balbes150 Posted October 18, 2023 Author Posted October 18, 2023 19 часов назад, linuxfriend сказал: could you please provide the download link for these image ver 20231011-edge kernel 6.5 ? See the first message of this topic, there are the necessary links to all available versions. 0 Quote
balbes150 Posted October 26, 2023 Author Posted October 26, 2023 Version 20231026-current (pancsf) Version 20231026-edge (panthor) Added support for HDMI audio. After installing mesa with HW acceleration, can use the system for full-screen video playback with sound, including 4k 0 Quote
archetech Posted October 26, 2023 Posted October 26, 2023 inxi -SMCG System: Host: rock-5b Kernel: 6.5.0-rc2-station-m3-p arch: aarch64 bits: 64 Desktop: GNOME v: 45.0 Distro: Ubuntu 23.10 (Mantic Minotaur) Machine: Type: ARM System: Radxa ROCK 5 Model B details: N/A CPU: Info: quad core (2-mt/2-st) model: N/A variant-1: cortex-a55 variant-2: cortex-a76 bits: 64 type: MST AMCP cache: L2: 1.5 MiB Speed: N/A min/max: N/A cores: No per core speed data found. Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A Device-2: rk3588-mali driver: panthor v: kernel Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A Display: wayland server: X.Org v: 1.23.2 with: Xwayland v: 23.2.0 compositor: gnome-shell driver: X: loaded: modesetting dri: rockchip gpu: rockchip_drm,panthor,dwhdmi_rockchip resolution: 1920x1080~60Hz API: OpenGL v: 3.1 Mesa 23.3.0-devel (git-b3cfa8adfd) renderer: Mali-G610 (Panfrost) I used balbes edge zip to get the Ubu lunar installed. Installed the mesa 23.3.0-devel. tests on gnome 44 went well so I did the big move to 23.10 Mantic. So far its quite good. Some kernel traces so I'd suggest a move to 6.6.0 kernel from Boris B asap. 0 Quote
balbes150 Posted November 24, 2023 Author Posted November 24, 2023 ver 20231123-edge kernel 6.7-rc2 0 Quote
specs Posted November 24, 2023 Posted November 24, 2023 (edited) Does the latest version include Andy Yan's HDMI/VOP2 patch? (I believe the downstream patch v1 was dated 14 november.) Edited November 24, 2023 by specs 0 Quote
balbes150 Posted January 25, 2024 Author Posted January 25, 2024 Version 20240125-edge with core 6.7 + package DEB mesa 20240125 (panthor) with HW acceleration. 1 Quote
balbes150 Posted January 26, 2024 Author Posted January 26, 2024 add image KDE kernel 6.7 + panthor ____ _ _ _ __ __ _____ / ___|| |_ __ _| |_(_) ___ _ __ | \/ |___ / \___ \| __/ _` | __| |/ _ \| '_ \ | |\/| | |_ \ ___) | || (_| | |_| | (_) | | | | | | | |___) | |____/ \__\__,_|\__|_|\___/|_| |_| |_| |_|____/ Welcome to Armbian 23.12 Lunar with bleeding edge Linux 6.7.0-rc3-station-m3-p No end-user support: built from trunk System load: 13% Up time: 4 min Local users: 3 Memory usage: 8% of 7.75G IP: 192.168.1.47 CPU temp: 37°C Usage of /: 50% of 14G [ General system configuration (beta): armbian-config ] user@station-m3:~$ neofetch user@station-m3 --------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.12) aarch64 ███████████████████████ Host: Firefly ROC-RK3588S-PC SATA ▄▄██ ██▄▄ Kernel: 6.7.0-rc3-station-m3-p ▄▄██ ███████████ ██▄▄ Uptime: 4 mins ▄▄██ ██ ██ ██▄▄ Packages: 1870 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Resolution: 1920x1080 ▄▄██ █████████████ ██▄▄ Terminal: /dev/pts/1 ▄▄██ ██ ██ ██▄▄ CPU: (8) ▄▄██ ██ ██ ██▄▄ Memory: 943MiB / 7937MiB ▄▄██ ██ ██ ██▄▄ ▄▄██ ██▄▄ ███████████████████████ █ █ █ █ █ █ █ █ █ █ █ user@station-m3:~$ glmark2-wayland ======================================================= glmark2 2021.02 ======================================================= OpenGL Information GL_VENDOR: Mesa GL_RENDERER: Mali-G610 (Panfrost) GL_VERSION: 3.1 Mesa 24.1.0-devel ======================================================= [build] use-vbo=false: FPS: 1669 FrameTime: 0.599 ms [build] use-vbo=true: FPS: 1750 FrameTime: 0.571 ms [texture] texture-filter=nearest: