ChrisO Posted January 14, 2023 Posted January 14, 2023 The zfs-dkms included in Armbian_22.11.1_Odroidhc4_jammy in version 2.1.4 is to old for 5.19.17 kernel. It should be 2.1.6 like in Armbian_22.08.7. Loading new zfs-2.1.4 DKMS files... Building for 5.19.17-meson64 Building initial module for 5.19.17-meson64 configure: error: *** None of the expected "blk_queue_discard" interfaces were detected. *** This may be because your kernel version is newer than what is *** supported, or you are using a patched custom kernel with *** incompatible modifications. *** *** ZFS Version: zfs-2.1.4-0ubuntu0.1 *** Compatible Kernels: 3.10 - 5.17 http://paste.debian.net/1267188/ 0 Quote
Igor Posted January 16, 2023 Posted January 16, 2023 On 1/14/2023 at 3:49 PM, ChrisO said: It should be 2.1.6 Expand Update has been initiated. 24 - 48h until it shows up in CDN. 0 Quote
drikus Posted January 21, 2023 Posted January 21, 2023 require zfs as well. bulsseye minimal pulls even older zfs Building for 5.19.17-meson64 Building initial module for 5.19.17-meson64 configure: error: *** None of the expected "PDE_DATA" interfaces were detected. *** This may be because your kernel version is newer than what is *** supported, or you are using a patched custom kernel with *** incompatible modifications. *** *** ZFS Version: zfs-2.0.3-9 *** Compatible Kernels: 3.10 - 5.10 Therefore on yammy route then still same error Loading new zfs-2.1.4 DKMS files... Building for 5.19.17-meson64 Building initial module for 5.19.17-meson64 configure: error: *** None of the expected "blk_queue_discard" interfaces were detected. *** This may be because your kernel version is newer than what is *** supported, or you are using a patched custom kernel with *** incompatible modifications. *** *** ZFS Version: zfs-2.1.4-0ubuntu0.1 *** Compatible Kernels: 3.10 - 5.17 What does Quote Update has been initiated. 24 - 48h until it shows up in CDN. Expand Actually mean and how to build zfs 2.16 then ? 0 Quote
drikus Posted January 24, 2023 Posted January 24, 2023 Was unable to pull zfs-dkms 2.1.6 being available on cdn https://armbian.hosthatch.com/apt/pool/jammy-utils/z/zfs-linux/ After armbian-config and apt reconfigure mirrors and apt update && apt upgrade i could pull the zfs 2.1.6 goods (dkms and zfs-utils) These values are and where fine cat /etc/apt/sources.list deb http://ports.ubuntu.com/ jammy main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-security main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-security main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse cat /etc/apt/sources.list.d/armbian.list deb http://apt.armbian.com jammy main jammy-utils jammy-desktop Not sure why apt reconfigure mirrors solved this.. but never the less, happy eyes with the zfs goods to play with. 1 Quote
