prahal Posted October 16, 2024 Posted October 16, 2024 2 hours ago, BipBip1981 said: Since few days i note a problem with SATA on my Helios64. @BipBip1981 Could you grep for "ata", or check the logs for ata errors and paste them? Or tell if there are no other messages with ata in the logs? Don't you have any "hard resetting link" messages in the kernel logs? On my side I once had drives that were not detected extracting the drive from the SATA power and data socket a few times (and cleaning them with isopropanol once, might have helped) did it. I believe my socket were oxidized though that is a wild guess. Issue gone either way. 0 Quote
BipBip1981 Posted October 17, 2024 Posted October 17, 2024 (edited) Hi, Same with 28.11-trunk build myself and 6.6.56 kernel Below grep SATA and grep ata: root@helios64:~# dmesg | grep SATA [ 3.137429] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 3.151033] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 74 [ 3.151704] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 75 [ 3.152392] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 76 [ 3.153059] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 77 [ 3.153722] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 78 [ 10.588155] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 11.116112] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 11.628156] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 12.116158] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 12.624185] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) root@helios64:~# dmesg | grep ata [ 0.000000] Memory: 3787452K/4061184K available (16960K kernel code, 2318K rwdata, 5248K rodata, 4736K init, 604K bss, 142660K reserved, 131072K cma-reserved) [ 0.018184] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.719520] libata version 3.00 loaded. [ 3.151033] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 74 [ 3.151704] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 75 [ 3.152392] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 76 [ 3.153059] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 77 [ 3.153722] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 78 [ 3.163337] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 82,32 bit host data width,256 deep fifo [ 8.508139] ata1: link is slow to respond, please be patient (ready=-19) [ 10.588155] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 10.610022] ata1.00: ATA-9: WDC WD80EFAX-68KNBN0, 81.00A81, max UDMA/133 [ 10.620898] ata1.00: 15628053168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 10.624658] ata1.00: Features: NCQ-sndrcv NCQ-prio [ 10.639786] ata1.00: configured for UDMA/133 [ 11.116112] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 11.117876] ata2.00: ATA-9: WDC WD80EFAX-68KNBN0, 81.00A81, max UDMA/133 [ 11.128615] ata2.00: 15628053168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 11.132356] ata2.00: Features: NCQ-sndrcv NCQ-prio [ 11.148021] ata2.00: configured for UDMA/133 [ 11.628156] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 11.630146] ata3.00: ATA-9: TS256GSSD370S, O1225G, max UDMA/133 [ 11.630849] ata3.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32), AA [ 11.632376] ata3.00: Features: Dev-Sleep [ 11.635170] ata3.00: configured for UDMA/133 [ 12.116158] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 12.118227] ata4.00: ATA-9: WDC WD80EFBX-68AZZN0, 85.00A85, max UDMA/133 [ 12.128937] ata4.00: 15628053168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 12.132823] ata4.00: Features: NCQ-sndrcv NCQ-prio [ 12.148357] ata4.00: configured for UDMA/133 [ 12.624185] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 12.626073] ata5.00: ATA-9: WDC WD80EFBX-68AZZN0, 85.00A85, max UDMA/133 [ 12.636772] ata5.00: 15628053168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 12.640617] ata5.00: Features: NCQ-sndrcv NCQ-prio [ 12.656091] ata5.00: configured for UDMA/133 [ 52.828386] EXT4-fs (dm-1): mounted filesystem 58534626-3f89-40db-9b0e-9519a2805962 ro with writeback data mode. Quota mode: none. [ 56.637970] EXT4-fs (mmcblk0p1): mounted filesystem ba516afd-4114-4179-8bcf-3d0f63b058fe r/w with ordered data mode. Quota mode: none. [ 64.262140] EXT4-fs (dm-2): mounted filesystem cc702057-ff5f-4b6f-ad29-4f5d5d96216e r/w with ordered data mode. Quota mode: none. [ 64.341677] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 64.358217] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 66.316142] systemd-journald[1673]: Data hash table of /var/log/journal/21a29cba476e44048a808d9a655190f3/system.journal has a fill level at 88.2 (4015 of 4551 items, 2621440 file size, 652 bytes per hash table item), suggesting rotation. Edited October 17, 2024 by BipBip1981 0 Quote
