August 19, 20233 yr I want to install jellyfin as a docker container on my Orange pi 5. How can I enable hardware acceleration for it? On the container page (https://hub.docker.com/r/linuxserver/jellyfin) there are instructions for various options, but orange pi 5 is not there of course. I have enabled 3D acceleration as mentioned on the armbian page for orange pi 5. Edited August 19, 20233 yr by Netnax
August 20, 20233 yr Just a guess but I assume it won't work anyways. It would need at least a modified ffmpeg version that supports rockchip vpu which I guess isn't default in these pre-made containers. Could be wrong though.
October 4, 20233 yr I use the 3d accelerated driver and this docker compose code: version: '3.5' services: jellyfin: image: jellyfin/jellyfin container_name: jellyfin environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC network_mode: 'host' devices: - '/dev/dri/card0:/dev/dri/card0' #define what gpu device is being used - '/dev/dri/card1:/dev/dri/card1' - '/dev/dri/renderD128:/dev/dri/renderD128' - '/dev/dri/renderD129:/dev/dri/renderD129' volumes: - /yourpath:/lib #library where you have jellyfin-ffmpeg6 located - /your_path:/config - /your_path:/data/tvseries - /your_path:/data/movies restart: 'unless-stopped' this code you can edit to your convenience, it seems to work for me. I have used VAAPI for transcoding, and it appears to work fine with minimum load in CPU; but i do mention that it appears that av1 doesn't run that well for now. This problem with av1 might improve in the future, I have asked the Jellyfin team to make a transcoding option for the rk3588 we just need enough votes for that dream to become a reality.
October 15, 20233 yr @Miguel González did you compile jellyfin-ffmpeg6 yourself? If yes could you share how you did it?
November 1, 20233 yr Video Acceleration API, but im truly not sure if it works, I have noticed it does run better
November 1, 20233 yr And sorry for the late reply @Tan the ffmpeg6 I had to download it so im not really sure if its ok since I just kept searching in the net until I found something.
December 26, 20232 yr the new jellyfin docker image had released by nyanmisaka. thanks nyanmisaka https://github.com/jellyfin/jellyfin/pull/10748 docker run -d \ --name jellyfin \ --privileged \ --net=host \ --restart=unless-stopped \ --volume /path/to/config:/config \ --volume /path/to/cache:/cache \ --volume /path/to/media:/media \ `for dev in dri dma_heap mali0 rga mpp_service \ iep mpp-service vpu_service vpu-service \ hevc_service hevc-service rkvdec rkvenc vepu h265e ; do \ [ -e "/dev/$dev" ] && echo " --device /dev/$dev"; \ done` \ nyanmisaka/jellyfin:latest-rockchip
December 27, 20232 yr @leeson I only have `/dev/dma_heap`, will it work? if not, how can I get `rga` (Rockchip graphics acceleration?) module? I already `Enable 3D Acceleration` on the Armbian site. Armbian 23.8.1 Jammy with bleeding edge Linux 6.5.0-rc5-edge-rockchip-rk3588
December 27, 20232 yr 1 hour ago, LoneExile said: 6.5.0-rc5-edge-rockchip-rk3588 never heard of that version. Current mainline is 6.7-rc Anyway the stuff mentioned on the download page works with legacy 5.10.y kernel only.
