October 12, 20233 yr @roykYour overlay works. Maybe I have done something wrong by directly modify the devicetree. I will investigate it later.
November 3, 20233 yr 10.10.2023 в 02:25, royk сказал: If there are people that still have problems with the overlays in Kodi, unable to see the OSD while playing a movie. You could try the following: Install the overlay: sudo armbian-add-overlay vop.dts Then: armbian-config -> System -> DTC Then search (crtl+w) for 'disable-win-move;' and remove that line. After that ctrl+x and save and agree to reboot Thank you! This helped me also solve the problems with the overlays in Kodi on orangepi 5.
December 26, 20232 yr Hey guys, have you ever noticed that Kodi occasionally automatically fast-forwards when playing videos?
December 26, 20232 yr @vale Yeah, I found out it was because I was sitting on the remote. But seriously In case you've got the OPi5 plus it is possible that the IR receiver receives a signal from another remote, I remember that mine did with a remote, I thought the one of LG. Perhaps it's better to disable the remote in the DTB by default, for now you could try to put a piece of tape over it or disable it if it's a module.
January 1, 20242 yr Does `Armbian 23.11 Bookworm cli (minimal)` have 3D/HW Video Acceleration enabled?
January 3, 20242 yr Hello, first, thanks for the detailed instructions! I followed the guide step by step: - Downloaded image from https://fi.mirror.armbian.de/archive/orangepi5/archive/Armbian_23.02.2_Orangepi5_jammy_legacy_5.10.110_xfce_desktop.img.xz So far so good, made all settings as described. However, after I add some Movies to the library, kodi keeps crashing and resetting the session (crashlog attachedkodi_crashlog-20240103_143357.log I've loaded 3 x265 (.mkv) files for testing purposes directly on the SD-Card) How can I fix that? I did not change the system in any other way so far, my goal is to get this problem solved first. My System: - OrangePI 5 16GB with 64GB MicroSD Card - Display / TV: Toshiba 40RV723 (1080p) If more information is required, let me know Thanks and regards
January 3, 20242 yr @XXXBold Perhaps because you're using a kernel from February while the FFmpeg you're using needs recent made fixes. Try a newer kernel/image. https://fi.mirror.armbian.de/archive/orangepi5/archive/Armbian_23.8.1_Orangepi5_jammy_legacy_5.10.160_xfce_desktop.img.xz
January 3, 20242 yr @royk Thanks for your response. I tried again with the image you linked, but same issue. Here are two kodi crashlogs: 1:1_kodi_crashlog-20240103_191538.log (This is the first crash after adding the Movies) 2: 2_kodi_crashlog-20240103_191715.log This is on of the other crashes (the crash session / restart loop is infinite, so the logs all look more or less the same)
January 4, 20242 yr @XXXBold You could try updating mpp: git clone https://github.com/rockchip-linux/mpp.git -b develop cd mpp/build/linux/aarch64 nano make-Makefiles.bash add after '-DHAVE_DRM=ON \' the following lines and save (ctrl-x then y) -DCMAKE_INSTALL_PREFIX:PATH='/usr' \ -DCMAKE_INSTALL_LIBDIR:PATH='lib/aarch64-linux-gnu' \ bash make-Makefiles.bash make -j8 sudo make install
January 4, 20242 yr @royk I can't find the '-DHAVE_DRM=ON \' in the file. See here: https://github.com/rockchip-linux/mpp/blob/develop/build/linux/aarch64/make-Makefiles.bash I added the lines below "-DCMAKE_TOOLCHAIN_FILE=./arm.linux.cross.cmake \" Now it looks like: # generate Makefile cmake -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_TOOLCHAIN_FILE=./arm.linux.cross.cmake \ -DCMAKE_INSTALL_PREFIX:PATH='/usr' \ -DCMAKE_INSTALL_LIBDIR:PATH='lib/aarch64-linux-gnu' \ -G "Unix Makefiles" \ ${MPP_TOP} Compile & install worked. I rebooted the machine, and now it seems to work! Kodi no longer crashes & when playing an x265-file the CPU usage is quite low, thanks! However, another (small) issue: When playing a video, it's always in front, when using the menu in kodi (Esc) it's behind the video, so not really usable, until the playback is stopped completly, see Image. Is there a fix for this? Otherwise it seems to work really well now (need more testing to confirm for sure) EDIT: Fixed, see answer from @royk, thanks! Edited January 6, 20242 yr by XXXBold
January 5, 20242 yr Btw, there's also another way. Combination kodi + mpv. it's not difficult to make mpv as external player inside of kodi. In that case it's not necessary to do full set of instructions of 1st post. Generic kodi installation from apt would be enough. And, what is an advantage - with mpv you get hdr tonemapping, that makes better and more contrast look of hdr videos for most of tv's relatively to kodi's internal player. (unless you have "true" hdr tv , that is rare case, end even if you do, wayland is unable to output hdr as far i know, so tonemapping will make better look anyway) Edited January 5, 20242 yr by rix81
January 6, 20242 yr @rix81 Great tip! Although Wayland can't output HDR yet (it's almost there), Kodi under GBM can output HDR and these days it's pretty common to have a HDR TV, at least where I live unless you mean something different with "true HDR". Eitherway it seems like a good alternative but you might still need to edit the dtb for HDR.