BipBip1981 Posted October 18, 2024 Posted October 18, 2024 (edited) Hi everybody, For information Prahal dtb patch file is not for me the problem because my problem is only on ata1 after cold boot, never after reboot command. I think hardware problem like harddisk, cables or mainboard... i continu to search. Have good day Edited October 18, 2024 by BipBip1981 0 Quote
prahal Posted October 18, 2024 Posted October 18, 2024 On 10/17/2024 at 7:20 AM, BipBip1981 said: [ 8.508139] ata1: link is slow to respond, please be patient (ready=-19) [ 10.588155] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 10.610022] ata1.00: ATA-9: WDC WD80EFAX-68KNBN0, 81.00A81, max UDMA/133 [ 10.620898] ata1.00: 15628053168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 10.624658] ata1.00: Features: NCQ-sndrcv NCQ-prio [ 10.639786] ata1.00: configured for UDMA/133 -19 in ata1: link is slow to respond, please be patient (ready=-19) is ENODEV in https://github.com/torvalds/linux/blob/6efbea77b390604a7be7364583e19cd2d6a1291b/drivers/ata/libata-core.c#L3594 but ready is resetted to 0 else the function would exit before this message https://github.com/torvalds/linux/blob/6efbea77b390604a7be7364583e19cd2d6a1291b/drivers/ata/libata-core.c#L3577 As I told, I had bad contact on my sata ports, try removing and inserting the HDD in the sata socket a few times. That might remove things on the contacts. On my side I also clean the sata sockets with isopropanol when I bought some (I use 99,5% isopropanol but I don't know if less concentrated is OK). You might paste the complete log around the ata1 lines in the kernel log. If the issue is always with the same sata port, you could try swapping the HDD to see if the issue follows the HDD or if this is the link or port. But indeed I guess the issue is hardware. 0 Quote
BipBip1981 Posted October 18, 2024 Posted October 18, 2024 Hi, I swap ata1 and ata5, problem stay on ata1, i look cable and socket on ata1 Keep in touch 0 Quote
BipBip1981 Posted October 22, 2024 Posted October 22, 2024 (edited) Hi, few days ago, i disconnect and reconnect all connectors on ATA1 line, it's seem to become Okok 😉 Edited October 23, 2024 by BipBip1981 0 Quote
prahal Posted October 25, 2024 Posted October 25, 2024 On 10/22/2024 at 6:22 PM, BipBip1981 said: Hi, few days ago, i disconnect and reconnect all connectors on ATA1 line, it's seem to become Okok 😉 Awesome. And thanks a lot for the feedback. Could you explain which side you disconnect/reconnected? The HDD side only? Or on the motherboard too? I believe HDD side is enough, just want a clue if that could be wrong. I believe the connector were not clean, or a bit oxidized out of fabric (maybe connectors were stored in an area with an aggressive climate... I am no expert, but I clue that with the parts being serviced during Covid mess, some unusual process happened). It is not like the hardware is bad, only "dirty". Here I had bad lost connectivity to an HDD, extracting and inserting it a few times back seemed to have cleaned the connectors (I also put isopropanol on them, but I don't remind if I brushed them at that time). 0 Quote
BipBip1981 Posted October 27, 2024 Posted October 27, 2024 Hi, For feedback, i disconnect from SATA connector by unrack/rack harddisk and i disconnect and reconnect plug on mainboard side. Have a good day. 0 Quote
drs Posted December 15, 2024 Posted December 15, 2024 Hey everyone, I just updated my helios64, from bullseye to bookworm and the armbian packages from 23.02.2 to 24.11.1 After rebooting I couldn't reach my helios64 anymore via network, i.e. dropbear within initramfs. So I figured that nic device names may have changed (and so the IP= setting within initramfs.conf wouldn't work anymore) and connected via serial console with picocom. But unfortunately the serial console output just ends every reboot with these lines (full serial console output as attachment): [ 7.169342] r8152 2-1.4:1.0 enx646266d0034d: renamed from eth0 [ 7.236959] device-mapper: uevent: version 1.0.3 [ 7.237900] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com [ 