  On 2/26/2018 at 1:02 PM, balbes150 said:
Try starting the system from external media and manually mounting the /dev/data partition. Check it for errors and see how the system formed on it.
Expand
I try again Still same error when I lunch debian from the emmc
I can mount the emmc from the sdcard wo error I lunch the script wo error but when it's time to boot from the emmc It's faill
I get this error on first boot from the sdcard
PS this try was done with https://yadi.sk/d/m6P1mLUbuHcHG/S812/Linux/Armbian/5.41/Armbian_5.41_S812_Debian_stretch_3.10.108_server_20180227.img.xz
  On 3/3/2018 at 7:42 AM, balbes150 said:
If there are corrupted files on the SD card, the system cannot be properly copied to the eMMC.
Expand
I just try 4 USB stick and 2 sdcard and Still same result
Can inerase all this partition on the emmc?
with more detail
(parted) print list
Model:   (scsi)
Disk /dev/sda: 2005MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      4194kB  138MB   134MB   primary  fat16        lba
 2      138MB   1795MB  1657MB  primary  ext4
Error: /dev/boot: unrecognised disk label
Model: Unknown (unknown)
Disk /dev/boot: 33.6MB
Sector size (logical/physical): 512B/524288B
Partition Table: unknown
Disk Flags:
Disk /dev/data: 5578MB
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  5578MB  5578MB  ext4
Error: /dev/logo: unrecognised disk label
Disk /dev/logo: 33.6MB
Disk Flags:
Error: /dev/misc: unrecognised disk label
Disk /dev/misc: 33.6MB
Disk Flags:
Disk /dev/cache: 537MB
Disk Flags:
 1      0.00B  537MB  537MB  ext4
Disk /dev/system: 1074MB
Disk Flags:
 1      0.00B  1074MB  1074MB  ext4
Error: /dev/recovery: unrecognised disk label
Disk /dev/recovery: 33.6MB
Disk Flags:
I'll format all of them to see ...
once connected on the sdcard runing ambian
I try to mount /dev/boot
It's not work. So going to /boot/dtb and then cp a dtb file move it to /boot/dtb.img
Now I not abble to boot the system at all :D
In log first boot on the usbstick second boot on emmc
M8S12.log
This is normal ?
[    7.589663@0] ALSA device list:
[    7.592714@0]   #0: AML-M8AUDIO
[    7.596011@0] Freeing unused kernel memory: 220K
[    7.600544@1] Failed to execute /init
[    7.608150@1] request_module: runaway loop modprobe binfmt-abcd
[    7.613077@2] Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[    7.623931@3] CPU3: stopping
Expand
OK the install script doesnt work but can run this board in headlesse mod ?
Actually if the hdmi not pluged it's doesn't boot!
Hi folks,
I've got a more rare flavor of m8s+ sold in Russia as Redmond SkyTVbox RSA-100S. It has got very buggy Android firmware. That's why I want to swap it for Linux. The box has root out of the box and can boot from SD and usb. Unfortunately none of the dbt.img files worked for me( I tried many). It boots and goes through resizing the ext4 partition, but after that it hangs and were never able to get HDMI screen working(it's just black and no terminal prompt). If I don't place the dbt file in the root of fat partition it throws some logs to the screen (yes, HDMI) and crashes with kernel panics due to interrupts issue. I took photos of her mb. Please check it out and let me know if you have any ideas for me. Thanks!d0708836e536c904697820e89b4c85b9.jpg7158db9153505b5e27b141155b8e7e36.jpg
Sent from my ONEPLUS A3003 using Tapatalk
  On 3/13/2018 at 6:18 PM, windumasta said:
We have the same issue but not the same card !
Di you tray witjout the dtbFile ?
Thanks for your reply! Yes I tried with out dtb file and received different results. Sometimes it were freezing very early and black screen. Other times would throw kernel panics to the HDMI screen and exit. One time I were lucky to get the login promp, but it crashed after I tried to change password. Couldn't get to it again never after that. I'm suspecting that the power supply is not enough. I were using stock 2 amper power adapter. Planning to try 4a once I get hold of it.
Update image kernel 4.x for s802\s812 20180327
https://yadi.sk/d/-3WALlEG3FyTvs
Works wired network and USB (you can run the system from a USB flash drive). The display does not work. This image is compiled using Martin Blumenstingl kernel sources. Welcome feedback in the form of logs of system start-up using the UART on different models S812.
Update the Volumio image for S802\S812 0.2 20180327.
Audio output works through the standard HDMI output. So far it is implemented with dtb file for "meson8m2_n200_2G_volumio.dtb" . For those who use other dtb files, please write the names of the files (to enable output via the regular HDMI i'm need to make changes to the dtb file).
https://yadi.sk/d/vAHmhi0w3REpkT
forum
https://volumio.org/forum/volumio-fo...812-t8028.html
New test version of the server image 20180402 with kernel 4.X. in this version the wired network works and it is possible to start system from the SD card or USB media.
