PatrikO Posted February 22, 2023 Posted February 22, 2023 Hello, I'm having issues with my Orange Pi 4 LTS. I cannot get any HDMI output at the moment. Neither with the Debian flashed on the eMMC, or with Armbian running of the SD card. In both cases I can SSH into the Orange and run commands normally. The HDMI worked just a day before, but in the meantime I was flashing different systems and it stopped working. I tried different monitors and cables. Any ideas what can I do? 0 Quote
PatrikO Posted February 22, 2023 Author Posted February 22, 2023 `cat /sys/class/drm/card0-HDMI-A-1/status` says "disconnected." `/sys/class/drm/card0-HDMI-A-1/mode` doesn't exist. 0 Quote
jock Posted February 23, 2023 Posted February 23, 2023 Hello, what do you mean exactly with: Quote The HDMI worked just a day before, but in the meantime I was flashing different systems and it stopped working. Also post the link given by armbianmonitor -u 0 Quote
JDoll Posted March 15, 2023 Posted March 15, 2023 Have the same problem on Orange Pi 4 LTS. Last working version was Armbian_22.08.1_Orangepi4-lts_jammy_current_5.15.63. After system update monitor was black but system was still up and connectable trough SSH. Installing Armbian_23.02.2_Orangepi4-lts_jammy_current_5.15.93 shows the same result. Any suggestion will appreciated. I can reinstall Armbian_22.08.1 for analysis. Thanks in advance. edit: Please forget what I've said about Armbian_23.02.2_Orangepi4-lts. Meanwhile I've got 23.02.2_Orangepi4-lts running flawlessly. My last testing environment had a broken HDMI-cable. Thus it has no urgency anymore for me. Sorry & thanks. 0 Quote
jock Posted July 31, 2023 Posted July 31, 2023 I resume this thread to see if anyone is still interested in this issue: I can provide a minimal testing image to see if some patches may reduce or eliminate the HDMI problem. Please answer here if there is still interest in this topic 0 Quote
jock Posted August 1, 2023 Posted August 1, 2023 I prepared an experimental minimal build for Orange Pi 4 LTS with some extra patches that may fix the HDMI issues: https://users.armbian.com/jock/misc/Armbian_23.08.0-trunk_Orangepi4-lts_bookworm_edge_6.3.13_minimal.img.xz Please try it and report if possible, thanks! 0 Quote
cgutman Posted August 2, 2023 Posted August 2, 2023 Wow perfect timing. I just got an Orange Pi 4 LTS today and experienced the same HDMI issues reported by OP when trying to use the Armbian_23.5.1_Orangepi4-lts_bookworm_current_6.1.30_xfce_desktop image. Your experimental image works perfectly. 1 Quote
going Posted August 4, 2023 Posted August 4, 2023 01.08.2023 в 15:31, jock сказал: I prepared an experimental minimal build for Orange Pi 4 LTS with some extra patches that may fix the HDMI issues: https://users.armbian.com/jock/misc/Armbian_23.08.0-trunk_Orangepi4-lts_bookworm_edge_6.3.13_minimal.img.xz Please describe briefly the problem that you managed to solve in order to make HDMI work P.S. @jock Or just let me take a look at the changes in the git repository. 0 Quote
jock Posted August 4, 2023 Posted August 4, 2023 1 hour ago, going said: Please describe briefly the problem that you managed to solve in order to make HDMI work Eh, I had to apply the famous libreelec patches (most of them are work from @Kwiboo, btw) that change and fix the various HDMI timings and the subsystem in general. I cut out those patches which seems to be non applicable to the case, but still there are plenty of them (I actually count 48 of them) that, in a way or another, touch the rockchip HDMI subsystem; some of them are difficult to remove because there depend from each other, but I will try to refine to get a small group of patches. Those changes seem to solve problems both with rk3399 and with rk3318/rk3328 and also provide new features, but I don't want to encounter the wall of the last time I did the refactor of the rockchip64 patches into series. BTW this is the commit on my private branch were the work is in progress (based upon 6.3, but I will rebase upon 6.4 soon) 0 Quote
