verb Posted January 27, 2018 Posted January 27, 2018 Hello everyone I have two amlogic boxes one is with s805 and another with s905 processor and neither of them has mmc slot . In this forum balbes150 has helped me with the boot script from uart . Now i try to boot from usb flash drive on s905 with following commands : usb start fatload usb 0 1020000 aml_autoscript autoscr 1020000 but the boot process stucked on this - > Link Appreciate any help.
balbes150 Posted January 27, 2018 Author Posted January 27, 2018 On 1/27/2018 at 10:27 AM, verb said: but the boot process stucked on this - > Link Appreciate any help. Expand The startup script works correctly and the kernel starts, but no data correct dtb to the kernel. The reason is not the correct dtb file. Pick the right option dtb file.
verb Posted January 27, 2018 Posted January 27, 2018 On 1/27/2018 at 11:32 AM, balbes150 said: The startup script works correctly and the kernel starts, but no data correct dtb to the kernel. The reason is not the correct dtb file. Pick the right option dtb file. Expand I think the right dtb for my box is -> gxbb_p201.dtb (gxb_p201_v1# ) so i set this one as dtb.img and booted unfortunately i got kernel panic . Output is here . I have tried several other dtb files and neither of them works . Also i am not sure if the box has any hw problems because it doesn;t boot Android when left without USB flash drive.
balbes150 Posted January 28, 2018 Author Posted January 28, 2018 On 1/27/2018 at 12:57 PM, verb said: I think the right dtb for my box is -> gxbb_p201.dtb (gxb_p201_v1# ) so i set this one as dtb.img and booted unfortunately i got kernel panic . Output is here . I have tried several other dtb files and neither of them works . Also i am not sure if the box has any hw problems because it doesn;t boot Android when left without USB flash drive. Expand I understand that this TV box may not start with any systems, including those with Android ?
verb Posted January 28, 2018 Posted January 28, 2018 On 1/28/2018 at 8:31 AM, balbes150 said: I understand that this TV box may not start with any systems, including those with Android ? Expand Hello balbes150 the box doesn't boot Android don;t know if it's some hw or sw problem ( i got some exceptions and the kernel crashes during boot) . I have it from friend of mine so no idea what's wrong with it. I hope it is software problem and that's why i tried to boot armbian. My question is do you find something wrong in the steps i try to boot: 1.Burned the ubuntu server image and copy gxbb_p201.dtb as dtb.img ( booting from uart show this as hostname -> gxb_p201_v1#) 2.after that from uart i tried with this commands -> usb start fatload usb 0 1020000 aml_autoscript autoscr 1020000 i am not sure for this options but i have seen them from aml_autoscript 3.the output is here -> LINK ( these are the last lines after enter the commands from uart) .Do you recognize them as output from armbian or the box try to boot Android ???
balbes150 Posted January 28, 2018 Author Posted January 28, 2018 Try to record on USB image LE. Add correct dtb (to try all that apply). Connect USB media to TV box and check how the system's going to start. To activate the multi-boot is NOT necessary (it is already activated). To execute the commands in the UART is NOT needed (everything has to start automatically). By the way, it is possible that your friend recorded in a TV box is not the correct u-boot and it's not gxbb_p201. Need to try other options gxbb*.
fatugazuhati Posted January 28, 2018 Posted January 28, 2018 Until some days ago I had installed armbian server based on jessie and everything was working apart the bluetooth. I decided to try the new armbian server based on stretch and I'm not more able to have the wifi working. I'm using the same dtb that I was using with jessie and I also loaded the module dhd that I used in jessie. What can I do? Some advice?
balbes150 Posted January 29, 2018 Author Posted January 29, 2018 On 1/28/2018 at 4:18 PM, fatugazuhati said: Until some days ago I had installed armbian server based on jessie and everything was working apart the bluetooth. I decided to try the new armbian server based on stretch and I'm not more able to have the wifi working. I'm using the same dtb that I was using with jessie and I also loaded the module dhd that I used in jessie. What can I do? Some advice? Expand Try to replace the directory /lib/firmware (copy it from the old version to the new one).