7.254918] NET: Registered PF_ALG protocol family [ 7.323029] zram: Added device: zram0 [ 7.646108] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 7.834575] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 7.835330] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 7.836020] sd 2:0:0:0: Attached scsi generic sg2 type 0 [ 7.836914] sd 3:0:0:0: Attached scsi generic sg3 type 0 [ 7.837806] sd 4:0:0:0: Attached scsi generic sg4 type 0 [ 7.969567] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 8.043475] async_tx: api initialized (async) Does anyone have any idea why the serial console output just ends and any idea what to do? bookworm_serial_console.txt 0 Quote
prahal Posted December 18, 2024 Posted December 18, 2024 (edited) On 12/16/2024 at 12:05 AM, drs said: After rebooting I couldn't reach my helios64 anymore via network, i.e. dropbear within initramfs. So I figured that nic device names may have changed (and so the IP= setting within initramfs.conf wouldn't work anymore) and connected via serial console with picocom. But unfortunately the serial console output just ends every reboot with these lines (full serial console output as attachment): I don't know why you don't get a shell on the serial console. But we can get the network issue worked around. There are two ethernet interfaces: end0 the 1Gbls and the second in your cawe enx646266d0034d the 2.5Gbps ethernet one. The enx646266d0034d is MAC hw address 64:62:66:d0:03:4d (I've the mac addr is in the interface name). The end0 should be the same minus one is 64:62:66:d0:03:4c. What are the status of the LEDs on the front panel (blinking/solid)? Edited December 18, 2024 by prahal request details 0 Quote
snakekick Posted December 23, 2024 Posted December 23, 2024 (edited) Hello @prahal do you think you will impementing your dtb changes to official sources so we can upgrade to newer kernel without manuell changes are needed? Thank you Edited December 23, 2024 by snakekick 0 Quote
BipBip1981 Posted December 24, 2024 Posted December 24, 2024 Hello @prahal, i agree with @snakekick , you dtb changes is ready to go to official sources. I use it from the beginning, my helios now work good and stop to crash. My brother use it and same result. Your dtb changes commit to official sources for the first january 2025 will be a perfect. 0 Quote
prahal Posted December 25, 2024 Posted December 25, 2024 On 12/23/2024 at 3:23 PM, snakekick said: Hello @prahal do you think you will impementing your dtb changes to official sources so we can upgrade to newer kernel without manuell changes are needed? Yes I planned them for 24.11 but had personal issue and also I took part in another board mainternship. The emmc patch need only that I sort out of to apply it to the current patfhset. I asked for insight on how to handle reformatting existing patch that I modify and was told that I should submit any changes to a patch in a separate patch by Werner but I am still uneasy to small patch files instead of fixing existing patches. I wonder if I explain my situation clearly ... The voltage patch needs a little more work as I made many instances of the voltage change on my side, so I need to disassemble ebin-dev dtb though it is achievable in a few hours. In short I tried learn ingambian processes first, had a little more work on another board (mostly learning required additional hardware and ordering it, then handlingna few glitches like power supply dying) then personal matters and taking part in gatherings. I now plan these commits for 25.02. 0 Quote
ebin-dev Posted December 25, 2024 Author Posted December 25, 2024 (edited) On 12/25/2024 at 5:50 PM, prahal said: The voltage patch needs a little more work as I made many instances of the voltage change on my side, so I need to disassemble ebin-dev dtb though it is achievable in a few hours. The voltage values were changed in opp-table-1 - the values used can be found (here) earlier in this thread. The dtb for the 6.6 branch still works fine with them (cache awareness and emmc HS400 speed is also enabled in it). I am currently using it with linux-6.6.74 as it provides the best performance and stability. rockchip64-current was bumped from kernel branch 6.6 to 6.12 (on Dec. 21st) and rockchip64-edge bumped to branch 6.13. These kernel versions are available on beta.armbian.com and any issues with them could be reported here. The downside is that linux-6.6 rockchip64 kernel versions are not built anymore by the current armbian build system. rk3399-kobol-helios64.dtb-6.6.xx-L2-hs400-opp rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp Edited January 23 by ebin-dev updated linux debs 0 Quote
