include comedi drivers in kernel
Go to solution Solved by Thomas Schmidt,
I'd like to run usbdux usb hardware with armbian but have no experience so far in building modules. I compiled the current armbian branch form github. But I could not figure out how to compile the comedi drivers and include it in the kernel.
help appreciated
Thomas
did this already but ended up with
usb 4-1: new high-speed USB device number 2 using ehci-platform
[  301.651818] usb 4-1: New USB device found, idVendor=13d8, idProduct=0020, bcdDevice= 0.00
[  301.651863] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  301.712173] comedi: loading out-of-tree module taints kernel.
[  301.712890] comedi: module verification failed: signature and/or required key missing - tainting kernel
[  301.715097] comedi: version 0.7.76 - http://www.comedi.org
[  301.726392] usb 4-1: Direct firmware load for usbduxsigma_firmware.bin failed with error -2
[  301.726425] usbduxsigma 4-1:1.0: driver 'usbduxsigma' failed to auto-configure device.
[  301.726916] usbduxsigma: probe of 4-1:1.0 failed with error -2
[  301.727011] usbcore: registered new interface driver usbduxsigma
Is the firmware file present?
tried the same procedure with armbian bullseye current version and tried to compile the files form raspberry pi (Bernd Porr) this is the result
root@rockpi-4cplus:/home/ts/usbdux# ls -l /usr/src/
insgesamt 4
drwxr-xr-x 24 root root 4096  8. May 12:06 linux-headers-5.15.93-rockchip64
root@rockpi-4cplus:/home/ts/usbdux# cd comedi_raspberry_pi_bullseye/
root@rockpi-4cplus:/home/ts/usbdux/comedi_raspberry_pi_bullseye# make -C /usr/src/linux-headers-5.15.93-rockchip64
make: Verzeichnis „/usr/src/linux-headers-5.15.93-rockchip64“ wird betreten
  UPD     include/config/kernel.release
  UPD     include/generated/utsrelease.h
make[1]: *** Keine Regel vorhanden, um das Ziel „arch/arm64/tools/gen-cpucaps.awk“,
  benötigt von „arch/arm64/include/generated/asm/cpucaps.h“, zu erstellen.  Schluss.
make: *** [arch/arm64/Makefile:173: archprepare] Fehler 2
make: Verzeichnis „/usr/src/linux-headers-5.15.93-rockchip64“ wird verlassen
what I have to install to succeed??
On 5/7/2023 at 1:52 PM, Thomas Schmidt said:
no
sudo apt install linux-firmware-free is not available on the system
Did you install the armbian-firmware-full package?
