eshelton Posted February 14, 2023 Share Posted February 14, 2023 @cotonec The OPi5 seems to simply not work with some HDMI devices. When I first booted my OPi5, I attached it to an older DVI display via a DVI to HDMI cable. Nothing showed on the display and I would have thought it was DOA if it weren’t for the green heartbeat LED letting me know the kernel was running. The same monitor and cable worked just fine when plugged instead into my laptop. Switching to a different monitor got things going with the Opi5 - it just worked as expected. No idea if this is a hardware or software issue - I didn’t dig into it once I got going with the other monitor. You might be running into the same problem I did. 0 Quote Link to comment Share on other sites More sharing options...
gartox Posted February 14, 2023 Share Posted February 14, 2023 Hello, I had the same issue also. My screen has 3 input (DVI,HDMI,DP). My old laptop was connected using a HMDI>DVI cable and works OK, but when connecting the OPI5 I got nothing on screen not even the screen wakes up. But when connecting the OPI5 with HDMI>HDMI cable it works OK. 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted February 14, 2023 Share Posted February 14, 2023 Do you have dmesg output? 0 Quote Link to comment Share on other sites More sharing options...
cotonec Posted February 17, 2023 Share Posted February 17, 2023 rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -2 [ 6.894118] [drm] failed to init overlay plane Cluster0-win1 [ 6.894151] [drm] failed to init overlay plane Cluster1-win1 [ 6.894181] [drm] failed to init overlay plane Cluster2-win1 [ 6.894210] [drm] failed to init overlay plane Cluster3-win1 [ 6.905202] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc0111aa5a0) [ 6.906117] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 6.906317] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc0111b2440) [ 6.906383] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffffffc0111b4a78) [ 6.906991] rockchip-drm display-subsystem: failed to parse loader memory [ 7.015024] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 7.015065] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1024x600p60, type: 11(if:800) for vp0 dclk: 49000000 [ 7.015213] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2 [ 7.015231] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:77a10 rate:490000 [ 7.015506] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked! [ 7.015513] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 49000000, get 49000000 [ 7.015545] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 49000000 [ 7.015555] dwhdmi-rockchip fde80000.hdmi: dw_hdmi_qp_setup DVI mode [ 7.015579] dwhdmi-rockchip fde80000.hdmi: Rate 49000000 missing; compute N dynamically [ 7.032281] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 7.048878] Console: switching to colour frame buffer device 128x37 [ 7.065849] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 7.091388] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 7.101830] dwhdmi-rockchip fde80000.hdmi: use tmds mode [ 7.115520] dwhdmi-rockchip fde80000.hdmi: use tmds mode 0 Quote Link to comment Share on other sites More sharing options...
Blackenz Posted February 21, 2023 Share Posted February 21, 2023 Hi @Efe Çetin After some busy weeks i finally had some more time to play around with de OPI5. After some more tests i found out that display port over usb-c is working but unfortunatetly it is not outputting the 5120x1440 resolution. The Samsung G9 display has a PIP functionality which splits the screen in 2 halves. When in this mode, the Pi5 can drive half of the display, with a 4k resolution (i might need to confirm the exact resolution values), through the USB-C to DisplayPort cable. The problems arise when the display is configured in native mode... I tried using xrandr to configure a custom resolution but had no success... Is there any other way i can try this? Another question is, i have a usb to serial adapter. Is the UART enabled by default in armbian? This would be a great way to capture dmesg output when the OPI5 cannot drive the display in its native resolution. Also, was not OPI5 supposed to support 8k60hz in HDMI? Thank You for Your support 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted February 21, 2023 Share Posted February 21, 2023 Don't have any idea about 8k but it should be supported. Yes uart debug is working but its 1500000 as default 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 21, 2023 Share Posted February 21, 2023 15 minutes ago, Efe Çetin said: 15000000 15Mbaud? Are you sure it is not 1.5Mbaud? 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted February 21, 2023 Share Posted February 21, 2023 Just a typo 😅 1 Quote Link to comment Share on other sites More sharing options...
Blackenz Posted February 21, 2023 Share Posted February 21, 2023 So as far as i understand, the uart in the red box should work out of the box, correct? Even considering @Efe Çetin typo i still get some garbage on the serial console: 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted February 22, 2023 Share Posted February 22, 2023 @Blackenzwhat's your usb ttl convertor chip? And how did you do wiring 0 Quote Link to comment Share on other sites More sharing options...
Blackenz Posted February 22, 2023 Share Posted February 22, 2023 (edited) It's a prolific pl2303hxa. The wiring is GND - GND, TX (pl2303hxa) - RX (OPi5), RX (pl2303hxa) - TX (OPi5). I know this converter is a bit old, but it was the only one i had lying around. Might be the problem? Edited February 22, 2023 by Blackenz 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted February 22, 2023 Share Posted February 22, 2023 pl2303hxa supports 1.2M max. You need to change default baud rate of opi5 or buy new one 0 Quote Link to comment Share on other sites More sharing options...
