wzor Posted May 25, 2017 Posted May 25, 2017 1 hour ago, balbes150 said: Try to set configuration file /boot/hdmi.sh or /boot/amlogics905x_init.sh value instead "mode=720p" to "mode=1080i59Hz" not working(((
RaptorSDS Posted May 25, 2017 Posted May 25, 2017 7 hours ago, balbes150 said: You need to compare what is written in the normal dtb and put it in the new to check. sorry but your meson8m2_n200_2gb.dtb hasnt any led infos. i search google for android and other m8s dtb/dts but also no led infos inside this files . i found only this info about led config https://lists.freebsd.org/pipermail/freebsd-arm/2015-February/010126.html there is a info about gpio ao 13 , how i write this to the dts ( is red right or blue ?) or maybe complet wrong. Maybe LED dont control by GPIO only by power state ? red_led_gpio = "GPIOAO_13"; blue_led_gpio = <0x13>; (or 0xc8100024 )
balbes150 Posted May 26, 2017 Posted May 26, 2017 You have the source code from the regular dtb (used in firmware) ?
RaptorSDS Posted May 26, 2017 Posted May 26, 2017 2 hours ago, balbes150 said: You have the source code from the regular dtb (used in firmware) ? no i do not have extract the dtb from the android that is on the box
balbes150 Posted May 26, 2017 Posted May 26, 2017 Uploaded the new version of the initialization script monitor (hdmi.sh) with support of resolution 1080. To use simply replace the script in the image to a new version. Please try in both modes (720 and 1080). For use on older images you need to rename amlogics905x_init.sh or change the call line in /etc/rc.local . https://yadi.sk/d/L-F3RlhX3JYtif
wzor Posted May 27, 2017 Posted May 27, 2017 18 hours ago, balbes150 said: Uploaded the new version of the initialization script monitor (hdmi.sh) with support of resolution 1080. To use simply replace the script in the image to a new version. Please try in both modes (720 and 1080). For use on older images you need to rename amlogics905x_init.sh or change the call line in /etc/rc.local . https://yadi.sk/d/L-F3RlhX3JYtif Does not work((( "Armbian_5.27_S812_Ubuntu_xenial_3.10.99_server_20170526" armbian31099.log And "Armbian_5.24_Vegas812_Ubuntu_xenial_3.10.99_desktop_20170113" works ! _armbian31099.log
balbes150 Posted May 27, 2017 Posted May 27, 2017 1 hour ago, wzor said: Armbian_5.24_Vegas812_Ubuntu_xenial_3.10.99_desktop_20170113 What dtb are used ?
balbes150 Posted May 27, 2017 Posted May 27, 2017 The name of the dtb file that you would use in 20170113 ? In the image 20170526 have you tried all the dtb files that are in the directory /dtb ?
wzor Posted May 27, 2017 Posted May 27, 2017 meson8m2_n200_m8s_plus.log meson8m2_n200C_2G.log meson8m2_n200_m8s.log meson8m2_n200_2G.dtb.log
balbes150 Posted May 27, 2017 Posted May 27, 2017 Spoiler Какой dtb файл (имя) используется в версии 20170113 ?
wzor Posted May 27, 2017 Posted May 27, 2017 Spoiler имя meson8m2_n200_m8s_plus переименовыл в dts.img.
balbes150 Posted May 27, 2017 Posted May 27, 2017 All files means - all the files including meson8_k200.
balbes150 Posted May 27, 2017 Posted May 27, 2017 Try this version of the dtb file with 20170526. https://yadi.sk/d/5Yujtmen3Ja535
wzor Posted May 27, 2017 Posted May 27, 2017 No load((( meson8m2_n200_2G_M8SPlus.log The problem is not dtb files. The problem in the kernel.
balbes150 Posted May 27, 2017 Posted May 27, 2017 Try this file. The reason is not in the kernel. The reason for the dtb. Need to choose the parameters. https://yadi.sk/d/dnGiOmKV3Ja6pi
balbes150 Posted May 27, 2017 Posted May 27, 2017 update dtb meson8m2_n200_m8s_plus https://yadi.sk/d/qm-o7QH03JWPEg
balbes150 Posted May 27, 2017 Posted May 27, 2017 Spoiler Перезалил файл, пробуй. На сегодня - всё, вариантов пока нет.
wzor Posted May 27, 2017 Posted May 27, 2017 Spoiler Заработал но на полоску вверху экрана! Разрешение меня 720 и 1080, полоска только уже становится. meson8m2_n200_m8s_plus(2).log
balbes150 Posted May 27, 2017 Posted May 27, 2017 Spoiler Если знаком с утилитой dtc , распакуй этот dtb и пробуй сравить параеметры из meson8m2_n200_2G и постепенно подбирать, а потом упаковать.
wzor Posted May 27, 2017 Posted May 27, 2017 Spoiler распаковал но что там менять, и главное на что(((( Почему в январском образе прекрасно работало с моим дтб? Только с сетью проблемы и сервис хостнаме не подгружались. PS. Решил с разрешением, заменил hdmi.sh на старый vegas805_init.sh и все заработало!!!! СПАСИБО ЗА ВАШЕ ВНИМАНИЕ И ПОМОЩЬ!!!!!! Осталось несколько ошибок. 1. Failed to start Hostname service. 2. Failed to start Network Manager Wain online и что за ошибка " [ 50.294613@0] CONFIG-ERROR) dhd_conf_set_mimo_bw_cap: mimo_bw_cap setting failed -23 "
zador.blood.stained Posted May 27, 2017 Posted May 27, 2017 1 hour ago, wzor said: 1. Failed to start Hostname service. If linux-vegas812-default.config is the kernel config for this board/SoC, then it's missing CONFIG_NAMESPACES (and all namespaces inside the submenu) and some CONFIG_CGROUP_* options which may prevent some services from starting.
balbes150 Posted May 28, 2017 Posted May 28, 2017 15 hours ago, zador.blood.stained said: then it's missing CONFIG_NAMESPACES (and all namespaces inside the submenu) Adding this option to the config, causes a build error in the kernel.
balbes150 Posted May 28, 2017 Posted May 28, 2017 (edited) Show the config. Found why I gave the error (used the experimental source in which a lot changed). Edited May 28, 2017 by balbes150
