mcerveny Posted January 27, 2023 Posted January 27, 2023 (edited) Hello. I see some progress in H616 (OPIZ2) support in mainline linux (now 6.2RC5 comes with USB) - https://linux-sunxi.org/Linux_mainlining_effort . I tried to setup/enable some other components and I am successful with upstream linux kernel 6.2RC5: - displayengine (drm, fb, mixer, tcon, hdmi) (seems to have some I2C/EDID problems) - videoengine (cedrus) (in testing now) - gpu (3d mali, panfrost) - dma, efuse, thermal ... but I am unsuccessful with - crypto (total different behavior in contrast to H616 manual) and untested - audio codecs and hdmi audio - opp power management (frequency + voltage) for CPU and GPU - SDIO wifi I was also successful with uBoot (some patches from upstream uBoot) to boot sdcard-less from SPI flash and then from network PXE+NFS. Does anyone do some work in this direction ? Edited January 27, 2023 by mcerveny add url 1 Quote
ALIGMSTEN Posted January 27, 2023 Posted January 27, 2023 (edited) Nice, looks like you standing up on Orangepi there? 9 hours ago, mcerveny said: Does anyone do some work in this direction ? Interesting, I've been working low down your list, testing cpu-frequency-scaling for a while, which I think now will submit PR to 5.19 for others to try. The patch addresses all variants, but is not optimized, limited to 1512 Mhz, still WIP is the frequency calc's and micro-volt testing. All that you list has been in progress for a while, but has not seen the light here for lack of someone knowledgeable having time or perhaps interest, and that it seems there are still issues to be worked out in some parts. @going is doing an incredible job at maintaining sunxi here for us to develop off. Edited January 28, 2023 by ALIGMSTEN Forgot to say!! 0 Quote
mcerveny Posted January 28, 2023 Author Posted January 28, 2023 Thanks. I cannot find your work under H616 and Allwinner is too generic. Can you navigate me to the right patch (maybe WIP repo outside patch queue) ? h616 patchwork allwinner patchwork 0 Quote
going Posted January 29, 2023 Posted January 29, 2023 27.01.2023 в 23:03, mcerveny сказал: crypto (total different behavior in contrast to H616 manual) Unfortunately, this is not the only discrepancy. 27.01.2023 в 23:03, mcerveny сказал: Does anyone do some work in this direction ? I'm doing a little work, but it's about supporting a series of patches. Which are applied using the function lib/functions/compilation/patch/patching.sh. The day after the origin/linux-6.1.y branch appeared in linux-stable.git I extract from this repository branch origin/orange-pi-6.1 all the commits that were applied from above. And it becomes a series of megous patches. A series of armbian patches are those patches that one of the users once suggested for use. I am not able to check all of them and the correctness of their work after applying them. All I do is monitor their correct application when moving the kernel code upstream. And I fix compilation errors if they occur. @Igor also makes a huge contribution to this process. We hope for your contribution to the development. 1 Quote
ALIGMSTEN Posted January 29, 2023 Posted January 29, 2023 On 1/28/2023 at 9:42 AM, mcerveny said: Can you navigate me Hi nope, fun in spare time approach here, arm64-dts-allwinner-h616-Add-efuse_xlate-cpufreq.patch. Will submit pr to armbian 5.19.17 this week, if @going and @mcerveny can please review. 0 Quote
mcerveny Posted January 29, 2023 Author Posted January 29, 2023 (edited) So the question, the armbian patches are well aligned with the new kernel, why are they not pushed to mainline ? Do you also have a terrible experience with linux mainlining process ? Edited January 29, 2023 by mcerveny 0 Quote
ALIGMSTEN Posted January 29, 2023 Posted January 29, 2023 If you addressing me and above patch @mcerveny I'm happy to play here, its not serious. I cant speak for mainline process. In similar vein could quite happily carry on and not 'contribute' getting the 'stuffs' I need working and abuse. However I am completely against that type of behavior, and why I choose to donate and contribute. 0 Quote
mcerveny Posted January 30, 2023 Author Posted January 30, 2023 On 1/29/2023 at 4:08 PM, ALIGMSTEN said: Hi nope, fun in spare time approach here, arm64-dts-allwinner-h616-Add-efuse_xlate-cpufreq.patch. I tested with kernel 6.2RC4 (some driver code change needed), notes: do not increase GPU voltage reg_dcdcc: dcdcc { regulator-always-on; regulator-min-microvolt = <810000>; - regulator-max-microvolt = <1080000>; + regulator-max-microvolt = <1100000>; regulator-name = "vdd-gpu-sys"; }; absolute maximum (from H616_Datasheet_V1.0_cleaned.pdf): recommended (from H616_Datasheet_V1.0_cleaned.pdf): my sun50i-h616-orangepi-zero2.dts: reg_dcdcc: dcdcc { regulator-always-on; regulator-min-microvolt = <810000>; regulator-max-microvolt = <990000>; regulator-name = "vdd-gpu-sys"; }; I also reworked temperature - cooling my sun50i-h616.dtsi: cpu_thermal: cpu-thermal { polling-delay-passive = <500>; polling-delay = <1000>; thermal-sensors = <&ths 2>; trips { cpu_target: cpu-target { temperature = <75000>; hysteresis = <2000>; type = "passive"; }; critical { temperature = <105000>; hysteresis = <2000>; type = "critical"; }; }; cooling-maps { map0 { trip = <&cpu_target>; cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; my sun50i-h616-orangepi-zero2.dts: &cpu_thermal { /delete-node/ trips; // beaware, all points must have different names otherwise dts compiller does not hold position and driver stuck in differnt trip point trips { cpu_warm: cpu_warm { temperature = <75000>; hysteresis = <2000>; type = "passive"; }; cpu_hot_pre: cpu_hot_pre { temperature = <80000>; hysteresis = <2000>; type = "passive"; }; cpu_hot: cpu_hot { temperature = <85000>; hysteresis = <2000>; type = "passive"; }; cpu_very_hot: cpu_very_hot { temperature = <90000>; hysteresis = <2000>; type = "passive"; }; cpu_critical { temperature = <105000>; hysteresis = <2000>; type = "critical"; }; }; /delete-node/ cooling-maps; cooling-maps { cpu_warm_limit_cpu { trip = <&cpu_warm>; cooling-device = <&cpu0 THERMAL_NO_LIMIT 2>; }; cpu_hot_pre_limit_cpu { trip = <&cpu_hot_pre>; cooling-device = <&cpu0 3 3>; }; cpu_hot_limit_cpu { trip = <&cpu_hot>; cooling-device = <&cpu0 4 4>; }; cpu_very_hot_limit_cpu { trip = <&cpu_very_hot>; cooling-device = <&cpu0 5 THERMAL_NO_LIMIT>; }; }; }; my testing 0 - idle 10 - run "stress --cpu 4" 36 - additional external heating 134 - remove heating 304 - stop "stress --cpu 4" 1 Quote
ALIGMSTEN Posted January 30, 2023 Posted January 30, 2023 Thank you @mcerveny, refreshing to have such constructive input. Was aware that gpu was at max, I should have changed that back. To clarify how are you compiling, xunlong? 0 Quote
going Posted January 30, 2023 Posted January 30, 2023 23 часа назад, mcerveny сказал: So the question, the armbian patches are well aligned with the new kernel, why are they not pushed to mainline ? That's not so. Some patches are outdated and do not work in the 6.1 kernel. sunxi-6.1/series.conf the bad ones are off Some patches are applied and work, but these changes in the 6.1 kernel are useless. I only discovered this today. Most of the armbian patches were taken from those that were proposed for kernel.org . Those patches that were accepted are gone from this list. 0 Quote
mcerveny Posted January 30, 2023 Author Posted January 30, 2023 On 1/29/2023 at 4:08 PM, ALIGMSTEN said: Hi nope, fun in spare time approach here, arm64-dts-allwinner-h616-Add-efuse_xlate-cpufreq.patch. This code does not seem to be right: #define SUN50I_H616_NVMEM_MASK 0x22 #define SUN50I_H616_NVMEM_SHIFT 5 ... u32 efuse_value = (*(u32 *)efuse >> SUN50I_H616_NVMEM_SHIFT) & SUN50I_H616_NVMEM_MASK; ... if (efuse_value >=1 && efuse_value <= 3) Are you sure about MASK ? Or it is bitmask that should be translated like A100 -> https://www.lkml.org/lkml/2020/12/8/70 0 Quote
ALIGMSTEN Posted January 31, 2023 Posted January 31, 2023 The pointer is correct and what got me through the traps before differentiating with xlate, I am uncertain about the exact shift. What do you suggest? 0 Quote
