Hi
Pulled latest git repo and build mainline image (Ubuntu/Debian both) 4.9.2-sun8i kernel.
Eth0 now stuck at 100mb/s and half duplex.  I have tried using ethertool to make it full duplex.   Not working.
The previous image which I used and suggested was Armbian_5.24.170109_Orangepizero_Ubuntu_xenial_4.9.0
This image works with full duplex.
Is this a bug or there is more configs needed when I building my own images?  From ethtool output, looks like problem with auto negotiation.
pi@orangepizero:~$ sudo ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes:   10baseT/Half 10baseT/Full
                        100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes:  10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes:  10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Half
Port: MII
PHYAD: 1
Transceiver: external
Auto-negotiation: on
Current message level: 0x00000000 (0)
Link detected: yes
eth0: negotiated 100baseTx-HD, link ok
  product info: vendor 00:11:05, model 0 rev 0
  basic mode:   isolate, autonegotiation enabled
  basic status: autonegotiation complete, link ok
  capabilities: 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD
  advertising:  100baseTx-HD 10baseT-FD
  link partner: 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD flow-control
-jerry
I don't have this board yet, but I have done ethernet driver development in the past. You really want to make sure that your setup is valid. I suggest switching out the ethernet cable and switch. A lot of these embedded PHY's are quirky (that is why linux kernel is filled with vendor specific phy drivers) and different switches can cause issues. Another potential problem is a bad cable.
@jerryc
Our kernel sources are attached to development branches and there are a list of patches on top of this, that things works. Building from mainline sources without additional patches is not the way to go. Waste of time. ATM.
That's why we have tools.
@admin
The kernel was build using the github repo that you listed.   Hence my question on why the latest build locks into half duplex.  Unless you mean there are other batches beside your repo? or other ways to build? (I am following your build instructions)  Unless you are saying there are additional patches that are not in the repo that you listed.
Also, I am very possitive it is not switch/cable/power issue.  the test was done using two images.  One was provided by you a while back on another question, and one is the image I build using the repo.
any ideas?
-jerry
@jerryc
any ideas?
You are trying to use kernel built from developer branch where problems are more than expected. This kernel is not ready for usage ... we can't and we don't waste time on supporting something that changes within hours.
Is there a way to tell the tool That's why we have tools, to build using different kernel?  or it is fixed?
My OPiZero is in full duplex, either with last week's build or today's build.
@martinayotte
Just did a git pull and used compile.sh to create a new mainline image for orangepizero.  The half duplex is still there.   I assume you also used the compile.sh script for your images.  If not let me know, I can try your way as well.
root@orangepizero:~# uname -a
Linux orangepizero 4.9.3-sun8i #5 SMP Fri Jan 13 15:57:42 PST 2017 armv7l GNU/Linux
root@orangepizero:~# ethtool eth0
Settings for eth0:
Speed: 100Mb/s
Duplex: Half
Port: MII
PHYAD: 1
Link detected: yes
root@orangepizero:~# mii-tool -v
Yes, you can change sources, branches, ... this question was brought up few times. Start here: https://www.armbian.com/search_gcse and https://docs.armbian.com/Developer-Guide_Build-Preparation if you want to start learning more about the build process.
I move this topic to development section, since it suits here more.
@martinayotte
Yes, it was my own builds done with compile.sh
@martinayotte
Appreciate your help.  Just cloned a workspace and build a fresh image.   (no special config, just a orange pi zero debian 4.9 server image)  I am still getting the eth0 at half Duplex.   An older image given to be by @igor this image  works perfectly (with Full Duplex and solved stability issues)
Linux orangepizero 4.9.3-sun8i #1 SMP Sat Jan 14 17:08:59 PST 2017 armv7l GNU/Linux
root@orangepizero:~# mii-tool eth0 -v
@szwistak  I can't find it any more either.  I been trying to reproduce that build done by igore, but no success, so i give up and wait until some one build another working image with 4.9.4 or something like it ...
NanoPi Neo have same problem with kernel 4.9+...4.10+. It's problem in sun8i-emac - driver. After ifconfig eth0 down && ifconfig eth0 up autonegatiation work fine. I think, that problem is garbage in PHY-state register after U-boot.
Problem can be resolved with adding:
pre-up /sbin/ifconfig eth0 down
pre-up /sbin/ifconfig eth0 up
in section eth0.
That fixes the problem on OPi PC with 4.10.1 kernel (Armbian 5.27.170309 nightly) for me too.
Same problem here, anyone with a solution?
uname -a
Linux orangepizero 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l armv7l armv7l GNU/Linux
Stuck at 10/Full and only Orange led is lit on the ethernet port.
   18.282122] PHY: gmac0-0:00 - Link is Up - 100/Full
[   26.280234] PHY: gmac0-0:00 - Link is Down
[   28.280327] PHY: gmac0-0:00 - Link is Up - 100/Full
[   34.281213] PHY: gmac0-0:00 - Link is Down
[   36.280262] PHY: gmac0-0:00 - Link is Up - 100/Full
[   40.280224] PHY: gmac0-0:00 - Link is Down
[   41.280426] PHY: gmac0-0:00 - Link is Up - 100/Full
[   43.280368] PHY: gmac0-0:00 - Link is Down
[   44.280429] PHY: gmac0-0:00 - Link is Up - 100/Full
[   46.280335] PHY: gmac0-0:00 - Link is Down
[   47.280425] PHY: gmac0-0:00 - Link is Up - 100/Full
[   53.280416] PHY: gmac0-0:00 - Link is Down
[   54.280439] PHY: gmac0-0:00 - Link is Up - 100/Full
[   56.280425] PHY: gmac0-0:00 - Link is Down
[   57.280474] PHY: gmac0-0:00 - Link is Up - 100/Full
[   63.280415] PHY: gmac0-0:00 - Link is Down
[   66.280470] PHY: gmac0-0:00 - Link is Up - 100/Full
[   80.280448] PHY: gmac0-0:00 - Link is Down
[   87.280431] PHY: gmac0-0:00 - Link is Up - 10/Full
If I try /sbin/ifconfig eth0 down /sbin/ifconfig eth0 up, then:
[  618.485543] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[  618.499102] ADDRCONF(NETDEV_UP): eth0: link is not ready
[  624.480374] PHY: gmac0-0:00 - Link is Up - 100/Full
[  624.481017] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  634.480360] PHY: gmac0-0:00 - Link is Down
[  640.480347] PHY: gmac0-0:00 - Link is Up - 100/Full
[  642.480401] PHY: gmac0-0:00 - Link is Down
[  647.480745] PHY: gmac0-0:00 - Link is Up - 10/Full
This topic is about (known) issues with Ethernet driver on mainline kernel, which is still in development phase and this driver is about to be rewritten AFAIK.
On kernel 3.4.113 we didn't notice such problems. Double check your cables and other equipment first.
I upgraded to nightly beta.
I added to /etc/network/interfaces:
auto eth0
allow-hotplug eth0
iface eth0 inet manual
With this extra "pre-up" config I get full duplex connection (without only half duplex).
A: Macbook, Samsung TV: 100Mb/s full duplex
B: Old laptop Asus F5R, it is equipped with 10/100Lan card, but for some reason it is advertising itself 10Mb/s only (Live Ubuntu + Acronis True Image CD). Doesn't matter.
I use this little board for wlan0 to eth0 bridging and it's really good.