axel Posted January 10 Posted January 10 It's really nice to see all these recent community efforts to revive and keep the Helios64 alive and useful. However, the relevant info seems to be a bit all over the place. For instance, with the device tree files (dtb files). Which one is the "latest" one? How do you know which one to use for your current kernel? Where should you download it? (as an attachment to a user post on this forum?) Are they going to be merged as part of regular Armbian? These questions are not that hard to answer if you read through the topics and have some technical knowledge, but that's sort of the problem! Essentially, it would be great to start making things a bit more organised so people don't have to piece the information together from various forum posts 0 Quote
prahal Posted January 10 Posted January 10 4 hours ago, axel said: However, the relevant info seems to be a bit all over the place. For instance, with the device tree files (dtb files). Which one is the "latest" one? How do you know which one to use for your current kernel? Where should you download it? (as an attachment to a user post on this forum?) Are they going to be merged as part of regular Armbian? These questions are not that hard to answer if you read through the topics and have some technical knowledge, but that's sort of the problem! Essentially, it would be great to start making things a bit more organised so people don't have to piece the information together from various forum posts There is only ebin-dev dtb that has the non armbian upstreamed fixes (the older other comments are about doing the same changes on your own dtb, or about requesting feedback from people testing these changes). As far as I know ebin-dev dtb has the emmc fix in dtb and the CPU big voltage upped a little also in dtb. Both from me. They will both be uostreamed to armbian but only the Emma fix will go in Linux upstream (as the voltage up is only a hack that I was requested to try by a pine64 engineer but the cause of the crash is still not know. The current voltages are supposed to be already correct). 0 Quote
ebin-dev Posted January 11 Author Posted January 11 (edited) On 1/10/2025 at 2:50 PM, axel said: For instance, with the device tree files (dtb files). Which one is the "latest" one? How do you know which one to use for your current kernel? Where should you download it? (as an attachment to a user post on this forum?) Are they going to be merged as part of regular Armbian? The dtbs attached to my previous post can be used for kernel branches 6.6.xx and 6.12.xx respectively as identified in their names. There is no latest version - they are all the same for each kernel branch and posted for your convenience (so you don't have to compile them by yourself) until the patches make it into Armbian - hopefully soon. The message is actually that linux 6.6 rockchip64 kernels (LTS) are not built anymore by the current Armbian build system. Therefore there is an urgent need to test linux 6.12 on Helios64 (and report any issues here), since that is what is going to be shipped with the next release. Edited January 22 by ebin-dev link updated 0 Quote
BipBip1981 Posted January 12 Posted January 12 (edited) Hi, i build and pass to last armbian from source with 6.12 kernel to test dtb file with it. Keep in touch. Edited January 12 by BipBip1981 0 Quote
BipBip1981 Posted January 16 Posted January 16 (edited) Hi, System work well with Kernel 6.12 and DTB patch, juste a problem with the service folow. Keep in touch. root@helios64:~# systemctl status helios64-heartbeat-led.service × helios64-heartbeat-led.service - Enable heartbeat & network activity led on Helios64 Loaded: loaded (/etc/systemd/system/helios64-heartbeat-led.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Thu 2025-01-16 20:26:24 CET; 34min ago Process: 2899 ExecStart=bash -c echo heartbeat | tee /sys/class/leds/helios64\:\:status/trigger (code=exited, status=1/FAILURE) Main PID: 2899 (code=exited, status=1/FAILURE) CPU: 20ms Jan 16 20:26:24 helios64 systemd[1]: Starting helios64-heartbeat-led.service - Enable heartbeat & network activity led on Helios64... Jan 16 20:26:24 helios64 bash[2906]: tee: '/sys/class/leds/helios64::status/trigger': No such file or directory Jan 16 20:26:24 helios64 bash[2906]: heartbeat Jan 16 20:26:24 helios64 systemd[1]: helios64-heartbeat-led.service: Main process exited, code=exited, status=1/FAILURE Jan 16 20:26:24 helios64 systemd[1]: helios64-heartbeat-led.service: Failed with result 'exit-code'. Jan 16 20:26:24 helios64 systemd[1]: Failed to start helios64-heartbeat-led.service - Enable heartbeat & network activity led on Helios64. Edited January 16 by BipBip1981 0 Quote