Blackenz Posted February 23, 2023 Share Posted February 23, 2023 (edited) Hi @Efe Çetin So i finally got uart working and captured dmesg output. Could you take a look and see if something might say why the display isn't recognized when in native mode? I am connecting the display using the usb-c to display port cable, and it's native resolution is 5120x1440 Once again Thank You Very much for your help and effort uart-dmesg.out EDIT 1. - After digging a bit around i found this post on the radxa foruns which might be useful: https://forum.radxa.com/t/ubuntu-image-with-x11-and-resolution-2560x1440/12553/8 As they state there, compiling the https://raw.githubusercontent.com/amazingfate/radxa-rock5b-overlays/main/rk3588-add-hdptxphy_hdmi_clk.dts dts file and installing it as an overlay might fix the issue. Would this be applicable to OPI5? EDIT 2 - I tried the above solution using armbian-add-overlay with no success. 234849 bytes read in 27 ms (8.3 MiB/s) reading /overlay-user/rk3588-add-hdptxphy_hdmi_clk.dtbo 621 bytes read in 2 ms (302.7 KiB/s) Applying user provided DT overlayfailed on fdt_overlay_apply(): FDT_ERR_NOTFOUND Error applying DT overlays, restoring original DT reading /dtb/rockchip/rk3588s-orangepi-5.dtb Edited February 23, 2023 by Blackenz 0 Quote Link to comment Share on other sites More sharing options...
Blackenz Posted February 26, 2023 Share Posted February 26, 2023 (edited) Okay, so after a lot of digging i might found the reason why i am having a lot of trouble with this display and the orange pi. I extracted edid from x64 Ubuntu (which is partiatly working, since it is also not outputing in display native mode), and it seems that the native resolution is only beeing specified in the DisplayID Extension Block and not in the Base Blocks: cat /sys/class/drm/card0-HDMI-A-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 4c 2d 52 70 58 4a 58 43 ff ff 01 03 80 77 22 78 2a c7 25 b1 4b 46 a8 26 0e 50 54 bf ef 80 71 4f 81 00 81 c0 81 80 a9 c0 b3 00 95 00 d1 c0 1a 68 00 a0 f0 38 1f 40 30 20 3a 00 a9 50 41 00 00 1a 00 00 00 fd 00 32 4b 1e b7 3c 00 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 43 34 39 47 39 35 54 0a 20 20 20 20 00 00 00 ff 00 48 34 5a 54 31 30 31 31 34 38 0a 20 20 03 24 f0 02 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9e 02 03 3d f1 49 90 61 60 1f 04 13 12 03 5a 23 09 07 07 83 01 00 00 e2 00 4f e3 05 c0 00 67 03 0c 00 10 00 b8 3c 67 d8 5d c4 01 78 80 03 e6 06 05 01 8b 73 12 e2 0f 06 e5 01 8b 84 90 01 56 5e 00 a0 a0 a0 29 50 30 20 35 00 a9 50 41 00 00 1a 58 4d 00 b8 a1 38 14 40 f8 2c 45 00 a9 50 41 00 00 1e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 71 70 12 79 00 00 03 01 28 33 b7 00 88 ff 13 9f 00 2f 80 1f 00 9f 05 28 00 02 00 09 00 6e c2 00 08 ff 09 9f 00 2f 80 1f 00 9f 05 54 00 02 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d6 90 ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: SAM Model: 28754 Serial Number: <redacted> Model year: 2245 Basic Display Parameters & Features: Digital display Maximum image size: 119 cm x 34 cm Gamma: 2.20 DPMS levels: Off RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6943, 0.2929 Green: 0.2744, 0.6591 Blue : 0.1484, 0.0566 White: 0.3134, 0.3291 Established Timings I & II: IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz Apple : 640x480 66.666667 Hz 4:3 35.000 kHz 30.240000 MHz DMT 0x05: 640x480 72.808802 Hz 4:3 37.861 kHz 31.500000 MHz DMT 0x06: 640x480 75.000000 Hz 4:3 37.500 kHz 31.500000 MHz DMT 0x08: 800x600 56.250000 Hz 4:3 35.156 kHz 36.000000 MHz DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz DMT 0x0a: 800x600 72.187572 Hz 4:3 48.077 kHz 50.000000 MHz DMT 0x0b: 800x600 75.000000 Hz 4:3 46.875 kHz 49.500000 MHz Apple : 832x624 74.551266 Hz 4:3 49.726 kHz 57.284000 MHz DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz DMT 0x11: 1024x768 70.069359 Hz 4:3 56.476 kHz 75.000000 MHz DMT 0x12: 1024x768 75.028582 Hz 4:3 60.023 kHz 78.750000 MHz DMT 0x24: 1280x1024 75.024675 Hz 5:4 79.976 