mcerveny Posted February 2, 2023 Author Posted February 2, 2023 (edited) On 1/27/2023 at 9:03 PM, mcerveny said: - displayengine (drm, fb, mixer, tcon, hdmi) (seems to have some I2C/EDID problems) - videoengine (cedrus) (in testing now) I successfully tested videoengine (tested 2k,4k,hevc,h264 and 4k hdr hevc (with non hdr output)). I found the problem in VI (video) layer in DRM (displayengine) output. I must change at least once after poweron DRM property "COLOR_RANGE" to DRM_COLOR_YCBCR_FULL_RANGE to get correctly setup CSC (color space conversion) in hw 🤨, lost 3 days in kernel debug. Edited February 2, 2023 by mcerveny 0 Quote
ALIGMSTEN Posted February 9, 2023 Posted February 9, 2023 On 2/2/2023 at 11:42 PM, mcerveny said: n hw 🤨, lost 3 days in kernel debug Very interesting, thanks for your work. Personally still making changes during my testing atm, better understanding uboot registers, static const struct sunxi_cpufreq_soc_data sun50i_h616_data.. . etc... I see 10 Members have downloaded , Add-h616-efuse_xlate-cpu-freq-scaling - any other feedback? Here as is sbc-bench output ( no extended thermal and gpu-sys set as manual recommends) Spoiler alistair@orangepizero2:~$ sudo /bin/bash ./sbc-bench.sh -c [sudo] password for alistair: Average load and/or CPU utilization too high (too much background activity). Waiting... Too busy for benchmarking: 12:02:09 up 19 min, 0 users, load average: 0.13, 0.16, 0.17, cpu: 7% Too busy for benchmarking: 12:02:14 up 19 min, 0 users, load average: 0.12, 0.16, 0.17, cpu: 0% Too busy for benchmarking: 12:02:19 up 19 min, 0 users, load average: 0.11, 0.15, 0.17, cpu: 0% Too busy for benchmarking: 12:02:24 up 20 min, 0 users, load average: 0.10, 0.15, 0.17, cpu: 0% Too busy for benchmarking: 12:02:29 up 20 min, 0 users, load average: 0.09, 0.15, 0.17, cpu: 0% Status of performance related governors/policies found below /sys: cpufreq-policy0: performance / 1512 MHz (conservative ondemand userspace powersave performance schedutil) sbc-bench v0.9.13 Installing needed tools: apt -f -qq -y install dmidecode lshw mbw, tinymembench., ramlat, mhz, cpuminer. Done. Checking cpufreq OPP. Done (results will be available in 20-30 minutes). Executing tinymembench. Done. Executing RAM latency tester. Done. Executing OpenSSL benchmark. Done. Executing 7-zip benchmark..../sbc-bench.sh: line 3003: 11120 Killed "${SevenZip}" b ${DictSize} -mmt=${CPUCores} >> ${TempLog} Done. Executing cpuminer. 5 more minutes to wait. Done. Checking cpufreq OPP again. Done (29 minutes elapsed). ATTENTION: Throttling might have occured. Check the log for details. Memory performance memcpy: 1664.7 MB/s memset: 5294.1 MB/s Cpuminer total scores (5 minutes execution): 3.94,3.72,3.71,3.70,3.69,3.68 kH/s 7-zip total scores (3 consecutive runs): 2715,2723, single-threaded: 1085 OpenSSL results: type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 98069.94k 312232.98k 667921.24k 974638.42k 1124769.79k 1136678.23k aes-128-cbc 98187.41k 312142.08k 667988.74k 974738.43k 1124734.29k 1137016.83k aes-192-cbc 94054.75k 283486.10k 557781.33k 759236.61k 848199.68k 855009.96k aes-192-cbc 94047.96k 283296.06k 557753.43k 759076.86k 848158.72k 854944.43k aes-256-cbc 91867.29k 264464.04k 489722.20k 638698.84k 700489.73k 704856.06k aes-256-cbc 91867.89k 264689.41k 489831.25k 638774.95k 700609.88k 705232.90k Full results uploaded to http://ix.io/4nxo. Please check the log for anomalies (e.g. swapping or throttling happenend). sbc-bench v0.9.13 OrangePi Zero2 (Thu, 09 Feb 2023 12:08:08 +0200) Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye Armbian info: Orange Pi Zero2, sun50iw9, sunxi64, 23.02.0-trunk, https://github.com/AGM1968/build /usr/bin/gcc (Debian 10.2.1-6) 10.2.1 20210110 Uptime: 12:08:09 up 25 min, 0 users, load average: 1.19, 0.91, 0.52, 50.3°C, 330893796 Linux 5.19.17-sunxi64 (orangepizero2) 02/09/23 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 9.25 0.01 2.31 0.70 0.00 87.72 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 9.99 276.05 276.53 0.00 427622 428364 0 mtdblock0 0.02 0.07 0.00 0.00 112 0 0 zram0 0.54 1.55 0.61 0.00 2396 948 0 zram1 0.28 0.32 3.28 0.00 488 5084 0 total used free shared buff/cache available Mem: 984Mi 276Mi 586Mi 12Mi 121Mi 627Mi Swap: 492Mi 1.0Mi 490Mi Filename Type Size Used Priority /dev/zram0 partition 503972 1280 5 ########################################################################## Checking cpufreq OPP (Cortex-A53): Cpufreq OPP: 1512 Measured: 1510 (1510.763/1510.694/1510.556) Cpufreq OPP: 1200 Measured: 1198 (1198.722/1198.559/1198.504) Cpufreq OPP: 1008 Measured: 1006 (1006.661/1006.637/1006.590) Cpufreq OPP: 792 Measured: 790 (790.694/790.583/790.546) Cpufreq OPP: 600 Measured: 598 (598.660/598.660/598.634) Cpufreq OPP: 480 Measured: 478 (478.697/478.581/478.570) ########################################################################## Hardware sensors: cpu_thermal-virtual-0 temp1: +51.3 C gpu_thermal-virtual-0 temp1: +50.7 C ddr_thermal-virtual-0 temp1: +52.4 C ve_thermal-virtual-0 temp1: +51.5 C ########################################################################## Executing benchmark on cpu0 (Cortex-A53): tinymembench v0.4.9 (simple benchmark for memory throughput and latency) ========================================================================== == Memory bandwidth tests == == == == Note 1: 1MB = 1000000 bytes == == Note 2: Results for 'copy' tests show how many bytes can be == == copied per second (adding together read and writen == == bytes would have provided twice higher numbers) == == Note 3: 2-pass copy means that we are using a small temporary buffer == == to first fetch data into it, and only then write it to the == == destination (source -> L1 cache, L1 cache -> destination) == == Note 4: If sample standard deviation exceeds 0.1%, it is shown in == == brackets == ========================================================================== C copy backwards : 1652.7 MB/s (8.5%) C copy backwards (32 byte blocks) : 1655.1 MB/s (3.7%) C copy backwards (64 byte blocks) : 1672.5 MB/s (4.3%) C copy : 1555.9 MB/s (1.2%) C copy prefetched (32 bytes step) : 1159.5 MB/s (3.5%) C copy prefetched (64 bytes step) : 1159.2 MB/s (1.0%) C 2-pass copy : 1342.8 MB/s (6.3%) C 2-pass copy prefetched (32 bytes step) : 967.3 MB/s (4.6%) C 2-pass copy prefetched (64 bytes step) : 830.9 MB/s (0.8%) C fill : 5431.6 MB/s (1.1%) C fill (shuffle within 16 byte blocks) : 5413.6 MB/s (1.5%) C fill (shuffle within 32 byte blocks) : 5434.6 MB/s (1.3%) C fill (shuffle within 64 byte blocks) : 5425.0 MB/s (1.0%) --- standard memcpy : 1664.7 MB/s (1.7%) standard memset : 5294.1 MB/s --- NEON LDP/STP copy : 1543.6 MB/s NEON LDP/STP copy pldl2strm (32 bytes step) : 977.1 MB/s (1.0%) NEON LDP/STP copy pldl2strm (64 bytes step) : 1254.0 MB/s (0.9%) NEON LDP/STP copy pldl1keep (32 bytes step) : 1634.6 MB/s (0.1%) NEON LDP/STP copy pldl1keep (64 bytes step) : 1648.5 MB/s NEON LD1/ST1 copy : 1527.8 MB/s (0.5%) NEON STP fill : 5298.8 MB/s NEON STNP fill : 4328.3 MB/s (0.5%) ARM LDP/STP copy : 1538.4 MB/s (1.2%) ARM STP fill : 5304.1 MB/s ARM STNP fill : 4314.1 MB/s (0.7%) ========================================================================== == Memory latency test == == == == Average time is measured for random memory accesses in the buffers == == of different sizes. The larger is the buffer, the more significant == == are relative contributions of TLB, L1/L2 cache misses and SDRAM == == accesses. For extremely large buffer sizes we are expecting to see == == page table walk with several requests to SDRAM for almost every == == memory access (though 64MiB is not nearly large enough to experience == == this effect to its fullest). == == == == Note 1: All the numbers are representing extra time, which needs to == == be added to L1 cache latency. The cycle timings for L1 cache == == latency can be usually found in the processor documentation. == == Note 2: Dual random read means that we are simultaneously performing == == two independent