manuti Posted January 29, 2018 Posted January 29, 2018 Hi @balbes150 I finally manage to open my MXQ Pro Plus and the Wi-Fi chips is marked as HS2734A V15628 98MA Any chance of having this Wi-Fi working with your images? Thanks in advance
manuti Posted January 29, 2018 Posted January 29, 2018 Also I need to do something with the stock heat sink, because the SoC is the same than the ODROID-C2. This heat sink is far away the size and for sure the performance.
balbes150 Posted January 30, 2018 Author Posted January 30, 2018 Strange WiFi chip. I haven't found information about it freely available. For cooling fans. Then should be enough for this radiator.
fatugazuhati Posted January 30, 2018 Posted January 30, 2018 On 1/29/2018 at 6:14 AM, balbes150 said: Try to replace the directory /lib/firmware (copy it from the old version to the new one). Expand Well, now everything works. With the firmware directory from jessie the wifi works and I have this : root@amlogic:# dmesg | grep firmware [ 77.673467] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/brcm/config.txt [ 78.559879] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 78.559884] dhd_conf_set_nv_name_by_chip: nvram_path=/lib/firmware/brcm/nvram_ap6330.txt [ 78.559888] dhdsdio_download_firmware: set use_rxchain 0 [ 78.559891] dhdsdio_download_firmware: set txglomsize 16 [ 78.559899] Final fw_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 78.559902] Final nv_path=/lib/firmware/brcm/nvram_ap6330.txt [ 78.559905] Final conf_path=/lib/firmware/brcm/config.txt With the firmware directory from stretch the wifi doesn't work and I have this : root@amlogic:~# dmesg | grep firmware [ 53.980967] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/brcm/config.txt [ 54.869114] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 54.869119] dhdsdio_download_firmware: set use_rxchain 0 [ 54.869122] dhdsdio_download_firmware: set txglomsize 16 [ 54.869129] Final fw_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 54.869132] Final nv_path=/lib/firmware/brcm/ [ 54.869135] Final conf_path=/lib/firmware/brcm/config.txt [ 54.898305] _dhdsdio_download_firmware: dongle nvram file download failed What could be the problem? How can I correctly solve it? Postedit: I solved the problem correctly editing the config.txt
manuti Posted January 30, 2018 Posted January 30, 2018 On 1/30/2018 at 9:01 AM, balbes150 said: Strange WiFi chip Expand I only can find a couple of mentions, here in English: http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x/639329-m96x-max-4k-hdr-vp9-tv-box-android-6-0-amlogic-s905x-2g-16g-802-11b-g-n-lan-kodi-bluetooth/page4 and here in Russian: http://4pda.ru/forum/lofiversion/index.php?t764777-7200.html And if you say "Strange" for me thats mean no-wifi on armbian Thanks!!!
fatugazuhati Posted January 30, 2018 Posted January 30, 2018 On 1/16/2018 at 9:37 AM, balbes150 said: While it is not. Soon will release a new image with the updated kernel. Perhaps it will be possible to add BT. Expand At the moment I have enough free time and if you want I can help to test\debug the bluetooth but you should tell me what to do because I haven't any idea. I have an s95 telos and an s95 meta and at the moment I'm using the s95 meta that has an ampak ap6330.
balbes150 Posted January 31, 2018 Author Posted January 31, 2018 On 1/30/2018 at 11:51 PM, fatugazuhati said: At the moment I have enough free time and if you want I can help to test\debug the bluetooth but you should tell me what to do because I haven't any idea. I have an s95 telos and an s95 meta and at the moment I'm using the s95 meta that has an ampak ap6330. Expand On the Internet there are instructions on how to configure BT. You can try different options to find the cause. May need to try different dtb.
