hello , i use opi pc +
i was install armbian in emmc with nand-sata-install without problems. so after a few mouths of work i would backup emmc.
i plug an sd in a usb reader and launch nand-sata-install. i has been just one choise: "boot to sd , systeme on sata usb".
all copy was good. but now opi boot only with sd card plug in the usb reader or with a fresh image in sd slot.
if i try nand-sata-install from usb reader , i have error message "this toll must run  from sd card!"
how is it possible to reinstall old systeme (with all my work) in emmc.
thanks.
Nand-sata-installer is not a eMMC backup tool, not designed for such scenarios ... it's job is to transfer data from SD media somewhere else and adjust boot scripts, install bootloader, ...
dd if=/usr/lib/linux-u-boot-dev-orangepipcplus_5.24_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8
You also need to check rootdev is set properly in your /boot/boot.cmd
thanks.
I try your command from fresh dedian console (boot with sd card) , i must modifie to :
dd if=/usr/lib/linux-u-boot-orangepipcplus_5.20_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8
/usr/lib/linux-u-boot-orangepipcplus_5.20_armhf/u-boot-sunxi-with-spl.bin find in debian sd
and of=/dev/mmcblk1 because i haven't mmcblk2 in /dev/
no errors in console , i try to reboot without sd card : no succes
boot log from serial cable :
U-Boot SPL 2016.09-armbian (Sep 15 2016 - 07:38:36)
DRAM: 1024 MiB
Trying to boot from MMC2
U-Boot 2016.09-armbian (Sep 15 2016 - 07:38:36 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC Plus
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 1, SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
2374 bytes read in 136 ms (16.6 KiB/s)
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
** File not found /boot/.verbose **
** File not found /boot/.next **
** File not found .next **
37596 bytes read in 374 ms (97.7 KiB/s)
3137557 bytes read in 293 ms (10.2 MiB/s)
5024944 bytes read in 462 ms (10.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Data Size:    3137493 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
and after console on hdmi screen:
many line :begin runing /script/local-block ... done
at the end:
Gave up waiting for root device. common problemes:
   -boot args (cat /proc/cmdline)
       -Check rootdelay= (did the systeme wait long enouth?)
       -Check root= (did the systeme wait for the right device ?)
  -missing modules (cats /proc/modules; ls /dev)
alert! /dev/disk/by-uuid/39e............1b7e doesnot exist. dropping to a shell!
rebooting automatically due to panic = boot argument.
to finish i can't check rootdev is set properly in my  /boot/boot.cmd because i don't no how do that.
Boot from SD again, then do "mount /dev/mmcblk1p1 /mnt", then check /mnt/boot/boot.cmd and make sure the rootdev=/dev/mmcblk1p1.
Also check the same thing in /mnt/boot/armbianEnv.txt (I'm not sure if this file exist in older 5.20).
Check the /mnt/etc/fstab too for the device or UUID used in "/" partition.
(If some UUID is used, check what "blkid" is reporting)
thanks for reply.
1) i mount mmcblk1p1 and there's no line rootdev in boot.cmd , where add this? and must i run "mkimage -C none -A arm -T script -d /mnt/boot/boot.cmd /mnt/boot/boot.scr" after change boot.cmd.
strangely in line 11 , root=uuid=39e06b78-4f68-4cfb-a505-c7bd1f801b7e is different of  uuid mmcblk1p1  in /dev/disk/by-uuid/a80ecb16-1adb-4a2b-ad23-b15d3b4f7517 maybe must i change this too?
2) i havn't /mnt/boot/armbianEnv.txt.
3) /mnt/etc/fstab:
/dev/mmcblk1p1 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
/var/swap none swap sw 0 0
There is a lot of changes that occured between 5.20 and 5.24, so don't worry about things that are missing, it would be useless to add them.
But for root=UUID, yes, you need to fix that, either by placing proper one, or simply by using "root=/dev/mmcblk1p1".
Yes, you will need to use mkimage command to get the boot.scr updated, then reboot without SD.
I modified boot.cmd as below:
gpio set PL10
gpio set PG11
setenv machid 1029
setenv bootm_boot_mode sec
if ext4load mmc 0 0x00000000 /boot/.verbose
then
setenv verbosity 7
else
setenv verbosity 1
fi
setenv bootargs "console=tty1 root=/dev/mmcblk1p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=1$
# Boot loader script to boot with different boot methods for old and new kernel
if ext4load mmc 0 0x00000000 /boot/.next || fatload mmc 0 0x00000000 .next || ext4load mmc 0 0x00000000 .next
then
# sunxi mainline kernel
ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile} || fatload mmc 0 0x49000000 /dtb/${fdtfile} || ext4load mmc 0 0x490000$
ext4load mmc 0 0x42000000 /boot/uInitrd || fatload mmc 0 0x42000000 uInitrd || ext4load mmc 0 0x42000000 uInitrd
ext4load mmc 0 0x46000000 /boot/zImage || fatload mmc 0 0x46000000 zImage || ext4load mmc 0 0x46000000 zImage
bootz 0x46000000 0x42000000 0x49000000
#bootz 0x46000000 - 0x49000000
else
# sunxi android kernel
ext4load mmc 0 0x43000000 /boot/script.bin || fatload mmc 0 0x43000000 script.bin || ext4load mmc 0 0x43000000 script$
ext4load mmc 0 0x48000000 /boot/zImage || fatload mmc 0 0x48000000 zImage || ext4load mmc 0 0x48000000 zImage
bootz 0x48000000 0x42000000
#bootz 0x48000000
fi
and run :
allways run fail without sd.
it seems boot is ok but kernel launch error.
boot log on tty:
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
Scanning mmc 0:1...
2347 bytes read in 140 ms (15.6 KiB/s)
37596 bytes read in 386 ms (94.7 KiB/s)
3137557 bytes read in 298 ms (10 MiB/s)
5024944 bytes read in 470 ms (10.2 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
        Start:  0x40000000
and after at tv screen :
alert! /dev/disk/mmcblk1p1 doesnot exist. dropping to a shell!
"/dev/disk/by-uuid/39e.......... doesnot exist" was change by "/dev/disk/mmcblk1p1 doesnot exist" indicate boot.scr has been updated but after.....why doesn't exist mmcblk1p1????
( i not include rootdev line . must include at end of boot.cmd?)
You seems to be at 2 inch from success ...
The "disk" in /dev/disk/mmcblk1p1 should not be there ...
Maybe the error isn't in boot.cmd, since you provide proper root there.
Did you check again in /etc/fstab of the eMMC ? (so in /mnt/etc/fstab when mounted from sd boot)
yes 2 inch it is better than nothink :)
i recheck /mnt/etc/fstab:
i see nothing wrong . maybe try /dev/mmcblk1? or reload just kernel core?
thanks again for your help ang youtr time.
I don't know which script is trying to access it using /dev/disk/mmcblk1p1.
If we knew, we could have that fixed ...
Sorry, if my help didn't provide solution.
Don't sorry you spent verry time to help me, and the mistake was mine. yesterday i try to explore nand -sata-install script to try to understand how it work and try some commandes. and one time i have a rebbot on emmc but with sd plugged.... very strangely. i continue to rummage this emmc.
So,in finnaly if i find nothing, i know how access emmc data from sd boot, i will backup this on usb key , execute nand-sata-install from fresh debian sd card and manualy copie datato emmc  from backup.
