Hi everyone!👋
I would like to turn off the leds on my Orange Pi 5.
I already tried this with no success, since I can't find the mentioned files (I have /sys/class/leds/status_led instead of red/orangepi etc.).
Any tips? Thank you in advance! 🙂
Since there are no standards vendors of more or less cheap boards follow names are not standardized. Try something like find /sys |grep led|grep trigger
echo none | sudo tee /sys/class/leds/status_led/trigger
To set it "permanent" add this line to rc.local
echo none > /sys/class/leds/status_led/trigger
The red LED you can't turn off by software, the ethernet LED I expect it is possible, but I don't know how.
Edited by royk
14 hours ago, Tony3 said:
Cover it with a piece  of plastic? Lol
I assume OP is preferring a software-based solution but I like your thinking :lol:
I guess this needs to be done in the driver, so no easy switch unless you could make that. I've seen there is some information (GitHub commits) how they did with the RPI4.
Tony's advice will be easier😁
