I'm using,
TV Box Name: X96 mini
CPU (example: amlogic s905w): amlogic s905w
Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz
DTB file used: meson-gxl-s905w-gxl-s905w-p281.dtb
During the boot time stacked(freeze) the screen.
Posted (edited)
Dear Stee man,
I'm tried those links with updated image file, but still the problem occurred.
last 2 lines are
Memory Limit : none
[end Kernel panic - not syncing : Asynchronous SError Interrupt ]---
*I'm using device have no boot button. So chose the "aml_autoscript" update method.
Edited by Nandhu
added Mentioned the replay
I have two x96 mini's and don't have any issues.  Could you screen capture the boot process before it starts loading the kernel?
Also pictures of your board would be helpful to compare to mine.
Expand
Your first post says you are using the p281 dtb (which is what I use), but the screen shots show you are using the tx3-mini dtb.  You need to fix your extlinux.conf
Can you include pictures of the top and bottom of your box and then open the case and take pictures of the top and bottom of the board (with good enough resolution to see the markings on the board as well as on the chips).  My boxes work fine, so I want to see if your box as different hardware.  TV box manufacturers often make hardware changes but still call it by the same name.
@Nandhu  Thanks for the info.  I need to take my box apart to compare.  But I am heading out for a week of vacation, so I might not get to that until I get back in early April.
@Nandhu After so many attempts I managed to install Armbian on the TX3 Mini (Amlogic S905W), on its internal memory (eMMC), but it was trial and error, and I still only managed on an old version (Armbian 5.91, based on Debian), but for my purpose must meet.
@Nandhu I followed the already known steps that you did earlier, the difference was the image I used, which I found in this link here: https://loksado.com/2020/02/download-armbian-linux-untuk-hg680p-dan-b860h-amlogic-s905-p212/ (I hope it doesn't cause problems to post this link), I used some versions, and for my case the one that worked was "5.91", I used the dtb referring to my TV Box (meson-gxl-s905w-tx3-mini.dtb) and using the versions with and without interface and both worked, at first I tested it on the SD Card, when I saw that it was everything went well, I ran "install.sh" which ran smoothly, and now I'm running my Armbian smoothly.
I hope this helps you and others who have had the same problem as me.
@andersonpersan Could you do some tests for me?  Since I can't reproduce the problem (the newest images work on my s905x boxes, including multiple TX3 mini's and X96 mini's), i'm not able to solve the problem.
Since you have found that an older build is working for you, I would request that you try a couple of things to see we can figure out what isn't working in your case for the latest builds.
Since you have already installed to emmc, the first test I would ask is to now try to boot a new build from an sd card with the old build in emmc. (The boot logic should boot from SD card first, before emmc)
Hello @SteeMan, when I managed to run and install the previous version, I was excited and believed that I could run a current version, because I thought I had "unlocked" something in the hardware, but it was not possible to run through the SD Card. I could record a video to show the steps I followed, but I speak Brazilian Portuguese and I don't speak English (I translate the texts via Google Translate), you wouldn't understand me. But basically what I did was trial and error, I tried the "Focal" and "Bullseye" versions, and 6 months ago I talked to you (TX3 Mini without reset button does not boot), and you suggested me to test all available dtb's and that's what I did, were almost 50 attempts on each of these versions, and the common errors I had were: "kernel panic - not syncing: asynchronous serror interrupt armbian", "memory limit none" and finally there was a moment when I managed to access a console, but without success to advance appeared "(initramfs)".
So searching here on the forum I saw this link and decided to try, and by "luck" I managed to run it on my first attempt with an interface, I even installed it on my eMMC, but I needed to install Open Media Vault and I discovered that it does not run on Linux with an interface , so I decided to run it with the same version without interface and once again I managed to install it in eMMC, and now I'm running it without many problems, I have an Open Media Vault installed, an external HD connected and I also installed and configured Emby ( this one I'm still trying to find the best setting, as it crashes with some movies when transcoding because of the modest hardware).
If you have other tests I can run, I'd be happy to help.
Posted (edited)
@andersonpersan Faced with same issue on my box with no reset button =(( Could you please share with link on working img you use? And wich dtb was finally used? 😃
Edited by kostkol87
Hi @kostkol87, the link and dtb are in my post, if your problem is exactly the same as mine, it will probably work for you!
Expand