FPS: 1977 FrameTime: 0.506 ms [texture] texture-filter=linear: FPS: 1968 FrameTime: 0.508 ms [texture] texture-filter=mipmap: FPS: 2024 FrameTime: 0.494 ms [shading] shading=gouraud: FPS: 1947 FrameTime: 0.514 ms [shading] shading=blinn-phong-inf: FPS: 2981 FrameTime: 0.335 ms [shading] shading=phong: FPS: 2575 FrameTime: 0.388 ms [shading] shading=cel: FPS: 2764 FrameTime: 0.362 ms [bump] bump-render=high-poly: FPS: 925 FrameTime: 1.081 ms [bump] bump-render=normals: FPS: 2223 FrameTime: 0.450 ms [bump] bump-render=height: FPS: 2071 FrameTime: 0.483 ms [effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 1951 FrameTime: 0.513 ms [effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 502 FrameTime: 1.992 ms [pulsar] light=false:quads=5:texture=false: FPS: 1925 FrameTime: 0.519 ms [desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 456 FrameTime: 2.193 ms [desktop] effect=shadow:windows=4: FPS: 1988 FrameTime: 0.503 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 355 FrameTime: 2.817 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 350 FrameTime: 2.857 ms [buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 428 FrameTime: 2.336 ms [ideas] speed=duration: FPS: 1144 FrameTime: 0.874 ms [jellyfish] <default>: FPS: 974 FrameTime: 1.027 ms [terrain] <default>: FPS: 69 FrameTime: 14.493 ms [shadow] <default>: FPS: 1643 FrameTime: 0.609 ms [refract] <default>: FPS: 211 FrameTime: 4.739 ms [conditionals] fragment-steps=0:vertex-steps=0: FPS: 1665 FrameTime: 0.601 ms [conditionals] fragment-steps=5:vertex-steps=0: FPS: 2928 FrameTime: 0.342 ms [conditionals] fragment-steps=0:vertex-steps=5: FPS: 2777 FrameTime: 0.360 ms [function] fragment-complexity=low:fragment-steps=5: FPS: 3054 FrameTime: 0.327 ms [function] fragment-complexity=medium:fragment-steps=5: FPS: 2944 FrameTime: 0.340 ms [loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 3229 FrameTime: 0.310 ms [loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 3246 FrameTime: 0.308 ms [loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 2950 FrameTime: 0.339 ms ======================================================= glmark2 Score: 1807 ======================================================= 0 Quote
balbes150 Posted February 4, 2024 Author Posted February 4, 2024 Ver 20240201 current (6.2) and edge (6.8). Support for HW acceleration was immediately added to these images, additional manual installation of the package is no longer required. Added Debian Gnome and Ubuntu KDE images with wayland acceleration. 0 Quote
Dams2000 Posted February 5, 2024 Posted February 5, 2024 Hi, first of all thank you, your images are the only ones that work with my screen. However, I have a problem, the Armbian_24.02_Rock-5b_lunar_edge_6.8.0_kde-plasma_desktop.img.xz image works well but once upgraded to 23.10, black screen. Shouldn't it be updated? another thing, with the image Armbian_24.02_Rock-5b_sid_edge_6.8.0.img.xz I wanted to install kde but installation blocked because of the mesa packages. Do you know if it's possible to install it? 0 Quote
balbes150 Posted February 6, 2024 Author Posted February 6, 2024 18 часов назад, Dams2000 сказал: once upgraded to 23.10, black screen. Shouldn't it be updated? By launching the update, you kill the settings and the working mesa. 18 часов назад, Dams2000 сказал: I wanted to install kde but installation blocked because of the mesa packages. Do you know if it's possible to install it? this option will not work. 0 Quote
Dams2000 Posted February 18, 2024 Posted February 18, 2024 Be careful, I hear loud crackling noises coming from the card when I use plasma desktop, I go back to 5.10. suspicious, right? 0 Quote