going Posted August 4, 2023 Posted August 4, 2023 28 минут назад, jock сказал: BTW this is the commit on my private branch were the work is in progress (based upon 6.3, but I will rebase upon 6.4 soon) Thanks, I saw it. 30 минут назад, jock сказал: I cut out those patches which seems to be non applicable to the case, but still there are plenty of them (I actually count 48 of them) that, in a way or another, touch the rockchip HDMI subsystem; some of them are difficult to remove because there depend from each other, but I will try to refine to get a small group of patches. Those changes seem to solve problems both with rk3399 and with rk3318/rk3328 and also provide new features, but I don't want to encounter the wall of the last time I did the refactor of the rockchip64 patches into series. 48 fixes or 148 is a small difference. The main thing in switching to the series is the ease of maintenance, there are a large number of small patches (several thousand) of the code. I think people are used to something different. They are used to experiencing the torment of processing several dozen patches, and we say that there will be 1000 patches and it will be easier to maintain, they just don't believe it. 0 Quote
its.not.working Posted September 22, 2023 Posted September 22, 2023 I'm having the same problem with no HDMI output. @jock Do I understand correctly then that fixes are in the works? That patched image works so far. (Thanks!) 0 Quote
jock Posted April 6, 2024 Posted April 6, 2024 Hello; for anyone is still having issues with HDMI output, I have arranged a minimal set of patches that could go into mainline armbian. The .deb packages for an experimental 6.6.25 kernel and dtbs are here. Just install them with dpkg -i I can't test if they are effective by myself because I have no setup where HDMI fails, nonetheless they seem not to harm my current setup. If you can afford to try that experimental kernel, please report your experience, thanks! 0 Quote
wilsonh Posted May 4, 2024 Posted May 4, 2024 Quote Hello; for anyone is still having issues with HDMI output, I have arranged a minimal set of patches that could go into mainline armbian. Thanks!! The patch works perfectly! I have the similar but not exactly issue (no options above 1080p) on RockPro64 here: After applying the patch, immediately the system picks 2K automatically after robot. By the way, am I supposed to do so since I just realized the patch is made for OPi 4 LTS. 0 Quote
Viken Posted June 9, 2024 Posted June 9, 2024 Hello, I have the same issue using a Orange Pi 4 (no LTS) : since I have done the update the HDMI doesn't work, but I can reach my OPI 4 using the SSH. Is it a way to fix the issue / activate the HDMI port by any command ? I believe the patch shared is only for the LTS version. Before I updated I had the version : Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64 After I updated I had the version : Armbian 24.5.1 Bookworm with Linux 6.6.32-current-rockchip64 And the armbianmonitor -u result : https://paste.armbian.com/werugeguso Thanks Viken 0 Quote
jock Posted June 9, 2024 Posted June 9, 2024 Hello, the patch is shared for all rockchip 64 bit devices, since the problem was shared with several rk3399 boards. You should first start with the output of these commands to see if the system gets the monitor EDID parameters: sudo i2cdetect -l sudo get-edid | parse-edid then perhaps see if you have success in changing HDMI cable, or try with a different monitor. The patch was merge here and changed some timings. When timings are changed, some configurations gets benefits but some others may regress. 0 Quote
Viken Posted June 9, 2024 Posted June 9, 2024 Thank you for your quick feedback. I got : sudo i2cdetect -l i2c-0 i2c rk3x-i2c I2C adapter i2c-1 i2c rk3x-i2c I2C adapter i2c-3 i2c rk3x-i2c I2C adapter i2c-4 i2c rk3x-i2c I2C adapter i2c-7 i2c rk3x-i2c I2C adapter sudo get-edid | parse-edid This is read-edid version 3.0.2. Prepare for some fun. Attempting to use i2c interface No EDID on bus 0 No EDID on bus 1 Looks like no busses have an EDID. Sorry! I'm sorry nothing was successful. Maybe try some other arguments if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>. Partial Read... Try again I have changed the cable, but it is the same. I will check on the patch if I can deploy it. 0 Quote
wilsonh Posted August 14, 2024 Posted August 14, 2024 @jock Thank you very much for the patch file (deb) and it works very well. However, when I try to build images with the patches you provided on linux 6.6, it seems not work. I am sure the patches which is "general-hdmi-clock-fixes.patch" is applied, but seems still no output on TVs or monitors other than 1080P. Do you have any idea or could you please share how you compile to get those debs? Many thanks again! 0 Quote
