MediaTek MT7612U driver in current jammy image
Go to solution Solved by royk,
I know this driver should be part of the recent kernel releases (and definitely avail for 5.10) but I am not sure how/why/where this driver would be in the armbian release. I also did install the firmware files but I don't see the module in the /usr/lib/module section. Any suggestions to build or enable this driver?
Thanks
2 hours ago, royk said:
Build the kernel with the MT76x2U driver, it's disabled by default.
Ah thank you - so I started looking into the build. My understanding is that the armbian build generates a new custom image. The tool is quite amazing and straightforward but few questions:
- For any updates, would I need to re-build and re-install a new image?
- Is there a way I could update my current build using a generated image?
  • Solution
You could install the kernel from the debs folder, output/debs/linux-image... Mr Hacker😀
When you update the kernel from the apt repository you will loose the WiFi driver again.
To build only the kernel as in the manual: ./compile.sh BUILD_ONLY=kernel KERNEL_CONFIGURE=yes BOARD=orangepi5 BRANCH=legacy
Thank you!! I rebuilt the whole image - I can't believe how easy the armbian build system is. Couple questions:
1) Any particular reason many modules are completly disabled from kernel?
2) Would it be worth doing a PR to build the MediaTek drivers as modules?
No reason. In this particular case however it might been the influence of the BSP.
Well there is no warranty that it gets accepted, however if it is well documented and enabled across all configurations so people/maintainer have a chance to test I don't see a reason against.
PR was accepted 🙂 so for anyone stumbling on this issue - it should be something of the past
https://github.com/armbian/build/pull/4727
Edited by OttawaHacker
I unfrozed kernel on Armbian Config, then i write uname -r and saw i have 5.10.110-rockchip-rk3588 kernel.
Then i apt-cache show linux-image*rk3588 and checked the newest kernel is linux-6.2.0-rc2-rockchip-rk3588.
But as far as i know linux, i dont know how to update kernel. Can you give me some directions please @Efe Çetin
All you need to do is unfreeze and enable nightly in armbian-config. Enable nightly will run all the apt updates for you. This should update you to
5.10.110-rockchip-rk3588 #trunk.0211 SMP Sat Jan 28 03:01:04 UTC 2023 aarch64 aarch64 aarch64 GNU/Linu
which has a bunch of USB modules enabled
