Trouble Building and Loading the `rbd` Module with Armbian Kernel
Go to solution Solved by schwar3kat,
Hello, Armbian community,
I've been trying to build the Armbian kernel for my board "Orange Pi 5" with the rbd (RADOS Block Device) module enabled. I followed the standard build procedure using Armbian's build tools, and I explicitly enabled the rbd support during the menuconfig step. Despite doing this, after completing the build and installation processes, I'm unable to load the rbd module.
When I attempt to load the module with modprobe rbd, I get the following error:
modprobe: FATAL: Module rbd not found in directory /lib/modules/5.10.160-rk35xx
Here are the steps I followed:
1. Cloned the Armbian Build Repository.
2. Started the kernel configuration using:
./compile.sh
1. In Menuconfig, I navigated to Device Drivers > Block devices and enabled Rados block device (RBD) support as a module.
2. Continued with the build process and installed the newly built kernel.
3. Booted the board and tried to load the module, which resulted in the error.
Has anyone faced a similar issue or can you provide guidance on what I might be doing wrong or missing? Any help or suggestions would be much appreciated!
I really appreciate any help you can provide.
Thank you for your response.
I understand the importance of the appropriate privileges. I did indeed try the modprobe command with sudo earlier, but I still received the same error:
To ensure I was running the most up-to-date software, I also executed `sudo apt update && sudo apt upgrade -y`, but unfortunately, the issue persists.
Thank you, @Werner. I've already left my house, but I'll quickly check the kernel config in `/boot` as soon as I get home. Just for my understanding, if the mentioned module is not marked as M there, the next step would be to re-compile the kernel, correct? If it is marked as M, do you have any further recommendations?
And @schwar3kat, I appreciate you taking the time to look into this. Yes, as seen in the previous screenshot, compiling the kernel took around 2 hours for me. It's kind of you to offer your assistance despite not having my board or familiarity with the Rados block device.
  • Solution
Just started - and I can see it configured in the Makefile.  "obj-$(CONFIG_BLK_DEV_RBD)     += rbd.o"
Halfway through - and it's built the module object.  "rdb.o"
Completed - and I can see the file "rdb.o" in the image in "/lib/modules/5.10.160-rk35xx/kernel/drivers/block" which is correct. (Do you have this in your image?).
/boot/config-5.10.160-legacy-rk35xx contains  "CONFIG_BLK_DEV_RBD=m" as expected.
Looks okay as far as i understand, but I'm no expert.  Did you save your new configuration after selection and exits?
Your second build on the same clone should be faster because of caching.
I apologize, but I still haven’t figured out how to correctly build an image with RBD support. Could you share detailed instructions?
1. Cloned and started build script.
git clone --depth=1 --branch=main https://github.com/armbian/build
./compile.sh
2. In Menuconfig Device Drivers > Block devices > Rados block device (RBD) set <M>.
3. Saved config as .conf and continued build process.
4. In the end, I received the image Armbian_23.11.0-trunk_Orangepi5-plus_bookworm_legacy_5.10.160.img from which I downloaded, but there is no module in it.
I read the thread several times but still don’t understand how the topicstarter solved the problem.
@Dexogen I followed the same instructions as you did to build the image, but I encountered a snag. After running `apt update && apt upgrade`, the `rbd` module seemed to get overwritten somehow. I stopped investigating further when I found that using `ubuntu jammy edge` worked for me. I hope this helps!
@LoneExile Thanks for the answer! Unfortunately, I need the Debian version of the distribution because I'm installing Proxmox. I discovered that the default build bookworm_edge_6.6.0-rc1 contains the RBD module. But here I encountered the surprising behavior of the Orange Pi 5 Plus board: now it boots not every time. I literally have to switch the power supply several times until the OS boots. This does not happen on the bookworm_legacy_5.10.160 kernel version. I have three identical Oragne Pis with different power supplies and this problem is reproduced on the bookworm_edge_6.6.0-rc1 kernel.  But this is a question for a another thread. Nevertheless thank you!
By some miracle I built a legacy kernel 5.10.160 with RBD support. I can't say exactly what exactly helped, but I did the following:
1. I literally added output/config/linux-* and config/kernel/linux-* to every file:
2. Added to ./config/boards/orangepi5-plus.conf
MODULES="rbd"
3. Repeated previous build instructions.
And on this kernel the OPie5+ boots without problems every time.
Thanks, @Dexogen, this was helpful for me. I found that the MODULES line wasn't needed, and specifically the linux-rk35xx-legacy kernel config file is used for these boards.
Here were the full steps I followed to successfully build an Armbian image with ceph RBD & cephfs support for a PVE arm64 installation. I built on an Ubuntu Jammy qemu VM running on an x86 Proxmox host, and ran as a normal user with sudo privileges as per the Armbian build docs. I needed to ensure the machine could reach external DNS (I think Cloudflare but I just allowed all outbound UDP/TCP 53) to build successfully - I only allow certain DNS servers in my network. You also need more than 10GB free space for the build to complete successfully. Ignore the warnings regarding shallow build.
cd build
sed -i 's/.*CONFIG_BLK_DEV_RBD.*/CONFIG_BLK_DEV_RBD=m/' config/kernel/linux-rk35xx-legacy.config
sed -i 's/.*CONFIG_CEPH_FS.*/CONFIG_CEPH_FS=m/' config/kernel/linux-rk35xx-legacy.config
./compile.sh build BOARD=orangepi5-plus BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=bookworm
I also have some Rock 5b boards, you can simply replace 'orangepi5-plus' with 'rock-5b' in the above commands to build for that board.
It's also currently necessary to downgrade the bundled edk2 firmware for rk3588 to succesfully boot VMs. I used the following commands:
apt download pve-edk2-firmware=3.20220526-1 && dpkg -i pve-edk2-firmware_3.20220526-1_all.deb && rm pve-edk2-firmware*.deb
echo 'Package: pve-edk2-firmware
Pin: version 3.20220526-1
Pin-Priority: 999' > /etc/apt/preferences.d/pve-edk2-firmware
Edited by rinseaid