memory accesses at a time. In the case if == == the memory subsystem can't handle multiple outstanding == == requests, dual random read has the same timings as two == == single reads performed one after another. == ========================================================================== block size : single random read / dual random read, [MADV_NOHUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.0 ns / 0.0 ns 65536 : 4.3 ns / 7.2 ns 131072 : 6.6 ns / 10.4 ns 262144 : 8.1 ns / 12.3 ns 524288 : 79.0 ns / 123.2 ns 1048576 : 121.2 ns / 162.5 ns 2097152 : 143.1 ns / 175.5 ns 4194304 : 159.3 ns / 186.1 ns 8388608 : 168.2 ns / 192.2 ns 16777216 : 173.5 ns / 197.2 ns 33554432 : 177.7 ns / 201.2 ns 67108864 : 190.5 ns / 225.2 ns block size : single random read / dual random read, [MADV_HUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.0 ns / 0.0 ns 65536 : 4.3 ns / 7.4 ns 131072 : 6.6 ns / 10.4 ns 262144 : 8.1 ns / 12.3 ns 524288 : 78.9 ns / 123.2 ns 1048576 : 121.1 ns / 162.4 ns 2097152 : 142.3 ns / 174.7 ns 4194304 : 153.4 ns / 178.9 ns 8388608 : 158.9 ns / 180.5 ns 16777216 : 161.5 ns / 181.2 ns 33554432 : 162.8 ns / 181.4 ns 67108864 : 163.5 ns / 181.6 ns ########################################################################## Executing ramlat on cpu0 (Cortex-A53), results in ns: size: 1x32 2x32 1x64 2x64 1xPTR 2xPTR 4xPTR 8xPTR 4k: 2.654 2.650 1.986 1.986 1.987 1.986 2.734 5.545 8k: 2.648 2.650 1.986 1.989 1.986 1.986 2.734 5.559 16k: 2.651 2.651 1.997 1.997 1.993 1.990 2.733 5.549 32k: 5.720 7.517 5.350 7.101 5.347 7.240 10.72 19.30 64k: 15.69 17.49 15.14 17.02 15.13 17.07 22.86 43.76 128k: 19.49 20.30 19.14 19.90 19.98 20.01 25.73 50.78 256k: 44.95 56.59 42.81 55.29 43.24 55.33 87.50 164.0 512k: 150.2 162.1 149.0 152.0 149.9 152.3 222.7 444.4 1024k: 168.9 168.7 168.1 166.0 166.1 166.0 229.9 458.5 2048k: 169.3 169.3 169.1 167.3 167.5 167.0 230.0 460.2 4096k: 175.3 176.1 175.4 178.5 175.6 176.0 239.1 483.3 8192k: 177.3 180.4 177.1 182.1 177.3 179.7 245.3 493.8 16384k: 179.6 182.5 178.6 184.0 178.6 182.0 247.2 497.3 ########################################################################## Executing benchmark twice on cluster 0 (Cortex-A53) OpenSSL 1.1.1n, built on 15 Mar 2022 type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 98069.94k 312232.98k 667921.24k 974638.42k 1124769.79k 1136678.23k aes-128-cbc 98187.41k 312142.08k 667988.74k 974738.43k 1124734.29k 1137016.83k aes-192-cbc 94054.75k 283486.10k 557781.33k 759236.61k 848199.68k 855009.96k aes-192-cbc 94047.96k 283296.06k 557753.43k 759076.86k 848158.72k 854944.43k aes-256-cbc 91867.29k 264464.04k 489722.20k 638698.84k 700489.73k 704856.06k aes-256-cbc 91867.89k 264689.41k 489831.25k 638774.95k 700609.88k 705232.90k ########################################################################## Executing benchmark single-threaded on cpu0 (Cortex-A53) 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 - - - - - - - - RAM size: 984 MB, # CPU hardware threads: 4 RAM usage: 435 MB, # Benchmark threads: 1 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 829 100 808 807 | 16347 100 1396 1396 23: 774 100 790 789 | 16000 100 1385 1385 24: 727 100 782 782 | 15644 100 1374 1373 25: 689 100 787 787 | 15237 100 1357 1356 ---------------------------------- | ------------------------------ Avr: 100 792 791 | 100 1378 1378 Tot: 100 1085 1085 ########################################################################## Executing benchmark 3 times multi-threaded on CPUs 0-3 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 64000000 64000000 - - - 512000000 - - RAM size: 984 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 1823 320 555 1774 | 44853 397 963 3827 23: 1850 333 566 1885 | 42321 398 919 3662 24: 1792 344 561 1927 | 42512 398 938 3732 25: 1081 289 427 1234 | 41328 398 925 3678 ---------------------------------- | ------------------------------ Avr: 321 527 1705 | 398 936 3725 Tot: 360 732 2715 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 - - - - - - - - RAM size: 984 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 1800 319 548 1751 | 44063 397 946 3759 23: 1783 330 550 1817 | 42117 397 918 3644 24: 1720 339 545 1850 | 42440 397 938 3726 25: 1352 312 495 1545 | 41444 398 926 3688 ---------------------------------- | ------------------------------ Avr: 325 535 1741 | 397 932 3704 Tot: 361 733 2723 Compression: 1705,1741 Decompression: 3725,3704 Total: 2715,2723 ########################################################################## ** cpuminer-multi 1.3.7 by tpruvot@github ** BTC donation address: 1FhDPLPpw18X4srecguG3MxJYe4a1JsZnd (tpruvot) [2023-02-09 12:31:49] 4 miner threads started, using 'scrypt' algorithm. [2023-02-09 12:31:50] CPU #2: 1.16 kH/s [2023-02-09 12:31:50] CPU #3: 1.13 kH/s [2023-02-09 12:31:50] CPU #0: 1.11 kH/s [2023-02-09 12:31:50] CPU #1: 1.08 kH/s [2023-02-09 12:31:54] Total: 3.94 kH/s [2023-02-09 12:31:59] CPU #2: 0.93 kH/s [2023-02-09 12:31:59] CPU #1: 0.93 kH/s [2023-02-09 12:31:59] CPU #0: 0.93 kH/s [2023-02-09 12:31:59] CPU #3: 0.92 kH/s [2023-02-09 12:31:59] Total: 3.71 kH/s [2023-02-09 12:32:05] CPU #3: 0.92 kH/s [2023-02-09 12:32:05] Total: 3.70 kH/s [2023-02-09 12:32:08] Total: 3.71 kH/s [2023-02-09 12:32:09] CPU #2: 0.93 kH/s [2023-02-09 12:32:09] CPU #1: 0.93 kH/s [2023-02-09 12:32:09] CPU #0: 0.92 kH/s [2023-02-09 12:32:09] Total: 3.72 kH/s [2023-02-09 12:32:14] CPU #3: 0.93 kH/s [2023-02-09 12:32:14] Total: 3.71 kH/s [2023-02-09 12:32:19] CPU #2: 0.93 kH/s [2023-02-09 12:32:19] CPU #1: 0.93 kH/s [2023-02-09 12:32:19] CPU #0: 0.93 kH/s [2023-02-09 12:32:19] Total: 3.72 kH/s [2023-02-09 12:32:24] CPU #3: 0.93 kH/s [2023-02-09 12:32:24] Total: 3.72 kH/s [2023-02-09 12:32:29] CPU #2: 0.93 kH/s [2023-02-09 12:32:29] CPU #1: 0.93 kH/s [2023-02-09 12:32:29] CPU #0: 0.93 kH/s [2023-02-09 12:32:29] Total: 3.72 kH/s [2023-02-09 12:32:34] CPU #3: 0.93 kH/s [2023-02-09 12:32:34] Total: 3.72 kH/s [2023-02-09 12:32:39] CPU #2: 0.93 kH/s [2023-02-09 12:32:39] CPU #1: 0.92 kH/s [2023-02-09 12:32:39] CPU #0: 0.92 kH/s [2023-02-09 12:32:40] CPU #3: 0.92 kH/s [2023-02-09 12:32:40] Total: 3.69 kH/s [2023-02-09 12:32:44] Total: 3.70 kH/s [2023-02-09 12:32:48] CPU #3: 0.93 kH/s [2023-02-09 12:32:48] Total: 3.71 kH/s [2023-02-09 12:32:49] CPU #2: 0.93 kH/s [2023-02-09 12:32:49] CPU #1: 0.93 kH/s [2023-02-09 12:32:49] CPU #0: 0.93 kH/s [2023-02-09 12:32:49] Total: 3.72 kH/s [2023-02-09 12:32:55] CPU #3: 0.92 kH/s [2023-02-09 12:32:55] Total: 3.70 kH/s [2023-02-09 12:32:58] Total: 3.70 kH/s [2023-02-09 12:32:59] CPU #2: 0.93 kH/s [2023-02-09 12:32:59] CPU #1: 0.93 kH/s [2023-02-09 12:32:59] CPU #0: 0.93 kH/s [2023-02-09 12:32:59] Total: 3.72 kH/s [2023-02-09 12:33:04] CPU #3: 0.93 kH/s [2023-02-09 12:33:04] Total: 3.72 kH/s [2023-02-09 12:33:09] CPU #2: 0.93 kH/s [2023-02-09 12:33:09] CPU #1: 0.93 kH/s [2023-02-09 12:33:09] CPU #0: 0.93 kH/s [2023-02-09 12:33:09] Total: 3.72 kH/s [2023-02-09 12:33:14] CPU #3: 0.93 kH/s [2023-02-09 12:33:14] Total: 3.72 kH/s [2023-02-09 12:33:19] CPU #2: 0.94 kH/s [2023-02-09 12:33:19] CPU #1: 0.93 kH/s [2023-02-09 12:33:19] CPU #0: 0.93 kH/s [2023-02-09 12:33:19] Total: 3.72 kH/s [2023-02-09 12:33:25] CPU #3: 0.92 kH/s [2023-02-09 12:33:25] Total: 3.70 kH/s [2023-02-09 12:33:28] Total: 3.70 kH/s [2023-02-09 12:33:29] CPU #2: 0.93 kH/s [2023-02-09 12:33:29] CPU #1: 0.93 kH/s [2023-02-09 12:33:29] CPU #0: 0.93 kH/s [2023-02-09 12:33:29] Total: 3.71 kH/s [2023-02-09 12:33:34] CPU #3: 0.93 kH/s [2023-02-09 12:33:34] Total: 3.72 kH/s [2023-02-09 12:33:39] CPU #2: 0.93 kH/s [2023-02-09 12:33:39] CPU #1: 0.92 kH/s [2023-02-09 12:33:39] CPU #0: 0.93 kH/s [2023-02-09 12:33:40] CPU #3: 0.92 kH/s [2023-02-09 12:33:40] Total: 3.70 kH/s [2023-02-09 12:33:44] Total: 3.71 kH/s [2023-02-09 12:33:49] CPU #2: 0.94 kH/s [2023-02-09 12:33:49] CPU #3: 0.93 kH/s [2023-02-09 12:33:49] Total: 3.72 kH/s [2023-02-09 12:33:49] CPU #1: 0.93 kH/s [2023-02-09 12:33:49] CPU #0: 0.93 kH/s [2023-02-09 12:33:54] Total: 3.72 kH/s [2023-02-09 12:33:58] CPU #2: 0.94 kH/s [2023-02-09 12:33:59] CPU #3: 0.93 kH/s [2023-02-09 12:33:59] Total: 