OttawaHacker Posted January 22, 2023 Posted January 22, 2023 I'm trying to setup LIRC on my OPI5 but I can't find any details on how that would be possible. I checked the kernel configuration and I cannot see any references to LIRC either. The module list has nothing obvious - is this feature completely disabled? Any suggested alternatives? 0 Quote
royk Posted January 24, 2023 Posted January 24, 2023 There is by default a Rockchip IR receiver module installed, but seems only to work with with the remote codes hardcoded in the module, just had a quick test that didn't work: https://forum.odroid.com/viewtopic.php?f=215&t=44671 LIRC would be a better option indeed and you can find it under "Device drivers" --> Remote controller support. When you enable the driver you'll get more options, probably you would need "GPIO IR remote control" and the right decoder for your remote. There should also be made a dtb overlay, here they made it work for the Odroid m1: https://forum.odroid.com/viewtopic.php?p=350183#p350183 0 Quote
OttawaHacker Posted January 24, 2023 Author Posted January 24, 2023 I'm going to try this python project instead https://pypi.org/project/PiIR/ and see if I can re-use my LIRC configuration somehow. I really can't figure out why LIRC and all these IR systems are so complex and require a kernel module... Sending the IR stuff is just sending pulses on a LED - should only just require GPIO permissions. The IR option doesn't seem to be available yet on the Orange Pi 5 images - somehow that hardware menu is not in the armbian-config yet. 0 Quote
royk Posted January 24, 2023 Posted January 24, 2023 (edited) True I can't understand that either, would think that installing LIRC and pointing it to the the right gpio pin should be enough. Perhaps because of the way it is built-in. Nice project, would like to know if you could make it work. I think I'll look into the LIRC option next weekend. I'm using the Armbian image with opi5 config and the options are really there, but you could easily read over it. I thought Device drivers is one of the latest options and then somewhere in the middle Remote controller support. It could be that it's because I'd enabled some media support options for my dvb tuner Edit: sorry I misread your comment, I thought you ment the options of the kernel config . Edited January 24, 2023 by royk 0 Quote
OttawaHacker Posted January 24, 2023 Author Posted January 24, 2023 On 1/24/2023 at 1:45 AM, royk said: I'm using the Armbian image with opi5 config and the options are really there, but you could easily read over it. I thought Device drivers is one of the latest options and then somewhere in the middle Remote controller support. It could be that it's because I'd enabled some media support options for my dvb tuner Expand I did build my own image and there are definitely some odd differences... like the boot partition on my custom image is fat vs on the official image it is ext4. Wouldn't be surprised that this is the cause 0 Quote
Werner Posted January 24, 2023 Posted January 24, 2023 On 1/24/2023 at 2:44 AM, OttawaHacker said: like the boot partition on my custom image is fat vs on the official image it is ext4. Expand Not sure but I think there were some very recent changes about this pushed to master (?). Maybe check against trunk images? (https://github.com/armbian/build/releases/download/23.02.0-trunk.0191/Armbian_23.02.0-trunk.0191_Orangepi5_jammy_legacy_5.10.110_minimal.img.xz) Regardless, all pre-built downloadable images from Armbian are built using the same build script as it is available on Github. Just with a bunch of - partially undocumented - switches that allow better automation and build distribution in that matter. 0 Quote
Efe Çetin Posted January 24, 2023 Posted January 24, 2023 Hardware menu is not exists due to linuxfamily property. Today i'll make a pr to fix it. 1 Quote
royk Posted February 6, 2023 Posted February 6, 2023 (edited) These I found somewhere a long time ago which did work for the rk3288. It's using the WiringPi library so it should work on this board too scanir.cFetching info... sendir.cFetching info... Edited February 6, 2023 by royk 0 Quote
