balbes150 Posted May 31, 2017 Posted May 31, 2017 Updated images Armbian 20170531. Changes to scripts activate the multi-boot and run system from external media. In the new version of the scripts allow to start the system from any USB socket (if the is connected other USB media). Back support "nodm", now in the images is used in common with the main branch Armbian authorization system. If you want you can install the package "lightdm" in version Mate-that-be to have a graphical authentication when you log into the system (just don't forget together with the installation of lightdm, remove the nodm package, otherwise they will interfere with each other). Other changes see the description of changes to main branch Armbian (replacement browser on Chromium, etc.). New scripts activate the multi-boot and system start-up can be found here. You can download them and use for old images. To reactivate the multi-boot again. https://yadi.sk/d/cEPIULGW3Jgpee https://yadi.sk/d/QCGU0PIv3G5kEa New script to activate the multi-boot on the Minix models H8x and H8x plus. https://yadi.sk/d/BU_pyfHW3JgpEP
balbes150 Posted June 1, 2017 Posted June 1, 2017 10 hours ago, wzor said: Will it be Debian? The problem of module loading. I can get the Debian images for s812. But I don't know if this is in demand. Debian has problems with the multimedia support (video playback). Which modules are not loaded ?
RaptorSDS Posted June 1, 2017 Posted June 1, 2017 should i install the new launcher script , when my system now start sd and usb ? or is there more new that i need for stable booting?
balbes150 Posted June 2, 2017 Posted June 2, 2017 11 hours ago, RaptorSDS said: should i install the new launcher script , when my system now start sd and usb ? or is there more new that i need for stable booting? 1. If you have all the normal start and there is no need to connect more than one USB storage device, then update the multiboot not required. A new version of multi-boot is needed for those who use simultaneous connection of several USB to TV box. With the old multiboot it was necessary to connect the system USB drive strictly to the first connector (which is defined by system as USB 0). With the new multi-boot option you can connect USB drives in any order (in any USB port). 2. New scripts autostart system from external media (s805_autoscript) are compatible with both-boot options.
RaptorSDS Posted June 5, 2017 Posted June 5, 2017 thanks for the new rom 3.10.99 but there are more and more problems , now i can not find my AP and also ifup wlan0 with wpa_supplicant config gives errors
balbes150 Posted June 5, 2017 Posted June 5, 2017 Now you need to load wifi modules manually (for validation) and with proper operation they must be set in the configuration file /etc/modules.
RaptorSDS Posted June 5, 2017 Posted June 5, 2017 That is the first i done, set etc/modules to 8723bs and add blacklist etc/modprobe.d/blacklist.config to dhd How can I load manually (validate) the WiFi modules
balbes150 Posted June 6, 2017 Posted June 6, 2017 What's the problem, write concretely. I understand that it is independent building the kernel ? Turn off all the WiFi modules from startup, maybe the system is waiting for answer from them.
balbes150 Posted June 8, 2017 Posted June 8, 2017 Update image 4.x Armbian_5.27_S812_Ubuntu_xenial_4.12.0+_server_20170608
freestart Posted June 9, 2017 Posted June 9, 2017 Hi to everyone, I have a tvbox beelink S82 con chip S802 with 2Gb/16gb rom android 4.4.2, I have tried all dtb files but I see only google tv logo and after black screen, I have waited loading more of 10 minutes for all dtb but nothing someone can help me? thanks! Best Regards
balbes150 Posted June 9, 2017 Posted June 9, 2017 2 hours ago, freestart said: I have a tvbox beelink S82 con chip S802 with 2Gb/16gb rom android 4.4.2, I have tried all dtb files but I see only google tv logo and after black screen, I have waited loading more of 10 minutes for all dtb but nothing someone can help me? thanks! What version image are you trying to run ? You can connect the console UART ? You have the opportunity to run Lebreelec from external media ?
freestart Posted June 9, 2017 Posted June 9, 2017 7 hours ago, balbes150 said: What version image are you trying to run ? You can connect the console UART ? You have the opportunity to run Lebreelec from external media ? Hi, thanks for answer, I am using the image version "Armbian_5.27_S812_Ubuntu_xenial_3.10.99_server_20170531.img" sorry I can't connect the console UART, I have found on internet one version Lebreelec for my device but I must try it yet, I must? I have found these Lebreelec for my device: http://download.drieschel.de/LibreElec/S82/ https://androidfilehost.com/?fid=961840155545567730 I have found this too for Tronsmart Vega S89 (clone S82): http://www.cnx-software.com/2014/05/12/how-to-extract-a-device-tree-file-from-android-firmware-files/ dts script of Tronsmart Vega S89: https://pastebin.com/zqh1vfHR
balbes150 Posted June 10, 2017 Posted June 10, 2017 Try this one dtb. https://yadi.sk/d/CbI-DQSG3JzHyX
freestart Posted June 10, 2017 Posted June 10, 2017 3 hours ago, balbes150 said: Try this one dtb. https://yadi.sk/d/CbI-DQSG3JzHyX Thanks! I will try and make you know!