3.72 kH/s [2023-02-09 12:33:59] CPU #1: 0.93 kH/s [2023-02-09 12:33:59] CPU #0: 0.93 kH/s [2023-02-09 12:34:04] Total: 3.72 kH/s [2023-02-09 12:34:04] CPU #2: 0.94 kH/s [2023-02-09 12:34:09] CPU #3: 0.92 kH/s [2023-02-09 12:34:09] Total: 3.72 kH/s [2023-02-09 12:34:09] CPU #1: 0.92 kH/s [2023-02-09 12:34:09] CPU #0: 0.92 kH/s [2023-02-09 12:34:10] CPU #2: 0.93 kH/s [2023-02-09 12:34:14] Total: 3.70 kH/s [2023-02-09 12:34:18] CPU #2: 0.94 kH/s [2023-02-09 12:34:19] CPU #3: 0.93 kH/s [2023-02-09 12:34:19] Total: 3.71 kH/s [2023-02-09 12:34:19] CPU #1: 0.93 kH/s [2023-02-09 12:34:19] CPU #0: 0.93 kH/s [2023-02-09 12:34:23] Total: 3.72 kH/s [2023-02-09 12:34:24] CPU #2: 0.94 kH/s [2023-02-09 12:34:24] Total: 3.72 kH/s [2023-02-09 12:34:29] CPU #1: 0.93 kH/s [2023-02-09 12:34:29] CPU #0: 0.93 kH/s [2023-02-09 12:34:29] CPU #3: 0.93 kH/s [2023-02-09 12:34:29] Total: 3.72 kH/s [2023-02-09 12:34:34] CPU #2: 0.94 kH/s [2023-02-09 12:34:34] Total: 3.72 kH/s [2023-02-09 12:34:39] CPU #1: 0.93 kH/s [2023-02-09 12:34:39] CPU #0: 0.93 kH/s [2023-02-09 12:34:39] CPU #3: 0.93 kH/s [2023-02-09 12:34:39] Total: 3.72 kH/s [2023-02-09 12:34:44] CPU #2: 0.94 kH/s [2023-02-09 12:34:44] Total: 3.72 kH/s [2023-02-09 12:34:49] CPU #1: 0.93 kH/s [2023-02-09 12:34:49] CPU #0: 0.93 kH/s [2023-02-09 12:34:49] CPU #3: 0.93 kH/s [2023-02-09 12:34:49] Total: 3.72 kH/s [2023-02-09 12:34:54] CPU #2: 0.93 kH/s [2023-02-09 12:34:55] CPU #3: 0.92 kH/s [2023-02-09 12:34:55] Total: 3.70 kH/s [2023-02-09 12:34:59] Total: 3.70 kH/s [2023-02-09 12:34:59] CPU #1: 0.92 kH/s [2023-02-09 12:34:59] CPU #0: 0.92 kH/s [2023-02-09 12:35:00] CPU #2: 0.93 kH/s [2023-02-09 12:35:04] CPU #3: 0.92 kH/s [2023-02-09 12:35:04] Total: 3.70 kH/s [2023-02-09 12:35:08] Total: 3.71 kH/s [2023-02-09 12:35:09] CPU #1: 0.93 kH/s [2023-02-09 12:35:09] CPU #0: 0.93 kH/s [2023-02-09 12:35:09] Total: 3.72 kH/s [2023-02-09 12:35:09] CPU #2: 0.94 kH/s [2023-02-09 12:35:14] CPU #3: 0.93 kH/s [2023-02-09 12:35:14] Total: 3.72 kH/s [2023-02-09 12:35:19] CPU #1: 0.93 kH/s [2023-02-09 12:35:19] CPU #0: 0.93 kH/s [2023-02-09 12:35:19] CPU #2: 0.94 kH/s [2023-02-09 12:35:19] Total: 3.72 kH/s [2023-02-09 12:35:24] CPU #3: 0.93 kH/s [2023-02-09 12:35:24] Total: 3.72 kH/s [2023-02-09 12:35:29] CPU #1: 0.93 kH/s [2023-02-09 12:35:29] CPU #0: 0.93 kH/s [2023-02-09 12:35:29] CPU #2: 0.94 kH/s [2023-02-09 12:35:29] Total: 3.72 kH/s [2023-02-09 12:35:34] CPU #3: 0.93 kH/s [2023-02-09 12:35:34] Total: 3.72 kH/s [2023-02-09 12:35:39] CPU #1: 0.92 kH/s [2023-02-09 12:35:39] CPU #0: 0.92 kH/s [2023-02-09 12:35:40] CPU #2: 0.93 kH/s [2023-02-09 12:35:40] CPU #3: 0.92 kH/s [2023-02-09 12:35:40] Total: 3.70 kH/s [2023-02-09 12:35:44] Total: 3.70 kH/s [2023-02-09 12:35:48] CPU #2: 0.94 kH/s [2023-02-09 12:35:48] CPU #3: 0.93 kH/s [2023-02-09 12:35:48] Total: 3.71 kH/s [2023-02-09 12:35:49] CPU #1: 0.93 kH/s [2023-02-09 12:35:49] CPU #0: 0.93 kH/s [2023-02-09 12:35:49] Total: 3.72 kH/s [2023-02-09 12:35:54] CPU #2: 0.94 kH/s [2023-02-09 12:35:54] CPU #3: 0.93 kH/s [2023-02-09 12:35:54] Total: 3.72 kH/s [2023-02-09 12:35:59] CPU #1: 0.93 kH/s [2023-02-09 12:35:59] CPU #0: 0.93 kH/s [2023-02-09 12:35:59] Total: 3.72 kH/s [2023-02-09 12:36:04] CPU #3: 0.93 kH/s [2023-02-09 12:36:04] Total: 3.72 kH/s [2023-02-09 12:36:04] CPU #2: 0.94 kH/s [2023-02-09 12:36:09] CPU #1: 0.92 kH/s [2023-02-09 12:36:09] CPU #0: 0.91 kH/s [2023-02-09 12:36:10] CPU #3: 0.91 kH/s [2023-02-09 12:36:10] Total: 3.68 kH/s [2023-02-09 12:36:13] Total: 3.69 kH/s [2023-02-09 12:36:14] CPU #2: 0.94 kH/s [2023-02-09 12:36:14] Total: 3.71 kH/s [2023-02-09 12:36:19] CPU #1: 0.93 kH/s [2023-02-09 12:36:19] CPU #0: 0.93 kH/s [2023-02-09 12:36:19] CPU #3: 0.93 kH/s [2023-02-09 12:36:19] Total: 3.72 kH/s [2023-02-09 12:36:24] CPU #2: 0.93 kH/s [2023-02-09 12:36:25] CPU #3: 0.92 kH/s [2023-02-09 12:36:25] Total: 3.70 kH/s [2023-02-09 12:36:29] Total: 3.70 kH/s [2023-02-09 12:36:29] CPU #1: 0.92 kH/s [2023-02-09 12:36:29] CPU #0: 0.92 kH/s [2023-02-09 12:36:33] CPU #3: 0.93 kH/s [2023-02-09 12:36:33] Total: 3.70 kH/s [2023-02-09 12:36:34] CPU #2: 0.94 kH/s [2023-02-09 12:36:34] Total: 3.72 kH/s [2023-02-09 12:36:39] CPU #1: 0.93 kH/s [2023-02-09 12:36:39] CPU #0: 0.93 kH/s [2023-02-09 12:36:39] CPU #3: 0.93 kH/s [2023-02-09 12:36:39] Total: 3.72 kH/s [2023-02-09 12:36:44] CPU #2: 0.94 kH/s [2023-02-09 12:36:44] Total: 3.72 kH/s Total Scores: 3.94,3.72,3.71,3.70,3.69,3.68 ########################################################################## Testing maximum cpufreq again, still under full load. System health now: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:36:27: 1008MHz 4.07 100% 0% 99% 0% 0% 0% 62.0°C Checking cpufreq OPP (Cortex-A53): Cpufreq OPP: 1512 Measured: 1510 (1510.659/1510.625/1510.590) ########################################################################## Hardware sensors: cpu_thermal-virtual-0 temp1: +58.7 C gpu_thermal-virtual-0 temp1: +56.9 C ddr_thermal-virtual-0 temp1: +56.1 C ve_thermal-virtual-0 temp1: +55.5 C ########################################################################## Thermal source: /sys/devices/virtual/thermal/thermal_zone0/ (cpu-thermal) (Armbian wants to use /sys/class/hwmon/hwmon0 instead, that zone is named gpu_thermal. Please check and if wrong file a bug here: https://github.com/armbian/build/issues/) System health while running tinymembench: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:08:31: 1512MHz 1.14 12% 2% 9% 0% 0% 0% 57.8°C 12:09:11: 1008MHz 1.11 25% 0% 25% 0% 0% 0% 60.7°C 12:09:51: 1008MHz 1.09 25% 0% 25% 0% 0% 0% 60.9°C 12:10:31: 1008MHz 1.05 25% 0% 25% 0% 0% 0% 62.1°C 12:11:12: 1008MHz 1.02 25% 0% 25% 0% 0% 0% 62.8°C 12:11:52: 1512MHz 1.01 25% 0% 25% 0% 0% 0% 59.7°C 12:12:32: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 58.4°C 12:13:12: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 58.0°C 12:13:52: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C 12:14:32: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.3°C 12:15:12: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.9°C 12:15:52: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.5°C 12:16:32: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 54.7°C 12:17:12: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.6°C 12:17:52: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 55.9°C 12:18:32: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C System health while running ramlat: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:18:57: 1512MHz 1.00 16% 1% 13% 0% 0% 0% 56.8°C 12:19:00: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.0°C 12:19:04: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 55.9°C 12:19:07: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 57.0°C 12:19:10: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.7°C 12:19:13: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 56.9°C 12:19:16: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 57.0°C 12:19:19: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 57.1°C 12:19:22: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 57.1°C 12:19:25: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C System health while running OpenSSL benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:19:27: 1512MHz 1.00 16% 1% 14% 0% 0% 0% 59.4°C 12:19:44: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C 12:20:00: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C 12:20:16: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 58.8°C 12:20:32: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 56.8°C 12:20:48: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 58.1°C 12:21:04: 1512MHz 1.00 25% 0% 25% 0% 0% 0% 57.9°C System health while running 7-zip single core benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:21:16: 1512MHz 1.00 16% 1% 14% 0% 0% 0% 57.8°C 12:21:26: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 56.0°C 12:21:36: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 56.5°C 12:21:46: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 55.8°C 12:21:56: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 