X96mini,S905w Stuck on boot time.
Nandhu
I'm using,
TV Box Name: X96 mini
CPU (example: amlogic s905w): amlogic s905w
Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz
DTB file used: meson-gxl-s905w-gxl-s905w-p281.dtb
During the boot time stacked(freeze) the screen.
Link to comment
Share on other sites
Help us fund some #badass gear for our continuous integration build framework
Dear Stee man,
I'm tried those links with updated image file, but still the problem occurred.
last 2 lines are
Memory Limit : none
[end Kernel panic - not syncing : Asynchronous SError Interrupt ]---
*I'm using device have no boot button. So chose the "aml_autoscript" update method.
Edited by Nandhu
added Mentioned the replay
Link to comment
I have two x96 mini's and don't have any issues.  Could you screen capture the boot process before it starts loading the kernel?
Also pictures of your board would be helpful to compare to mine.
Link to comment
Your first post says you are using the p281 dtb (which is what I use), but the screen shots show you are using the tx3-mini dtb.  You need to fix your extlinux.conf
Link to comment
Can you include pictures of the top and bottom of your box and then open the case and take pictures of the top and bottom of the board (with good enough resolution to see the markings on the board as well as on the chips).  My boxes work fine, so I want to see if your box as different hardware.  TV box manufacturers often make hardware changes but still call it by the same name.
Link to comment