ebin-dev Posted January 17 Author Posted January 17 (edited) On 1/16/2025 at 9:01 PM, BipBip1981 said: Hi, System work well with Kernel 6.12 and DTB patch, juste a problem with the service folow. Keep in touch. I have noticed that the rtl8156a-2 v2 firmware update is not shown in dmesg anymore but ethtool confirms that it is loaded. With linux 6.12.10 the 2.5G interface seems to work as reliable and as fast as with linux 6.6.72: # uname -a Linux grid 6.12.10-current-rockchip64 #2 SMP PREEMPT Fri Jan 17 12:41:00 UTC 2025 aarch64 GNU/Linux # dmesg | grep r8152 [ 5.246547] usbcore: registered new device driver r8152-cfgselector [ 5.492500] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 5.798285] r8152 2-1.4:1.0 eth0: v1.12.13 [ 5.825026] usbcore: registered new interface driver r8152 [ 6.057832] r8152 2-1.4:1.0 end1: renamed from eth0 [ 10.098029] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 10.218126] r8152 2-1.4:1.0 eth0: v1.12.13 [ 10.666024] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 10.744275] r8152 2-1.4:1.0 eth0: v1.12.13 [ 10.935926] r8152 2-1.4:1.0 end1: renamed from eth0 [ 14.284797] r8152 2-1.4:1.0 end1: carrier on # ethtool -i end1 driver: r8152 version: v1.12.13 firmware-version: rtl8156a-2 v2 04/27/23 # ./iperf3 -c 192.168.xx.30 -p 5201 Connecting to host 192.168.xx.30, port 5201 [ 5] local 192.168.xx.43 port 50652 connected to 192.168.xx.30 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 282 MBytes 2.36 Gbits/sec [ 5] 1.01-2.01 sec 280 MBytes 2.34 Gbits/sec [ 5] 2.01-3.01 sec 278 MBytes 2.33 Gbits/sec [ 5] 3.01-4.01 sec 282 MBytes 2.36 Gbits/sec [ 5] 4.01-5.01 sec 280 MBytes 2.35 Gbits/sec [ 5] 5.01-6.01 sec 280 MBytes 2.35 Gbits/sec [ 5] 6.01-7.01 sec 268 MBytes 2.25 Gbits/sec [ 5] 7.01-8.00 sec 281 MBytes 2.36 Gbits/sec [ 5] 8.00-9.00 sec 281 MBytes 2.35 Gbits/sec [ 5] 9.00-10.01 sec 281 MBytes 2.35 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.01 sec 2.73 GBytes 2.34 Gbits/sec sender [ 5] 0.00-10.01 sec 2.73 GBytes 2.34 Gbits/sec receiver iperf Done. # ./iperf3 -c 192.168.xx.30 -p 5201 -R Connecting to host 192.168.xx.30, port 5201 Reverse mode, remote host 192.168.xx.30 is sending [ 5] local 192.168.xx.43 port 50656 connected to 192.168.xx.30 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 230 MBytes 1.93 Gbits/sec [ 5] 1.00-2.00 sec 226 MBytes 1.90 Gbits/sec [ 5] 2.00-3.00 sec 222 MBytes 1.86 Gbits/sec [ 5] 3.00-4.00 sec 224 MBytes 1.88 Gbits/sec [ 5] 4.00-5.01 sec 232 MBytes 1.94 Gbits/sec [ 5] 5.01-6.00 sec 230 MBytes 1.93 Gbits/sec [ 5] 6.00-7.00 sec 231 MBytes 1.94 Gbits/sec [ 5] 7.00-8.01 sec 232 MBytes 1.95 Gbits/sec [ 5] 8.01-9.01 sec 229 MBytes 1.92 Gbits/sec [ 5] 9.01-10.00 sec 228 MBytes 1.91 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 2.23 GBytes 1.92 Gbits/sec 92 sender [ 5] 0.00-10.00 sec 2.23 GBytes 1.92 Gbits/sec receiver iperf Done. # ./iperf3 -c 192.168.xx.30 -p 5201 --bidir Connecting to host 192.168.xx.30, port 5201 [ 5] local 192.168.xx.43 port 50661 connected to 192.168.xx.30 port 5201 [ 7] local 192.168.xx.43 port 50662 connected to 192.168.xx.30 port 5201 [ ID][Role] Interval Transfer Bitrate [ 5][TX-C] 0.00-1.01 sec 234 MBytes 1.95 Gbits/sec [ 7][RX-C] 0.00-1.01 sec 225 MBytes 1.87 Gbits/sec [ 5][TX-C] 1.01-2.01 sec 209 MBytes 1.75 Gbits/sec [ 7][RX-C] 1.01-2.01 sec 229 MBytes 1.92 Gbits/sec [ 5][TX-C] 2.01-3.01 sec 225 MBytes 1.89 Gbits/sec [ 7][RX-C] 2.01-3.01 sec 228 MBytes 1.92 Gbits/sec [ 5][TX-C] 3.01-4.00 sec 235 MBytes 1.98 Gbits/sec [ 7][RX-C] 3.01-4.00 sec 227 MBytes 1.91 Gbits/sec [ 5][TX-C] 4.00-5.01 sec 236 MBytes 1.98 Gbits/sec [ 7][RX-C] 4.00-5.01 sec 228 MBytes 1.91 Gbits/sec [ 5][TX-C] 5.01-6.01 sec 219 MBytes 1.84 Gbits/sec [ 7][RX-C] 5.01-6.01 sec 226 MBytes 1.90 Gbits/sec [ 5][TX-C] 6.01-7.01 sec 185 MBytes 1.55 Gbits/sec [ 7][RX-C] 6.01-7.01 sec 230 MBytes 1.93 Gbits/sec [ 5][TX-C] 7.01-8.00 sec 253 MBytes 2.13 Gbits/sec [ 7][RX-C] 7.01-8.00 sec 191 MBytes 1.61 Gbits/sec [ 5][TX-C] 8.00-9.00 sec 242 MBytes 2.03 Gbits/sec [ 7][RX-C] 8.00-9.00 sec 227 MBytes 1.90 Gbits/sec [ 5][TX-C] 9.00-10.01 sec 237 MBytes 1.98 Gbits/sec [ 7][RX-C] 9.00-10.01 sec 182 MBytes 1.52 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID][Role] Interval Transfer Bitrate Retr [ 5][TX-C] 0.00-10.01 sec 2.22 GBytes 1.91 Gbits/sec sender [ 5][TX-C] 0.00-10.01 sec 2.22 GBytes 1.91 Gbits/sec receiver [ 7][RX-C] 0.00-10.01 sec 2.15 GBytes 1.84 Gbits/sec 25 sender [ 7][RX-C] 0.00-10.01 sec 2.14 GBytes 1.84 Gbits/sec receiver Edited January 18 by ebin-dev 0 Quote
