Hello.
I freshly installed bullseye from the other supported variant links for an odroid XU4.  When trying to get docker daemon running, it looked like the ip_tables module and br_netfilter modules weren't available in the kernel.
I think I have sorted out ip_tables (modprobe doesn't return any problems now), but docker's daemon is still showing a problem when running dockerd (with debug level info in the daemon.json file):
Running modprobe bridge br_netfilter failed with message: modprobe: WARNING: Module bridge not found in directory /lib/modules/5.19.10-armmp-lpae
When executing
systemctl status docker.service
... too see if the daemon is running I get:
● docker.service - Docker Application Container Engine
     Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sun 2022-11-20 00:24:34 UTC; 4s ago
TriggeredBy: ● docker.socket
       Docs: https://docs.docker.com
    Process: 8266 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
   Main PID: 8266 (code=exited, status=1/FAILURE)
        CPU: 1.868s
Nov 20 00:24:34 odroid-bullseye systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 20 00:24:34 odroid-bullseye systemd[1]: Stopped Docker Application Container Engine.
Nov 20 00:24:34 odroid-bullseye systemd[1]: docker.service: Consumed 1.868s CPU time.
Nov 20 00:24:34 odroid-bullseye systemd[1]: docker.service: Start request repeated too quickly.
Nov 20 00:24:34 odroid-bullseye systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 20 00:24:34 odroid-bullseye systemd[1]: Failed to start Docker Application Container Engine.
You are not running kernel provided by Armbian. Perhaps that is the reason?
