eddievxx Posted January 14, 2017 Posted January 14, 2017 Hello, I have got my Orange Pi PC+ reading a DS18B20, but it only gives 0.5 degree increments so I believe the resolution is set to 9 bit. This is nowhere near good enough for the application I plan to use it for. When I cat w1_slave I get: 90 01 80 01 1f ff 02 04 5c : crc=5c YES 90 01 80 01 1f ff 02 04 5c t=25000 I have attempted to use this: https://github.com/danjperron/BitBangingDS18B20 but it appears to be specifically for RaspPi. Does anyone know how I can change the resolution to 11 or 12 bit? Many thanks
martinayotte Posted January 14, 2017 Posted January 14, 2017 There is a thread where someone tweak the kernel to get this functionality : https://forum.armbian.com/index.php/topic/1558-w1-therm-driver-modifications/#entry12058 But it seem that he never completed the task to provide actual patch for Armbian build. Looking at kernel history, I saw that someone else done it a different way : https://github.com/megous/linux/commit/0a19f129d71f18e73249d54de96c835186b8607e It should be done like : echo 12 > /sys/bus/w1/devices/28-000005a2fac5/w1_slave But comments say that this change is volatile and will be reset at next power recycle : Writing a value between 9 and 12 to the sysfs w1_slave file will change the precision of the sensor for the next readings. This value is in (volatile) SRAM, so it is reset when the sensor gets power-cycled. To store the current precision configuration into EEPROM, the value 0 has to be written to the sysfs w1_slave file. Since the EEPROM has a limited amount of writes (>50k), this command should be used wisely.
nedoskiv Posted March 8, 2017 Posted March 8, 2017 rc14_one:/sys/bus/w1/devices/28-0115832712ff/driver# echo 12 > 28-0115831d2eff/w1_slave -bash: 28-0115831d2eff/w1_slave: Permission denied setting manual write permission to w1_slave rc14_one:/sys/bus/w1/devices/28-0115832712ff/driver/28-0315826d08ff# echo 12 > w1_slave -bash: echo: write error: Input/output error I was using latest armbian debian jessie. How can I implement that to it?
martinayotte Posted March 8, 2017 Posted March 8, 2017 Which kernel are you running ? My above post was for 4.9.x, and I've just verify that the same code is present on 4.10.x.
borombo Posted March 10, 2017 Posted March 10, 2017 try: su -c "echo 12 > /sys/bus/w1/devices/28-0316a154bfff/w1_slave"
nedoskiv Posted March 10, 2017 Posted March 10, 2017 oh I was on 3.4.113, gonna upgrade and test it, thank you