fatugazuhati Posted January 31, 2018 Posted January 31, 2018 On 1/31/2018 at 7:53 AM, balbes150 said: On the Internet there are instructions on how to configure BT. You can try different options to find the cause. May need to try different dtb. Expand I'm trying but without success. I'm not able to understand if the problem is a wrong dtb, a wrong module or a wrong software configuration. These are my steps to install the bluetooth: apt-get install bluetooth blueman bluez bluez-tools rfkill libbluetooth-dev modprobe hci_uart I check that the module is correctly loaded: lsmod | grep hci_uart hci_uart 21653 0 bluetooth 242323 1 hci_uart I check that the firmware is correctly loaded: dmesg | grep firmware [ 15.261423] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/brcm/config.txt [ 18.800655] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 18.800660] dhd_conf_set_nv_name_by_chip: nvram_path=/lib/firmware/brcm/nvram_ap6330.txt [ 18.800665] dhdsdio_download_firmware: set use_rxchain 0 [ 18.800668] dhdsdio_download_firmware: set txglomsize 16 [ 18.800675] Final fw_path=/lib/firmware/brcm/fw_bcm40183b2.bin [ 18.800678] Final nv_path=/lib/firmware/brcm/nvram_ap6330.txt [ 18.800681] Final conf_path=/lib/firmware/brcm/config.txt I check the bluetooth status and I start it: systemctl status bluetooth ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset Active: inactive (dead) Docs: man:bluetoothd(8) systemctl start bluetooth systemctl status bluetooth ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset Active: active (running) since Wed 2018-01-31 10:11:40 UTC; 1s ago Docs: man:bluetoothd(8) Main PID: 8845 (bluetoothd) Status: "Running" CGroup: /system.slice/bluetooth.service └─8845 /usr/lib/bluetooth/bluetoothd Jan 31 10:11:40 amlogic systemd[1]: Starting Bluetooth service... Jan 31 10:11:40 amlogic bluetoothd[8845]: Bluetooth daemon 5.43 Jan 31 10:11:40 amlogic bluetoothd[8845]: Starting SDP server Jan 31 10:11:40 amlogic systemd[1]: Started Bluetooth service. Jan 31 10:11:40 amlogic bluetoothd[8845]: Bluetooth management interface 1.4 ini I attach the HCI adapter: sudo hciattach /dev/ttyS1 any I re-check the bluetooth status: service bluetooth status ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Wed 2018-01-31 14:58:49 UTC; 7min ago Docs: man:bluetoothd(8) Main PID: 4459 (bluetoothd) Status: "Running" CGroup: /system.slice/bluetooth.service └─4459 /usr/lib/bluetooth/bluetoothd Jan 31 14:58:49 amlogic systemd[1]: Starting Bluetooth service... Jan 31 14:58:49 amlogic bluetoothd[4459]: Bluetooth daemon 5.43 Jan 31 14:58:49 amlogic systemd[1]: Started Bluetooth service. Jan 31 14:58:49 amlogic bluetoothd[4459]: Starting SDP server Jan 31 14:58:49 amlogic bluetoothd[4459]: Bluetooth management interface 1.4 initialized Jan 31 15:06:15 amlogic bluetoothd[4459]: Failed to obtain handles for "Service Changed" characteristic Jan 31 15:06:15 amlogic bluetoothd[4459]: Sap driver initialization failed. Jan 31 15:06:15 amlogic bluetoothd[4459]: sap-server: Operation not permitted (1) Jan 31 15:06:16 amlogic bluetoothd[4459]: hci0 Load Connection Parameters failed: Unknown Command (0x01) and I have 4 erros. The bluetooth seems active: hcitool dev Devices: hci0 8F:CD:8A:1D:F9:D5 rfkill list 0: bt-dev: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no 2: brcmfmac-wifi: Wireless LAN Soft blocked: no Hard blocked: no 3: hci0: Bluetooth Soft blocked: no Hard blocked: no but I'm not able to see any device or to bee saw from any device: bluetoothctl [NEW] Controller 8F:CD:8A:1D:F9:D5 amlogic [default] [bluetooth]# power on Changing power on succeeded [bluetooth]# discoverable on Changing discoverable on succeeded [CHG] Controller 8F:CD:8A:1D:F9:D5 Discoverable: yes [bluetooth]# pairable on Changing pairable on succeeded [bluetooth]# scan on Discovery started [CHG] Controller 8F:CD:8A:1D:F9:D5 Discovering: yes [bluetooth]# exit [DEL] Controller 8F:CD:8A:1D:F9:D5 amlogic [default] Any advice? Postedit: I was been able to solve the problem with the bluetooth with patchram, now everythings work on my minibox linux :-) Do you think will be possible install kodi on debian server and have the hardware acceleration working?
