volumio is debian based, You can bring the Root image from Volumio distro and apply the BootLoader from @hzdm v0.8 method. Follow this Guide it's based on original guide Edited December 26, 20232 yr by hotnikq
December 31, 20232 yr Hello, I sucesfullly flashed image "Ubuntu_20.04.5_K4.19.219_RK3566_H96_MAX_8GB_No_Video_OUT_WIFI_OK_PARTITIONING" to my RK3566" device (model = H96 Max v56). I did an apgrade to Ubuntu 22.04. Only the kernel update won't work: root@localhost:~# apt --fix-broken install E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem. root@localhost:~# apt --fix-broken install E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem. root@localhost:~# dpkg --configure -a Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Processing triggers for flash-kernel (3.104ubuntu17) ... Unsupported platform 'Rockchip RK3566 EVB3 DDR3 V10 Board'. dpkg: error processing package flash-kernel (--configure): installed flash-kernel package post-installation script subprocess returned error exit status 1 Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.0-39-generic Warning: root device does not exist Unsupported platform 'Rockchip RK3566 EVB3 DDR3 V10 Board'. run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: flash-kernel initramfs-tools root@localhost:~# apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required: linux-headers-6.2.0-33-generic linux-headers-6.2.0-35-generic linux-hwe-6.2-headers-6.2.0-33 linux-hwe-6.2-headers-6.2.0-35 linux-image-6.2.0-33-generic linux-image-6.2.0-35-generic linux-modules-6.2.0-33-generic linux-modules-6.2.0-35-generic linux-modules-extra-6.2.0-33-generic linux-modules-extra-6.2.0-35-generic Use 'apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 2 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Setting up flash-kernel (3.104ubuntu17) ... flash-kernel: deferring update (trigger activated) Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.0-39-generic Warning: root device does not exist Rockchip RK3566 EVB3 DDR3 V10 BoardUnsupported platform 'Rockchip RK3566 EVB3 DDR3 V10 Board'. run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) W: Operation was interrupted before it could finish root@localhost:~# apt clean root@localhost:~# apt autoclean Reading package lists... Done Building dependency tree... Done Reading state information... Done root@localhost:~# ^C root@localhost:~# apt-mark hold /initrd.img-6.2.0-39-generic E: Unable to locate package I keep getting the error " device root not found". Can someone help me?
December 31, 20232 yr I did manage to upgrade the kernel to version 6 by copying the boot directory from this post: : After that I upgraded to version 6.2.0 using "apt upgrade" twice: The list of available updates is more than a week old. To check for new updates run: sudo apt update Last login: Sun Dec 31 14:15:25 2023 from 10.10.10.10 root@localhost:~# apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: linux-headers-6.2.0-33-generic linux-headers-6.2.0-35-generic linux-hwe-6.2-headers-6.2.0-33 linux-hwe-6.2-headers-6.2.0-35 linux-image-6.2.0-33-generic linux-image-6.2.0-35-generic linux-modules-6.2.0-33-generic linux-modules-6.2.0-35-generic linux-modules-extra-6.2.0-33-generic linux-modules-extra-6.2.0-35-generic Use 'apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Processing triggers for flash-kernel (3.104ubuntu17) ... dpkg-query: no packages found matching dpkg: error processing package flash-kernel (--configure): installed flash-kernel package post-installation script subprocess returned error exit status 1 Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_MdVH3i/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_MdVH3i/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_MdVH3i/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: flash-kernel initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) root@localhost:~# apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required: linux-headers-6.2.0-33-generic linux-headers-6.2.0-35-generic linux-hwe-6.2-headers-6.2.0-33 linux-hwe-6.2-headers-6.2.0-35 linux-image-6.2.0-33-generic linux-image-6.2.0-35-generic linux-modules-6.2.0-33-generic linux-modules-6.2.0-35-generic linux-modules-extra-6.2.0-33-generic linux-modules-extra-6.2.0-35-generic Use 'apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 2 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Setting up flash-kernel (3.104ubuntu17) ... flash-kernel: deferring update (trigger activated) Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_WTqKvI/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_WTqKvI/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_WTqKvI/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) root@localhost:~# dpkg --configure -a Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Processing triggers for flash-kernel (3.104ubuntu17) ... dpkg-query: no packages found matching dpkg: error processing package flash-kernel (--configure): installed flash-kernel package post-installation script subprocess returned error exit status 1 Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_YFa55a/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_YFa55a/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_YFa55a/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: flash-kernel initramfs-tools root@localhost:~# dpkg --configure -a Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Setting up flash-kernel (3.104ubuntu17) ... flash-kernel: deferring update (trigger activated) Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_jeuqZz/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_jeuqZz/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_jeuqZz/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools root@localhost:~# apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required: linux-headers-6.2.0-33-generic linux-headers-6.2.0-35-generic linux-hwe-6.2-headers-6.2.0-33 linux-hwe-6.2-headers-6.2.0-35 linux-image-6.2.0-33-generic linux-image-6.2.0-35-generic linux-modules-6.2.0-33-generic linux-modules-6.2.0-35-generic linux-modules-extra-6.2.0-33-generic linux-modules-extra-6.2.0-35-generic Use 'apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Processing triggers for flash-kernel (3.104ubuntu17) ... dpkg-query: no packages found matching dpkg: error processing package flash-kernel (--configure): installed flash-kernel package post-installation script subprocess returned error exit status 1 Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_q0BhM7/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_q0BhM7/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_q0BhM7/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: flash-kernel initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) root@localhost:~# apt autoremove Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: linux-headers-6.2.0-33-generic linux-headers-6.2.0-35-generic linux-hwe-6.2-headers-6.2.0-33 linux-hwe-6.2-headers-6.2.0-35 linux-image-6.2.0-33-generic linux-image-6.2.0-35-generic linux-modules-6.2.0-33-generic linux-modules-6.2.0-35-generic linux-modules-extra-6.2.0-33-generic linux-modules-extra-6.2.0-35-generic 0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded. 2 not fully installed or removed. After this operation, 1413 MB disk space will be freed. Do you want to continue? [Y/n] y] (Reading database ... 403395 files and directories currently installed.) Removing linux-headers-6.2.0-33-generic (6.2.0-33.33~22.04.1) ... Removing linux-headers-6.2.0-35-generic (6.2.0-35.35~22.04.1) ... Removing linux-hwe-6.2-headers-6.2.0-33 (6.2.0-33.33~22.04.1) ... Removing linux-hwe-6.2-headers-6.2.0-35 (6.2.0-35.35~22.04.1) ... Removing linux-image-6.2.0-33-generic (6.2.0-33.33~22.04.1) ... I: /boot/vmlinuz.old is now a symlink to vmlinuz-6.2.16-media I: /boot/initrd.img.old is now a symlink to initrd.img-6.2.16-media I: /boot/vmlinuz is now a symlink to vmlinuz-6.2.16-media I: /boot/initrd.img is now a symlink to initrd.img-6.2.16-media /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-6.2.0-33-generic /etc/kernel/postrm.d/zz-flash-kernel: flash-kernel: Kernel 6.2.0-33-generic has been removed. flash-kernel: A higher version (6.2.16-media) is still installed, no reflashing required. Removing linux-image-6.2.0-35-generic (6.2.0-35.35~22.04.1) ... /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-6.2.0-35-generic /etc/kernel/postrm.d/zz-flash-kernel: flash-kernel: Kernel 6.2.0-35-generic has been removed. flash-kernel: A higher version (6.2.16-media) is still installed, no reflashing