olex0 Posted July 1, 2023 Posted July 1, 2023 For a long time, for more than three years, I did not use my BananapiPro board. And recently I decided to launch it again.I downloaded new Armbian image distribution. But the system when loading gives out an error. After the initialization of the devices, a message appears: Device 0: unknown device ethernet@1c50000 Waiting for PHY auto negotiation to complete......... done Speed: 100, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.2.200 (5ms) *** Warning: no boot file name: using 'COA802c8.img' Using ethernet@1c50000 device TFTP from server 192.168.2.1; our IP address is 192.169.2.200 Filename 'COA802C8.img'. Load address: 0x42000000 Loading: T T T T T T T Retry count exceeded; strarting again missing enviroment variable: pxeuuid Retrieving file: pxelinux.cfg/01-02-89-0b-41-bb-9e Speed 100, fulduplex .... which is postponed and the loading does not happen. I tried to record the image with different programs and dd from console. Also I use three different sd cards. I also tried the old images from the archive, but the situation is repeated. And the old images from 2019 have not been found. Does that mean that new images are not supported by my board? Did it be broken? 0 Quote
Solution Igor Posted July 1, 2023 Solution Posted July 1, 2023 On 7/1/2023 at 3:55 PM, olex0 said: Does that mean that new images are not supported by my board? Did it be broken? Expand We are aware software support for Allwinner is slowly but surely collapsing, so this is the plan https://armbian.atlassian.net/browse/AR-1502 There is no support from any side, not from users, not from industry, budget is negative and we already lost lets say hundred hours for preparation and meetings, without counting the work on the code that is already in motion. Just to improve this section. We also purchased some additional devices so we can monitor upgrades better ... To save time answering this question. If you build image from sources, it will work. I just did it earlier today: https://paste.armbian.com/amufuxisen 0 Quote
teknoid Posted December 2, 2023 Posted December 2, 2023 Zitat MMC: no card present Expand Probably it is a problem in uboot, it cannot detect any SD-Cards. Thats why uboot is searching for a TFTP server to boot from there. You can set up a TFTP Server and check if you can at least boot the kernel and see if your SD-Card is detected in the kernel. 0 Quote
teknoid Posted December 2, 2023 Posted December 2, 2023 I just tested Armbian_23.11.1_Bananapipro_bookworm_current_6.1.63.img: dd bs=8M if=Armbian_23.11.1_Bananapipro_bookworm_current_6.1.63.img of=/dev/sdc Boots without any problems, opening ssh gives me: Welcome to Armbian! Documentation: https://docs.armbian.com | Community support: https://forum.armbian.com IP address: 192.168.25.15 Create root password: ********* Repeat root password: ********* Support status: community support (looking for a dedicated maintainer) Choose default system command shell: 1) bash 2) zsh 1 Shell: BASH Creating a new user account. Press <Ctrl-C> to abort 0 Quote
Gunjan Gupta Posted December 2, 2023 Posted December 2, 2023 @teknoidI wonder why you suddenly commented on 5 months old thread that had no activity what so ever 0 Quote