balbes150 Posted February 1, 2018 Author Posted February 1, 2018 On 1/31/2018 at 3:15 PM, fatugazuhati said: Do you think will be possible install kodi on debian server and have the hardware acceleration working? Expand This issue has already been discussed, it is possible but would require a large amount of manual operations (installing all the required packages, configure them, etc.).
manuti Posted February 1, 2018 Posted February 1, 2018 On 1/29/2018 at 11:46 AM, manuti said: Hi @balbes150 I finally manage to open my MXQ Pro Plus and the Wi-Fi chips is marked as HS2734A V15628 98MA Any chance of having this Wi-Fi working with your images? Thanks in advance Expand OK no support for HS2734A on my supposed MXQ Pro Plus but, what about SV6051P TAB1723 BMT84 on my supposed MXQ Pro? Thanks again @balbes150
fatugazuhati Posted February 2, 2018 Posted February 2, 2018 Hi @balbes150, a new little problem, on stretch the remote commands doesn't work, I used the same remote.conf that I used in Jessie. I retried in Jessie and everything works. I'm trying to solve this problem, any advice? This time I really don't have any idea on what to check, everything seems ok but amremote doesn't work. I'have correctly installed aml-amremote-905_5.34_arm64, I have placed in /etc/amremote the same remote.conf that I have correctly used in jessie, I have started the service amlogic-remotecfg and it runs without problems but the remote controller doesn't work. Every time that I press a remote controller's button in the syslog I have something similar to this: Feb 2 23:21:40 localhost kernel: [ 682.978463@0] remote: Wrong custom code is 0xe718ff00 Feb 2 23:21:41 localhost kernel: [ 683.887669@0] remote: Wrong custom code is 0xb946ff00 Feb 2 23:21:42 localhost kernel: [ 684.608617@0] remote: Wrong custom code is 0xf906ff00 Feb 2 23:21:42 localhost kernel: [ 685.296251@0] remote: Wrong custom code is 0xbd42ff00 Feb 2 23:21:43 localhost kernel: [ 686.308314@0] remote: Wrong custom code is 0xfb04ff00 Feb 2 23:21:44 localhost kernel: [ 687.122292@0] remote: Wrong custom code is 0xf906ff00 Feb 2 23:21:45 localhost kernel: [ 687.820066@0] remote: Wrong custom code is 0xaa55ff00 but the factory code in /etc/amremote/remote.conf is already set to factory_code= 0xff000001. I have already tried replacing /lib/firmware with the one from jessie where everythings works. What can I do? Could this be a kernel's problem?
balbes150 Posted February 3, 2018 Author Posted February 3, 2018 A little surprise to Chinese New Year holiday. Image update 20180203. 3
fatugazuhati Posted February 4, 2018 Posted February 4, 2018 Hi @balbes150, thanks a lot for your work. I have just tried Armbian_5.37_S9xxx_Debian_stretch_4.9.40_server_20180202.img on an s95 meta but I have a black screen and it doesn't boot, I tried using the file gxm_q200_2g.dtb obviously rename as dtb.img, what dtb should I use with my box? About Armbian_5.37_S9xxx_Debian_stretch_3.14.29_server_20180203.img, it works fabulously but I have always to edit the config.txt to make working the wifi and I have to use patchram to make working the bluetooth and I have no way to make working the ir remote, I have the same problems as I described in my previous post. Could you help me in debugging the problem with amremote, I tried everythings and I have no more idea.