prahal Posted January 18 Posted January 18 On 1/16/2025 at 9:01 PM, BipBip1981 said: System work well with Kernel 6.12 and DTB patch, juste a problem with the service folow. Can you reproduce the helios64 crash without the dtb patch? On 1/16/2025 at 9:01 PM, BipBip1981 said: Jan 16 20:26:24 helios64 bash[2906]: tee: '/sys/class/leds/helios64::status/trigger': No such file or directory Could you provide output from /sys/class/leds/ with and without the dtb patch? (and by dtb patch could you confirm you mean you replace the full dtb file, not edit the dtb via dtc or armbian-config to only changed the emmc/opp voltages? I am on 6.12.1-edge-rockchip64 from linux-image-edge-rockchip64 24.11.1 with vanilla armbian dtb and the leds trigger file exists for helios64::status phn@helios64:~$ ls /sys/class/leds/ helios64:blue:hdd-status helios64:blue:power-status helios64:red:ata1-err helios64:red:ata3-err helios64:red:ata5-err helios64::status helios64:blue:net helios64:blue:usb3 helios64:red:ata2-err helios64:red:ata4-err helios64:red:fault mmc0:: phn@helios64:~$ ls /sys/class/leds/helios64\:\:status brightness device invert max_brightness power subsystem trigger uevent 0 Quote
ebin-dev Posted January 18 Author Posted January 18 (edited) 16 hours ago, prahal said: Could you provide output from /sys/class/leds/ with and without the dtb patch? The output using the original dtb of linux 6.12.10 (vanilla Armbian) looks like this: # uname -a Linux grid 6.12.10-current-rockchip64 #2 SMP PREEMPT Fri Jan 17 12:41:00 UTC 2025 aarch64 GNU/Linux # ls /sys/class/leds/ helios64:blue:hdd-status helios64:blue:net helios64:blue:power-status helios64:blue:usb3 helios64:green:status helios64:red:ata1-err helios64:red:ata2-err helios64:red:ata3-err helios64:red:ata4-err helios64:red:ata5-err helios64:red:fault mmc1:: # ls /sys/class/leds/helios64\:\:status ls: cannot access '/sys/class/leds/helios64::status': No such file or directory And the output using the patched dtb (voltages and hs400) for linux 6.12.10 looks like this: # ls /sys/class/leds/ helios64:blue:hdd-status helios64:blue:net helios64:blue:power-status helios64:blue:usb3 helios64:green:status helios64:red:ata1-err helios64:red:ata2-err helios64:red:ata3-err helios64:red:ata4-err helios64:red:ata5-err helios64:red:fault mmc1:: # ls /sys/class/leds/helios64\:\:status ls: cannot access '/sys/class/leds/helios64::status': No such file or directory The output is identical. I have also noticed this with linux 6.12.7: 'helios64::status' is simply missing. Edited January 19 by ebin-dev 0 Quote
prahal Posted January 20 Posted January 20 from reading the dts there is a helios64:green:status which does not show in 6.12.1 from armbian edge but does in 6.12.9 armbian current. On the opposite side helios64::status is listed in the 6.12.1 but not the 6.12.9. I guess the "green" was discarded from the sysfs file name before but no more. If the fact "green" is not removed anymore is a feature the systemd service helios64-heartbeat-led.service will have to be modified to cope with both file names. It might be a good idea to rename this gpio line as helios64:blue:status (as the led is blue not green). I wonder why it was labelled as green, maybe as a hackish way to have the color not included in the sysfs gpio led file name, as it seems green was not preserved in the sysfs name before around Linux 6.12.9. Or maybe labelling a system led OK status as green is a convention. That would require research as I know few about gpio leds conventions, and that would be better done now, before hard-coding "green" in the helios64-heartbeat-led.service systemd service. 0 Quote