December 29, 20232 yr @LoneExile This is my process: I used 5.10.x kernel, which was already there when I installed the system as @nyanmisaka he said,download the OpenCL,then use sudo apt install ./libmali-valhall-g610-g13p0-x11-wayland-gbm_1.9-1_arm64.deb docker run -d \ --name jellyfin \ --privileged \ --net=host \ --restart=unless-stopped \ --volume /path/to/config:/config \ --volume /path/to/cache:/cache \ --volume /path/to/media:/media \ --device /dev:/dev \ nyanmisaka/jellyfin:latest-rockchip maybe need chmod 777 -R /dev (i'm not sure to run it yes or no) Edited December 29, 20232 yr by leeson code not show
December 31, 20232 yr Thanks, @Werner, I'm not sure about the build. I created the image 2 months ago. However, after rebuilding the image recently, I've obtained the modules I need. Also, thank you, @leeson, for the guidance and solution. I've got it running on my Kubernetes cluster now. And Happy New Year, guys! 🎉
January 8, 20242 yr does this version of jellyfin able to play h265 smoothly? @leeson because jjm2473/jellyfin-mpp build is having hard time to play h265. and also what transcoding method you use
January 8, 20242 yr @Arif Setiadi yes,it worked very smoothly with 4K HEVC HDR 10bit,keep at 60 frames,and lowwer ram usage.about more you can see https://hub.docker.com/r/nyanmisaka/jellyfin thanks @nyanmisaka
January 10, 20242 yr First of all, thank you @leeson for pointing out that jellyfin image, transcoding seems to work. However, I also want home decoding in client app, since this board sometimes is connected to Armbian from orangepi website, hwaccel was "enabled" from their instructions, but mpv was not using it/neither did jellyfin client. When I tried to compile modified ffmpeg from nyanmisaka github the screen goes blank, and gnome session fails to start. There were error messages in journalctl about mpp, and something along these lines recently: Jan 09 22:04:01 orangepi5 gnome-shell[34647]: Running GNOME Shell (using mutter 42.9) as a Wayland display server Jan 09 22:04:01 orangepi5 gnome-shell[34647]: Added device '/dev/dri/card0' (rockchip) using atomic mode setting. Jan 09 22:04:01 orangepi5 gnome-shell[34647]: g_hash_table_destroy: assertion 'hash_table != NULL' failed Jan 09 22:04:01 orangepi5 gnome-shell[34647]: Failed to open gpu '/dev/dri/card1': No suitable mode setting backend found Jan 09 22:04:01 orangepi5 gnome-shell[34647]: g_str_has_prefix: assertion 'str != NULL' failed Jan 09 22:04:01 orangepi5 gnome-shell[34647]: g_str_has_prefix: assertion 'str != NULL' failed Jan 09 22:04:01 orangepi5 gnome-shell[34647]: g_str_has_prefix: assertion 'str != NULL' failed Jan 09 22:04:01 orangepi5 gnome-shell[34647]: Failed to get string: No error has been recorded. Jan 09 22:04:01 orangepi5 systemd[7299]: org.gnome.Shell@wayland.service: Main process exited, code=killed, status=11/SEGV Jan 09 22:04:01 orangepi5 systemd[7299]: org.gnome.Shell@wayland.service: Failed with result 'signal'. Jan 09 22:04:01 orangepi5 systemd[7299]: Failed to start GNOME Shell on Wayland. For the reference I was running Armbian 23.11.1 Jammy with Linux 5.10.160-legacy-rk35xx downloaded from the website not so long ago, not sure if this version involves all required kernel patches or not. What would be the general direction to troubleshoot? Reinstall everything gpu related, then try compiling ffmpeg again?
January 10, 20242 yr so we use jellyfin server from github, and jellyfin desktop client from docker right? @leeson i will try when my setup complete. currently waiting for custom desk.
January 10, 20242 yr @StarboardOtter i had tryed with debian12,you need download the jellyfin client app, then add your server's ip or domain ,chose the quality as low, like this,it worked here is the link for jellyfin client app https://github.com/jellyfin/jellyfin-media-player/releases . In general, the Jellyfin client app works by utilizing your client device's GPU for transcoding when your client device's GPU is supported (direct play). Otherwise, it uses your server device for transcoding. Sorry, my English is not very good. I hope this helps. Edited January 10, 20242 yr by leeson
January 10, 20242 yr @Arif Setiadidocker image is server , client app you need download form https://github.com/jellyfin/jellyfin-media-player/releases
January 13, 20242 yr So with a little bit more of troubleshooting and fresh install from image: the server side with nyanmisaka image works just fine, transcodes FHD HEVC 10bit into something browsers can play easily. However, when I try to play the same file in mpv on the host machine rkmpp goes green screen, can play it without hardware decoding though. Issues begin when I install jellyfin-media-player client from flathub. Please correct me if I am wrong, but flatpaks are similar to containers in a way that they probably have their own mpv without hw acceleration and that's why results are poor? Did anyone successfully compiled a client? Github instructions seem a little outdated (python vs python3 package, it's a stupid roadblock and so far I haven't figured out how to bypass it). Second edit: I realized that leeson is selecting different quality in the client, forcing the transcode probably on the server side. Edited January 13, 20242 yr by StarboardOtter
January 18, 20242 yr @leeson just have time to try now. but on web browser and jellyfin media client the play method is direct playing. not transcode. is it allright? from what i feel. now i can play HEVC video on web browser. on my old jellyfin this won't happen.