55.4°C 12:22:06: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 54.7°C 12:22:16: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 54.5°C 12:22:26: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 54.5°C 12:22:36: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 55.2°C 12:22:46: 1512MHz 1.00 25% 0% 24% 0% 0% 0% 54.9°C 12:22:56: 1512MHz 1.16 25% 0% 24% 0% 0% 0% 54.5°C 12:23:07: 1512MHz 1.13 25% 0% 24% 0% 0% 0% 54.8°C 12:23:17: 1512MHz 1.11 25% 0% 24% 0% 0% 0% 55.5°C 12:23:27: 1512MHz 1.10 25% 0% 24% 0% 0% 0% 54.3°C 12:23:37: 1512MHz 1.08 25% 0% 24% 0% 0% 0% 55.0°C System health while running 7-zip multi core benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:23:40: 1512MHz 1.07 17% 1% 15% 0% 0% 0% 59.4°C 12:24:06: 1512MHz 1.95 90% 0% 89% 0% 0% 0% 66.0°C 12:24:32: 1008MHz 2.52 93% 0% 92% 0% 0% 0% 66.4°C 12:24:57: 1008MHz 2.79 88% 1% 87% 0% 0% 0% 65.5°C 12:25:19: 1008MHz 3.03 88% 0% 87% 0% 0% 0% 60.8°C 12:26:03: 1512MHz 3.74 95% 24% 70% 0% 0% 0% 63.8°C 12:26:35: 1008MHz 4.41 92% 37% 52% 0% 1% 0% 61.1°C 12:27:01: 1008MHz 4.45 92% 0% 92% 0% 0% 0% 60.8°C 12:27:23: 1008MHz 4.16 89% 1% 88% 0% 0% 0% 60.8°C 12:27:45: 1008MHz 4.17 97% 0% 96% 0% 0% 0% 59.7°C 12:28:07: 1008MHz 3.80 80% 1% 78% 0% 0% 0% 61.2°C 12:28:45: 1008MHz 3.97 97% 51% 45% 0% 0% 0% 62.7°C 12:29:07: 1512MHz 3.97 92% 17% 74% 0% 0% 0% 59.5°C 12:29:32: 1008MHz 3.99 89% 0% 89% 0% 0% 0% 61.1°C 12:29:58: 1008MHz 3.86 92% 0% 91% 0% 0% 0% 62.6°C 12:30:20: 1008MHz 3.98 88% 1% 87% 0% 0% 0% 61.6°C 12:30:41: 1008MHz 4.05 97% 0% 96% 0% 0% 0% 61.1°C 12:31:03: 1008MHz 3.58 79% 1% 77% 0% 0% 0% 60.2°C 12:31:28: 1008MHz 3.86 96% 35% 60% 0% 0% 0% 62.3°C System health while running cpuminer: Time CPU load %cpu %sys %usr %nice %io %irq Temp 12:31:55: 1008MHz 3.97 29% 3% 25% 0% 0% 0% 62.6°C 12:32:40: 1008MHz 4.02 100% 0% 99% 0% 0% 0% 61.4°C 12:33:26: 1008MHz 4.05 100% 0% 99% 0% 0% 0% 62.0°C 12:34:11: 1008MHz 4.06 100% 0% 99% 0% 0% 0% 61.9°C 12:34:56: 1008MHz 4.07 100% 0% 99% 0% 0% 0% 62.6°C 12:35:41: 1008MHz 4.07 100% 0% 99% 0% 0% 0% 62.0°C 12:36:27: 1008MHz 4.07 100% 0% 99% 0% 0% 0% 62.0°C ########################################################################## Throttling statistics (time spent on each cpufreq OPP): 1512 MHz: 835.30 sec 1200 MHz: 0 sec 1008 MHz: 862.78 sec 792 MHz: 0 sec 600 MHz: 0 sec 480 MHz: 0 sec ########################################################################## dmesg output while running the benchmarks: [ 2628.376703] Xtightvnc invoked oom-killer: gfp_mask=0xcc0(GFP_KERNEL), order=0, oom_score_adj=0 [ 2628.376747] CPU: 3 PID: 1396 Comm: Xtightvnc Tainted: G C 5.19.17-sunxi64 #trunk [ 2628.376758] Hardware name: OrangePi Zero2 (DT) [ 2628.376765] Call trace: [ 2628.376769] dump_backtrace+0x12c/0x138 [ 2628.376792] show_stack+0x18/0x48 [ 2628.376803] dump_stack_lvl+0x68/0x84 [ 2628.376816] dump_stack+0x18/0x34 [ 2628.376825] dump_header+0x44/0x1d8 [ 2628.376834] oom_kill_process+0x274/0x278 [ 2628.376846] out_of_memory+0x180/0x548 [ 2628.376854] __alloc_pages_slowpath.constprop.138+0x94c/0xa78 [ 2628.376866] __alloc_pages+0x248/0x2d0 [ 2628.376875] alloc_pages+0xac/0x168 [ 2628.376887] __get_free_pages+0x14/0x40 [ 2628.376894] __pollwait+0x54/0x100 [ 2628.376905] unix_poll+0x30/0x118 [ 2628.376916] sock_poll+0x70/0xf8 [ 2628.376929] do_select+0x278/0x648 [ 2628.376938] core_sys_select+0x220/0x4f8 [ 2628.376948] __arm64_sys_pselect6+0x188/0x218 [ 2628.376958] invoke_syscall+0x44/0x108 [ 2628.376969] el0_svc_common.constprop.3+0x94/0xf8 [ 2628.376979] do_el0_svc+0x2c/0xb8 [ 2628.376988] el0_svc+0x20/0x50 [ 2628.376998] el0t_64_sync_handler+0x98/0xc0 [ 2628.377007] el0t_64_sync+0x170/0x174 [ 2628.377017] Mem-Info: [ 2628.377023] active_anon:75877 inactive_anon:76110 isolated_anon:64 active_file:467 inactive_file:306 isolated_file:45 unevictable:16 dirty:0 writeback:0 slab_reclaimable:3171 slab_unreclaimable:9046 mapped:578 shmem:3 pagetables:1991 bounce:0 kernel_misc_reclaimable:0 free:6078 free_pcp:86 free_cma:1093 [ 2628.377044] Node 0 active_anon:303508kB inactive_anon:304440kB active_file:1868kB inactive_file:1224kB unevictable:64kB isolated(anon):256kB isolated(file):180kB mapped:2312kB dirty:0kB writeback:0kB shmem:12kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB kernel_stack:3792kB pagetables:7964kB all_unreclaimable? no [ 2628.377062] Node 0 DMA free:24312kB boost:2048kB min:24576kB low:30208kB high:35840kB reserved_highatomic:0KB active_anon:304184kB inactive_anon:304200kB active_file:1492kB inactive_file:1376kB unevictable:64kB writepending:0kB present:1048576kB managed:1007952kB mlocked:64kB bounce:0kB free_pcp:344kB local_pcp:32kB free_cma:4372kB [ 2628.377089] lowmem_reserve[]: 0 0 0 0 [ 2628.377106] Node 0 DMA: 1546*4kB (UMEC) 617*8kB (UMEC) 306*16kB (UEC) 146*32kB (UEC) 66*64kB (UE) 4*128kB (U) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 25424kB [ 2628.377180] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB [ 2628.377188] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB [ 2628.377196] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB [ 2628.377203] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB [ 2628.377210] 839 total pagecache pages [ 2628.377214] 29 pages in swap cache [ 2628.377218] Swap cache stats: add 510830, delete 510667, find 215/384851 [ 2628.377224] Free swap = 0kB [ 2628.377228] Total swap = 503972kB [ 2628.377232] 262144 pages RAM [ 2628.377236] 0 pages HighMem/MovableOnly [ 2628.377240] 10156 pages reserved [ 2628.377243] 32768 pages cma reserved [ 2628.377248] Tasks state (memory values in pages): [ 2628.377251] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name [ 2628.377288] [ 309] 0 309 5244 1 69632 328 -1000 systemd-udevd [ 2628.377305] [ 504] 0 504 6451 2 77824 268 -250 systemd-journal [ 2628.377319] [ 508] 0 508 1953 6 57344 767 0 haveged [ 2628.377333] [ 551] 109 551 1765 0 57344 99 0 avahi-daemon [ 2628.377345] [ 557] 0 557 1674 10 49152 53 0 cron [ 2628.377358] [ 559] 103 559 2121 3 49152 249 -900 dbus-daemon [ 2628.377370] [ 563] 0 563 63755 0 135168 587 0 NetworkManager [ 2628.377383] [ 572] 0 572 55220 0 77824 286 0 rsyslogd [ 2628.377396] [ 585] 0 585 3597 0 73728 203 0 systemd-logind [ 2628.377409] [ 591] 0 591 98253 2 122880 538 0 udisksd [ 2628.377422] [ 593] 0 593 3393 6 69632 159 0 wpa_supplicant [ 2628.377435] [ 634] 109 634 1722 1 57344 76 0 avahi-daemon [ 2628.377448] [ 1014] 0 1014 7362 0 90112 431 0 cupsd [ 2628.377460] [ 1033] 104 1033 4707 1 57344 182 0 chronyd [ 2628.377473] [ 1043] 0 1043 58784 0 98304 553 0 polkitd [ 2628.377486] [ 1060] 0 1060 3410 0 61440 235 -1000 sshd [ 2628.377499] [ 1095] 104 1095 2706 0 57344 149 0 chronyd [ 2628.377513] [ 1112] 0 1112 43527 5 110592 390 0 cups-browsed [ 2628.377526] [ 1114] 0 1114 1369 0 45056 29 0 agetty [ 2628.377539] [ 1115] 0 1115 1277 0 49152 30 0 agetty [ 2628.377552] [ 1226] 1000 1226 4055 2 65536 376 0 systemd [ 2628.377565] [ 1227] 1000 1227 42172 1 94208 694 0 (sd-pam) [ 2628.377578] [ 1241] 1000 1241 22787 0 65536 250 0 pipewire [ 2628.377590] [ 1258] 107 1258 38363 0 69632 83 0 rtkit-daemon [ 2628.377602] [ 1322] 1000 1322 2033 27 53248 196 0 dbus-daemon [ 2628.377615] [ 1342] 1000 1342 21294 0 69632 303 0 pipewire-media- [ 2628.377628] [ 1396] 1000 1396 19497 57 118784 4131 0 Xtightvnc [ 2628.377641] [ 1402] 1000 1402 515 0 40960 23 0 xstartup [ 2628.377654] [ 1404] 1000 1404 1456 53 53248 73 0 autocutsel [ 2628.377667] [ 1407] 1000 1407 66813 3 151552 1275 0 xfce4-session [ 2628.377680] [ 1449] 1000 1449 1360 0 53248 116 0 ssh-agent [ 2628.377692] [ 1459] 1000 1459 76479 0 90112 197 0 at-spi-bus-laun [ 2628.377706] [ 1464] 1000 1464 1954 2 53248 137 0 dbus-daemon [ 2628.377718] [ 1468] 1000 1468 57627 2 73728 213 0 xfconfd [ 2628.377731] [ 1474] 1000 1474 40643 4 77824 208 0 at-spi2-registr [ 2628.377744] [ 1484] 1000 1484 20139 18 57344 55 0 gpg-agent [ 2628.377757] [ 1486] 1000 1486 60476 4 200704 2015 0 xfwm4 [ 2628.377769] [ 1489] 1000 1489 59385 2 98304 231 0 gvfsd [ 2628.377783] [ 1495] 1000 1495 56946 3 172032 1374 0 xfsettingsd [ 2628.377795] [ 1498] 1000 1498 80307 272 