freestart Posted June 10, 2017 Posted June 10, 2017 5 hours ago, balbes150 said: Try this one dtb. https://yadi.sk/d/CbI-DQSG3JzHyX I have tried but it stops on "google tv" logo and doesn't show black screen I have waited more of 10 minutes
RaptorSDS Posted June 10, 2017 Posted June 10, 2017 do you have flash the autoscript.zip in android to update the bootmanager ? ( is the google tv logo part of android ?)
freestart Posted June 10, 2017 Posted June 10, 2017 3 hours ago, RaptorSDS said: do you have flash the autoscript.zip in android to update the bootmanager ? ( is the google tv logo part of android ?) yes; yes Look the my attached, I have this screen with half screen with "Google TV" logo
RaptorSDS Posted June 10, 2017 Posted June 10, 2017 you have use the server rom , that is why dont have a HDMI support and you have to use SSH ( Network LAN ) to remote login , please use the first run script on the boot partition( normally when you have a fresh flash of the sd card ) maybe you can use the xenial_3.10.99_mate rom to test the dtb . armbian_first_run.txt
freestart Posted June 10, 2017 Posted June 10, 2017 17 minutes ago, RaptorSDS said: you have use the server rom , that is why dont have a HDMI support and you have to use SSH ( Network LAN ) to remote login , please use the first run script on the boot partition( normally when you have a fresh flash of the sd card ) maybe you can use the xenial_3.10.99_mate rom to test the dtb . armbian_first_run.txt thanks, I will try with xenil mate rom and armbian_first_run.txt and make you know
freestart Posted June 10, 2017 Posted June 10, 2017 51 minutes ago, RaptorSDS said: you have use the server rom , that is why dont have a HDMI support and you have to use SSH ( Network LAN ) to remote login , please use the first run script on the boot partition( normally when you have a fresh flash of the sd card ) maybe you can use the xenial_3.10.99_mate rom to test the dtb . armbian_first_run.txt I have tried but nothing, same problem in my root microSD have these files: but s805_autoscript.cmd I must to run it?
balbes150 Posted June 11, 2017 Posted June 11, 2017 Multiboot you have already activated, so you can try to start system from USB (to capture the image on the USB flash drive and try all the dtb files).
RaptorSDS Posted June 11, 2017 Posted June 11, 2017 hi there i test 4.12 first two start error at gpio 32 third and four start random stop at "kernel loading.." and R/W sd-card error (reflash of SD-Card) fifth can log in and config 4.12 log without next root.log
freestart Posted June 11, 2017 Posted June 11, 2017 3 hours ago, balbes150 said: Multiboot you have already activated, so you can try to start system from USB (to capture the image on the USB flash drive and try all the dtb files). I already tried with usb and with some dtb but same problem, I will try again
freestart Posted June 11, 2017 Posted June 11, 2017 2 hours ago, RaptorSDS said: hi there i test 4.12 first two start error at gpio 32 third and four start random stop at "kernel loading.." and R/W sd-card error (reflash of SD-Card) fifth can log in and config 4.12 log without next root.log Where can I found my log file?
freestart Posted June 11, 2017 Posted June 11, 2017 On Fri Jun 09 2017 at 3:46 PM, balbes150 said: You can connect the console UART ? I have bought uart interface, I am waiting that it arrive; it can help me?
RaptorSDS Posted June 11, 2017 Posted June 11, 2017 23 minutes ago, freestart said: I have bought uart interface, I am waiting that it arrive; it can help me? yes it can , but that is only the half way , you have to connect (soldering) the interface with your box ( that means open it search the board for soldering pads of the uart , soldering wire and connect to pc) my log is the uart log from my box ( akaso m8s clone box) , uart kabel to usb and putty on my windows maschine
RaptorSDS Posted June 11, 2017 Posted June 11, 2017 ia also test 4.12 NEXT image here the log but i can not logging problems gpio32 and WLAN 4.12 with next test.log with the 4.12 server image (without NEXT) i could "ifup Wlan0 " and box successful start dhcp
freestart Posted June 11, 2017 Posted June 11, 2017 10 hours ago, RaptorSDS said: yes it can , but that is only the half way , you have to connect (soldering) the interface with your box ( that means open it search the board for soldering pads of the uart , soldering wire and connect to pc) my log is the uart log from my box ( akaso m8s clone box) , uart kabel to usb and putty on my windows maschine I understand, I have good experience with soldering and pc connection with interface
