rajivdeo Posted December 26, 2023 Posted December 26, 2023 My orange Pi Zero 2W does not boot with all accessible images. Following error is displayed - [/ init]: getty is ttyl [/init]: RootDevice is "/dev/mtdblock4" , GPT_SUPPORT=1 [/ init]: Try to load Nor mount: mounting /dev/mtdbIock4 on /mnt failed: No such file or directory [/init]: Failed to mount /dev/mtdbIock4! / #_ Can any member provide me a path to fix this error and boot my Orange Pi Zero 2W? 0 Quote
Werner Posted December 26, 2023 Posted December 26, 2023 Armbian does not support this board. Any Armbian images you might have found in the web is not ours. Ask where you got the image from. 0 Quote
Gunjan Gupta Posted December 26, 2023 Posted December 26, 2023 6 hours ago, rajivdeo said: RootDevice is "/dev/mtdblock4" , GPT_SUPPORT=1 mtdblock is nand devices. For sdcard and emmcs, it should be something starting with mmcblk. 0 Quote
ag123 Posted December 27, 2023 Posted December 27, 2023 @Werner is right, there is no Armbian images currently for Zero 2W and Zero 3. But that if you are willing to play with *experimental* stuff i.e. no assurance of anything or if it even works, you may like to try an Zero 3 *wild experimental totally unsupported use at your own risk* image If anything works as a result, which presumbly shouldn't work, do feedback in that thread or this about your findings 0 Quote
