Hello,
I'm having issues with my Orange Pi 4 LTS.
I cannot get any HDMI output at the moment. Neither with the Debian flashed on the eMMC, or with Armbian running of the SD card.
In both cases I can SSH into the Orange and run commands normally.
The HDMI worked just a day before, but in the meantime I was flashing different systems and it stopped working.
I tried different monitors and cables.
Any ideas what can I do?
Hello, what do you mean exactly with:
  Quote
Expand
Also post the link given by armbianmonitor -u
Have the same problem on Orange Pi 4 LTS. Last working version was Armbian_22.08.1_Orangepi4-lts_jammy_current_5.15.63. After system update monitor was black but system was still up and connectable trough SSH. Installing Armbian_23.02.2_Orangepi4-lts_jammy_current_5.15.93 shows the same result.
Any suggestion will appreciated.
I can reinstall Armbian_22.08.1 for analysis.
Thanks in advance.
edit:
Please forget what I've said about Armbian_23.02.2_Orangepi4-lts. Meanwhile I've got 23.02.2_Orangepi4-lts running flawlessly. My last testing environment had a broken HDMI-cable. Thus it has no urgency anymore for me.
Sorry & thanks.
I resume this thread to see if anyone is still interested in this issue: I can provide a minimal testing image to see if some patches may reduce or eliminate the HDMI problem.
Please answer here if there is still interest in this topic
Wow perfect timing. I just got an Orange Pi 4 LTS today and experienced the same HDMI issues reported by OP when trying to use the Armbian_23.5.1_Orangepi4-lts_bookworm_current_6.1.30_xfce_desktop image.
Your experimental image works perfectly.
  On 8/1/2023 at 12:31 PM, jock said:
I prepared an experimental minimal build for Orange Pi 4 LTS with some extra patches that may fix the HDMI issues:
https://users.armbian.com/jock/misc/Armbian_23.08.0-trunk_Orangepi4-lts_bookworm_edge_6.3.13_minimal.img.xz
Expand
Please describe briefly the problem that you managed to solve in order to make HDMI work
P.S. @jock Or just let me take a look at the changes in the git repository.
Expand
Eh, I had to apply the famous libreelec patches (most of them are work from @Kwiboo, btw) that change and fix the various HDMI timings and the subsystem in general.
I cut out those patches which seems to be non applicable to the case, but still there are plenty of them (I actually count 48 of them) that, in a way or another, touch the rockchip HDMI subsystem; some of them are difficult to remove because there depend from each other, but I will try to refine to get a small group of patches.
Those changes seem to solve problems both with rk3399 and with rk3318/rk3328 and also provide new features, but I don't want to encounter the wall of the last time I did the refactor of the rockchip64 patches into series.
BTW this is the commit on my private branch were the work is in progress (based upon 6.3, but I will rebase upon 6.4 soon)
Expand
Thanks, I saw it.
Expand
48 fixes or 148 is a small difference.
The main thing in switching to the series is the ease of maintenance, there are a large number of small patches (several thousand) of the code.
I think people are used to something different. They are used to experiencing the torment of processing several dozen patches, and we say
that there will be 1000 patches and it will be easier to maintain, they just don't believe it.
Hello; for anyone is still having issues with HDMI output, I have arranged a minimal set of patches that could go into mainline armbian.
The .deb packages for an experimental 6.6.25 kernel and dtbs are here. Just install them with dpkg -i
I can't test if they are effective by myself because I have no setup where HDMI fails, nonetheless they seem not to harm my current setup.
If you can afford to try that experimental kernel, please report your experience, thanks!
  Quote
Expand
Thanks!! The patch works perfectly! I have the similar but not exactly issue (no options above 1080p) on RockPro64 here:
After applying the patch, immediately the system picks 2K automatically after robot.
By the way, am I supposed to do so since I just realized the patch is made for OPi 4 LTS.
Hello,
I have the same issue using a  Orange Pi 4 (no LTS) : since I have done the update the HDMI doesn't work, but I can reach my OPI 4 using the SSH.
Is it a way to fix the issue / activate the HDMI port by any command ? I believe the patch shared is only for the LTS version.