required. Removing linux-modules-extra-6.2.0-33-generic (6.2.0-33.33~22.04.1) ... Removing linux-modules-6.2.0-33-generic (6.2.0-33.33~22.04.1) ... Removing linux-modules-extra-6.2.0-35-generic (6.2.0-35.35~22.04.1) ... Removing linux-modules-6.2.0-35-generic (6.2.0-35.35~22.04.1) ... Setting up initramfs-tools (0.140ubuntu13.4) ... update-initramfs: deferring update (trigger activated) Setting up flash-kernel (3.104ubuntu17) ... flash-kernel: deferring update (trigger activated) Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.2.16-media W: missing /lib/modules/6.2.16-media W: Ensure all necessary drivers are built into the linux image! depmod: ERROR: could not open directory /lib/modules/6.2.16-media: No such file or directory depmod: FATAL: could not search modules: No such file or directory cat: /var/tmp/mkinitramfs_XylMnf/lib/modules/6.2.16-media/modules.builtin: No such file or directory W: Can't find modules.builtin.modinfo (for locating built-in drivers' firmware, supported in Linux >=5.2) Warning: root device does not exist depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_XylMnf/lib/modules/6.2.16-media: No such file or directory depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_XylMnf/lib/modules/6.2.16-media: No such file or directory dpkg-query: no packages found matching run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) root@localhost:~# apt install ^C root@localhost:~# ^C root@localhost:~# apt install initramfs-tools Reading package lists... Done Building dependency tree... Done Reading state information... Done initramfs-tools is already the newest version (0.140ubuntu13.4). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] n Abort. root@localhost:~# apt atoremove E: Invalid operation atoremove root@localhost:~# apt clean root@localhost:~# apt autoclean Reading package lists... Done Building dependency tree... Done Reading state information... Done root@localhost:~# So the issue is fixed
January 3, 20242 yr Author On 12/31/2023 at 2:35 PM, wootje said: Only the kernel update won't work: the image was build from trunk, by default it doesn´t update. On 12/31/2023 at 4:01 PM, wootje said: So the issue is fixed You can use it to upgrade images build from trunk
January 12, 20242 yr Installed on 8GB/64GB, and it runs well, although I know that for Cinnamon it wouldn't be ideal because it lacks hardware acceleration. However, it's suitable for use as a server.
January 12, 20242 yr Hello, I am very struggling of starting Bluetooth (WiFi works). My chip is marked as HCY6335, but i am unable to start it. Where do i need to begin with? Using unmodified hotnikq's image
January 15, 20242 yr Author On 1/12/2024 at 3:14 AM, Antonio Cahuana said: I know that for Cinnamon it wouldn't be ideal because it lacks hardware acceleration You can try to apply things from Manjaro Arc Linux. the build something with hardware acceleration for RK3566 and I test it on Rock3A device. To build graphic responsive distro: Follow the path: Rk3566 ----> ARK -----> Manjaro ----> Wayland ------> Chromium
January 15, 20242 yr Author On 1/12/2024 at 10:05 AM, Martynas Skapas said: Where do i need to begin with? I don't put bluetooth drivers there you need to figure out and bring this to our forum here your patch to follow: https://github.com/gouwa/hwpacks/blob/master/wifibt/bluetooth-ap6335.conf https://datasheetspdf.com/datasheet/AP6335.html https://download.kamami.pl/p562297-AP6335 datasheet_V1.3_02102014.pdf @Martynas SkapasBring that to us!
January 15, 20242 yr @Martynas Skapas : I have already played through this problem with another rockchip box. The problem there was that the manufacturer unexpectedly replaced the 6334 chip with the 2734C. Here is my post about it from the past: https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/?do=findComment&comment=143890
January 16, 20242 yr @hotnikq Quote Rk3566 ----> ARK -----> Manjaro ----> Wayland ------> Chromium Can you explain this? Is it mainline? Is the repository package or compiled or something else? I cannot get video acceleration in youtube. I have tried with gstreamer web browsers, ffmpeg with v4l2-request and firefox, but nothing. It works very well in video player and web video acceleration it's just the last item to get a decent desktop computer.
