octal8 Posted December 31, 2023 Posted December 31, 2023 (edited) New OPI5+, unable to finish install because ethernet doesn't work. I haven't been able to figure it out and my searches turned up nothing. journalctl has the following messages: - hpptx phy lane locked! - rk_gmac-dwmac fe1c0000.ethernet error: no phy at addr -1 - stmmac_open: cannot attach to phy (error -19) I've checked power supply, cables, edited the interfaces file, and more , with no success. I have an Orange Pi 5 that I can swap as is in its place and everything works. Coupled with the fact that I couldn't find mention of the errors, I'm hoping that someone can help me before I give up and return the OPI5+. Edited December 31, 2023 by octal8 Spelling error. 0 Quote
Tony3 Posted December 31, 2023 Posted December 31, 2023 Returning and giving up is indeed a simple solution! (the other solution may consist of giving more information about the type of network used, wired? wifi? what wifi card?.....) 1 Quote
Werner Posted December 31, 2023 Posted December 31, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. Armbianmonitor -U pastes to console 1 Quote
Efe Çetin Posted December 31, 2023 Posted December 31, 2023 @octal8 which image did you download 1 Quote
Marco Schirrmeister Posted December 31, 2023 Posted December 31, 2023 If you used the 6.7.0-rc7 image, then check what overlay and dt file you have configured. This image defaults to the dt file for the original non-plus version. Check and adjust in /boot/armbianEnv.txt the following 2 lines. overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb 1 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 (edited) I switched to the official Orange Pi installation and it works fine. So it's not a hardware issue. Since an Orange Pi 5 worked fine in the same setup, I was suspecting that and am glad because I didn't want to return it. Based on the symptoms, it seems like a driver/configuration issue. The problem is I don't want to use the official Orange Pi installation since it is run by Huawei with servers in China. For one, I'd much rather use an organization run by volunteers (Armbian) than one run by a corporation. Also, with the way things are going between the USA and China, who knows what may happen in the future with respect to sanctions, etc... Marco, I tried your suggestion and it didn't work. Still no USB3 and Ethernet. Werner, I'm going to try your suggestion next to see if it narrows down what I need to do to make Armbian work. Edited January 1, 2024 by octal8 Spelling error. 0 Quote
Efe Çetin Posted January 1, 2024 Posted January 1, 2024 I think you use opi5 image instead of opi5+. You have to read description properly 2 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 On 1/1/2024 at 9:05 AM, Efe Çetin said: I think you use opi5 image instead of opi5+. You have to read description properly Expand On the Armbian website, they only have one image that combines all three hardware versions Orange Pi 5 / 5B / 5 Plus. https://www.armbian.com/orangepi-5/ 0 Quote
Efe Çetin Posted January 1, 2024 Posted January 1, 2024 On 1/1/2024 at 9:30 AM, octal8 said: On the Armbian website, they only have one image that combines all three hardware versions Orange Pi 5 / 5B / 5 Plus. Expand Check here 1 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 On 1/1/2024 at 9:40 AM, Efe Çetin said: Check here Expand Thank you, I will. 0 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 (edited) Update: -Still no USB3 - Still no Ethernet - Parted doesn't recognize the nvme M.2 card installed. - Installing the OS to the emmc chip remains a mystery. - No sound Edited January 1, 2024 by octal8 Added "No sound" 0 Quote
Werner Posted January 1, 2024 Posted January 1, 2024 Ethernet works, USB3 works, HDMI works. Did not bother test further https://paste.armbian.com/ruteyebapu 1 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 On 1/1/2024 at 10:11 AM, Werner said: Which image?` Expand Sorry, I thought I posted that info: Armbian_23.11.1_Orangepi5_bookworm_legacy_5.10.160.img 0 Quote
Solution Werner Posted January 1, 2024 Solution Posted January 1, 2024 On 1/1/2024 at 10:54 AM, octal8 said: 1_Orangepi5_bookworm_legacy_5 Expand As Efe stated. You are using the wrong images. Oranhe Pi 5 != Orange Pi 5 Plus 1 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 On 1/1/2024 at 11:05 AM, Werner said: As Efe stated. You are using the wrong images. Oranhe Pi 5 != Orange Pi 5 Plus Expand On the Armbian website, all three OP5 hardware versions are lumped together on the same page. There are two images available on the page, the cli version that I'm using, and a Gnome version. https://www.armbian.com/orangepi-5/ There is also a link for older versions, but since the OPI5+ is new, something tells me they would not be better. What am I missing? 0 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 Since I want to use an official Armbian image, I would say that the problem isn't solved until they make one available that works. 0 Quote
Werner Posted January 1, 2024 Posted January 1, 2024 On 1/1/2024 at 11:30 AM, octal8 said: What am I missing? Expand https://forum.armbian.com/topic/33008-new-install-ethernet-doesnt-work-no-lights-even-and-usb3-ports-are-dead/?do=findComment&comment=178365 1 Quote
ricardo_brz Posted January 1, 2024 Posted January 1, 2024 On 1/1/2024 at 11:40 AM, octal8 said: Since I want to use an official Armbian image Expand The one posted by Efe here is official, do you mean you want something more official than that? 0 Quote
octal8 Posted January 1, 2024 Author Posted January 1, 2024 On 1/1/2024 at 12:46 PM, ricardo_brz said: The one posted by Efe here is official, do you mean you want something more official than that? Expand My apologies to all, especially Efe. I missed the obvious. I need some sleep. 1 Quote