Before I updated I had the version : Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64
After    I updated I had the version : Armbian 24.5.1 Bookworm with Linux 6.6.32-current-rockchip64
And the armbianmonitor -u result https://paste.armbian.com/werugeguso
Thanks
Viken
Hello, the patch is shared for all rockchip 64 bit devices, since the problem was shared with several rk3399 boards.
You should first start with the output of these commands to see if the system gets the monitor EDID parameters:
sudo i2cdetect -l
sudo get-edid | parse-edid
 then perhaps see if you have success in changing HDMI cable, or try with a different monitor.
The patch was merge here and changed some timings. When timings are changed, some configurations gets benefits but some others may regress.
Thank you for your quick feedback.
I got :
sudo i2cdetect -l
i2c-0   i2c             rk3x-i2c                                I2C adapter
i2c-1   i2c             rk3x-i2c                                I2C adapter
i2c-3   i2c             rk3x-i2c                                I2C adapter
i2c-4   i2c             rk3x-i2c                                I2C adapter
i2c-7   i2c             rk3x-i2c                                I2C adapter
This is read-edid version 3.0.2. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 0
No EDID on bus 1
Looks like no busses have an EDID. Sorry!
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.
Partial Read... Try again
I have changed the cable, but it is the same. I will check on the patch if I can deploy it.
@jock Thank you very much for the patch file (deb) and it works very well.
However, when I try to build images with the patches you provided on linux 6.6, it seems not work. I am sure the patches which is "general-hdmi-clock-fixes.patch" is applied, but seems still no output on TVs or monitors other than 1080P. Do you have any idea or could you please share how you compile to get those debs?
Many thanks again!
@wilsonh hello! There are no particular compilation steps, once you put the patch in the right place (patch/kernel/archive/rockchip64-6.6), the armbian build system should automatically apply it.
Anyway, the patch is already in the main branch of armbian for quite a lot of time; perhaps the patch does not solve the issue with your monitor - for example, I have been unable to run my AOC 3440x1440 monitor on any SBC I have here around, Opi4 included 😕
@jock Thank you for your quick reply! Yes I do see the patch script has been applied by the build script. Maybe my TV just has no luck :(.
Just one more question, The interesting thing is that my TV works with the patch debs you provided before --> https://users.armbian.com/jock/rk3318/hdmi/. My TV immediately picks up 2K resolution once I have done dpkg -i.  Are they compiled using the same patch scripts you provided which is in the main branch now? I would like to know how they are built and would like to merge it into my compilation.
Thank you again for your time and have a good day!
@wilsonh hmmm, that commit I think it was an attempt to bring the libreelec patches into rockchip64 family. Those attempts generated a lot of discussions, where many were happy and some concerned. Concerns won the battle, and the branch was never merge into mainline, despite it was tested a lot by libreelec folks and gave an all-around improvement in the video/display front.
The patch in the main armbian branch instead is a knitwork I did around the libreelec patches to figure out what could fix the HDMI issues on rockchip64 in the latest kernels without including the whole libreelec patchset. Unfortunately (or fortunately) I have no issues with any monitor/TV I have here around, so I could not test directly the outcome of the knitwork. I got some positive feedback from the community, so the smaller patch went in main armbian, but some useful things that fixed issues may have been left out in the process.
Anyway I read that, with kernel 6.12, a number of patches that are in the kernel mailing lists (that also are in the libreelec patchset) will be finally mainlined. Hopefully, that would be a step forware the right direction (or wreck everything...)
Hi,
I,m using the OPI 4 LTS in a project with a touchscreen connect to HDMI port.
The screen detection failed most of the time, checking for the reason I reviewed the schematics of the i2c7 bus and
found a design flaw on the level shifter 5V side!  The pull-ups on SDA / SCL are 2k ohm, far to strong.  (picture attached)
I replaced them with a 6.8k resistor fix the problem and the EDID read out first time not show any Checksum errors.
Additionally I changed the DTS defines for i2c7 pinctrl using a weak pull-up show below.
root@joyai6:/home/orangepi# get-edid -b 7 | parse-edid
7
Only trying 7 as per your request.