January 7, 20242 yr On 1/6/2024 at 3:27 AM, royk said: it's pretty common to have a HDR TV Yea) kind of offtop probably. Hdr is marketing thing. I also have Samsung hdr tv, that is not hdr at all.. And tonemapped into 8bit hdr videos on it looks much better than ones without tonemapping. I'm not in this market, but suspect that most of tv's selling nowadays are fake hdr. Except Oled etc. Actually it easy to find out that tv either true or fake hdr just looking at brightness level of specs, it would be self explanatory, Edited January 7, 20242 yr by rix81
January 21, 20242 yr Hello everyone I did some more tests now, and most things seem to work pretty good so far. There's one thing that makes watching movies with (not burned in) subtitles a bit a bad experience: Whenever a subtitle is shown, the Image of the video will turn Black and stay black, sound keeps playing normally. This seems to happen every time when a subtitle is shown, so you should be able to reproduce it easily. I found 2 workarounds, but both are not really nice: 1: After the subtitle disappeared, let the movie play for ~15s, then jump back 10s, that will make the image reappear (simple pause-play won't). However, when this is done too often, the stream hangs and the OPI needs a hard reboot (Kodi is no longer responsive), seems the system doesn't like that skipping much. 2: Disable subtitles completely. This is possible but obviously bad for scenes that require them (e.g. native language dialogs etc.). Did anyone experience this aswell, were you able to fix it?
January 28, 20242 yr Hi everyone, I've got an orange pi 5 plus running Kodi that is almost working perfectly, I followed the instructions in this thread and am using the vop.dts overlay @royk posted earlier in this thread, but when fast-fowarding through some videos the screen will completely freeze. it seems to need a hard reboot to change it's display output again--I can't figure out anything (including quitting Kodi entirely) that changes the display output until I reboot. Accessing the system through SSH still works fine though, I don't see any processes with high CPU usage, and even ssh with x forwarding still works fine. I didn't have subtitles on but this sounds very similar to the issue @XXXBold was describing above. The only logs I know how to find are Kodi's logs, but that log didn't update between it working and not working. It only freezes when I fast-forward at 4x or faster, but freezes almost every time I try to fast-forward that fast. As far as I can tell, it only freezes when fast-forwarding through a video encoded with HEVC, but is totally fine fast-forwarding through an AV1 encoded video. Does anyone have advice on what logs to look for to try to fix an issue like this? I don't even know where to start on this one. Thanks so much!
January 29, 20242 yr The posts sound promising. I've got an old Zidoo Media player z9s which is on Android 6. Sometimes it stutters with the 2160p x265 . I'm guessing a OPi 3B would be too underpowered to run 2160p so maybe a OPi5b will be perfect if I can support a bluetooth remote, HDR, DTS and ATMOS pass through. Has anyone had success with this kind of setup so far with no issues? Thanks. Edited January 29, 20242 yr by Thewonderer further clarification
February 2, 20242 yr I saw this article regarding RK3588 today from cnx-software I thought this thread would would like to know... Sounds very promising! Add full HWA transcoding pipeline for Rockchip RKMPP HW decoder (MPEG1, MPEG2, MPEG4, H264, HEVC, VP8, VP9, AV1) HW encoder (H264, HEVC) up to 1080p @ 480fps / 4k @ 120fps on RK3588 HW scaler, format conversion, and subtitle burn-in HW HDR-to-SDR tone-mapping (requires OpenCL, RK3588 only) The OpenCL runtime can be downloaded and installed from libmali-valhall-g610-g13p0-x11-wayland-gbm_1.9-1_arm64.deb Support lossless AFBC (Arm frame buffer compression) to save memory bandwidth and improve FPS Support async RGA filter and MPP encoder https://www.cnx-software.com/2024/02/01/jellyfin-rockchip-rk3588-mpp-hardware-acceleration/ https://github.com/jellyfin/jellyfin-ffmpeg/pull/318#commits-pushed-d89df02
February 20, 20242 yr @roykHi, I find just adding quotation marks to rockchip,plane-mask/rockchip,primary-plane/cursor-win-id will fix kodi. No need to toggle primary plane and cursor plane. So this patch should work for rock5b: https://paste.armbian.com/exuhabuzim.diff
March 3, 20242 yr Hi, I have a problem with Kodi on Armbian. When I interrupt (stop, not pause) watching a movie and then start it again, Kodi freezes and I have to do a hard reset. Is there any solution? A thousand thanks
March 5, 20242 yr Mine freeze randomly on pi 5 plus. Let say freeze once a week, but I can still get control with ssh and reboot. I guess this is the best we can get with voluntary support . So would rather thanks all the ones giving us a not so bad working system. The question I would ask is how to diagnose the cause of a kodi freeze? What should be run before the freeze? After the freeze?