January 17, 20242 yr Author On 1/16/2024 at 12:38 PM, maka said: It works very well in video player and web video acceleration it's just the last item to get a decent desktop computer. ok, share with us how did you archive this acceleration. How I kwnew it: https://forum.armbian.com/topic/22476-video-playback/?do=findComment&comment=154884 https://forum.armbian.com/topic/22476-video-playback/?do=findComment&comment=154951 https://forum.armbian.com/topic/22476-video-playback/?do=findComment&comment=154967 @maka bring it to your chromium! https://forum.armbian.com/topic/22476-video-playback/?do=findComment&comment=155372 Edited January 17, 20242 yr by hotnikq
January 17, 20242 yr I have got video player acceleration with flathub clapper for 1080p with 20% CPU. Enough for me. Based on hantro driver so no 4k. There's also a @jock tutorial for debían to enable ffmpeg v4l2-request that is equivalent. I have understood that must enable webrtc-pipewire in chromium, isnt It? Edited January 17, 20242 yr by maka
January 21, 20242 yr Author On 1/17/2024 at 5:22 PM, maka said: I have understood that must enable webrtc-pipewire in chromium, isnt It? did you archive it? Quote Enabled: WebRTC PipeWire support When enabled the WebRTC will use the PipeWire multimedia server for capturing the desktop content on the Wayland display server. – Linux #enable-webrtc-pipewire-capturer On 1/17/2024 at 6:09 PM, maka said: No way. I get 100% with 1080p. if your wayland dispay acceleration works, you will need a patched chromium with WebRTC enabled
February 6, 20242 yr Could someone make an update image that already has Wayland pre-installed, with working acceleration?
February 10, 20242 yr Author On 2/6/2024 at 7:04 AM, paradigman said: Wayland pre-installed, with working acceleration? This is the 4gb topic! did you have a ubuntu 22.04 x86-64 computer? You can build it by your self: 1. Copy the h96-max-v56 directory to build/packages/blobs/ directory 2. Copy the h96-max-v56.conf file to the build/config/boards/ directory 3. Run the image build https://docs.armbian.com/Developer-Guide_Build-Preparation/ https://drive.google.com/file/d/1oYK4EhbfcThfBs3F1Ri582jf6PYYp5x2/view?usp=drive_link https://drive.google.com/file/d/1G5KBVq1oR-QrIKG3FoHmUTwh8OSAG018/view https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/?do=findComment&comment=175357 You can also try the Gnome Wayland Armbian 23.11.0 Desktop Gnome V1.0 The Latest unofficial Debian 12 BookWorm Desktop Gnome v1.0 The Latest unofficial Edited April 17, 20242 yr by Hqnicolas
April 3, 20242 yr I installed it and when it experienced a sudden shutdown, the boot got damaged and didn't start, so I reinstalled the boot to boot up, something that doesn't happen with other rk using the Multitool which helps a lot
April 3, 20242 yr Author On 1/12/2024 at 3:14 AM, Antonio Cahuana said: Installed on 8GB/64GB, and it runs well, although I know that for Cinnamon it wouldn't be ideal because it lacks hardware acceleration. However, it's suitable for use as a server. This Chinese box It's always a surprise. sometimes it works, sometimes it doesn't Kernel V6.6 was the new standart if you build any image let me know @Antonio Cahuana About the hardware acceleration, i think you can install Video drivers: https://developer.arm.com/downloads/-/mali-drivers/bifrost-kernel https://docs.mesa3d.org/download.html https://docs.mesa3d.org/drivers/panfrost.html Edited April 4, 20242 yr by Hqnicolas