Update images kernel 3.10.108 20180402.
The main change - updated kernel (possible problems with some equipment).
@balbes150 I'm new to the @mlogic world,  from surfing the web you seem to be the one of the foremost experts of the platform so 1st off thank you for all your hard work you do for the community.  Recently i bought a MBOX MXIII (I'm sure it's some clone) k200C, is there away / somewhere in the kernel i can look to figure out if it is actually an s812 or s802 i know it has the ap6330 WiFi module.  I'd really like to avoid taking the heat sink off which seems to be what most people suggest i'd have to do to know what SoC it has.
Expand
You don't need to disassemble the TV box. Try all the dtb files. According to the file with which the TV box will work, it will be clear which model you have.
Hello balbes150
I'm trying to use your armbian s812 builds on my device : it's a Wetek Core, with Libreelec installed on nand.
From what I understand, I'm in a particular case since my box already supports booting from sdcard, but it doesn't work for your builds (sdcard not seen as bootable by my box).
So, I applied your autoscript to activate universal multiboot.
Now my box detect your builds on sdcard (not on usb), boot on it but is stuck (with screen no signal) with every dtbs I tried.
I think the wetek proprietary multiboot script is in conflict with your.
Here is my fw_printenv ...  thank you if you can help me :
  Reveal hidden contents
Edit : I manage to boot by using dtb and uimage of libreelec for my device (3.10.99)
Balbes : can you repost old 3.10.99 debian or ubuntu links ? they are no more on your yandex
EDIT: Issue resolved. Needed to initialize the disk and create a partition using another system first.
Edited by Huskion
Hi @balbes150
Thanks for all the hard work you put on this images.
I have one question:
Installed "Armbian_5.41_S812_Ubuntu_xenial_3.10.108_mate_20180402.img.xz" on my box.
Everything works fine except running Kodi. I get this output:
/usr/lib/arm-linux-gnueabihf/kodi/kodi-xrandr: Failed to get size of gamma for output default
libEGL warning: DRI2: failed to authenticate
Segmentation fault
Is it possible to run Kodi with hardware acceleration on these images?
  On 4/27/2018 at 8:07 AM, balbes150 said:
Yes, it is possible if you build the necessary version of KODI yourself.
Expand
Ok, I can try that if you help me :)
Cloned your xmbc repository and trying to build "AML-Leia".
Running "./kodi_cmake" gives:  "Could NOT find AML (missing: AML_INCLUDE_DIR)"
What package/repository do I need to build?
Expand
Oh, at least one of the users is not requests to all do for free, decided to help. That's very good. Yes, I will help with the description and steps. First you need to add libMali and amlcodec (you can just copy the working files from Libreelec version to Armbian). Then set all dependencies for the Assembly. Uncomment SRC repositories and execute "apt build-dep kodi" . Alternatively, you can view the KODI build options and build order for The odroid C1 in ArchLinux.
https://github.com/150balbes/PKGBUILDs/blob/amlogic/alarm/kodi-c1/PKGBUILD
  On 1/6/2018 at 4:50 PM, balbes150 said:
Do I understand correctly that you are using the same SD card to activate the multi-boot on all TV boxes ? On some TV boxes activation takes place this SD card, and one model does not work (error message with a photo) ?
Judging by the logs, you have a model n200C . So you need to pick up the dtb from this group. When you start with dtb n200C_1GB system starts but a lot of mistakes from the media. Multiboot you have already activated, so try to use a USB flash drive to capture the image and add dtb n200C_1GB. I have my doubts that your model has real 2GB of RAM, it is desirable to open the case and get the brand of memory chips.
Perhaps the manufacturer specially recorded in the built-in dtb is not correct RAM, the kernel in Armbian itself checks for physical memory access and sets the real value (which it itself received under test).
Expand
Hi all,
I'm still stuck at this point. I created diferent SD card with debian or ubuntu, but at this point autoscript gives me always the same answer. Do have any idea I can test / do to make it happen?
  On 5/1/2018 at 11:11 PM, Gossamer said:
Hi all,
Expand
Hi all,
Last night I managed to make it happen.
I searched around but I'm still not able to apply aml_autoscript from update & backup and it always gives me header/footer signature errors.
I conencted the board using serial console and defined/update environment variable myself :) (copying from the aml_script).
I had some problems with syntax errors for typos but at the end It worked!!
For the next step I will search how to include wifi drivers for ap6330 and blutooth.
Cheers ! :P
Update image kernel 4.17
Armbian_5.41.1_S812_Ubuntu_xenial_4.17.0-rc3_server_20180502.img.xz
Use console UART or SSH
Hey ,
I have tried almost all the dtb files with several versions..but the wired network and wifi refuse to work ..it boots fine.
I have UART, but it doesn't show anything abnormal.
My Chipset is Netxeon M82G V2.1 with Amlogic S812, with network chip AP6330
though this seems to happen in every single build
Thanks in advance :)