May 3, 20242 yr Following initial steps with Armbian_23.8.1_Orangepi5_jammy_legacy_5.10.160_xfce_desktop at sudo apt install ubuntu-desktop kodi receiving The following packages have unmet dependencies: gjs : Depends: libgjs0g (= 1.72.2-0ubuntu2) but 1.72.4-0ubuntu0.22.04.1 is to be installed E: Unable to correct problems, you have held broken packages.
May 3, 20242 yr @VanGeldon Seems like an old image, try one from here: https://imola.armbian.com/dl/orangepi5/archive/ When you choose an image with amazingfated and Wayland like Gnome or KDE you probably only need to install Kodi. By the way when I search the package with apt search, this is the result: libgjs0g/jammy-updates 1.72.2-0ubuntu2 arm64 So or it's corrected or you've got other sources in /etc/apt/sources.list deb http://ports.ubuntu.com/ jammy main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-security main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-security main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse Edited May 3, 20242 yr by royk
May 5, 20242 yr Thanks @royk From the archive link I tried with Armbian_24.2.1_Orangepi5_jammy_legacy_5.10.160_gnome-amazingfated_desktop.img : Hit the same package unmet dependency issue. With Armbian_24.2.4_Orangepi5_jammy_vendor_6.1.43_kde-neon-amazingfated_desktop.img I could follow all steps successfully but just always black screen with DRM prime direct to plane, even h264.
May 5, 20242 yr @VanGeldon You could add the apt sources in my previous post in the 5.10.160 image. With the linux 6.1.43 image I've got Kodi working, but had to change some things, see here You can try if it works with the kernel build from the source of Joshua Riek's repo: https://drive.google.com/drive/folders/17NT-h0FWKA9irXPBUN883xVoPWganMu-?usp=sharing
May 30, 20242 yr EDIT: Have discussed with Werner on Discord, I will need to migrate to armbian for this as Debian does not work with PPAs. I will use release 6.1.x from here: https://dl.armbian.com/orangepi5/archive/Armbian_24.5.1_Orangepi5_jammy_vendor_6.1.43.img.xz No longer need assistance with below. I'm trying to install this on my Orange Pi 5 running standard Orange Pi Debian 12 (bookworm). I'd like my Pi 5 to run both Home Assistant as well as Kodi, so I first used this guide: https://gist.github.com/renatoccosta/c30f0b4216c8caaf1f202b0a0561b5d3 and am now trying to follow the guide in this thread. When I try to add the repos and update, I get the following errors: E: The repository 'https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Is there a way for me to use these repos on my OS (standard Orange Pi release of Debian)? I thought that as I am running Debian bookworm and the guide is for armbian bookworm, then it should work OK? I am also unable to install the ubuntu-desktop repo. Am I out of luck? Or is there a way around this? Edited May 30, 20242 yr by benadamson
May 30, 20242 yr Home assistant can be run from any platform that supports docker. Kodi also has a headless docker container from Linuxserver.io Docker is an incredible tool that allows you to run almost anything from a preconfigured container. Edited May 30, 20242 yr by Michael Robinson
June 1, 20242 yr Hi, I have problem with Kodi in new version Armbian 24.5.1 Noble Gnome. Kodi freeze when I trie to add objects to library. Is there any solutions? Thanks to all
June 9, 20242 yr Hello, can these exact steps be followed in order to have this working on the Orange Pi 5b?
