Mario663 Posted December 23, 2022 Author Share Posted December 23, 2022 (edited) with your file it works now what command should I give to start the graphic environment...remember that this is the minimal image, the only one that has about 2.5GB to be able to install it in the flash memory Edited December 23, 2022 by Mario663 used google translate to forum language of english Link to comment Share on other sites More sharing options...
Mario663 Posted December 23, 2022 Author Share Posted December 23, 2022 Link to comment Share on other sites More sharing options...
SteeMan Posted December 23, 2022 Share Posted December 23, 2022 What build did you download from the armbian servers? I assume you are looking for a desktop build, it looks like you installed a server/command line build. Link to comment Share on other sites More sharing options...
Mario663 Posted December 23, 2022 Author Share Posted December 23, 2022 (edited) Yes you are right I downloaded the minimal sid because I saw that the xfce occupies more than 8GB from etcher to be able to install it in the emmc Edited December 23, 2022 by Mario663 Link to comment Share on other sites More sharing options...
Mario663 Posted December 24, 2022 Author Share Posted December 24, 2022 Yes, I have to see how much the penultimate release takes up....if it takes up less than 8 gb then I can install it on the emmc....what is the penultimate release if 20.10!? Link to comment Share on other sites More sharing options...
Mario663 Posted December 24, 2022 Author Share Posted December 24, 2022 (edited) or is there some other version!? Edited December 24, 2022 by Mario663 Link to comment Share on other sites More sharing options...
SteeMan Posted December 24, 2022 Share Posted December 24, 2022 Have you run the desktop version from SD card? No reason to worry about emmc install if the performance isn't going to meet your needs. I personally find the performance on most TV boxes to be too slow for real use desktop use. They in my opinion are best for usage as servers. Link to comment Share on other sites More sharing options...
SteeMan Posted December 24, 2022 Share Posted December 24, 2022 Also have you tried installing the desktop build on emmc? It should work. You shouldn't care what size it takes on the SD card, as that doesn't impact how it is installed on emmc. Most of the space on the SD card is unused empty space. Link to comment Share on other sites More sharing options...
Mario663 Posted December 24, 2022 Author Share Posted December 24, 2022 Ah so even if etcher requires 8 gb then in the emmc I can install it anyway!? ok then as soon as i have some time i redownload the xfce and burn it to sd....i will always have to use your extlinux.conf file right? keep in mind that now on the emmc I have Armbian version 5.88 pre-installed! Link to comment Share on other sites More sharing options...
Mario663 Posted December 25, 2022 Author Share Posted December 25, 2022 etcher 8.33GB Link to comment Share on other sites More sharing options...
SteeMan Posted December 25, 2022 Share Posted December 25, 2022 16 hours ago, Mario663 said: Ah so even if etcher requires 8 gb then in the emmc I can install it anyway!? Yes Link to comment Share on other sites More sharing options...
Mario663 Posted December 25, 2022 Author Share Posted December 25, 2022 ok now I just finished burning XFCE now I try and update you! Link to comment Share on other sites More sharing options...
Mario663 Posted December 25, 2022 Author Share Posted December 25, 2022 I get stuck on this screen!! Link to comment Share on other sites More sharing options...
SteeMan Posted December 25, 2022 Share Posted December 25, 2022 Can you help even a little bit. How about you start with telling what you have done? Give context to the screen shot. Showing a random screen shot is of no help. List the exact steps you have done, and what you are trying to do. Also you need to answer my questions when I ask, if you want help. You still haven't answered the question I asked if you have successfully tested running the desktop build from the SD card? Because you were able to run the cli version from sd only based on prior reports. I've taken hours of my time to help you. You need to try harder to make it easier to help you. Link to comment Share on other sites More sharing options...
Mario663 Posted December 25, 2022 Author Share Posted December 25, 2022 Dude I'm doing everything you tell me, I'm trying to explain everything I've done, I downloaded the xfce kinetic with whale etcher I burned it on an sd then I downloaded your extlinux.conf file and replaced it with what's inside...then i changed the u-boot 905X 912 file to u-boot.ext i inserted the sd into the tv-box slot and it stuck on the photo screen! Link to comment Share on other sites More sharing options...