January 19, 20242 yr @Arif Setiadi the browser supports h264 direct playing at default,you can try 4k hevc ,it will transcode from high vedio bitrate to low vedio bitrate when you chose low vedio bitrate ,and transcode from hevc vedio codec to h264 vedio codec
July 23, 20242 yr in case someone still not know. jellyfin now support official RK3588/3588S HWA. here the official steps https://jellyfin.org/docs/general/administration/hardware-acceleration/rockchip/
July 26, 20242 yr @Anderson Castro i try. with docker container. but you need to change a little bit. since the docker run cli command on official use net=host I cannot access the jellyfin. so I just delete that line and add this line and work fine for me: -e JELLYFIN_PublishedServerUrl=192.168.0.55 `#optional` \ -p 8096:8096 \ -p 8920:8920 `#optional` \ -p 7359:7359/udp `#optional` \ -p 1900:1900/udp `#optional` \
August 17, 20242 yr Dont forget that you can now use the vendor 6.1.x kernel now for hardware acceleration using MPP - acas@t6:~$ ls -l /dev/rga crw-rw---- 1 root video 10, 121 Aug 17 15:12 /dev/rga acas@t6:~$ ls -l /dev/mpp_service crw-rw---- 1 root video 241, 0 Aug 17 15:12 /dev/mpp_service acas@t6:~$ uname -a Linux t6 6.1.75-vendor-rk35xx #1 SMP Thu Aug 8 17:42:28 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux acas@t6:~$ hostnamectl Static hostname: t6 Icon name: computer Machine ID: 8a38793a5b9543f2a8467803940786e8 Boot ID: 0840de02a4a249e884141dee335ede77 Operating System: Armbian-unofficial 24.8.0-trunk noble Kernel: Linux 6.1.75-vendor-rk35xx Architecture: arm64 dont need to be stuck on 5.10 for MPP support. Works fine with rkmppenc just as for kernel 5.10 series. The only quirk is that for Ubuntu 24.04 you have to hack/build rkmppenc from source at the moment. Edited August 17, 20242 yr by ozacas
November 7, 20242 yr Using the latest 6.1.75-vendor-rk35xx ls -l /dev | grep -E "mpp|rga|dri|dma_heap" drwxr-xr-x 2 root root 80 Dec 31 1969 dma_heap drwxr-xr-x 3 root root 140 Nov 7 09:38 dri crw------- 1 root root 241, 0 Nov 7 09:38 mpp_service crw------- 1 root root 10, 122 Nov 7 09:38 rga I am having some issues, very similar to https://forum.radxa.com/t/opencl-fails-with-failed-creating-base-context-during-opening-of-kernel-driver-on-reboots-for-rockchip-rk3558-orange-pi-5-plus/21558. That is when I install the OpenCL extensions, it seems to work fine, but upon reboot the system is non responsive. I am following instructions for that that libmali https://github.com/tsukumijima/libmali-rockchip/releases/download/v1.9-1-2d267b0/libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb For the 6.1 LTS kernel on Ubuntu-Rockchip & Armbian and the legacy 5.10 LTS kernel, install v1.9-1-2d267b0. For the 6.1 LTS kernel on other SBC vendor-made distros, install v1.9-1-55611b0. ocker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk ffmpeg version 7.0.2-Jellyfin Copyright (c) 2000-2024 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto=auto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libharfbuzz --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=arm64 --cross-prefix=/usr/bin/aarch64-linux-gnu- --toolchain=hardened --enable-cross-compile --enable-rkmpp --enable-rkrga libavutil 59. 8.100 / 59. 8.100 libavcodec 61. 3.100 / 61. 3.100 libavformat 61. 1.100 / 61. 1.100 libavdevice 61. 1.100 / 61. 1.100 libavfilter 10. 1.100 / 10. 1.100 libswscale 8. 1.100 / 8. 1.100 libswresample 5. 1.100 / 5. 1.100 libpostproc 58. 1.100 / 58. 1.100 Splitting the commandline. Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'rkmpp=rk'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'opencl=ocl@rk'. Finished splitting the commandline. Parsing a group of options: global . Applying option v (set logging level) with argument debug. Applying option init_hw_device (initialise hardware device) with argument rkmpp=rk. Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab04dcb0d0] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaab04dcb0d0] 1 OpenCL devices found on platform "ARM Platform". arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab04dcb0d0] 0.0: ARM Platform / Unknown Device Any idea what's up?
