GBEM Posted August 20 Share Posted August 20 (edited) 5 hours ago, Armi said: p.s. I've made USB male to male cable from 2 cables ,I activated debug mode in Android on Tv box, but adb shell didn't see any device, other TV box too. On one USB jack GND has contact to the metal jack itself ( I've tested by multimeter),could this cause any problems? Hi, Armi. Thanks for your very welcome comments about the write-up. I suspect adb may be an Android thing, and is a total mystery to me. Try shorting the eMMC CLK and GND pads, then running lsusb and look for the Rockchip MASK ROM loader there. I also started-out with a hacked-together USB type-A male to type-A male cable. Yours might be different, but mine would only work plugged in one direction, and was so problematic that I finally relented and bought a 1-meter commercial cable. I think it was only around AUD$5. Sorry Armi, I'm having issues with the comment section on my website. Rather than have you wait for me to sort that out before replying to your query, yes, the current kernel does have linked-in support for video acceleration: dmesg | grep vpu [ 12.086654] hantro-vpu fdea0000.video-codec: Adding to iommu group 0 [ 12.137712] hantro-vpu fdea0000.video-codec: registered rockchip,rk3568-vpu-dec as /dev/video1 [ 12.138138] hantro-vpu fdee0000.video-codec: Adding to iommu group 1 [ 12.143445] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video2 Thanks again for your kind words. GBEM 👽 Edited August 20 by GBEM 0 Quote Link to comment Share on other sites More sharing options...
Vincenzoernst1 Posted August 20 Share Posted August 20 (edited) vor 4 Stunden schrieb GBEM: Try shorting the eMMC CLK and GND pads, t btw i personally never shorted any pins ever on my box. for me ALWAYS worked: while powercyle push an hold the reset button for 10 sec or so. then the bootloader comes up. maybe its not in mask rom mode then you have to switch to it via rockchip dev tool Edited August 20 by Vincenzoernst1 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted August 20 Author Share Posted August 20 4 hours ago, Vincenzoernst1 said: never shorted any pins ever on my box thinks changed in august 24.8.0 Trunk554 now the Mainline Uboot dont reconize the maskroom buttom, feel free to fix this erro on Uboot dtb/dts files. 0 Quote Link to comment Share on other sites More sharing options...
Vincenzoernst1 Posted August 20 Share Posted August 20 so it should be fixed with our PR in 24.8.0-trunk.596, right? 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted August 20 Author Share Posted August 20 (edited) 2 hours ago, Vincenzoernst1 said: so it should be fixed with our PR in 24.8.0-trunk.596, right? @Vincenzoernst1 I have no interest in fixing this I'm not going to keep polishing software since I already know how to get around the problem If you want, you can make a pull request creating an exclusive dts/dtb for the h96 max within uboot 2024/7 including the maskroom button I can help direct your efforts here Edited August 20 by Hqnicolas 0 Quote Link to comment Share on other sites More sharing options...
Vincenzoernst1 Posted August 21 Share Posted August 21 he! i also have no interest in fixing this, since my todo list is full of important real life problems to fix. so i literally already have work for years in my free time. so someone else should step in. 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted August 26 Author Share Posted August 26 I want to make it clear to everyone that now The H96 MAX Became Full supported by armbian Mainline 26/08/2024 Latest Release: https://github.com/armbian/community/releases/tag/24.11.0-trunk.25 desktop: https://github.com/armbian/community/releases/download/24.11.0-trunk.25/Armbian_community_24.11.0-trunk.25_H96-tvbox-3566_noble_current_6.6.47_gnome_desktop.img.xz Server: https://github.com/armbian/community/releases/download/24.11.0-trunk.25/Armbian_community_24.11.0-trunk.25_H96-tvbox-3566_bookworm_current_6.6.47_minimal.img.xz 1 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted August 26 Share Posted August 26 29 minutes ago, Hqnicolas said: The H96 MAX Became Full supported by armbian Mainline I want to clarify this statement. Armbian does not support this box. This is a Community Maintained box, which means it uses the Armbian infrastructure to produce automated weekly builds. The effort to maintain and support this box comes from the community not from Armbian resources. (https://docs.armbian.com/User-Guide_Board-Support-Rules) 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted August 26 Author Share Posted August 26 1 hour ago, SteeMan said: The effort to maintain and support this box comes from the community not from Armbian resources. So, keep a copy from this h96 armbian community, because in the future it may be useful, we left a period where the board was not working. 0 Quote Link to comment Share on other sites More sharing options...
ioncube Posted Saturday at 04:48 PM Share Posted Saturday at 04:48 PM @Hqnicolas [ 6.519079] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94 [ 6.525779] input: rockchip-rk809 Headset as /devices/platform/rk809-sound/sound/card0/input2 I am using OPi3b v2.1 with same RK817 audio, however I am failing for past month & my 3.5mm audio out is not working under vendor 6.1x kernel (both from Armbian / Joshua) interestingly both have same error! However mainline kernel has no problem but because of H265 VPU I prefer to use vendor kernel. Can you please help. My fiddlings are mentioned ar github https://github.com/Joshua-Riek/ubuntu-rockchip/issues/1041 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted yesterday at 06:25 AM Author Share Posted yesterday at 06:25 AM (edited) 13 hours ago, ioncube said: rk817-codec rk817-codec: rk817_probe here in this topic we dont use rk817 probe, the devices not even have a metalic connector to feedback here we remove it because the output was optic audio @Werner can you take @ioncube to orangepi3b topic? Edited yesterday at 06:37 AM by Hqnicolas 0 Quote Link to comment Share on other sites More sharing options...
