Hi there,
My Rock5B worked well with Armbian until I tried to migrate to an NVMe.
Here is a boot log without any SDCard:
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x6
CH0 RX Vref:31.7%, TX Vref:21.8%,21.8%
CH1 RX Vref:30.7%, TX Vref:21.8%,20.8%
CH2 RX Vref:31.7%, TX Vref:21.8%,21.8%
CH3 RX Vref:30.7%, TX Vref:22.8%,21.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE:  BL31: Built : 11:23:47, Aug 15 2022
INFO:    spec: 0x1
INFO:    ext 32k is not valid
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    system boots from cpu-hwid-0
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE init        ialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
done.
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk0p1 does not exist.  Dropping to a shell!
Now, if I put back the SDCard, I get:
▒▒DDR Version V1.08 20220617
LPDDR4X, 2112MHz
Manufacturer ID:0x6
CH2 RX Vref:30.7%, TX Vref:21.8%,21.8%
out
INFO:    spec: 0x1
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
INFO:    SPSR = 0x3c9
done.
done.
done.
That does look the same to me. Why can't it find the SDCard?
Thanks.
Edited by gounthar
  • gounthar changed the title to NVMe boot with Rock5B
I failed... I installed the  image, booted, launched armbian-config, chose the option write to NVMe/MPD, and after the poweroff, I removed the SDCard.
Unfortunately, I then get:
done.
done.
done.
The board still boots fine once I put the SDCard back in.
Edited by gounthar
11 часов назад, gounthar сказал:
Write in detail exactly which image you used, and show the full UART log. Did you answer all the questions about installing the bootloader on MTD correctly and waited for it to finish ? Which power supply do you use ? I strongly advise against using PD power supplies (this is the stupidest and idiotic solution for SbS), only ordinary "dumb" power supplies (optimally 12V 3a 5.5mm2.1mm + USB-C adapter).
Thanks balbes150. After a few reboots, the boards started to boot on the NVMe. 🤔
The image was
Armbian_23.02.0-trunk_Rock-5b_sid_edge_6.2.0.img
