build image : R1-> Jessy-> with_XFCE-> kernel_3.4.x fails on ubuntu 14.04
first tried building "https://github.com/igorpecovnik/lib"on ubuntu 14.04-Desktop, but "./compile.sh" failed and let crash the internal-terminal-gui-prog.
Today I tried on 14.04.3-Server-Fresh-installed in a vmware, but "./compile.sh" fails too:
make KBUILD_SRC=
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
make[3]: `include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  CHK     kernel/config_data.h
  Kernel: arch/arm/boot/Image is ready
  Kernel: arch/arm/boot/zImage is ready
  Building modules, stage 2.
  MODPOST 1170 modules
WARNING: drivers/net/wireless/bcm4330/bcm4330: 'bcmsdh_probe' exported twice. Previous export was in drivers/net/wireless/ap6210/ap6210.ko
WARNING: drivers/net/wireless/bcm4330/bcm4330: 'bcmsdh_remove' exported twice. Previous export was in drivers/net/wireless/ap6210/ap6210.ko
WARNING: drivers/net/wireless/bcmdhd/bcmdhd: 'bcmsdh_probe' exported twice. Previous export was in drivers/net/wireless/ap6210/ap6210.ko
WARNING: drivers/net/wireless/bcmdhd/bcmdhd: 'bcmsdh_remove' exported twice. Previous export was in drivers/net/wireless/ap6210/ap6210.ko
WARNING: modpost: Found 1 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
  IHEX2FW firmware/emi26/loader.fw
  IHEX2FW firmware/emi26/firmware.fw
  IHEX2FW firmware/emi26/bitstream.fw
  IHEX2FW firmware/emi62/loader.fw
  IHEX2FW firmware/emi62/bitstream.fw
  IHEX2FW firmware/emi62/spdif.fw
  IHEX2FW firmware/emi62/midi.fw
make[3]: *** No rule to make target `firmware/ap6210/bcm20710a1.hcd', needed by `__fw_modbuild'. Stop.
make[2]: *** [modules] Error 2
make[1]: *** [deb-pkg] Error 2
make: *** [deb-pkg] Error 2
mv: cannot stat ‘*.deb’: No such file or directory
real    11m58.600s
user    30m1.096s
sys    3m28.508s
Tue Sep 29 16:56:47 CEST 2015
root@armbian:~/armbian#
What am I doing wrong?
Are you using defaults settings and if not, what have you changed?
It's strange since I just build an image, Ubuntu 14.04 ... always up to date.
Reboot, force update scripts (remove /lib), ...
mhhhh....
i fresh installed :
ubuntu-14.04.3-server-i386.iso
md5 352009d5b44f0e97c9558919f0147c0c
ubuntu-14.04.3-desktop-amd64.iso
md5 cab6dd5ee6d649ed1b24e807c877c0ae
ubuntu-14.04.3-server-amd64.iso
md5 9e5fecc94b3925bededed0fdca1bd417
only did the:
     mkdir armbian
     cd armbian/
     apt-get -y install git
     git clone https://github.com/igorpecovnik/lib
     cp lib/compile.sh .
     chmod +x compile.sh
     time ./compile.sh ; date
     r1.jesse,with xfce,3.4    !!! USING DEFAULTS !!!
...but because of errors I needed to install some stuff:
    4  apt-get -y install git
   10  apt-get -y install make
   12  apt-get -y install build-essential
   29  apt-get -y install gcc-arm-linux-gnueabihf
   32  apt-get -y install device-tree-compiler
user@armbian:~$ arm-linux-gnueabihf-gcc --version
arm-linux-gnueabihf-gcc (Ubuntu/Linaro 4.8.2-16ubuntu4) 4.8.2
Copyright © 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
should it run on Desktop too?
today was testing with your iso: http://archive.ubuntu.com/ubuntu/dists/trusty-updates/main/installer-amd64/current/images/netboot/mini.iso
ERROR:
 o.k. ] ... Upgrade to 3.4.109 [ kernel ]
[ o.k. ] ... Bananapi/Orange/R1 gmac [ kernel ]
[ o.k. ] ... Bananapi PRO wireless [ kernel ]
[ o.k. ] Patching [ u-boot v2015.07 ]
[ o.k. ] ... Add Lamobo R1 [ u-boot ]
[ o.k. ] ... Add AW SOM [ u-boot ]
[ o.k. ] ... Add boot splash [ u-boot ]
[ o.k. ] Patching [ other sources ]
star kernel
[ o.k. ] ... DMA disable on FBTFT drivers [ misc ]
[ o.k. ] ... small TFT display support [ kernel ]
/home/dev/armbian/lib/common.sh: line 28: /home/dev/armbian/sources/u-boot/spl/.config: No such file or directory
/home/dev/armbian/lib/common.sh: line 30: /home/dev/armbian/sources/u-boot/spl/.config: No such file or directory
/home/dev/armbian/lib/common.sh: line 33: dialog: command not found
[ o.k. ] Building deb [ linux-u-boot-lamobo-r1_4.4_armhf.deb ]
[ error ] Building failed, check configuration. [ linux-u-boot-lamobo-r1_4.4_armhf deleted ]
Maybe because of the network?
apt-get update shows an error too:
Reading package lists... Done
W: GPG error: http://repo.aptly.infosqueeze InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E083A3782A194991
dev@dev-m-pack:~/armbian$
Any ideas?
System or network problem. Something is missing or is corrupted, not downloaded ...
apt-get update
Must give clean / error less output. Fix that part first.
No, you don't need an desktop and you can start with Ubuntu minimal image. I made few test rides and haven't got any problems.
good morning,
just for info.
Today i was able to compile r1.jesse,with xfce,3.4 on the 14.04.
Maybe network problems in the past.
Thanks!