halfa Posted Monday at 10:27 AM Posted Monday at 10:27 AM I've been running 6.12.9-current-rockchip64 for a bit more than a week after upgrading from 6.6.x, no issues so far besides the same issue with the status led service crashing. I'm running the 6.12.x dtb. $ ls /sys/class/leds/ helios64:blue:hdd-status helios64:blue:power-status helios64:green:status helios64:red:ata2-err helios64:red:ata4-err helios64:red:fault helios64:blue:net helios64:blue:usb3 helios64:red:ata1-err helios64:red:ata3-err helios64:red:ata5-err mmc1:: restarting to update to the latest 6.12.11-current-rockchip64, without replacing the dtb, I get the same output. md5sum /boot/dtb-6.12.9-current-rockchip64/rockchip/rk3399-kobol-helios64.dtb f4ca4834257ed410cbc53d994a251df0 /boot/dtb-6.12.9-current-rockchip64/rockchip/rk3399-kobol-helios64.dtb 0 Quote
kantantana Posted Tuesday at 12:31 PM Posted Tuesday at 12:31 PM root@helios64:/etc/systemd/system# uname -a Linux helios64 6.12.11-current-rockchip64 #1 SMP PREEMPT Thu Jan 23 16:23:05 UTC 2025 aarch64 GNU/Linux root@helios64:/etc/systemd/system# zfs version zfs-2.2.7-1~bpo12+1 zfs-kmod-2.2.7-1~bpo12+1 Check it out, its zfs on the latest kernel on helios64! I upgraded from the original buster back from 2021, it was running for years and had uptime more than 850 days. root@helios64:/etc/apt# cat sources.list deb http://deb.debian.org/debian/ bookworm main contrib deb-src http://deb.debian.org/debian/ bookworm main contrib deb http://security.debian.org/debian-security bookworm-security main deb-src http://security.debian.org/debian-security bookworm-security main deb http://deb.debian.org/debian/ bookworm-updates main deb-src http://deb.debian.org/debian/ bookworm-updates main deb http://deb.debian.org/debian bookworm-backports main contrib deb-src http://deb.debian.org/debian bookworm-backports main contrib The important part is the last bookworm-backports main contrib, thats where the zfs in right version comes from, also cat preferences.d/90_zfs Package: src:zfs-linux Pin: release n=bookworm-backports Pin-Priority: 990 I have the dtb from a dropbox link in here from Croatian-flag guy, and ondemand governor from 480 to 1.2ghz. Pretty stable so far, just have to set correct fan settings and drive standby time. Check your smartctl -a for drive-power-on cycles or spin-down-spin-up cycles, the stupid smartmontools smartd was causing the drives to spin up just because it was checking their values. My drives are now on 82k cycles, sigh. What power usage do you get from wall-meter, mine is on 11watt when all drives are powered down with hdparm -Y 0 Quote
prahal Posted Wednesday at 02:52 AM Posted Wednesday at 02:52 AM About the helios64-hearttbeat-led.service I found the cause. When I synced the armbian dts to the upstream one the fact there was a "green" in thre label of the upstream dts slipped through. I will revert this change back to helios64::status instead of helios64:green:status. (the issue was introduced in armbian 6.9 kernels). 0 Quote
kantantana Posted 18 hours ago Posted 18 hours ago (edited) Here is my dmesg about ata errors, [115174.042282] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [115174.044617] ata1.00: configured for UDMA/133 [119440.785506] ata2.00: exception Emask 0x0 SAct 0x100000 SErr 0x0 action 0x6 [119440.785537] ata2.00: waking up from sleep [119440.785554] ata2: hard resetting link [119440.785705] ata3.00: exception Emask 0x0 SAct 0x400000 SErr 0x0 action 0x6 [119440.785741] ata3.00: waking up from sleep [119440.785765] ata3: hard resetting link [119440.785813] ata4.00: exception Emask 0x0 SAct 0x80000000 SErr 0x0 action 0x6 [119440.785846] ata4.00: waking up from sleep [119440.785869] ata4: hard resetting link [119441.249776] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119441.253555] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119441.253794] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119450.515441] ata3.00: configured for UDMA/133 [119450.515514] ata3: EH complete [119450.734103] ata2.00: configured for UDMA/133 [119450.734159] ata2: EH complete [119450.763936] ata4.00: configured for UDMA/133 [119450.763985] ata4: EH complete [119450.869312] ata5.00: exception Emask 0x0 SAct 0x40 SErr 0x0 action 0x6 [119450.869329] ata5.00: waking up from sleep [119450.869338] ata5: hard resetting link [119451.337659] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119460.873060] ata5.00: configured for UDMA/133 [119460.873117] ata5: EH complete This basically happens every time I do hdparm -Y /dev/the/drives to put them to sleep, whenever they wake