kHz 135.000000 MHz Apple : 1152x870 75.061550 Hz 192:145 68.681 kHz 100.000000 MHz Standard Timings: DMT 0x15: 1152x864 75.000000 Hz 4:3 67.500 kHz 108.000000 MHz DMT 0x1c: 1280x800 59.810326 Hz 16:10 49.702 kHz 83.500000 MHz DMT 0x55: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz DMT 0x53: 1600x900 60.000000 Hz 16:9 60.000 kHz 108.000000 MHz (RB) DMT 0x3a: 1680x1050 59.954250 Hz 16:10 65.290 kHz 146.250000 MHz DMT 0x2f: 1440x900 59.887445 Hz 16:10 55.935 kHz 106.500000 MHz DMT 0x52: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz Detailed Timing Descriptors: DTD 1: 3840x1080 59.968497 Hz 32:9 66.625 kHz 266.500000 MHz (1193 mm x 336 mm) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 10 Vback 18 Vpol N Display Range Limits: Monitor ranges (GTF): 50-75 Hz V, 30-183 kHz H, max dotclock 600 MHz Display Product Name: 'LC49G95T' Display Product Serial Number: <redacted> Extension blocks: 3 Checksum: 0x24 ---------------- Block 1, Block Map Extension Block: Block 2: CTA-861 Extension Block Block 3: DisplayID Extension Block Checksum: 0x9e ---------------- Block 2, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (native) VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz VIC 90: 2560x1080 60.000000 Hz 64:27 66.000 kHz 198.000000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 48 44.1 32 Supported sample sizes (bits): 24 20 16 Speaker Allocation Data Block: FL/FR - Front Left/Right Video Capability Data Block: YCbCr quantization: No Data RGB quantization: Selectable (via AVI Q) PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Colorimetry Data Block: BT2020YCC BT2020RGB Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 1.0.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 300 MHz Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8: Version: 1 Maximum TMDS Character Rate: 600 MHz SCDC Present Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding HDR Static Metadata Data Block: Electro optical transfer functions: Traditional gamma - SDR luminance range SMPTE ST2084 Supported static metadata descriptors: Static metadata type 1 Desired content max luminance: 139 (1015.241 cd/m^2) Desired content max frame-average luminance: 115 (603.666 cd/m^2) Desired content min luminance: 18 (0.051 cd/m^2) YCbCr 4:2:0 Capability Map Data Block: VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz Vendor-Specific Video Data Block (HDR10+), OUI 90-84-8B: Application Version: 1 Detailed Timing Descriptors: DTD 2: 2560x1440 59.950550 Hz 16:9 88.787 kHz 241.500000 MHz (1193 mm x 336 mm) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 5 Vback 33 Vpol N DTD 3: 2560x1080 60.000000 Hz 64:27 66.000 kHz 198.000000 MHz (1193 mm x 336 mm) Hfront 248 Hsync 44 Hback 148 Hpol P Vfront 4 Vsync 5 Vback 11 Vpol P Checksum: 0x71 ---------------- Block 3, DisplayID Extension Block: Version: 1.2 Extension Count: 0 Display Product Type: Extension Section Video Timing Modes Type 1 - Detailed Timings Data Block: DTD: 5120x1440 59.976879 Hz 0:0 88.826 kHz 469.000000 MHz (aspect undefined, no 3D stereo, preferred) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 10 Vback 28 Vpol N DTD: 2560x1440 119.997589 Hz 0:0 182.996 kHz 497.750000 MHz (aspect undefined, no 3D stereo) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 5 Vback 77 Vpol N Checksum: 0xd6 Checksum: 0x90 When i connect the display to orange pi and check the modes in /sys/class/drm/card0-DP-1/modes , i can only find the modes that match the Block 0 and none from the DisplayID block from edid. So the question is, is kernel configured to check the DisplayID block from edid? Is kernel compiled with CONFIG_DRM_LOAD_EDID_FIRMWARE ? P.S. - I think i might be hitting a problem that might be above Armbian and maybe kernel / rockchip (?) related. If so, do you know where can i seek for further help? Once Again, Thank You for your support and hard work Edited February 26, 2023 by Blackenz 0 Quote Link to comment Share on other sites More sharing options...