212992 2397 0 xfce4-panel [ 2628.377815] [ 1502] 1000 1502 102679 4 229376 2899 0 Thunar [ 2628.377830] [ 1507] 1000 1507 90552 70 249856 4851 0 xfdesktop [ 2628.377844] [ 1510] 1000 1510 47490 3 135168 617 0 xfce4-power-man [ 2628.377857] [ 1511] 1000 1511 47110 0 139264 525 0 polkit-gnome-au [ 2628.377870] [ 1514] 1000 1514 15108 5 151552 4592 0 applet.py [ 2628.377883] [ 1525] 1000 1525 107478 0 204800 1759 0 nm-applet [ 2628.377895] [ 1532] 113 1532 60829 3 114688 888 0 colord [ 2628.377908] [ 1533] 1000 1533 65927 0 151552 587 0 xfce4-notifyd [ 2628.377922] [ 1540] 1000 1540 39083 2 73728 146 0 dconf-service [ 2628.377935] [ 1560] 0 1560 61573 0 102400 284 0 upowerd [ 2628.377948] [ 1564] 1000 1564 85188 0 167936 1280 0 panel-6-systray [ 2628.377961] [ 1565] 1000 1565 116481 227 172032 1468 0 panel-8-pulseau [ 2628.377974] [ 1566] 1000 1566 49609 0 155648 1510 0 panel-9-power-m [ 2628.377987] [ 1567] 1000 1567 59918 0 200704 1770 0 panel-10-notifi [ 2628.378000] [ 1585] 1000 1585 48886 4 151552 1360 0 panel-14-action [ 2628.378012] [ 1586] 1000 1586 87436 0 126976 481 0 gvfs-udisks2-vo [ 2628.378026] [ 1600] 1000 1600 77893 0 102400 295 0 gvfsd-trash [ 2628.378039] [ 1605] 1000 1605 39991 0 81920 150 0 gvfsd-metadata [ 2628.378053] [ 1611] 1000 1611 105893 0 98304 334 0 pulseaudio [ 2628.378067] [ 5722] 1000 5722 99687 4 237568 2294 0 xfce4-terminal [ 2628.378080] [ 5727] 1000 5727 1740 1 57344 133 0 bash [ 2628.378093] [ 5730] 1000 5730 3089 0 65536 157 0 sudo [ 2628.378106] [ 5731] 0 5731 2441 1 61440 887 0 bash [ 2628.378122] [ 11118] 0 11118 1683 44 61440 837 0 bash [ 2628.378135] [ 11120] 0 11120 307054 151119 1921024 72717 0 7zr [ 2628.378150] [ 11402] 0 11402 1683 54 61440 827 0 bash [ 2628.378161] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-3.scope,task=7zr,pid=11120,uid=0 [ 2628.378271] Out of memory: Killed process 11120 (7zr) total-vm:1228216kB, anon-rss:604392kB, file-rss:84kB, shmem-rss:0kB, UID:0 pgtables:1876kB oom_score_adj:0 ########################################################################## Linux 5.19.17-sunxi64 (orangepizero2) 02/09/23 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 32.50 0.01 3.02 0.37 0.00 64.10 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 6.39 207.14 131.10 0.00 677822 429004 0 mtdblock0 0.01 0.03 0.00 0.00 112 0 0 zram0 681.82 1239.83 1487.44 0.00 4057076 4867340 0 zram1 0.16 0.20 1.64 0.00 652 5376 0 total used free shared buff/cache available Mem: 984Mi 162Mi 754Mi 0.0Ki 67Mi 755Mi Swap: 492Mi 183Mi 308Mi Filename Type Size Used Priority /dev/zram0 partition 503972 188284 5 CPU sysfs topology (clusters, cpufreq members, clockspeeds) cpufreq min max CPU cluster policy speed speed core type 0 0 0 480 1512 Cortex-A53 / r0p4 1 0 0 480 1512 Cortex-A53 / r0p4 2 0 0 480 1512 Cortex-A53 / r0p4 3 0 0 480 1512 Cortex-A53 / r0p4 Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 NUMA node(s): 1 Vendor ID: ARM Model: 4 Model name: Cortex-A53 Stepping: r0p4 CPU max MHz: 1512.0000 CPU min MHz: 480.0000 BogoMIPS: 48.00 NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid SoC guess: Allwinner H616/H313 DT compat: xunlong,orangepi-zero2 allwinner,sun50i-h616 Compiler: /usr/bin/gcc (Debian 10.2.1-6) 10.2.1 20210110 / aarch64-linux-gnu Userland: arm64 Kernel: 5.19.17-sunxi64/aarch64 CONFIG_HZ=250 CONFIG_HZ_250=y CONFIG_PREEMPT_NONE=y CONFIG_PREEMPT_NONE_BUILD=y raid6: neonx8 gen() 728 MB/s raid6: neonx4 gen() 747 MB/s raid6: neonx2 gen() 708 MB/s raid6: neonx1 gen() 614 MB/s raid6: int64x8 gen() 506 MB/s raid6: int64x4 gen() 565 MB/s raid6: int64x2 gen() 479 MB/s raid6: int64x1 gen() 357 MB/s raid6: using algorithm neonx4 gen() 747 MB/s raid6: .... xor() 539 MB/s, rmw enabled raid6: using neon recovery algorithm xor: automatically using best checksumming function 32regs ########################################################################## Status of performance related governors/policies found below /sys: cpufreq-policy0: performance / 1512 MHz (conservative ondemand userspace powersave performance schedutil) ########################################################################## 5.19 has reached end-of-life on 2022-10-24. 5.19.17 is unsupported since then. ########################################################################## opp-table-cpu: 480 MHz 820.0 mV 880.0 mV 880.0 mV 600 MHz 820.0 mV 880.0 mV 880.0 mV 792 MHz 860.0 mV 940.0 mV 940.0 mV 1008 MHz 900.0 mV 1020.0 mV 1020.0 mV 1200 MHz 960.0 mV 1100.0 mV 1100.0 mV 1512 MHz 1100.0 mV 1100.0 mV 1100.0 mV | OrangePi Zero2 | 1512 MHz (throttled) | 5.19 | Armbian 23.02.0-trunk Bullseye arm64 | 2720 | 1085 | 705040 | 1660 | 5290 | 3.72 | alistair@orangepizero2:~$ 0 Quote
ALIGMSTEN Posted February 15, 2023 Posted February 15, 2023 Hello @mcerveny, I would like to include your thermal changes in a PR to armbian 6.1. Would this be agreeable and how can I best credit you <@users.noreply.github.com>, ofc should you be agreeable? Incidentally the switch case is finding the bins in the same manner, the sign(u32) has been noted. The intended patch is V1 as WIP and will evolve, so all constructive input very welcome please. Here are graphs called from sbc-bench sbc-bench-v0.9.13-orangepi-zero2-.YxRzeH.pdf 0 Quote
stewartwatson Posted April 18, 2023 Posted April 18, 2023 Hi I am afraid I cannot contribute much to this project, as I lack the technical expertise - but I have the orangepizero2 H616, and I think it is a fantastic bit of hardware for the price. I would like to do much more with it (currently I am using it as a pikvm, which works nicely and is fun... and a lot cheaper than a raspberypi based solution). It is a shame it is not more fully supported and I just wanted to say thank you for your work and efforts on this. Thank you! 1 Quote
ALIGMSTEN Posted May 11, 2023 Posted May 11, 2023 Armbian-next commits Commits on May 3, 2023 h616 Cpu frequency scaling (#5123) * Add-h616-efuse_xlate-cpu-freq-scaling * series_additions_h616-cpu-freq-scaling * series_armbian_changes_h616-cpu-freq-scaling --------- Co-authored-by: AGM1968 <AGM1968@users.noreply.githib.com> https://github.com/armbian/build/commit/250a9c2cc0206c586557f37bc3db820d3750da39 Commits on May 5, 2023 sunxi-6.2 h616: Fix thermal zones (add missing trips) main (#5135) @mdziekon @igorpecovnik mdziekon authored and igorpecovnik committed last week https://github.com/armbian/build/commit/7167d5c4200de30f7b103e5f9b478dcec78642ec sunxi-6.1 h616: Fix thermal zones (add missing trips) main (#5135) @mdziekon @igorpecovnik mdziekon authored and igorpecovnik committed last week https://github.com/armbian/build/commit/613234a75cebd4de421e8b832a4efc8bc23eeac2 0 Quote
ALIGMSTEN Posted May 12, 2023 Posted May 12, 2023 Hello, I see that the original xlate patch has been followed and adopted by other known kernel developers for 6.x.y. For the 6.x.y kernels there is a hard study to utilize the patch due to a change to tokens from tables. The probe fails because of these changes. I did not want to do the obvious, and have been working through some options. However for the sake of progress to 6.x.y perhaps that might be the way to go for now, I am more comfortable doing that, seeing that was a solution adopted by well known dev. [ 2.335847] Internal error: Oops: 0000000096000004 [#1] SMP [ 2.341864] Modules linked in: [ 2.345158] CPU: 1 PID: 50 Comm: kworker/u8:1 Not tainted 6.1.19-sunxi64 #trunk [ 2.353065] Hardware name: OrangePi Zero2 (DT) [ 2.357848] Workqueue: events_unbound deferred_probe_work_func [ 2.364173] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.371706] pc : sun50i_cpufreq_nvmem_probe+0xd4/0x2e8 [ 2.377270] lr : sun50i_cpufreq_nvmem_probe+0xcc/0x2e8 [ 2.382847] sp : ffff8000097abad0 [ 2.386405] x29: ffff8000097abad0 x28: 0000000000000000 x27: 0000000000000000 [ 2.394143] x26: ffff0000020b8a74 x25: 0000000000000000 x24: ffff0000022e0000 [ 2.401889] x23: ffff00003fd780b8 x22: ffff0000049c3300 x21: ffff0000049c3380 [ 2.409627] x20: ffff0000049c3400 x19: ffff8000090bbe18 x18: 0000000000000014 [ 2.417338] x17: 00000000413cc101 x16: 0000000042260e86 x15: 000066b8303dd330 [ 2.425076] x14: 0000000000000001 x13: 000000000000006e x12: 0000000000000001 [ 2.432778] x11: 0000000000000001 x10: 0000000000000050 x9 : ffff8000097ab890 [ 2.440480] x8 : 0000000000000050 x7 : ffff00003fd92240 x6 : ffff0000049c3480 [ 2.448199] x5 : ffff0000022e1304 x4 : 0000000000000000 x3 : 0000000000000001 [ 2.455910] x2 : 0000000000000001 x1 : 0000000000000002 x0 : ffff0000022e1304 [ 2.463612] Call trace: [ 2.466253] sun50i_cpufreq_nvmem_probe+0xd4/0x2e8 [ 2.471442] platform_probe+0x68/0xd8 [ 2.475378] really_probe+0xc0/0x3a0 [ 2.479265] __driver_probe_device+0x7c/0x188 [ 2.483967] driver_probe_device+0x3c/0x108 [ 2.488479] __device_attach_driver+0xbc/0x158 [ 2.493268] bus_for_each_drv+0x7c/0xd0 [ 2.497414] __device_attach+0xec/0x1a8 [ 2.501560] device_initial_probe+0x14/0x20 [ 2.506071] bus_probe_device+0x9c/0xa8 [ 2.510209] deferred_probe_work_func+0x9c/0xf0 [ 2.515101] process_one_work+0x220/0x3e8 [ 2.519420] worker_thread+0x258/0x500 [ 2.523477] kthread+0xd8/0xe8 [ 2.526758] ret_from_fork+0x10/0x20 [ 2.530605] Code: aa1503e0 9402276a b140069f 54000608 (f9400321) [ 2.537200] ---[ end trace 0000000000000000 ]--- 0 Quote
