Failed to boot after armbian-install (move system to SSD) - bug: wrong fstab entry created
After successfully installed and booted Armbian 23.02.2 Jammy from SD card on Odroid M1, I ran armbian-install script with using option "boot from SD, system on SSD" to move system to SSD. The process finished successfully, see the logs from armbianmonitor (taken before reboot): https://paste.armbian.com/folivedane
After reboot, system failed to boot automatically from SSD due to error:
[   13.766854] 8644d43f-c78d-4586-ab61-14dfa2e740ea: Can't open blockdev
[   13.774855] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   13.781860] systemd[1]: media-mmcboot.mount: Mount process exited, code=exited, status=32/n/a
[   13.781889] systemd[1]: media-mmcboot.mount: Failed with result 'exit-code'.
[   13.783141] systemd[1]: Failed to mount /media/mmcboot.
[   13.785392] systemd[1]: Dependency failed for /boot.
It asked for root password to go to maintenance mode. I found, boot failed because of wrong entry in /etc/fstab:
root@odroidm1:~# cat /etc/fstab
# <file system>                                 <mount point>   <type>  <options>                                                       <dump>  <pass>
tmpfs                                           /tmp            tmpfs   defaults,nosuid                                                 0       0
8644d43f-c78d-4586-ab61-14dfa2e740ea    /media/mmcboot  ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide       0       1
/media/mmcboot/boot                             /boot           none    bind                                                            0       0
UUID=832c2ac5-7666-4725-a85f-c8a015d9995a       /               ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide       0       1
as you can see there is missing "UUID=" before uuid string for /media/mmcboot entry.
After I fixed this problem by mounting /media/mmcboot and /boot (bind mount) manually and exited from maintenance mode it booted OK. I collected another armbianmonitor logs after boot, see: https://paste.armbian.com/qohidenowu
When the broken line is fixed in the /etc/fstab:
UUID=8644d43f-c78d-4586-ab61-14dfa2e740ea       /media/mmcboot  ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide       0       1
system is booting normally.
The same issue is present also when I used image Armbian 23.02.2 Bullseye
Could you fix this bug, please? I think problem in nand-sata-install script (line 371).
Thanks in advance!
  On 4/6/2023 at 8:08 PM, SteeMan said:
I'm not sure of the criteria for putting out patch releases for previous releases.
Expand
Normally I would already push this to the repository but in present state (due to upgrade to Armbian next and destruction of CI & repository management) this represent lots of hacking. Its one of those ... should I temporally fix old code to produce artefacts, fix repo management ... or invest time / wait that new system is up. According to yesterday's meeting, we are around 10-14 days from generating all artefacts properly. Good point is that repository management is more or less back as it was before. In case I manage to find time and rebuild BSP artefacts manually, they this can be done few days earlier ... but I have many other things :(
Hello everyone,
I know this topic is older but I have a similar problem to the topic creator.
1. For me the fstab looks normal but after the reboot there are a lot of errors when booting (see picture). I don't really know what it is or what I can do.
   I had burned the image "Armbian_23.11.1_Odroidc2_bookworm_current_6.1.63.img" onto the SD card several times, every time the same problem, sometimes the Odroid C2 gets into a boot loop, when I unplug the external SSD from the USB port and plug       it back in, many come up Error on the screen (see picture).
2. Another problem I discovered is that a reboot doesn't work if you use zsh instead of bash, with zfs reboot doesn't work if you use bash, reboot works normally.
The image with only white lines is a boot loop, but it goes so fast that I can't take a picture that quickly.
when booting from any available debian bookworm version with USB attached SSD device,
the boot process will hang in U-boot.
This is the message
S´´´sanning bus usb@ff500000 fordevices...
Stating "Synchronuos Abort" handler, esr 0x96 ...
Removing the SSD brings system up.