jock Posted August 14, 2024 Posted August 14, 2024 @wilsonh hello! There are no particular compilation steps, once you put the patch in the right place (patch/kernel/archive/rockchip64-6.6), the armbian build system should automatically apply it. Anyway, the patch is already in the main branch of armbian for quite a lot of time; perhaps the patch does not solve the issue with your monitor - for example, I have been unable to run my AOC 3440x1440 monitor on any SBC I have here around, Opi4 included 😕 0 Quote
wilsonh Posted August 14, 2024 Posted August 14, 2024 @jock Thank you for your quick reply! Yes I do see the patch script has been applied by the build script. Maybe my TV just has no luck :(. Just one more question, The interesting thing is that my TV works with the patch debs you provided before --> https://users.armbian.com/jock/rk3318/hdmi/. My TV immediately picks up 2K resolution once I have done dpkg -i. Are they compiled using the same patch scripts you provided which is in the main branch now? I would like to know how they are built and would like to merge it into my compilation. Thank you again for your time and have a good day! 0 Quote
wilsonh Posted August 16, 2024 Posted August 16, 2024 (edited) @jock I tried again and confirm that this patch --> https://github.com/armbian/build/commit/e2ba90368f1af995ba89b151c0913082b9ba0ab9 which comes from your repo works well. However the one you provided later which merged into the armbian main 6.6, 6.8 and 6.10 --> https://github.com/armbian/build/pull/6547/files seems no luck. Edited August 16, 2024 by wilsonh 0 Quote
jock Posted August 17, 2024 Posted August 17, 2024 @wilsonh hmmm, that commit I think it was an attempt to bring the libreelec patches into rockchip64 family. Those attempts generated a lot of discussions, where many were happy and some concerned. Concerns won the battle, and the branch was never merge into mainline, despite it was tested a lot by libreelec folks and gave an all-around improvement in the video/display front. The patch in the main armbian branch instead is a knitwork I did around the libreelec patches to figure out what could fix the HDMI issues on rockchip64 in the latest kernels without including the whole libreelec patchset. Unfortunately (or fortunately) I have no issues with any monitor/TV I have here around, so I could not test directly the outcome of the knitwork. I got some positive feedback from the community, so the smaller patch went in main armbian, but some useful things that fixed issues may have been left out in the process. Anyway I read that, with kernel 6.12, a number of patches that are in the kernel mailing lists (that also are in the libreelec patchset) will be finally mainlined. Hopefully, that would be a step forware the right direction (or wreck everything...) 0 Quote
MaxT Posted August 17, 2024 Posted August 17, 2024 FYI...rockchip:- Improve DP sink-capability reporting- Cleanups- dw_hdmi: Support 4k@60Hz; Cleanups- vop: Support RGB display on Rockchip RK3066; Support 4096px width...https://lore.kernel.org/dri-devel/20240816084109.GA229316@localhost.localdomain/T/#u 0 Quote
Christopher Ruehl Posted January 27 Posted January 27 Hi, I,m using the OPI 4 LTS in a project with a touchscreen connect to HDMI port. The screen detection failed most of the time, checking for the reason I reviewed the schematics of the i2c7 bus and found a design flaw on the level shifter 5V side! The pull-ups on SDA / SCL are 2k ohm, far to strong. (picture attached) I replaced them with a 6.8k resistor fix the problem and the EDID read out first time not show any Checksum errors. Additionally I changed the DTS defines for i2c7 pinctrl using a weak pull-up show below. root@joyai6:/home/orangepi# get-edid -b 7 | parse-edid 7 This is read-edid version 3.0.2. Prepare for some fun. Attempting to use i2c interface Only trying 7 as per your request. 256-byte EDID successfully retrieved from i2c bus 7 Looks like i2c was successful. Have a good day. Checksum Correct Section "Monitor" Identifier "MPI7002" ModelName "MPI7002" VendorName "MPI" # Monitor Manufactured week 1 of 2007 # EDID version 1.3 # Digital Display DisplaySize 180 130 Gamma 1.00 Option "DPMS" "false" #Not giving standard mode: 800x450, 60Hz #Not giving standard mode: 1024x576, 60Hz #Not giving standard mode: 1152x648, 60Hz #Not giving standard mode: 1280x720, 60Hz #Not giving standard mode: 1360x765, 60Hz #Not giving standard mode: 1440x810, 60Hz #Not giving standard mode: 1600x900, 60Hz #Not giving standard mode: 1920x1080, 60Hz #Extension block found. Parsing... Modeline "Mode 1" Modeline "Mode 0" -hsync +vsync Option "PreferredMode" "Mode 1" EndSection i2c7 { i2c7_xfer_up: i2c7-xfer-up { rockchip,pins = <2 RK_PB0 2 &pcfg_pull_up_2ma>, <2 RK_PA7 2 &pcfg_pull_up_2ma>; }; }; /* hdmi i2c */ &i2c7 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c7_xfer_up>; clock-frequency = <50000>; }; 0 Quote
