sooperior Posted November 13, 2016 Posted November 13, 2016 Hi I have a suggestion to modify update-mot.d script 30-sysinfo. It reports battery chargin or not depending on percentage (if <100% then is charging): # Battery info for Allwinner # kernel 4.4+ axp_dir="/sys/power/axp_pmu" if [[ -e "$axp_dir" ]]; then status_battery_connected=$(cat $axp_dir/battery/connected) if [[ "$status_battery_connected" == "1" ]]; then status_battery_charging=$(cat $axp_dir/charger/charging) status_ac_connect=$(cat $axp_dir/ac/connected) battery_percent=$(cat $axp_dir/battery/capacity) # dispay charging / percentage if [[ "$status_ac_connect" == "1" && "$battery_percent" -lt "100" ]]; then status_battery_text=" charging" elif [[ "$status_ac_connect" == "1" && "$battery_percent" -eq "100" ]]; then status_battery_text=" charged" else status_battery_text=" discharging" fi fi fi However, at least on banana pi M1 (A20) it can be below 100% and not charging, Seems that the PMU doesn't charge just for 1-2%. So we can just use driver info to check if it is really charging, like this: # Battery info for Allwinner kernel 4.4+ axp_dir="/sys/power/axp_pmu" if [[ -e "$axp_dir" ]]; then status_battery_connected=$(cat $axp_dir/battery/connected) if [[ "$status_battery_connected" == "1" ]]; then status_battery_charging=$(cat $axp_dir/charger/charging) status_ac_connect=$(cat $axp_dir/ac/connected) battery_percent=$(cat $axp_dir/battery/capacity) # dispay charging / percentage if [[ "$status_ac_connect" == "1" && "$status_battery_charging" == "1" ]]; then status_battery_text=" charging" elif [[ "$status_ac_connect" == "1" && "$status_battery_charging" == "0" ]]; then status_battery_text=" charged" else status_battery_text=" discharging" fi fi fi Hope someone else finds it useful 1
Igor Posted November 14, 2016 Posted November 14, 2016 Hmm, I have: status_battery_charging = 0 ... charging or not, on Linux lime2 4.8.7-sunxi.
PaceyIV Posted November 14, 2016 Posted November 14, 2016 According to the template of rpimonitor that I found at this forum in some topic we have to check this if (/sys/power/axp_pmu/battery/amperage > 0) "Battery Discharging" else if (/sys/power/axp_pmu/battery/charging == 1) "Battery Charging" else "Battery Charged" This works at every combination of power source - Board powered through battery only - Board powered through DC-IN - Board powered through USB OTG # Battery info for Allwinner # kernel 4.4+ axp_dir="/sys/power/axp_pmu" if [[ -e "$axp_dir" ]]; then status_battery_connected=$(cat $axp_dir/battery/connected) if [[ "$status_battery_connected" == "1" ]]; then battery_current=$(cat $axp_dir/battery/amperage) status_battery_charging=$(cat $axp_dir/charger/charging) status_battery_charge=$(cat $axp_dir/battery/charge) battery_percent=$(cat $axp_dir/battery/capacity) # dispay charging / percentage if [[ "$battery_current" -gt "0" ]]; then status_battery_text=" discharging" elif [[ "$status_battery_charging" -eq "1" ]]; then status_battery_text=" charging" else status_battery_text=" charged" fi fi fi I've tested it with 4.8.4-sunxi