ALIGMSTEN Posted May 12, 2023 Posted May 12, 2023 On 5/8/2023 at 12:23 PM, Alan Ma said: Hi, Do you get HDMI audio worked? Personally I've not traveled into those areas, there are patches to study. 0 Quote
dziekon Posted May 23, 2023 Posted May 23, 2023 (edited) Hi @ALIGMSTEN could you please clarify what do you mean by saying that kernel 6.x.y is problematic in terms of introduction of CPU frequency tables? Personally, I was able to replicate what you've done in that regard for kernel 5.19 (I'm referring to this PR: https://github.com/armbian/build/pull/5123) in both kernel 6.1 (current) and 6.2 (edge) with no issues (as in - the OS boots, works & passes sbc-bench). You can see my results summary here: https://github.com/mdziekon/armbian-build/pull/2 For now I've opened a PR against my own fork, but if you think this is the right path, there's nothing preventing me from opening a PR against main armbian repo. Edited May 23, 2023 by dziekon 0 Quote
ALIGMSTEN Posted May 23, 2023 Posted May 23, 2023 Hi @dziekon yeah I've been a bit too much on the experiential side with this, which caused some problems with the probe failing during those tests. I wasn't wanting to progress further myself until finished with v2-opp points, xlate alternative structure and PLL_CPUX experimentation. Your PR proposal is exactly how the xlate patch is transferred to 6.x.y, there is nothing magic about the change, I am experimenting with alternative ways of doing that. Best, Alistair Patch below as reference: (Nonetheless just to note I was about to 'finally' submit V1 in light of the comments 12 May) From 7aee19c8c4a6c400dc45556e138d577d5453661d Mon Sep 17 00:00:00 2001 From: AGM1968 <AGM1968@users.noreply.github.com> Date: Wed, 1 Mar 2023 14:16:30 +0200 Subject: [PATCH] Add-h616-efuse_xlate-cpu-freq-scaling-v1 Signed-off-by: AGM1968 <AGM1968@users.noreply.github.com> --- .../dts/allwinner/sun50i-h616-cpu-opp.dtsi | 75 ++++++++++++++++ .../allwinner/sun50i-h616-orangepi-zero2.dts | 6 ++ drivers/cpufreq/cpufreq-dt-platdev.c | 4 + drivers/cpufreq/sun50i-cpufreq-nvmem.c | 87 ++++++++++++++----- 4 files changed, 150 insertions(+), 22 deletions(-) create mode 100644 arch/arm64/boot/dts/allwinner/sun50i-h616-cpu-opp.dtsi diff --git a/arch/arm64/boot/dts/allwinner/sun50i-h616-cpu-opp.dtsi b/arch/arm64/boot/dts/allwinner/sun50i-h616-cpu-opp.dtsi new file mode 100644 index 000000000000..36f2950367c6 --- /dev/null +++ b/arch/arm64/boot/dts/allwinner/sun50i-h616-cpu-opp.dtsi @@ -0,0 +1,75 @@ +//SPDX-License-Identifier: (GPL-2.0+ OR MIT) +//Testing Version 1 from: AGM1968 <AGM1968@users.noreply.github.com> +//Noted: PLL_CPUX = 24 MHz*N/P (WIP) + +/ { + cpu_opp_table: opp-table-cpu { + compatible = "allwinner,sun50i-h616-operating-points"; + nvmem-cells = <&cpu_speed_grade>; + opp-shared; + + opp-480000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <480000000>; + opp-microvolt-speed0 = <820000 820000 1100000>; + opp-microvolt-speed1 = <880000 880000 1100000>; + opp-microvolt-speed2 = <880000 880000 1100000>; + }; + + opp-600000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <600000000>; + opp-microvolt-speed0 = <820000 820000 1100000>; + opp-microvolt-speed1 = <880000 880000 1100000>; + opp-microvolt-speed2 = <880000 880000 1100000>; + }; + + opp-792000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <792000000>; + opp-microvolt-speed0 = <860000 860000 1100000>; + opp-microvolt-speed1 = <940000 940000 1100000>; + opp-microvolt-speed2 = <940000 940000 1100000>; + }; + + opp-1008000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt-speed0 = <900000 900000 1100000>; + opp-microvolt-speed1 = <1020000 1020000 1100000>; + opp-microvolt-speed2 = <1020000 1020000 1100000>; + }; + + opp-1200000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt-speed0 = <960000 960000 1100000>; + opp-microvolt-speed1 = <1100000 1100000 1100000>; + opp-microvolt-speed2 = <1100000 1100000 1100000>; + }; + + opp-1512000000 { + clock-latency-ns = <244144>; /* 8 32k periods */ + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt-speed0 = <1100000 1100000 1100000>; + opp-microvolt-speed1 = <1100000 1100000 1100000>; + opp-microvolt-speed2 = <1100000 1100000 1100000>; + }; + }; +}; + +&cpu0 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu1 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu2 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu3 { + operating-points-v2 = <&cpu_opp_table>; +}; diff --git a/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts b/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts index b78941d290ad..4babfac99043 100644 --- a/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts +++ b/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts @@ -6,6 +6,7 @@ /dts-v1/; #include "sun50i-h616.dtsi" +#include "sun50i-h616-cpu-opp.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/arm-gic.h> @@ -216,6 +217,11 @@ &pio { vcc-pi-supply = <®_aldo1>; }; +&cpu0 { + cpu-supply = <®_dcdca>; + status = "okay"; +}; + &spi0 { status = "okay"; pinctrl-names = "default"; diff --git a/drivers/cpufreq/cpufreq-dt-platdev.c b/drivers/cpufreq/cpufreq-dt-platdev.c index 69a8742c0a7a..7fadcbe0c3c6 100644 --- a/drivers/cpufreq/cpufreq-dt-platdev.c +++ b/drivers/cpufreq/cpufreq-dt-platdev.c @@ -2,6 +2,9 @@ /* * Copyright (C) 2016 Linaro. * Viresh Kumar <viresh.kumar@linaro.org> + * + * ADD cpufreq nvmem for allwinner h616 SoC, known to be analagous to h6 + * Version 1 AGM1968 <AGM1968@users.noreply.github.com> */ #include <linux/err.h> @@ -102,6 +105,7 @@ static const struct of_device_id allowlist[] __initconst = { */ static const struct of_device_id blocklist[] __initconst = { { .compatible = "allwinner,sun50i-h6", }, + { .compatible = "allwinner,sun50i-h616", }, { .compatible = "arm,vexpress", }, diff --git a/drivers/cpufreq/sun50i-cpufreq-nvmem.c b/drivers/cpufreq/sun50i-cpufreq-nvmem.c index 1acec58c33c3..690ae956659b 100644 --- a/drivers/cpufreq/sun50i-cpufreq-nvmem.c +++ b/drivers/cpufreq/sun50i-cpufreq-nvmem.c @@ -6,6 +6,9 @@ * provide the OPP framework with required information. * * Copyright (C) 2019 Yangtao Li <tiny.windzz@gmail.com> + * + * ADD efuse_xlate to extract SoC version so that h6 and h616 can coexist. + * Version 1 AGM1968 <AGM1968@users.noreply.github.com> */ #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt @@ -19,25 +22,61 @@ #define MAX_NAME_LEN 7 -#define NVMEM_MASK 0x7 -#define NVMEM_SHIFT 5 +#define SUN50I_H616_NVMEM_MASK 0x22 +#define SUN50I_H616_NVMEM_SHIFT 5 +#define SUN50I_H6_NVMEM_MASK 0x7 +#define SUN50I_H6_NVMEM_SHIFT 5 + +struct sunxi_cpufreq_soc_data { + u32 (*efuse_xlate) (void *efuse); +}; static struct platform_device *cpufreq_dt_pdev, *sun50i_cpufreq_pdev; +static u32 sun50i_h616_efuse_xlate(void *efuse) +{ + u32 efuse_value = (*(u32 *)efuse >> SUN50I_H616_NVMEM_SHIFT) & + SUN50I_H616_NVMEM_MASK; + + /* Tested as V1 h616 soc. Expected efuse values are 1 - 3, + slowest to