Christopher Ruehl Posted January 27 Posted January 27 Here is what I had before the hardware fix up. root@joyai6:/home/orangepi# get-edid -b 7 | parse-edid 7 This is read-edid version 3.0.2. Prepare for some fun. Attempting to use i2c interface Only trying 7 as per your request. 256-byte EDID successfully retrieved from i2c bus 7 Looks like i2c was successful. Have a good day. You seem to have too many extension blocks. Will not continue to parse Something strange happened. Please contact the author, Matthew Kern at <pyrophobicman@gmail.com> root@joyai6:/home/orangepi# get-edid -b 7 | parse-edid 7 This is read-edid version 3.0.2. Prepare for some fun. Attempting to use i2c interface Only trying 7 as per your request. 256-byte EDID successfully retrieved from i2c bus 7 Looks like i2c was successful. Have a good day. WARNING: Checksum failed Trying to continue... Section "Monitor" Identifier "�PI7002" ModelName "�PI7002" VendorName "MPI" # Monitor Model Year: 2007 # EDID version 1.3 # Digital Display DisplaySize 180 130 Option "DPMS" "false" #Not giving standard mode: 800x450, 60Hz #Not giving standard mode: 1024x576, 60Hz #Not giving standard mode: 1152x648, 60Hz #Not giving standard mode: 1280x720, 60Hz #Not giving standard mode: 1360x765, 60Hz #Not giving standard mode: 1440x810, 60Hz #Not giving standard mode: 1600x900, 60Hz #Not giving standard mode: 1920x1080, 123Hz #Extension block found. Parsing... Extension block checksum failed 0 Quote
jock Posted January 27 Posted January 27 @Christopher Ruehl congratulations, great finding! That could explain some of the compatibility issues people is still having. I have a couple of questions: 1) what is the purpose of enabling the internal gpio pull-up when there already is the external pull-up? 2) do you have any suggestions to apply to existing device tree to enhance compatibility for other users? Exchanging SMD components on the board is out of the league for most people Thanks! 0 Quote
Christopher Ruehl Posted January 28 Posted January 28 hi @jock I agree that changing the SMD 0201 parts is a real challenge - for this reason I used 0402's soldered them direct to the level shifter and run a tiny wire to the 5V source. I'm thinking that an SoC side strong pull-up would do the trick eventually and remove R90611/12 entirely. But I haven't test this - but will do that with the next PCB I get on my table. The Level-shifter is a Texas Instruments TX0102DCU with and with OE is high the internal 10K pull ups are enabled. That might me not enough for the external monitor so the 6.8k has been applied. Same for the SoC side, 10K only , so I support the internal SDA/SCL lines with the light diving strength of 2ma. Datasheet: 8.3.5 Pullup or Pulldown Resistors on I/O Lines Each A-port I/O has an internal 10-kΩ pullup resistor to VCCA, and each B-port I/O has an internal 10-kΩ pullup resistor to VCCB. If a smaller value of pullup resistor is required, an external resistor must be added from the I/O to VCCA or VCCB (in parallel with the internal 10-kΩ resistors). Adding lower value pull-up resistors will effect VOL levels, however. The internal pull-ups of the TXS0102 are disabled when the OE pin is low. I would say it doesn't hurt to add the changes to the DTS for the i2c7_xfer pinctrl. But without fixing the Pull-up value on the 5V it will not improve anything. Yes it is tiny tiny. 4 Quote
Дмитрий Батин Posted April 1 Posted April 1 (edited) i think it is programm problem. I do not have problem with hdmi in standart firmware ( 4k LG TV ) But in the 6.x kernel line i have this problem 28.01.2025 в 12:37, Christopher Ruehl сказал: add the changes to the DTS for the i2c7_xfer pinctrl can you write the step to try do this ? Do you use overlay? Edited April 1 by Дмитрий Батин 0 Quote
yongwn Posted Wednesday at 01:21 AM Posted Wednesday at 01:21 AM I tried Armbina25.5.1 with 6.16.0-rc3-edge-rockchip64 on nanopc t4(rk3399), both hdmi and dp(type-c) works ok. But Armbina25.5.1 with 6.12 only works ok when both typec(dp) and hdmi are pulgged in. There is no output when I only plug in hdmi or typec(dp) . 0 Quote
Werner Posted Wednesday at 03:18 AM Posted Wednesday at 03:18 AM Then you should stay with edge for now. current will only receive critical and security fixes due to its LTS nature. 0 Quote