up. For some reason, they wake up within seconds, oh well. The 1gbit interface sucks and gives me only 34MB/s, even with the tx on and so on, in the dmesg there is something relevant about it [ 18.692986] r8152 2-1.4:1.0: checksum fail [ 18.693009] r8152 2-1.4:1.0: unable to load firmware patch rtl_nic/rtl8156a-2.fw (-14) [ 18.744799] r8152 2-1.4:1.0 eth0: v1.12.13 [ 18.744919] usbcore: registered new interface driver r8152 [ 18.776374] r8152 2-1.4:1.0 enx646266d00ac5: renamed from eth0 edit: I fixed the rtl_nic files from the latest linux-firmware, now it can load the firmware and says # dmesg |grep r8152 [ 18.094121] usbcore: registered new device driver r8152-cfgselector [ 18.265347] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 18.429147] r8152 2-1.4:1.0 eth0: v1.12.13 [ 18.429410] usbcore: registered new interface driver r8152 [ 18.482268] r8152 2-1.4:1.0 enx646266d00ac5: renamed from eth0 # ethtool -i enx646266d00ac5 driver: r8152 version: v1.12.13 firmware-version: rtl8156a-2 v2 04/27/23 But still, iperf3 says barely 200mbit/s, this is on the 1gbit interface. Another laptop towards same server, on same lan same switch gets 950mbit/s. I have the ondemand governor, and cpufreq settings and affinity in rc.local The 2.5gbit interface is unusable, tried many different options, but at most I can get iperf to finish once or twice, but third time it goes down to 0 and dmesg says reset. But I have only a cat 5e to test with. This helios64 doesnt have the hardware soldering fix. Edited 17 hours ago by kantantana 0 Quote
ebin-dev Posted 15 hours ago Author Posted 15 hours ago (edited) 8 hours ago, kantantana said: The 2.5gbit interface is unusable, tried many different options, but at most I can get iperf to finish once or twice, but third time it goes down to 0 and dmesg says reset. But I have only a cat 5e to test with. This helios64 doesnt have the hardware soldering fix. The limited transfer rates of 200Mbit/s might be caused by a bad cable or a bad connection (dust in the connector ?). The 2.5G interface is unusable because of the missing hardware soldering fix. It doesn't work without it, at least if you connect it to a 2.5G switch. Did you have a look at the processor utilization while accessing the server ? ZFS is certainly a burden on the CPUs and not known as particularly fast. XFS would be an option (I am still using ext4). Edited 9 hours ago by ebin-dev 0 Quote
prahal Posted 3 hours ago Posted 3 hours ago (edited) 18 hours ago, kantantana said: Here is my dmesg about ata errors, [115174.042282] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [115174.044617] ata1.00: configured for UDMA/133 [119440.785506] ata2.00: exception Emask 0x0 SAct 0x100000 SErr 0x0 action 0x6 [119440.785537] ata2.00: waking up from sleep [119440.785554] ata2: hard resetting link [119440.785705] ata3.00: exception Emask 0x0 SAct 0x400000 SErr 0x0 action 0x6 [119440.785741] ata3.00: waking up from sleep [119440.785765] ata3: hard resetting link [119440.785813] ata4.00: exception Emask 0x0 SAct 0x80000000 SErr 0x0 action 0x6 [119440.785846] ata4.00: waking up from sleep [119440.785869] ata4: hard resetting link [119441.249776] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119441.253555] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119441.253794] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119450.515441] ata3.00: configured for UDMA/133 [119450.515514] ata3: EH complete [119450.734103] ata2.00: configured for UDMA/133 [119450.734159] ata2: EH complete [119450.763936] ata4.00: configured for UDMA/133 [119450.763985] ata4: EH complete [119450.869312] ata5.00: exception Emask 0x0 SAct 0x40 SErr 0x0 action 0x6 [119450.869329] ata5.00: waking up from sleep [119450.869338] ata5: hard resetting link [119451.337659] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [119460.873060] ata5.00: configured for UDMA/133 [119460.873117] ata5: EH complete This basically happens every time I do hdparm -Y /dev/the/drives to put them to sleep, whenever they wake up. For some reason, they wake up within seconds, oh well. These are not error messages but information messages. Ie "waking up from sleep" messages when the device wakeup. Edit: I will have to investigate. "exception Emask 0x0 SAct 0x40 SErr 0x0 action 0x6" and hard resetting the link on wake-up from HDD sleep might not be normal after all. Edited 41 minutes ago by prahal reconsidered the issue 0 Quote