balbes150 Posted February 4, 2018 Author Posted February 4, 2018 Image update 20180204 kernel 3.14.29 and 4.9.40. Added version of the images with mali-6 (Ubuntu Mate and Debian XFCE). In these images uses a new library libMali r6p3. These images are in the directory mali-6 on the website. In the directory mali-5 are all old images 20180203 (server and desktop variants). Added to the website version of the images with the kernel 4.9.40 a working version of KODI. Pay attention to the images 20180204 c kernel 4.9.40 Mate and XFCE desktops contain a version of KODI 17.3, which can work on models with S905X. Important. The image with the kernel 4.9.40 to run KODI, you need to log on desktop (which would have been on MATE or XFCE) and from it (via the menu) to launch KODI. Only in this mode will work the sound in KODI. When you exit KODI the screen will remain blank (black), for the appearance of the desktop you need to switch to another console with CTRL+ALT+F1 and go back to your desktop CTRL+ALT+F7. 1
balbes150 Posted February 4, 2018 Author Posted February 4, 2018 On 2/4/2018 at 12:50 PM, fatugazuhati said: thanks a lot for your work. I have just tried Armbian_5.37_S9xxx_Debian_stretch_4.9.40_server_20180202.img on an s95 meta but I have a black screen and it doesn't boot, I tried using the file gxm_q200_2g.dtb obviously rename as dtb.img, what dtb should I use with my box? About Armbian_5.37_S9xxx_Debian_stretch_3.14.29_server_20180203.img, it works fabulously but I have always to edit the config.txt to make working the wifi and I have to use patchram to make working the bluetooth and I have no way to make working the ir remote, I have the same problems as I described in my previous post. Could you help me in debugging the problem with amremote, I tried everythings and I have no more idea. Expand In images with kernel 4.9.40 is no support for s905. These images can only run on s905X and S912 (s912 KODI does not work). To work remote need to verify the composition of packages and kernel configuration (I hope to test it next week). 1
fatugazuhati Posted February 4, 2018 Posted February 4, 2018 On 2/4/2018 at 2:57 PM, balbes150 said: In images with kernel 4.9.40 is no support for s905. These images can only run on s905X and S912 (s912 KODI does not work). To work remote need to verify the composition of packages and kernel configuration (I hope to test it next week). Expand Do you thing that the problem with the remote in Stretch is kernel related? Is there something that can I do? In Jessie the remote works. Can I try to boot stretch with the kernel from Jessie? If I can what files and directories should I replace?
talraash Posted February 4, 2018 Posted February 4, 2018 Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20180203.img - don't work hw decoding h264(media info say SW and huge cpu usage), on the same file previous stretch icewm release and kodi from deb folder, hw decoding work... Re check, 20180204 image same, but image 20171227 work normal...
fdopen Posted February 4, 2018 Posted February 4, 2018 On 2/4/2018 at 3:51 PM, talraash said: Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20180203.img - don't work hw decoding h264 Expand Yes, I've just noticed it, too. The kernel was compiled without CONFIG_V4L_AMLOGIC_VIDEO. So no /dev/video10 and no hardware acceleration. CONFIG_AMLOGIC_IONVIDEO is also not set. 2
fatugazuhati Posted February 5, 2018 Posted February 5, 2018 I have been able to boot Stretch with the kernel, the modules and the firmware from Jessie but amremote still doesn't work -.-"
balbes150 Posted February 5, 2018 Author Posted February 5, 2018 A corrected version kernel 3.14.29 of the images with mali-6 20180205. Fixed KODI in HW mode. 1
balbes150 Posted February 5, 2018 Author Posted February 5, 2018 On 2/5/2018 at 12:06 AM, fatugazuhati said: I have been able to boot Stretch with the kernel, the modules and the firmware from Jessie but amremote still doesn't work -.-" Expand I checked the remote on the latest version of Mate 3.14.29 (20180205). It works. Perhaps Debian changed\no used to do packages.
fatugazuhati Posted February 5, 2018 Posted February 5, 2018 On 2/5/2018 at 1:46 PM, balbes150 said: I checked the remote on the latest version of Mate 3.14.29 (20180205). It works. Perhaps Debian changed\no used to do packages. Expand I really don't like ubuntu and I'd like to continue using Debian, do you think that this problem can be solved in some way?