SteeMan Posted December 25, 2022 Share Posted December 25, 2022 So you were successful with the cli build, but the xfce build isn't booting? Link to comment Share on other sites More sharing options...
Mario663 Posted December 25, 2022 Author Share Posted December 25, 2022 3 minutes ago, SteeMan said: So you were successful with the cli build, but the xfce build isn't booting? exact Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 I also tried to remove the mouse & keyboard adapter as it crashed immediately after recognizing the drivers anyway but it still crashes before! Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 Anyway, I'm attaching the xlinux.conf file that you gave me and that I use now, I don't want windows to modify it again! extlinux.conf Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 [ 5.212700] lima d00c0000.gpu: error-ENODEV: _opp_set_regulator (mali) found Link to comment Share on other sites More sharing options...
SteeMan Posted December 26, 2022 Share Posted December 26, 2022 I am on vacation this week. So I can't really offer much support as I don't have access to my boxes to test any suggestions. Link to comment Share on other sites More sharing options...
SteeMan Posted December 26, 2022 Share Posted December 26, 2022 One thought I have for you to try is to go back to the clu version, and use armbian-config to install/enable desktop support on it. Link to comment Share on other sites More sharing options...
SteeMan Posted December 26, 2022 Share Posted December 26, 2022 Also going back to a very basic question. What do you intend to use the TV box for? Why do you even want to use the desktop version? Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 (edited) ok happy holidays meanwhile I'm testing other builds the 20.10 bullseye stays here for me! Edited December 26, 2022 by Mario663 Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 3 minutes ago, SteeMan said: Also going back to a very basic question. What do you intend to use the TV box for? Why do you even want to use the desktop version? for simple use as a mini pc! Link to comment Share on other sites More sharing options...
Mario663 Posted December 26, 2022 Author Share Posted December 26, 2022 As already said in the first post, I've already managed to install 5.88 in the emmc, this too would be fine, only that it annoys me to press x at startup! Link to comment Share on other sites More sharing options...
Mario663 Posted December 27, 2022 Author Share Posted December 27, 2022 (edited) Ok I burned the Armbian_20.05.6_Arm-64_bullseye_current_5.7.2_desktop_20200612.img.xz but this image still uses the old method with the .deb file I tried the following .deb files renaming them to deb.img but none make me boot still on the arc64 s905x screen! meson-gxl-s905x-p212.dtb meson-gxl-s905x-khadas-vim.dtb meson-gxbb-vega-s95-meta.dtb meson-gxbb-p200.dtb meson-gxbb-p201.dtb I am attaching my uEnv.txt configuration uEnv.txt armbian_first_run.txt.template Edited December 27, 2022 by Mario663 Link to comment Share on other sites More sharing options...
Mario663 Posted December 27, 2022 Author Share Posted December 27, 2022 (edited) I tried both to start it automatically from SD and with the toothpick it always stays on this image at startup Edited December 27, 2022 by Mario663 Link to comment Share on other sites More sharing options...
Mario663 Posted December 29, 2022 Author Share Posted December 29, 2022 On 12/26/2022 at 3:28 PM, SteeMan said: Why do you even want to use the desktop version? Ok after configuring the uEvn.tx file of the built Armbian_20.05.6_Arm-64_bullseye_current_5.7.2_desktop_20200612.img.xz and meson-gxbb-p201.dtb, when I start it ignores the SD and it starts me from the emmc even by pressing with the toothpick ! Link to comment Share on other sites More sharing options...
spirake Posted December 30, 2022 Share Posted December 30, 2022 I identified the reason why the box didn't start after the upgrade. At first when I wrote the image on the card, I used (meson-gxm-q200-mod.dtb) and it detected bluetooth with this dtb. After the upgrade the dtb was changed - the one without mode, respectively (meson-gxm-q200.dtb) and it no longer corresponded to the one written in extlinux.conf and the bluetooth was no longer connected either. Link to comment Share on other sites More sharing options...
