After finally getting a new Rock5B I tried with the collabora release (rolling), and it looks like the intel AX200 I have in the PCIe M2.E slot has issues loading firmware.
Looking forward to complete mainline support for this board as it's quite feature packed.
2 hours ago, Oskar Enoksson said:
when building in v23.11 branch. Will it be?
At release time, we make a branch from build framework and this was the 1st time that we also lock down sources. At least most of them. This means you can recreate identical images as those that were officially released. Since maintaining is very expensive and resources are slim, we have to focus very carefully what to maintain.
Is there anything I can do to help?
Maintaining stable branch is a dedication - merging bug fixes only from main https://github.com/armbian/build/commits/main on a daily basis
As this board doesn't match "Standard support" criteria:
https://docs.armbian.com/User-Guide_Board-Support-Rules/
its masked behind EXPERT="yes" switch. You can build it, but you have to understand that nobody is specifically taking care of. But you ... if you want to keep it on the requested levels of "Standard support".
  • Igor unpinned this topic