256-byte EDID successfully retrieved from i2c bus 7
Looks like i2c was successful. Have a good day.
Checksum Correct
Section "Monitor"
        Identifier "MPI7002"
        ModelName "MPI7002"
        VendorName "MPI"
        # Monitor Manufactured week 1 of 2007
        # EDID version 1.3
        # Digital Display
        DisplaySize 180 130
        Gamma 1.00
        Option "DPMS" "false"
        #Not giving standard mode: 800x450, 60Hz
        #Not giving standard mode: 1024x576, 60Hz
        #Not giving standard mode: 1152x648, 60Hz
        #Not giving standard mode: 1280x720, 60Hz
        #Not giving standard mode: 1360x765, 60Hz
        #Not giving standard mode: 1440x810, 60Hz
        #Not giving standard mode: 1600x900, 60Hz
        #Not giving standard mode: 1920x1080, 60Hz
        #Extension block found. Parsing...
        Modeline        "Mode 1"
        Modeline        "Mode 0" -hsync +vsync
        Option "PreferredMode" "Mode 1"
EndSection
i2c7 {
                i2c7_xfer_up: i2c7-xfer-up {
                        rockchip,pins =
                                <2 RK_PB0 2 &pcfg_pull_up_2ma>,
                                <2 RK_PA7 2 &pcfg_pull_up_2ma>;
/* hdmi i2c */
&i2c7 {
        status = "okay";
        pinctrl-names = "default";
        pinctrl-0 = <&i2c7_xfer_up>;
        clock-frequency = <50000>;
Here is what I had before the hardware fix up.
7
You seem to have too many extension blocks. Will not continue to parse
Something strange happened. Please contact the author,
Matthew Kern at <pyrophobicman@gmail.com>
7
WARNING: Checksum failed
Trying to continue...
Section "Monitor"
        Identifier "�PI7002"
        ModelName "�PI7002"
        VendorName "MPI"
        # Monitor Model Year: 2007
        # EDID version 1.3
        # Digital Display
        DisplaySize 180 130
        #Not giving standard mode: 1920x1080, 123Hz
Extension block checksum failed
@Christopher Ruehl congratulations, great finding! That could explain some of the compatibility issues people is still having.
I have a couple of questions:
1) what is the purpose of enabling the internal gpio pull-up when there already is the external pull-up?
2) do you have any suggestions to apply to existing device tree to enhance compatibility for other users? Exchanging SMD components on the board is out of the league for most people :D
Thanks!
hi @jock
I agree that changing the SMD 0201 parts is a real challenge - for this reason I used 0402's soldered them direct to the level shifter and run a tiny wire to the 5V source.
I'm thinking that an SoC side strong pull-up would do the trick eventually and remove R90611/12 entirely. But I haven't test this - but will do that with the next PCB I get on my table.
The Level-shifter is a Texas Instruments TX0102DCU with and with OE is high the internal 10K pull ups are enabled.  That might me not enough for the external monitor so the 6.8k has been applied.
Same for the SoC side, 10K only , so I support the internal SDA/SCL lines with the light diving strength of 2ma.
Datasheet:
8.3.5 Pullup or Pulldown Resistors on I/O Lines
Each A-port I/O has an internal 10-kΩ pullup resistor to VCCA, and each B-port I/O has an internal 10-kΩ pullup
resistor to VCCB. If a smaller value of pullup resistor is required, an external resistor must be added from the I/O
to VCCA or VCCB (in parallel with the internal 10-kΩ resistors). Adding lower value pull-up resistors will effect VOL
levels, however. The internal pull-ups of the TXS0102 are disabled when the OE pin is low.
I would say it doesn't hurt to add the changes to the DTS for the i2c7_xfer pinctrl. But without fixing the Pull-up value on the 5V it will not improve anything.
Yes it is tiny tiny.
Posted (edited)
i think it is programm problem. I do not have problem with hdmi in standart firmware ( 4k LG TV ) But in the 6.x kernel line i have this problem
Expand
can you write the step to try do this ?
Do you use overlay?
Edited by Дмитрий Батин