April 4, 20242 yr Author 🏆 Become a sponsor, help to add other boards in armbian standart, you don't need to be a programmer to help the community, just need a copy of the ARM BOARD and a x86 computer to compile new versions. ########################### EMMC: V1.1 HZDM Release Version ########################### If you like what you see here and want to help: Donate Armbian the like button only costs a few dollars. Armbian Needs you help! # Tested on 4gb 32gb version (04/04/2024) If you given up of Armbian Linux on your H96MAX RK3566 TV box Think Again and again and again and again, because: @hzdm updated armbian Build configuration: V1.1 HZDM original Build Armbian Tutorial: #START# On Linux: 1 - Follow the Build Armbian instructions if it doesnt Build your image as espected rm -rf build git clone --depth 1 --branch v24.02 https://github.com/armbian/build try again and again and again and again 2 - Download H96MAX Armbian Build Config (Original Source) 3 - Copy the h96-max-v56 directory to build/packages/blobs/ directory 4 - Copy the h96-max-v56.conf file to the build/config/boards/ directory 5 - Run the image build ./compile.sh On Windows: 6 - Download the Armbian.cfg file to RKDevTool (Original Source) 7 - Drop it on RKDevTool 8 - Shutting down H96 MAX. 9 - Press the Reset button. 10 - Turn on the H96 MAX. 11 - Wait until The message "Found One MASKROM Device" or "Found One LOADER Device" should appear. (1) 12 - Mark all 2 sections with check marks (2) 13 - Open 2 files for each section (3) 14 - Check "Write by Address" (4). 15 - Press the "Run" button (5). The download will start. When the message "Download image OK" appears, the download is finished (6). 16 - H96 MAX will automatically reboot. Done. Alternative: On Linux OS rkdeveloptool db MiniLoaderAll.bin # If this is not your first time flashing with this firmware, an error may appear here\. It\'s not a big deal rkdeveloptool wl 0x0 Your_Armbian_Image-trunk_H96-max-v56_jammy_current_6.1.62.img rkdeveloptool rd And because a malware was discovered in the XZ library from Edge trixie and Edge sid I came here again to remove and ReBuild all afected images. Ubuntu: One of the most popular Linux distributions is not affected as its xz version is the older 5.4 version. No updates are required. Debian Linux: No stable versions of the distribution were affected. but compromised packages were part of test, unstable and experimental versions. Users must update xz-utils. Read more: CVE-2024-3094 Video drivers: https://developer.arm.com/downloads/-/mali-drivers/bifrost-kernel https://docs.mesa3d.org/download.html https://docs.mesa3d.org/drivers/panfrost.html Edited June 1, 20242 yr by Hqnicolas
April 14, 20242 yr Author @Antonio Cahuana On 4/2/2024 at 11:56 PM, Hqnicolas said: Kernel V6.6 was the new standart if you build any image let me know Don't need anymore, @ning Build the JianPian Tv-Box and I use it to Bring the board UP on Kernel 6.6 Edited April 19, 20242 yr by Hqnicolas
April 21, 20242 yr Author ################################### ################################### Official armbian Images since 24.5.0-trunk.433 https://github.com/armbian/community/releases/ Wifi Driver: https://drive.google.com/file/d/1jU0VRhe-ou8lZ-D1COvwuqGvMBIht-Dw/view?usp=sharing Take some files from CoreElec https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/tree/master/firmware/brcm cd /lib/firmware/brcm/ sudo wget https://github.com/LibreELEC/brcmfmac_sdio-firmware/raw/master/BCM4335A0.hcd sudo wget https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/raw/master/firmware/brcm/fw_bcm4335b0_ag.bin sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.h96-TVbox,rk3566.bin sudo reboot now