USB C port doesn't work on pinebook pro after the latest update on kernel 6.6.2
pinebookpro-owner
Hello,
as already mentioned in topic USB C port doesn't work after upgrading to the latest kernel 6.6.2 .
The previous problem with not working left usb 3 port persist no more. Everything is fine. As I remember , before update the usb c port has worked with the adapter and the devices like mouse, usb flash etc. Now it doesn't work any more, furthermore it gives no signal of life. There is 0 amps current measured, also dmesg -W gives no output at all after plugging in the device.
PS: I was unable to upload the report file, also the service paste.armbian.com doesn't work at the moment.
Some issue is, but I don't know. Just checked again. Still not working . With manual paste on paste.armbian.com by saving come pop out message "some went wrong". And output from terminal by issuing sudo armbianmonitor -u
gives me following output:
System diagnosis information will now be uploaded to https://paste.armbian.com/
Please post the URL in the forum where you've been asked for.
As seen above there is no url with id.
About the problem with usb port itself. I could not state anything general, it could be that is some hardware problem only at my side, I don't know therefore I asked.
Use armbianmonitor -U to dump to terminal, then c&p to a paste service of your choice like paste.debian.net or p.na4.eu
Not sure whats wrong with armbian paste or if pbp has trouble.
Hello,
It is good news that is new armbian version here. But unfortunatelly my issue listed above was not resolved. Both problems persists. The usb c port still doesn't work and the initramfs issue is also not resolved:
Quote
run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Could you tell me is this error with usb c only on my comp or is it general, also for iniramfs?