balbes150 Posted February 4, 2025 Author Posted February 4, 2025 Ver 20250204-edge kernel 6.14 HDMI and analog sound. **** List of PLAYBACK Hardware Devices **** card 0: hdmi0 [hdmi0], device 0: fddf0000.i2s-i2s-hifi i2s-hifi-0 [fddf0000.i2s-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: rk3588es8316 [rk3588-es8316], device 0: fe470000.i2s-ES8316 HiFi ES8316 HiFi-0 [fe470000.i2s-ES8316 HiFi ES8316 HiFi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 0 Quote
pipi Posted April 12, 2025 Posted April 12, 2025 I've tried starting with edge, but none of them work for me. Maybe I have an old u-boot? Mine's on SPI, made with one of your EFI images from 2023. 0 Quote
balbes150 Posted April 23, 2025 Author Posted April 23, 2025 12.04.2025 в 05:33, pipi сказал: I've tried starting with edge, but none of them work for me. Maybe I have an old u-boot? Mine's on SPI, made with one of your EFI images from 2023. If you have the EFI version installed in SPI, it can only run EFI-enabled images. To run "regular" images with u-boot, you need to have a version with u-boot in SPI. 0 Quote
pipi Posted May 10, 2025 Posted May 10, 2025 On 4/23/2025 at 2:55 AM, balbes150 said: If you have the EFI version installed in SPI, it can only run EFI-enabled images. To run "regular" images with u-boot, you need to have a version with u-boot in SPI. Yes, I installed the efi version on SPI when I thought I could boot UEFI images that way. And that's what I kept because I had no problem booting other uboot images, like the joshuas archlinux one I'm currently using to write this. Now I'm downloading the last one you posted because I'm so stubborn. But after that, I plan to boot with version 20240201-current to install a new uboot on SPI. 0 Quote
balbes150 Posted June 7, 2025 Author Posted June 7, 2025 I checked the installation of KODI from the regular network repository (with the command apt install kodi ) with the latest kernel 6.15. Everything starts and works. all test videos are running and running. The overall load/heating of the system in running KODI when playing 4k video is not high. ____ _ ____ ____ | _ \ ___ ___| | __ | ___|| __ ) | |_) / _ \ / __| |/ / |___ \| _ \ | _ < (_) | (__| < ___) | |_) | |_| \_\___/ \___|_|\_\ |____/|____/ Welcome to Armbian 25.05 Noble with bleeding edge Linux 6.15.0-station-m3-p No end-user support: built from trunk System load: 19% Up time: 17 min Memory usage: 4% of 15.43G IP: 192.168.1.29 CPU temp: 33°C Usage of /: 37% of 15G [ 67 security updates available, 88 updates total: apt upgrade ] Last check: 2025-06-07 12:38 root@rock-5b:~# armbianmonitor -m Two CPU clusters are available for monitoring Stop monitoring using [ctrl]-[c] Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 16:06:26 1608/1800 MHz 2.77 6% 1% 2% 0% 1% 0% 34.2 °C 1/1 16:06:31 1200/1416 MHz 3.11 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:06:36 1800/1416 MHz 3.18 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:06:41 1800/1416 MHz 3.25 11% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:06:46 1416/1608 MHz 3.31 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:06:51 1800/1416 MHz 3.20 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:06:56 1416/1200 MHz 3.11 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:07:01 1608/1608 MHz 2.86 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:07:06 1800/1200 MHz 2.71 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:07:11 1800/1200 MHz 2.57 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:07:16 1608/1800 MHz 2.37 11% 3% 6% 0% 0% 1% 33.3 °C 1/1 16:07:21 1200/1416 MHz 2.26 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 16:07:26 1800/1608 MHz 2.24 10% 3% 5% 0% 0% 1% 34.2 °C 1/1 16:07:31 1608/1608 MHz 2.14 10% 3% 6% 0% 0% 1% 34.2 °C 1/1 0 Quote
balbes150 Posted June 7, 2025 Author Posted June 7, 2025 P.S. LibreElec for rk3588 and kernel 6.15 https://forum.libreelec.tv/thread/20823-unofficial-le-for-rk356x-rk3328-rk3399-rk3588-s-rk3576/?postID=200570#post200570 0 Quote