fastest */ + if (efuse_value >=1 && efuse_value <= 3) + return efuse_value - 1; + else + return 0; +}; + +static u32 sun50i_h6_efuse_xlate(void *efuse) +{ + u32 efuse_value = (*(u32 *)efuse >> SUN50I_H6_NVMEM_SHIFT) & + SUN50I_H6_NVMEM_MASK; + + /* + * We treat unexpected efuse values as if the SoC was from + * the slowest bin. Expected efuse values are 1 - 3, slowest + * to fastest. + */ + if (efuse_value >= 1 && efuse_value <= 3) + return efuse_value - 1; + else + return 0; +}; + /** * sun50i_cpufreq_get_efuse() - Determine speed grade from efuse value + * @soc_data: pointer to sunxi_cpufreq_soc_data context * @versions: Set to the value parsed from efuse * * Returns 0 if success. */ -static int sun50i_cpufreq_get_efuse(u32 *versions) +static int sun50i_cpufreq_get_efuse(const struct sunxi_cpufreq_soc_data *soc_data, + u32 *versions) { struct nvmem_cell *speedbin_nvmem; struct device_node *np; struct device *cpu_dev; - u32 *speedbin, efuse_value; + u32 *speedbin; size_t len; - int ret; cpu_dev = get_cpu_device(0); if (!cpu_dev) @@ -47,9 +86,9 @@ static int sun50i_cpufreq_get_efuse(u32 *versions) if (!np) return -ENOENT; - ret = of_device_is_compatible(np, - "allwinner,sun50i-h6-operating-points"); - if (!ret) { + if (of_device_is_compatible(np, "allwinner,sun50i-h6-operating-points")) {} + else if (of_device_is_compatible(np, "allwinner,sun50i-h616-operating-points")) {} + else { of_node_put(np); return -ENOENT; } @@ -65,17 +104,7 @@ static int sun50i_cpufreq_get_efuse(u32 *versions) if (IS_ERR(speedbin)) return PTR_ERR(speedbin); - efuse_value = (*speedbin >> NVMEM_SHIFT) & NVMEM_MASK; - - /* - * We treat unexpected efuse values as if the SoC was from - * the slowest bin. Expected efuse values are 1-3, slowest - * to fastest. - */ - if (efuse_value >= 1 && efuse_value <= 3) - *versions = efuse_value - 1; - else - *versions = 0; + *versions = soc_data->efuse_xlate(speedbin); kfree(speedbin); return 0; @@ -83,18 +112,23 @@ static int sun50i_cpufreq_get_efuse(u32 *versions) static int sun50i_cpufreq_nvmem_probe(struct platform_device *pdev) { + const struct of_device_id *match; int *opp_tokens; char name[MAX_NAME_LEN]; unsigned int cpu; u32 speed = 0; int ret; + match = dev_get_platdata(&pdev->dev); + if (!match) + return -EINVAL; + opp_tokens = kcalloc(num_possible_cpus(), sizeof(*opp_tokens), GFP_KERNEL); if (!opp_tokens) return -ENOMEM; - ret = sun50i_cpufreq_get_efuse(&speed); + ret = sun50i_cpufreq_get_efuse(match-> data, &speed); if (ret) { kfree(opp_tokens); return ret; @@ -160,8 +194,17 @@ static struct platform_driver sun50i_cpufreq_driver = { }, }; +static const struct sunxi_cpufreq_soc_data sun50i_h616_data = { + .efuse_xlate = sun50i_h616_efuse_xlate, +}; + +static const struct sunxi_cpufreq_soc_data sun50i_h6_data = { + .efuse_xlate = sun50i_h6_efuse_xlate, +}; + static const struct of_device_id sun50i_cpufreq_match_list[] = { - { .compatible = "allwinner,sun50i-h6" }, + { .compatible = "allwinner,sun50i-h6", .data = &sun50i_h6_data }, + { .compatible = "allwinner,sun50i-h616", .data = &sun50i_h616_data }, {} }; MODULE_DEVICE_TABLE(of, sun50i_cpufreq_match_list); @@ -197,8 +240,8 @@ static int __init sun50i_cpufreq_init(void) return ret; sun50i_cpufreq_pdev = - platform_device_register_simple("sun50i-cpufreq-nvmem", - -1, NULL, 0); + platform_device_register_data(NULL, + "sun50i-cpufreq-nvmem", -1, match, sizeof(*match)); ret = PTR_ERR_OR_ZERO(sun50i_cpufreq_pdev); if (ret == 0) return 0; -- Created with Armbian build tools https://github.com/armbian/build 0 Quote
dziekon Posted May 25, 2023 Posted May 25, 2023 @ALIGMSTEN thanks for the explanation. I've seen you've started a PR with your changes for newer kernels, so I guess I'll stop working on my own PR. 0 Quote
ALIGMSTEN Posted May 25, 2023 Posted May 25, 2023 @dziekon I've left current open, please go ahead and continue experimenting, and happy to collaborate. (If you can help with adding DE let us know? that is now priority) Zero2 needs people here to help! Armbian-next commits 26th May 2023 https://github.com/armbian/build/commit/e08645740bc75f456e51b785ad4555fbce4f40fd 0 Quote
ALIGMSTEN Posted May 26, 2023 Posted May 26, 2023 Simple led change proposal As development gains traction here I would like to propose a change to the way the onboard led's trigger. Please state your preference! Personal preference over time spent working with edge here. diff --git a/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts b/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts index 159ffe654..23349c6ec 100644 --- a/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts +++ b/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts @@ -28,16 +28,17 @@ leds { compatible = "gpio-leds"; led-0 { - function = LED_FUNCTION_POWER; + function = LED_FUNCTION_STATUS; color = <LED_COLOR_ID_RED>; gpios = <&pio 2 12 GPIO_ACTIVE_HIGH>; /* PC12 */ - default-state = "on"; + linux,default-trigger = "heartbeat"; }; led-1 { - function = LED_FUNCTION_STATUS; + function = LED_FUNCTION_POWER; color = <LED_COLOR_ID_GREEN>; gpios = <&pio 2 13 GPIO_ACTIVE_HIGH>; /* PC13 */ + default-state = "on"; }; }; 0 Quote
dziekon Posted May 27, 2023 Posted May 27, 2023 (edited) The proposed change patch looks malformed, but I assume you'd like to swap the LEDs, so that green is the board's power, while red is the board's activity (currently, power)? If that's the case, it makes sense to me, and I believe this was the original behavior as present on orangepi-xunlong 4.9 kernel. As for the patch itself, maybe it would be better to send these proposals as RFCs on Github directly, gists, or even just files? Looks like the board doesn't handle large code snippets that nicely, as it doesn't support highlighting, nor collapsing for easier thread maintenance. Just some thoughts to prevent spamming this discussion thread with non-exactly-discussion things. Edited May 27, 2023 by dziekon 0 Quote
ALIGMSTEN Posted May 27, 2023 Posted May 27, 2023 On 5/27/2023 at 2:07 AM, dziekon said: The proposed change patch looks malformed, My humble apologies, in haste copy/paste incorrectly! have amended the example. On 5/27/2023 at 2:07 AM, dziekon said: green is the board's power, while red is the board's activity (currently, power)? Correct I've found that change to be visually appealing and closest to the 4.9 legacy kernels Thanks, valid points, noted the on-page posting last couple, instead of correctly formatted text in attachments or links, agreed that might be easier read. Trigger Options: usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlo ck kbd-ctrlllock kbd-ctrlrlock usbport disk-activity disk-read disk-write ide-di sk mtd nand-disk heartbeat cpu cpu0 cpu1 cpu2 cpu3 activity default-on panic mmc 0 rfkill-any rfkill-none stmmac-0:01:link stmmac-0:01:1Gbps stmmac-0:01:100Mbps stmmac-0:01:10Mbps Lets see, perhaps doing this in a 'democratic-manner' here is not the way. Merged - https://github.com/armbian/build/pull/5270 As above your preferences can be altered when you build! 1 Quote
jquagga Posted July 1, 2023 Posted July 1, 2023 I'm not sure if this helps anything, but scrolling through github today I noticed orangepi has a 6.1 kernel tree out there with different dts for the Orange Pi Zero 2. It looks like they are adding some things for the Zero 3. https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-6.1-sun50iw9/ 0 Quote
Igor Posted July 1, 2023 Posted July 1, 2023 2 hours ago, jquagga said: orangepi has a 6.1 kernel tree out there with different dts for the Orange Pi Zero 2. With many patches taken directly from Armbian 6.1.y, but there are few more so its worth investigating. 0 Quote
ag123 Posted July 11, 2023 Posted July 11, 2023 hi, I'd just like to share some resources I stumbled into: BigTree tech CB1 is running on a H616 https://www.armbian.com/bigtreetech-cb1/ apparently they are using a 5.16 kernel as a base https://github.com/bigtreetech/CB1-Kernel https://github.com/bigtreetech/CB1 the commits and diffs could provide some hints on fixes, and there are apparently docs which may be unique 0 Quote