nmcli dev wifi Quote sudo cat > /lib/firmware/brcm/brcmfmac4335-sdio.txt << "EOF" # bcm94335wlcspMS_ES50_RC171p24p23_04052013_AM_mdfy_PAparam.txt -- 4/5/2013 by Murata, based on bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt, changed PA parameters and txidxcap parameters and ccode. # bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt -- 4/2/2013 by Broadcom Corporation # Use with AARDVARK_REL_6_30_171_24_23 -- Murata BCM4335 WLCSP 11AC Module # Sample variables file for Murata Type-XJ ES5.0 (0x00 0x11) -- bcm94335wlcspMS_AM_P400.txt as original sromrev=11 boardrev=0x1500 boardtype=0x064b boardflags=0x10401001 boardflags2=0x0 #updated boardflags3 for forcing to enable external LPO boardflags3=0x0800c08b macaddr=00:90:4c:c5:12:38 #ccode modified by Murata #ccode=0 ccode=XS regrev=0 antswitch=0 pdgain5g=1 pdgain2g=1 tworangetssi2g=0 tworangetssi5g=0 femctrl=4 vendid=0x14e4 devid=0x43ae manfid=0x2d0 #prodid=0x052e nocrc=1 #otpimagesize=502 xtalfreq=37400 extpagain2g=1 extpagain5g=1 rxgains2gelnagaina0=2 rxgains2gtrisoa0=6 rxgains2gtrelnabypa0=1 rxgains5gelnagaina0=3 rxgains5gtrisoa0=5 rxgains5gtrelnabypa0=1 rxchain=1 txchain=1 aa2g=1 aa5g=1 ag0=0 ag1=0 tssipos5g=1 tssipos2g=1 #PA parameters (2G20M/2G40M/5G20M/5G40M/5G80M) #PA parameters modified by Murata #pa2ga0=-208,6208,-764 #pa2ga1=-203,6429,-793 #pa5ga0=-167,5736,-685,-157,5669,-670,-157,5548,-665,-141,5621,-664 #pa5ga1=-101,6543,-735,-99,6452,-731,-147,5743,-695,-75,6468,-723 #pa5ga2=-172,5903,-708,-160,5868,-698,-113,6264,-722,-125,5915,-684 pa2ga0=0xff31,0x1759,0xFD1D pa2ga1=0xff35,0x18BB,0xFCEC pa5ga0=0xff78,0x1715,0xFD49,0xff89,0x1714,0xFD57,0xff86,0x1652,0xFD62,0xffa9,0x1760,0xFD5E pa5ga1=0xff56,0x1596,0xFD5F,0xff88,0x1764,0xFD45,0xff89,0x1632,0xFD65,0xff69,0x160E,0xFD49 pa5ga2=0xff5a,0x1667,0xFD4E,0xff5f,0x15F7,0xFD5E,0xff5a,0x1531,0xFD68,0xff6e,0x1587,0xFD6A # Default Target Power for 2G -- 17dBm(11)/14dBm(54)/13dBm(MCS7,MCS8)/16dBm(6,MCS0) maxp2ga0=74 cckbw202gpo=0 cckbw20ul2gpo=0 dot11agofdmhrbw202gpo=0x6666 ofdmlrbw202gpo=0x0022 mcsbw202gpo=0x88866662 # Default Target Power for 5G -- 14dBm(54)/13dBm(HT20-MCS7,VHT20-MCS8)/12dBm(HT40-MCS7,VHT40-MCS9)/11dBm(VHT80-MCS8/MCS9)/16dBm(6,20HT-MCS0) maxp5ga0=74,74,74,74 # Low mcslr5glpo=0 mcsbw205glpo=0x88866662 mcsbw405glpo=0xAAA88884 mcsbw805glpo=0xCCCAAAA6 # Mid mcslr5gmpo=0 mcsbw205gmpo=0x88866662 mcsbw405gmpo=0xAAA88884 mcsbw805gmpo=0xCCCAAAA6 # High mcslr5ghpo=0 mcsbw205ghpo=0x88866662 mcsbw405ghpo=0xAAA88884 mcsbw805ghpo=0xCCCAAAA6 #20MHz High Rate sb20in40hrpo=0x0 sb20in80and160hr5glpo=0x0 sb20in80and160hr5gmpo=0x0 sb20in80and160hr5ghpo=0x0 #40MHz High Rate sb40and80hr5glpo=0x0 sb40and80hr5gmpo=0x0 sb40and80hr5ghpo=0x0 #20MHz Low Rate sb20in40lrpo=0x0 sb20in80and160lr5glpo=0x0 sb20in80and160lr5gmpo=0x0 sb20in80and160lr5ghpo=0x0 #40MHz Low Rate sb40and80lr5glpo=0x0 sb40and80lr5gmpo=0x0 sb40and80lr5ghpo=0x0 dot11agduphrpo=0x0 dot11agduplrpo=0x0 tssifloor2g=80 tssifloor5g=160,190,240,260 #rpcal:use with 171.17 or later, compensates filter ripple rpcal2g=0x0 rpcal5gb0=0x0 #cckdigfilttype[0-7] 0:default cckdigfilttype=2 phycal_tempdelta=25 #GPIO 0 for SDIO HW OOB interruption muxenab=0x10 #sd_gpout=0 #sd_oobonly=1 rssicorrnorm_c0=-3,-2 rssicorrnorm5g_c0=-1,0,-3,-1,0,-3,-3,-2,-4,-3,-2,-4 #txidxcap2g and txidxcap5g modified by Murata #txidxcap2g=32 #txidxcap5g=44 txidxcap2g=36 txidxcap5g=36 paparambwver=1 EOF sudo rmmod brcmfmac_wcc brcmfmac brcmutil modprobe brcmfmac How to flash: Same as V1.1 ################################### ################################### Edited May 2, 20242 yr by Hqnicolas