SpikeyGG Posted June 17, 2023 Share Posted June 17, 2023 I just got an Orange Pi 5 from China and I also have a Samsung G9 monitor. I found your thread because I'm trying to get it working over HDMI and OMG is it a PITA. I've tried all the HDMI cables that I could find in my house (that's 5 so far) and none of them give me video on the G9 from this Orange Pi 5, even from a fresh boot the Orange Pi boot screen doesn't show up. I have an old spare monitor for testing that works great with all five of these HDMI cables and the Orange Pi 5 so I'm pretty sure that something fails to negotiate the video. @Blackenz, when you use HDMI do you see the Orange Pi boot logo on your G9? I can use the HDMI port on my G9 with another computer I have nearby and it seems to work fine but when I use the Orange Pi 5 as the source, nothing ever comes out. I tried forcing the monitor to HDMI version 1.4 instead of 2.0 but still nothing. I noticed that the OSD menu doesn't show very many options when the Orange Pi 5 is plugged in and on, almost like the G9 doesn't even see it there. After reading your thread I have on order a USB-C to DisplayPort 1.4 cable that says it supports 4k@144Hz and 2k@240Hz, but we'll see. It's supposed to arrive today so, hopefully, I can get a video feed from this thing on my primary monitor using DisplayPort. 0 Quote Link to comment Share on other sites More sharing options...
SpikeyGG Posted June 18, 2023 Share Posted June 18, 2023 Well, I got a USB-C to DisplayPort cable and a USB-C to HDMI cable so I could try them both. Turns out, the only thing that actually allows me to see anything is the USB-C to HDMI cable. When I get video though, it is crazy small. When I look at the mode, it says 3840x2160! I don't know how that mode is displayable on the monitor but somehow it is, I changed it to the next option down which is 1920x1080. I also pulled my edid information. It's much shorter and looks quite a bit different than Blackenz results for some reason: Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: SAM Model: 28754 Serial Number: <redacted> Model year: 2245 Basic Display Parameters & Features: Digital display Maximum image size: 119 cm x 34 cm Gamma: 2.20 DPMS levels: Off RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6943, 0.2929 Green: 0.2744, 0.6591 Blue : 0.1484, 0.0566 White: 0.3134, 0.3291 Established Timings I & II: IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz Apple : 640x480 66.667 Hz 4:3 35.000 kHz 30.240 MHz DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz DMT 0x08: 800x600 56.250 Hz 4:3 35.156 kHz 36.000 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz Apple : 832x624 74.551 Hz 4:3 49.726 kHz 57.284 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz Standard Timings: DMT 0x15: 1152x864 75.000 Hz 4:3 67.500 kHz 108.000 MHz DMT 0x1c: 1280x800 59.810 Hz 16:10 49.702 kHz 83.500 MHz DMT 0x55: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz DMT 0x53: 1600x900 60.000 Hz 16:9 60.000 kHz 108.000 MHz (RB) DMT 0x3a: 1680x1050 59.954 Hz 16:10 65.290 kHz 146.250 MHz DMT 0x2f: 1440x900 59.887 Hz 16:10 55.935 kHz 106.500 MHz DMT 0x52: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz Detailed Timing Descriptors: DTD 1: 3840x2160 30.000 Hz 16:9 67.500 kHz 297.000 MHz (1193 mm x 336 mm) Hfront 176 Hsync 88 Hback 296 Hpol P Vfront 8 Vsync 10 Vback 72 Vpol P Display Range Limits: Monitor ranges (GTF): 50-75 Hz V, 30-183 kHz H, max dotclock 600 MHz Display Product Name: 'LC49G95T' Display Product Serial Number: '<redacted>' Extension blocks: 1 Checksum: 0xf0 ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Native detailed modes: 1 Video Data Block: VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 1.0.0.0 Maximum TMDS clock: 300 MHz Detailed Timing Descriptors: DTD 2: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (621 mm x 341 mm) Hfront 88 Hsync 44 Hback 148 Hpol P Vfront 4 Vsync 5 Vback 36 Vpol P Checksum: 0x25 I don't see Block 2 nor Block 3. My monitor is running the 1016.0 Firmware which is the latest released version from Samsung. I don't really want to use this thing in 1080p since it is capable of so much more! I tried to do the process from the link @Blackenz shared: Create /boot/overlay-user wget https://raw.githubusercontent.com/amazingfate/radxa-rock5b-overlays/main/rk3588-add-hdptxphy_hdmi_clk.dts dtc -O dtb -o rk3588-add-hdptxphy_hdmi_clk.dtbo rk3588-add-hdptxphy_hdmi_clk.dts cp rk3588-add-hdptxphy_hdmi_clk.dtbo /boot/overlay-user edit orangepiEnv.txt and add user_overlays=rk3588-add-hdptxphy_hdmi_clk Based on the comments in the thread this should have worked but nothing seemed to change. I'm thinking that there's gotta be some BIOS firmware or something that needs to be updated on this thing to properly interact with my monitor but I can't seem to find that kind of detail anywhere on the OrangePi website. 0 Quote Link to comment Share on other sites More sharing options...
